I am trying to U-Boot in Flash, with TorizonCore Kernel and Rootfs in SATA drive. Apalis iMX8QM 4GB IT V1.1C on a Custom Carrier board based on Ixora V1.1B. As described here, I need a xxx-Image.bootfs.tar.xz and xxx-Image.rootfs.tar.xz. However, when downloading the TorizonCore image (TorizonCore PREEMPT_RT 5.6.0-devel-202203+build.22) and extracting the contents I find:
image.json
imx-boot
LA_OPT_NXP_SW.html
marketing.tar
prepare.sh
u-boot-initial-env-sd
wrapup.sh
torizon-core-docker-rt-apalis-imx8.ota.tar.zst
extracting torizon-core-docker-rt-apalis-imx8.ota.tar.zst shows a filesystem, but it is unclear to me how that will help me follow the two guides available to accomplish this goal.
Obviously the guide is written for a Yocto-based image but I’m trying to accomplish the same task with TorizonCore on the SSD instead. I also understand that the guide is a bit outdated (2018) so correct me if there is a more up-to-date resource to be using for this.
Related posts:
Enable SATA command in u-boot?
SATA support for u-boot updates
Boot up Linux and Android from mSata and PCIe/Mini PCIe Interface
Ixora apalis imx8
Boot iMX8 from SD or USB
Apalis Evaluation Module failed to boot up from external SATA Disk
Documentation for Booting from SD card on Apalis iMX8x
How to set IMx8 to boot OS from MSATA SSD or 4Bit SD slot?
Related Developer Resources:
Distro Boot
Linux - Booting
Boot From an SD Card / USB Stick / SATA drive
Reference Images for Yocto Project Software Downloads
U-Boot
Toradex Download Links (Torizon, Linux BSP, WinCE and Partner Demos)
BSP Layers and Reference Images for Yocto Project Software
