Hardware video encoding on Verdin iMX8MP
Hi, I am currently trying to get the AR0521 camera running on a Verdin iMX8MP on a Dahlia carrier board. I got the camera raw stream running, but as soon as I use the hardware video encoder or decoder in a gstreamer call, the pipeline fails immediately with this error message
vpuenc_h264-0: Could not initialize supporting library
I also saw this post from roughly 2 years ago, which mentions the same issue:
As the hardware video encoder and decoder is advertised on the Toradex website, I hope somebody can help me to get it running?
Could you unlock me for uploading files, then I can share how I created the Docker image for the camera?
It sounds like you’re encountering a challenge with the hardware video encoder/decoder on your Verdin iMX8MP when using GStreamer. The error message “vpuenc_h264-0: Could not initialize supporting library” typically indicates an issue with the necessary libraries or configurations.
Here are some steps you can take to troubleshoot and potentially resolve this issue:
  1. Update Software: Ensure you are using the latest version of TorizonCore and any related containers. Updates often include important fixes.
  2. GStreamer Plugins: Verify that all required GStreamer plugins are installed in your Docker container. The vpuenc_h264 element needs specific plugins that might not be included by default.
  3. Library Dependencies: Check for any missing library dependencies. Review your Dockerfile to ensure all necessary packages for the encoder/decoder are included.
  4. Device Tree Overlays: Make sure the correct device tree overlay is applied. For the AR0521 camera, use the verdin-imx8mp_ar0521_overlay.dts to ensure proper hardware configuration.
  5. Known Issues: Look into any known issues or errata related to the Verdin iMX8MP and Dahlia carrier board. There might be specific workarounds or patches available.
  6. Simplify the Pipeline: Try running a simpler GStreamer pipeline to isolate the problem. This can help determine if the issue lies with the encoder/decoder or another part of the pipeline.
I hope these suggestions help you get the hardware encoder/decoder running smoothly. If you have further questions, feel free to ask.
Toradex AI Assistant
Verdin iMX8MP GStreamer Hardware Decoder/Encoder.
Hello @j.kugele,
Which variant of the Verdin iMX8MP are you using?
The output of sudo tdx-info should contain all the necessary information.
Bruno
today I built the Docker image of the vpuGeneric sample again from the newest commit of the bookworm-new branch. This time it went through without any modifications.
The camera works, but using the video encoder I still get the same error:
# update-alternatives --set libg2d.so.1 /usr/lib/aarch64-linux-gnu/libg2d-viv.so.2.1.0
# gst-launch-1.0 videotestsrc num-buffers=300 ! video/x-raw, width=1920, height=1080, framerate=60/1 ! videoconvert ! vpuenc_h264 ! video/x-h264 ! h264parse ! qtmux ! filesink location=videotestsrc.mp4
Setting pipeline to PAUSED ...
====== VPUENC: 4.7.2 build on Jan  8 2025 10:48:49. ======
        wrapper: 3.0.0 (VPUWRAPPER_ARM64_LINUX Build on Jan  8 2025 10:47:54)
        vpulib: 1.1.1
        firmware: 1.1.1.0
ERROR: from element /GstPipeline:pipeline0/vpuenc_h264:vpuenc_h264-0: Could not initialize supporting library.
Additional debug info:
../gst-libs/gst/video/gstvideoencoder.c(1804): gst_video_encoder_change_state (): /GstPipeline:pipeline0/vpuenc_h264:vpuenc_h264-0:
Failed to start encoder
ERROR: pipeline doesn't want to preroll.
Failed to set pipeline to PAUSED.
Setting pipeline to NULL ...
Freeing pipeline ...
sudo tdx-info
Password:
Software summary
Kernel version:           5.15.129-6.5.0-devel+git.6f8fd49366db #1-TorizonCore SMP PREEMPT Mon Dec 23 14:11:20 UTC 2024
Kernel command line:      root=LABEL=otaroot rootfstype=ext4 quiet logo.nologo vt.global_cursor_default=0 plymouth.ignore-serial-consoles splash fbcon=map:3 ostree=/ostree/boot.1/torizon/a992185cd12dfcb0b279996dd90e68a45a466dfb41c80243d0c1e8940eff155c/0
Distro version:           VERSION_ID=6.5.0-devel-20241225134819-build.0
Hostname:                 verdin-imx8mp-15503045
Hardware info
HW model:                 Toradex Verdin iMX8M Plus WB on Verdin Development Board
Toradex version:          0058 V1.1B
Serial number:            15503045
I am currently using self-built Torizon OS 6.5.0 with the AR0521 Yocto overlay. Which one is the latest version where video encoding was confirmed working?
