When booting up as default I’ve noticed thet GPIO_3 is pulled up (+1,8V), and the other inputs are not (0v).
I need all 4 lines to be pulled up and I found out I need to customize the device tree, as libgpiod cannot set the pull up configuration for input - can someone help and please confirm that - that would be much easier to do it on libgpiod?
Well, if really customizing the device tree is necessary, I’ve seen I need to build a DTS file, compile it a use torizoncode-builder to add to my image.
Where can I find the right configuration to set pull up on those 4 lines?
I tried to find the /arch/arm/boot/dts original files but the board does not have that directory.
How can I get an example/guide on how to change the DTS file to enable pull up on these lines, and how to compile and add it to the tcbuild.yml?
To configure the GPIO pull-up settings on your iMX8M Plus board, you indeed need to customize the device tree, as libgpiod cannot set pull-up configurations for inputs. Here’s a step-by-step guide based on the context provided:
Create a Device Tree Source (DTS) File: You need to create or modify a DTS file to specify the pull-up configuration for the GPIO lines. The GPIO lines you are interested in are GPIO_1, GPIO_2, GPIO_3, and GPIO_4, which correspond to gpiochip0 pins 1, 2, 5, and 6 respectively.
Example Configuration: You will need to define these GPIO pins in the DTS file and set the appropriate properties to enable pull-up resistors. The specific syntax for enabling pull-ups can typically be found in the documentation for the iMX8M Plus or similar boards. Unfortunately, the context does not provide the exact syntax, so you may need to refer to the official documentation or existing DTS files for examples.
Compile the DTS File: Once you have your DTS file ready, compile it into a Device Tree Blob (DTB) file using the device tree compiler (DTC).
Integrate with Torizon: Use torizoncode-builder to integrate the new DTB into your Torizon image. Modify the tcbuild.yml file to include the path to your new DTB file so that it is included in the final image used for your board.
Finding Example DTS Files: If you cannot find the original DTS files in the /arch/arm/boot/dts directory, you might need to check the Torizon or Yocto Project repositories for example DTS files. These repositories often contain board-specific configurations that can serve as a reference.
Resources: Utilize the official documentation for the iMX8M Plus board and community forums for additional guidance and examples from other users who have configured similar setups.
If you need further assistance with specific DTS file configurations or examples, you may need to reach out to community forums or support channels for more detailed guidance.
Questions:
A1) Should I need to include any base file on that? Like #include
A2) How to compile this dtsi file into dts (didd not find how torizoncore-builder can do it…)
STEP 2: Build a image with tcbuild.yml
# Documentation https://developer.toradex.com/torizon/os-customization/torizoncore-builder-workflow/#customizing-the-configuration-file
# Configuration file outline:
# ⚠️ Mouse hover to the properties to see documentation
# ⚠️ ctrl+space inside an object or property to get the autocompletion tips
input:
easy-installer:
toradex-feed:
version: "6.7.0"
release: quarterly
machine: verdin-imx8mp
distro: torizon
variant: torizon-core-docker
build-number: 18
customization:
splash-screen: my_splash_screen.png
device-tree:
overlays:
add:
- gpio_pullup.dts
output:
easy-installer:
local: my-os
# bundle:
# compose-file: docker-compose.yml
ostree:
branch: my-os
commit-subject: my-os
I tried to run it without compiling the dtsi file, just copying the same file to .dts and naturally I got the following error:
$ torizoncore-builder build
Building image as per configuration file 'tcbuild.yaml'...
=>> Handling input section
Fetching URL 'https://artifacts.toradex.com/artifactory/torizoncore-oe-prod-frankfurt/kirkstone-6.x.y/release/18/verdin-imx8mp/torizon/torizon-core-docker/oedeploy/torizon-core-docker-verdin-imx8mp-Tezi_6.7.0+build.18.tar' into '/tmp/torizon-core-docker-verdin-imx8mp-Tezi_6.7.0+build.18.tar'
Download Complete!
Downloaded file name: '/tmp/torizon-core-docker-verdin-imx8mp-Tezi_6.7.0+build.18.tar'
No integrity check performed because checksum was not specified.
Unpacking Toradex Easy Installer image.
Unpacking TorizonCore Toradex Easy Installer image.
Importing OSTree revision b2ae8a9faf113b989787bc2f86be4b31741853b47bace9f1eaf0f19ca06fd9ce from local repository...
1050 metadata, 9446 content objects imported; 583.3 MB content written
0 metadata, 0 content objects imported; 0 bytes content written
Unpacked OSTree from Toradex Easy Installer image:
Commit checksum: b2ae8a9faf113b989787bc2f86be4b31741853b47bace9f1eaf0f19ca06fd9ce
TorizonCore Version: 6.7.0+build.18
=>> Handling customization section
=> Setting splash screen
splash screen merged to initramfs
=> Handling device-tree subsection
Not testing overlay because base image does not have a device-tree set!
=> Adding device-tree overlay 'gpio_pullup.dts'
Error: gpio_pullup.dts:27.4-5 syntax error
FATAL ERROR: Unable to parse input tree
error: cannot apply gpio_pullup.dts.
Questions:
B1) Is it the correct configuration for the tcbuild.yml - should I only add the overlay or do I need to configure the device tree overlay in the file - help appreeciated to fix that configuration file.
