I am trying to run a pipeline on the Dahlia Carrier Board for the Verdin iMX8MP, including the iMX-supplied hardware encoder and decoder. However, when running the pipeline, I am coming up against the error “vpuenc_h264-0: Could not initialize supporting library”. I am using the Reference Multimedia Image with Dunfell-5 as an image to test on.
The pipeline I am using is the following:
gst-launch-1.0 rtspsrc location=“rtsp://192.168.1.1:8554/visible” ! rtph264depay ! h264parse confg-interval=-1 ! vpudec ! imxvideoconvert_g2d ! video/x-raw, width=640, height=480 ! videorate ! video/x-raw, framerate=10/1 ! vpuenc_h264 bitrate=700 ! rtph264pay pt=96 name=“pay0” ! udpsink host=“192.168.10.1” port=1234
This pipeline has been proven to work correctly on other iMX8MP boards from a different manufacturer.
Hi @bfleming !
I was able to run the following pipeline on:
- Reference Multimedia Image from BSP 5.7.0 on a
- Verdin iMX8MP Q 4GB WB IT V1.0B and
- Verdin Development Board V1.1A and
- output the result via DSI to HDMI converter
gst-launch-1.0 filesrc location=video/testvideo_h264.mp4 \
! video/quicktime ! aiurdemux \
! vpudec \
! imxvideoconvert_g2d \
! video/x-raw,width=200,height=100 ! videorate ! video/x-raw,framerate=10/1 \
! vpuenc_h264 \
! vpudec \
autovideosink
Here is the explanation of the pipeline
- get example video available on the image
vpudec
imxvideoconvert_g2d
- convert video using GPU-2D
- setting very low resolution and framerate
vpuenc_h264
vpudec
autovideosink
Please share more information about your current setup:
- Which exact Verdin iMX8MP module and version are you using? Please share its full name.
- Which version is your Dahlia carrier board?
- Please share the outputs of:
cat /etc/os-release
cat /etc/issue
uname -a
- Did you build your own image or installed it from Toradex feeds (e.g. from Toradex Easy Installer image list)?
Henrique
Hi @bfleming!
Do you have news regarding this topic?
Hi @henrique.tx
I am seeing this issue as well. I built a custom Yocto image using the tdx-reference-multimedia-image and a few minor customizations.
The pipeline I am trying to run:
gst-launch-1.0 videotestsrc ! video/x-raw, format=I420, width=640, height=480 ! vpuenc_h264 ! filesink location=videotestsrc.mp4
I also tried running the pipeline you showed above and was getting the same message for vpudec.
cat /etc/os-release
ID=tdx-xwayland
NAME=“TDX Wayland with XWayland”
VERSION=“6.1.0-devel-20221213050554+build.0 (kirkstone)”
VERSION_ID=6.1.0-devel-20221213050554-build.0
PRETTY_NAME=“TDX Wayland with XWayland 6.1.0-devel-20221213050554+build.0 (kirkstone)”
DISTRO_CODENAME=“kirkstone”
cat /etc/issue
TDX Wayland with XWayland 6.1.0-devel-20221214012039+build.0 (kirkstone) \n \l
Verdin-iMX8MP_Reference-Multimedia-Image
uname -a
Linux verdin-imx8mp-07331488 5.15.40-6.1.0-devel+git.b4f7c3c44d85 #1 SMP PREEMPT Tue Oct 11 15:25:52 UTC 2022 aarch64 aarch64 aarch64 GNU/Linux
Same result with the precompiled binary
Hi @dandresky !
As you are using a whole different BSP (I used 5 and you are testing on 6), could you please create a new topic for your question?
Thanks for the comprehension