PS: It seems that multiple of the NXP provided libraries have undefined referenced symbols. Is this normal?
ldd -r /usr/lib/libfslvpuwrap.so.3.0.0
        linux-vdso.so.1 (0x0000ffff92c78000)
        libcodec.so.1 => /lib/libcodec.so.1 (0x0000ffff92bd0000)
        libhantro_vc8000e.so.1 => /lib/libhantro_vc8000e.so.1 (0x0000ffff92b60000)
        libc.so.6 => /lib/aarch64-linux-gnu/libc.so.6 (0x0000ffff929b0000)
        libhantro.so.1 => /lib/libhantro.so.1 (0x0000ffff92960000)
        libg1.so.1 => /lib/libg1.so.1 (0x0000ffff92810000)
        /lib/ld-linux-aarch64.so.1 (0x0000ffff92c3b000)
undefined symbol: pow   (/lib/libhantro_vc8000e.so.1)
undefined symbol: sqrt  (/usr/lib/libfslvpuwrap.so.3.0.0)
ldd -r /usr/lib/libhantro_vc8000e.so.1
        linux-vdso.so.1 (0x0000ffff869b9000)
        libc.so.6 => /lib/aarch64-linux-gnu/libc.so.6 (0x0000ffff86760000)
        /lib/ld-linux-aarch64.so.1 (0x0000ffff8697c000)
undefined symbol: pow   (/usr/lib/libhantro_vc8000e.so.1)
Hello @j.kugele,
Thanks for the additional information.
The 0058 Verdin iMX8M Plus Quad 4GB WB IT module has a working VPU, so we can look into what else may be the issue here.
Which command are you using to run the container?
With the following command, I can get the VPU encoding working using the same pipeline that you used:
docker run --rm -it -e MACHINE=verdin-imx8mp -v /tmp:/tmp -v /var/run/dbus:/var/run/dbus -v /dev:/dev -v /sys:/sys --device-cgroup-rule='c 226:* rmw' --device-cgroup-rule='c 199:* rmw' --device-cgroup-rule='c 81:* rmw' --device-cgroup-rule='c 234:* rmw' --device-cgroup-rule='c 235:* rmw' --device-cgroup-rule='c 253:* rmw' <container name>
This command has a few additional cgroup rules which are needed for the VPU.
I will add them to the developer website page as well.
Bruno
Hi Bruno,
thanks with this command I can use the hardware video encoder/decoder. Is there some way to detect if cgroup rules are missing, or how did you find that out?
For reference for other users, here are some usefull gstreamer pipelines:
Record valid .mp4 file:
gst-launch-1.0 v4l2src device='/dev/video2' num-buffers=300 ! "video/x-raw, format=RGB16, framerate=30/1, width=1920, height=1080" ! videoconvert ! vpuenc_h264 ! video/x-h264 ! h264parse ! qtmux ! filesink location=videotestsrc.mp4
Playback file (gstreamer automatically uses hardware H264 decoding):
gst-launch-1.0 filesrc location=videotestsrc.mp4 ! decodebin ! fpsdisplaysink video-sink=waylandsink text-overlay=false sync=false
Send MPEGTS network stream to host computer:
gst-launch-1.0 v4l2src device='/dev/video2' ! "video/x-raw, format=RGB16, framerate=30/1, width=1920, height=1080" ! videoconvert ! vpuenc_h264 ! video/x-h264 ! h264parse config-interval=-1 ! mpegtsmux ! udpsink host=<host ip> port=5000
To playback with vlc open “udp://@:5000” (host firewall might need to be adjusted)
Hello @j.kugele,
Thanks for the update.
To find out which device cgroup rules are needed for each device you can check the output of ls -la /dev. This is described in the following page: Best Practices with Peripheral Access | Toradex Developer Center
Otherwise, to find which cgroups are needed, it will depend on the task and which devices are needed.
Initially I added the relevant mxc devices’ cgroup rules and afterwards searched for the missing one by trying different configurations.
There may be a better way to do this, but this was simple enough.
Bruno