In order to set a pull-up in those 4 GPIOs you’ll need to write an overlay. You can follow this article to learn how to write a DTS.
About the configuration, if you check the Verdin iMX8MP device tree, you will find these GPIOs in 1129-1147 lines. On each pinctrl you’ll see a hexadecimal number along the pin name, this hexadecimal is used to set the pad control register of the SoC, which you can use to set a pull-up. You can use the Pad Mux Register table on page 27 of the Verdin iMX8MP datasheet to verify what number should be written (you must translate this hexadecimal to binary to use the table).
Following the table, your hexadecimal could be 0x1c4, which is 111000100 in binary.
To customize a pinctrl node, you can call it in your overlay using a &, for example:
Thanks Lucas for the response. I’ve already gone through all the reading and have build the code above.
So:
The .dtsi files are used as includes, if you are writing a device tree overlay it should be .dts.*
You mean I don’t need to compile the DTS file, or, in other words, use it as typed in the tcbuild.yml?
Indeed I’ve tried that - renamed my dtsi to dts and configured the tcbuild.yml as shown but I got the logged error. So, how to correctly setup the tcbuild.yml to use my dts?
Check the below log for a full session log of what’s going on:
renato@devlinux:~/workspace/testprj/my-os$ cat gpio_pullup.dts
GPIO control bits: PE HYS PUE ODE FSEL X DSE1 DSE0 X
Pull Select Field : PE_0_PULL_DISABLE / PE_1_PULL_ENABLE
Input Select Field : HYS_0_CMOS / HYS_1_SCHMITT
Pull Up / Down Config. : PUE_0_WEAK_PULL_DOWN / PUE_1_WEAK_PULL_UP
Open Drain Field : ODE_0_OPEN_DRAIN_DISABLE / ODE_1_OPEN_DRAIN_ENABLE
Slew Rate Field : FSEL_0_SLOW_SLEW_RATE / FSEL_1_FAST_SLEW_RATE
Drive Strength Field : DSE_X1 / DSE_X2 / DSE_X4 /DSE_X6
1C4 hexadecimal = 0b111000100 binary (PE_1_PULL_ENABLE | HYS+1+SCHMITT | PUE_1_WEAK_PULL_UP | ODE_0_OPEN_DRAIN_DISABLE | FSEL_0_SLOW_SLEW_RATE | DSE_X2 )
/dts-v1/;
/plugin/;
#include "imx8mp-pinfunc.h"
compatible = "toradex,verdin-imx8mp-nonwifi-dahlia",
"toradex,verdin-imx8mp-nonwifi",
"toradex,verdin-imx8mp",
"fsl,imx8mp";
&pinctrl_gpio1 {
fsl,pins = <MX8MP_IOMUXC_GPIO1_IO00__GPIO1_IO00 0x1c4>;
&pinctrl_gpio3 {
fsl,pins = <MX8MP_IOMUXC_GPIO1_IO05__GPIO1_IO05 0x1c4>;
&pinctrl_gpio4 {
fsl,pins = <MX8MP_IOMUXC_GPIO1_IO06__GPIO1_IO06 0x1c4>;
renato@devlinux:~/workspace/testprj/my-os$ cat tcbuild.yaml
input:
easy-installer:
toradex-feed:
version: "6.7.0"
release: quarterly
distro: torizon
build-number: 18
customization:
device-tree:
overlays:
add:
- gpio_pullup.dts
output:
easy-installer:
local: my-os
# bundle:
ostree:
branch: my-os
renato@devlinux:~/workspace/testprj/my-os$ torizoncore-builder build
Download Complete!
gpio_pullup.dts:25:35: error: no include path in which to search for dt-bindings/gpio/gpio.h
25 | #include <dt-bindings/gpio/gpio.h>
gpio_pullup.dts:26:10: fatal error: imx8mp-pinfunc.h: No such file or directory
26 | #include "imx8mp-pinfunc.h"
compilation terminated.
Error: gpio_pullup.dts:23.9-10 syntax error
input:
easy-installer:
toradex-feed:
version: "6.7.0"
release: quarterly
distro: torizon
build-number: 18
customization:
device-tree:
include-dirs:
- linux/include
- linux/arch/arm64/boot/dts/freescale/
custom: linux/arch/arm64/boot/dts/freescale/imx8mp-verdin-wifi-mallow.dts
overlays:
add:
- device-trees/overlays/verdin-imx8mp_hdmi_overlay.dts
- overlays/gpio_pullup.dts
output:
easy-installer:
local: my-os
# bundle:
ostree:
branch: my-os
And gpio_pullup.dts:
/dts-v1/;
/plugin/;
"fsl,imx8mp";
&pinctrl_gpio1 {
&pinctrl_gpio2 {
fsl,pins = <MX8MP_IOMUXC_GPIO1_IO01__GPIO1_IO01 0x1c4>;
&pinctrl_gpio3 {
&pinctrl_gpio4 {
A final comment:
The parameter: clear: false on tcbuild.yaml device-tree session seens not to be working. So it clears all overlays from custom dts on any condition. I had to add HDMI overlay again in order to have my HDMI display working again. I suggest a check/fix on this to engineering.
