Hello Charan,
Thank you for reaching out with your questions about interfacing a 7x7 keypad matrix with the Verdin iMX8MP. Let’s address each of your concerns step by step:
Calculating GPIO Pin Numbers:
- You are correct in using the formula
(bank number * 32) + line numberto calculate the GPIO number. For example, if SODIMM_200 is on gpiochip4 line 7, the GPIO number is4 * 32 + 7 = 135.
Exporting GPIO Pins:
- The sysfs interface (
/sys/class/gpio) is deprecated. Instead, use thelibgpiodtools, which are more modern and reliable. The “line busy” error often occurs if the pin is already in use by another process or not correctly configured in the device tree.
Using gpioget and gpioset:
- Ensure you are using the correct syntax. For example, to set a GPIO, use
gpioset gpiochipX Y=1whereXis the chip number andYis the line number. - The error “invalid line value” suggests incorrect usage or that the line is not available. Use
gpiodetectandgpioinfoto verify available lines and their status.
Interfacing the Keypad Matrix:
- Ensure that the GPIO pins are correctly configured in the device tree. This might involve setting the pins to GPIO mode if they are multiplexed with other functions.
- Consider using a GPIO matrix keypad driver in the Linux kernel, which can handle the scanning of the keypad matrix. You may need to modify the device tree to specify the GPIO lines used for rows and columns.
Device Tree Modifications:
- If the default pin configuration does not match your requirements, you will need to create a device tree overlay to set the pins to GPIO mode. This involves editing the device tree source to specify the correct pin functions and re-compiling it.
By following these steps, you should be able to configure the GPIOs for your keypad matrix and resolve the issues with exporting and setting GPIO lines. If you continue to face issues, ensure that no other processes are using the GPIOs and that the device tree is correctly configured for your hardware setup.
I hope this helps! If you have any more questions, feel free to ask.
