Hi @ritesh.tx,
we have made changes in the k3-am62-verdin.dtsi. As MMC2 pin configurations were already provided in this file CMD,CLK,D0-D3, we have added only the CD for the MMC2.
The file k3-am62-verdin-nonwifi.dtsi file is completely commented and we are not including this file in the k3-am62-verdin-nonwifi-dev.dts.
we are able to use the UART5 but MMC2 we are facing issues in detection.
dmesg logs:
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 6.1.80-6.7.0-devel+git.603f75dc931d (oe-user@oe-host) (aarch64-tdx-linux-gcc (GCC) 11.4.0, GNU ld (GNU Binutils) 2.38.20220708) #1 SMP PREEMPT Wed Aug 28 15:15:41 UTC 2024
[ 0.000000] Machine model: Toradex Verdin AM62 on Verdin Development Board
[ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[ 0.000000] printk: bootconsole [ns16550a0] enabled
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009db00000, size 12 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@9db00000, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000bfffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009dafffff]
[ 0.000000] node 0: [mem 0x000000009db00000-0x000000009e6fffff]
[ 0.000000] node 0: [mem 0x000000009e700000-0x000000009e77ffff]
[ 0.000000] node 0: [mem 0x000000009e780000-0x000000009fffffff]
[ 0.000000] node 0: [mem 0x00000000a0000000-0x00000000bfffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000bfffffff]
[ 0.000000] cma: Reserved 128 MiB at 0x00000000b6c00000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 20 pages/cpu s41064 r8192 d32664 u81920
[ 0.000000] pcpu-alloc: s41064 r8192 d32664 u81920 alloc=20*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: ARM erratum 845719
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 258048
[ 0.000000] Kernel command line: root=PARTUUID=230396cd-02 ro rootwait console=tty1 console=ttyS2,115200 consoleblank=0 earlycon=ns16550a,mmio32,0x02800000
[ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 840092K/1048576K available (11456K kernel code, 1396K rwdata, 3936K rodata, 2240K init, 425K bss, 77412K reserved, 131072K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 256 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: GICv3 features: 16 PPIs
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
[ 0.000000] ITS [mem 0x01820000-0x0182ffff]
[ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80800000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GICv3: using LPI property table @0x0000000080030000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080040000
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[ 0.000001] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[ 0.008610] Console: colour dummy device 80x25
[ 0.013623] printk: console [tty1] enabled
[ 0.017867] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[ 0.028562] pid_max: default: 32768 minimum: 301
[ 0.033340] LSM: Security Framework initializing
[ 0.038204] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
[ 0.045791] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
[ 0.055723] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.063204] cblist_init_generic: Setting shift to 1 and lim to 1.
[ 0.069513] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.076920] cblist_init_generic: Setting shift to 1 and lim to 1.
[ 0.083319] rcu: Hierarchical SRCU implementation.
[ 0.088235] rcu: Max phase no-delay instances is 1000.
[ 0.094312] Platform MSI: msi-controller@1820000 domain created
[ 0.100927] EFI services will not be available.
[ 0.105898] smp: Bringing up secondary CPUs ...
[ 0.111254] Detected VIPT I-cache on CPU1
[ 0.111384] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
[ 0.111404] GICv3: CPU1: using allocated LPI pending table @0x0000000080050000
[ 0.111470] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.111603] smp: Brought up 1 node, 2 CPUs
[ 0.141053] SMP: Total of 2 processors activated.
[ 0.145873] CPU features: detected: 32-bit EL0 Support
[ 0.151156] CPU features: detected: CRC32 instructions
[ 0.156479] CPU: All CPU(s) started at EL2
[ 0.160672] alternatives: applying system-wide alternatives
[ 0.168033] devtmpfs: initialized
[ 0.180785] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.190838] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.203669] pinctrl core: initialized pinctrl subsystem
[ 0.209867] DMI not present or invalid.
