Error on platform push today
Hi, I am seeing an error on running a platform push command as of this morning.
I source tcb-env-setup.sh in the way I always do (source tcb-env-setup.sh – --network=host), and it downloadstorizoncore-builder, but when running the platform push command I see:
Downloaded file ‘tdx-containers.json’ has wrong length (actual=92636, expected=92609 bytes)
Is anyone else seeing this error today?
The error you’re encountering with the ‘platform push’ command, specifically the mismatch in file size for ‘tdx-containers.json’, can arise from several factors. Here are some steps to help you troubleshoot and resolve this issue:
  1. Re-download the File: Files can sometimes become corrupted during download. Try deleting the current ‘tdx-containers.json’ file and re-running the command to see if it downloads correctly.
  2. Check Network Stability: Ensure your network connection is stable, as fluctuations can lead to incomplete or corrupted downloads.
  3. Verify File Integrity: If possible, compare the checksum of the downloaded file with a known good version to ensure its integrity.
  4. Server-side Changes: It’s possible that the file on the server has been updated, leading to a size mismatch. Checking for any announcements or updates from Toradex regarding changes to the Torizon platform or its components might provide insights.
Regarding whether others are experiencing the same issue, I recommend checking community forums or recent announcements from Toradex for real-time feedback and updates.
I hope these steps help resolve your issue.
Toradex AI Assistant
Failure to generate a lockbox.
Looks like this thread is a duplicate of Failure to generate a lockbox.
I’ll keep an eye on that one to see what your findings are.
For anyone looking at this thread. Please refer to the other thread here for the discussion/fix: Failure to generate a lockbox