[ 0.214523] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.221794] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations
[ 0.229148] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.237162] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.245369] audit: initializing netlink subsys (disabled)
[ 0.251186] audit: type=2000 audit(0.160:1): state=initialized audit_enabled=0 res=1
[ 0.251709] thermal_sys: Registered thermal governor 'step_wise'
[ 0.259128] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.265489] cpuidle: using governor menu
[ 0.276403] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.283414] ASID allocator initialised with 65536 entries
[ 0.302536] KASLR disabled due to lack of seed
[ 0.313859] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.320856] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.327276] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.334224] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[ 0.340639] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.347585] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.354000] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.360947] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[ 0.369042] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7e02f] Detected
[ 0.379079] iommu: Default domain type: Translated
[ 0.384102] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.390825] SCSI subsystem initialized
[ 0.394863] libata version 3.00 loaded.
[ 0.395064] usbcore: registered new interface driver usbfs
[ 0.400721] usbcore: registered new interface driver hub
[ 0.406187] usbcore: registered new device driver usb
[ 0.411883] pps_core: LinuxPPS API ver. 1 registered
[ 0.416971] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.426331] PTP clock support registered
[ 0.430478] EDAC MC: Ver: 3.0.0
[ 0.434762] FPGA manager framework
[ 0.438344] Advanced Linux Sound Architecture Driver Initialized.
[ 0.445664] clocksource: Switched to clocksource arch_sys_counter
[ 0.452236] VFS: Disk quotas dquot_6.6.0
[ 0.456309] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.469398] NET: Registered PF_INET protocol family
[ 0.474676] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.483403] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes, linear)
[ 0.492054] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.500004] TCP established hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.507996] TCP bind hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.515716] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.522420] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.529232] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.536651] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.543014] RPC: Registered named UNIX socket transport module.
[ 0.549119] RPC: Registered udp transport module.
[ 0.553935] RPC: Registered tcp transport module.
[ 0.558751] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.565351] NET: Registered PF_XDP protocol family
[ 0.571129] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.581345] Initialise system trusted keyrings
[ 0.586223] workingset: timestamp_bits=46 max_order=18 bucket_order=0
[ 0.597312] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.604053] NFS: Registering the id_resolver key type
[ 0.609302] Key type id_resolver registered
[ 0.613588] Key type id_legacy registered
[ 0.617754] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.624620] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.666940] Key type asymmetric registered
[ 0.671146] Asymmetric key parser 'x509' registered
[ 0.676203] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.683988] io scheduler mq-deadline registered
[ 0.688637] io scheduler kyber registered
[ 0.696462] pinctrl-single 4084000.pinctrl: 34 pins, size 136
[ 0.703191] pinctrl-single f4000.pinctrl: 171 pins, size 684
[ 0.715614] Serial: 8250/16550 driver, 8 ports, IRQ sharing enabled
[ 0.733080] brd: module loaded
[ 0.741252] loop: module loaded
[ 0.748554] tun: Universal TUN/TAP device driver, 1.6
[ 0.754595] VFIO - User Level meta-driver version: 0.3
[ 0.761403] usbcore: registered new interface driver uas
[ 0.766940] usbcore: registered new interface driver usb-storage
[ 0.773115] usbcore: registered new interface driver ums-sddr09
[ 0.779200] usbcore: registered new interface driver ums-sddr55
[ 0.785789] UDC core: g_mass_storage: couldn't find an available UDC
[ 0.792746] i2c_dev: i2c /dev entries driver
[ 0.799114] sdhci: Secure Digital Host Controller Interface driver
[ 0.805497] sdhci: Copyright(c) Pierre Ossman
[ 0.810185] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.816575] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.822921] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 0.829922] usbcore: registered new interface driver usbhid
[ 0.835632] usbhid: USB HID core driver
[ 0.840577] optee: probing for conduit method.
[ 0.845191] optee: revision 3.20 (8e74d476)
[ 0.845560] optee: dynamic shared memory is enabled
[ 0.855124] optee: initialized driver
[ 0.860931] Initializing XFRM netlink socket
[ 0.865392] NET: Registered PF_PACKET protocol family
[ 0.870676] Key type dns_resolver registered
[ 0.875523] registered taskstats version 1
[ 0.879763] Loading compiled-in X.509 certificates
[ 0.894588] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.0.5--v09.00.05 (Kool Koala)')
[ 0.974699] i2c 0-0030: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/pmic@30/regulators/buck2
[ 1.014139] input: tps65219-pwrbutton as /devices/platform/bus@f0000/20000000.i2c/i2c-0/0-0030/tps65219-pwrbutton.2.auto/input/input0
[ 1.028423] rtc-ds1307 0-0032: oscillator failed, set time!
[ 1.034350] rtc-ds1307 0-0032: registered as rtc0
[ 1.039316] rtc-ds1307 0-0032: hctosys: unable to read the hardware clock
[ 1.048275] at24 0-0050: supply vcc not found, using dummy regulator
[ 1.055255] at24 0-0050: 256 byte 24c02 EEPROM, writable, 16 bytes/write
[ 1.062194] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
[ 1.094210] lm73 1-0049: sensor 'lm73'
[ 1.098817] lm73 1-004a: sensor 'lm73'
[ 1.102706] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz
[ 1.108698] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 domain created
[ 1.117062] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
[ 1.126328] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
[ 1.137353] ti-udma 485c0100.dma-controller: Number of rings: 82
[ 1.145690] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
[ 1.156848] ti-udma 485c0000.dma-controller: Number of rings: 150
[ 1.167181] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
[ 1.177521] printk: console [ttyS2] disabled
[ 1.182013] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 287, base_baud = 3000000) is a 8250
[ 1.190915] printk: console [ttyS2] enabled
[ 1.199382] printk: bootconsole [ns16550a0] disabled
[ 1.210676] 2810000.serial: ttyS0 at MMIO 0x2810000 (irq = 288, base_baud = 3000000) is a 8250
[ 1.220396] 2820000.serial: ttyS3 at MMIO 0x2820000 (irq = 289, base_baud = 3000000) is a 8250
[ 1.230167] 2830000.serial: ttyS5 at MMIO 0x2830000 (irq = 290, base_baud = 3000000) is a 8250
[ 1.239847] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 291, base_baud = 3000000) is a 8250
[ 1.249498] 2850000.serial: ttyS4 at MMIO 0x2850000 (irq = 292, base_baud = 3000000) is a 8250
[ 1.259161] 2860000.serial: ttyS7 at MMIO 0x2860000 (irq = 293, base_baud = 3000000) is a 8250
[ 1.271012] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
[ 1.317665] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 1.326528] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000006
[ 1.339447] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
[ 1.346589] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
[ 1.353332] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:0
[ 1.363968] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
[ 1.376273] Mass Storage Function, version: 2009/09/11
[ 1.381551] LUN: removable file: (no medium)
[ 1.385924] no file given for LUN0
[ 1.389360] udc 31000000.usb: failed to start g_mass_storage: -22
[ 1.395461] g_mass_storage: probe of gadget.0 failed with error -22
[ 1.509107] mmc0: CQHCI version 5.10
[ 1.511686] gpio-427 (CTRL_SLEEP_MOCI#): hogged as output/high
[ 1.525917] debugfs: Directory 'spi0.0' with parent 'regmap' already present!
[ 1.554132] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
[ 1.569863] spi0.0: ttyMAX0 at I/O 0x0 (irq = 361, base_baud = 2764800) is a MAX3109
[ 1.578289] spi0.0: ttyMAX1 at I/O 0x1 (irq = 361, base_baud = 2764800) is a MAX3109
[ 1.587411] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
[ 1.625701] mmc0: new HS200 MMC card at address 0001
[ 1.631728] mmcblk0: mmc0:0001 Q2J55L 7.09 GiB
[ 1.636341] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 1.644420] mmcblk0: p1 p2
[ 1.648165] mmcblk0boot0: mmc0:0001 Q2J55L 16.0 MiB
[ 1.650106] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
[ 1.654654] mmcblk0boot1: mmc0:0001 Q2J55L 16.0 MiB
[ 1.663188] sdhci-am654 fa20000.mmc: Got CD GPIO
[ 1.667579] mmcblk0rpmb: mmc0:0001 Q2J55L 4.00 MiB, chardev (241:0)
[ 1.672460] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
[ 1.685346] mmc2: CQHCI version 5.10
[ 1.687862] input: gpio-keys as /devices/platform/gpio-keys/input/input1
[ 1.707014] ALSA device list:
[ 1.710057] No soundcards found.
[ 1.740698] mmc2: SDHCI controller on fa20000.mmc [fa20000.mmc] using ADMA 64-bit
[ 1.754228] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[ 1.761668] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 2.405077] EXT4-fs (mmcblk0p2): recovery complete
[ 2.414334] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
[ 2.422981] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 2.430602] devtmpfs: mounted
[ 2.435141] Freeing unused kernel memory: 2240K
[ 2.439786] Run /sbin/init as init process
[ 2.443895] with arguments:
[ 2.443902] /sbin/init
[ 2.443907] with environment:
[ 2.443911] HOME=/
[ 2.443916] TERM=linux
[ 2.592791] systemd[1]: System time before build time, advancing clock.
[ 2.645137] systemd[1]: systemd 250.5+ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP +SYSVINIT default-hierarchy=hybrid)
[ 2.677251] systemd[1]: Detected architecture arm64.
[ 2.743139] systemd[1]: Hostname set to <verdin-am62-15133535>.
[ 3.101600] systemd[1]: Binding to IPv6 address not available since kernel does not support IPv6.
[ 3.110583] systemd[1]: Binding to IPv6 address not available since kernel does not support IPv6.
[ 3.201532] systemd[1]: Binding to IPv6 address not available since kernel does not support IPv6.
[ 3.232905] systemd[1]: Queued start job for default target Graphical Interface.
[ 3.285966] systemd[1]: Created slice Slice /system/getty.
[ 3.312332] systemd[1]: Created slice Slice /system/modprobe.
[ 3.336555] systemd[1]: Created slice Slice /system/serial-getty.
[ 3.360189] systemd[1]: Created slice User and Session Slice.
[ 3.382536] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 3.406337] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 3.430755] systemd[1]: Reached target Host and Network Name Lookups.
[ 3.453913] systemd[1]: Reached target Path Units.
[ 3.470076] systemd[1]: Reached target Remote File Systems.
[ 3.489953] systemd[1]: Reached target Slice Units.
[ 3.506079] systemd[1]: Reached target Swaps.
[ 3.563134] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 3.590365] systemd[1]: Reached target RPC Port Mapper.
[ 3.617050] systemd[1]: Listening on Syslog Socket.
[ 3.639763] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 3.665638] systemd[1]: Listening on Journal Audit Socket.
[ 3.692390] systemd[1]: Listening on Journal Socket (/dev/log).
[ 3.716680] systemd[1]: Listening on Journal Socket.
[ 3.737951] systemd[1]: Listening on Network Service Netlink Socket.
[ 3.765065] systemd[1]: Listening on udev Control Socket.
[ 3.788019] systemd[1]: Listening on udev Kernel Socket.
[ 3.812303] systemd[1]: Listening on User Database Manager Socket.
[ 3.866470] systemd[1]: Mounting Huge Pages File System...
[ 3.896229] systemd[1]: Mounting POSIX Message Queue File System...
[ 3.928298] systemd[1]: Mounting Kernel Debug File System...
[ 3.946870] systemd[1]: Kernel Trace File System was skipped because of a failed condition check (ConditionPathExists=/sys/kernel/tracing).
[ 3.968751] systemd[1]: Mounting Temporary Directory /tmp...
[ 4.014875] systemd[1]: Starting Create List of Static Device Nodes...
[ 4.046582] systemd[1]: Starting Load Kernel Module configfs...
[ 4.071206] systemd[1]: Starting Load Kernel Module drm...
[ 4.104648] systemd[1]: Starting Load Kernel Module fuse...
[ 4.119561] fuse: init (API version 7.37)
[ 4.147061] systemd[1]: Starting RPC Bind...
[ 4.179886] systemd[1]: Starting File System Check on Root Device...
[ 4.229389] systemd[1]: Starting Journal Service...
[ 4.256029] systemd[1]: Starting Load Kernel Modules...
[ 4.276280] systemd[1]: Starting Generate network units from Kernel command line...
[ 4.307919] systemd[1]: Starting Coldplug All udev Devices...
[ 4.345164] systemd[1]: Started RPC Bind.
[ 4.357301] g_serial gadget.0: Gadget Serial v2.4
[ 4.362150] g_serial gadget.0: g_serial ready
[ 4.363115] systemd[1]: Mounted Huge Pages File System.
[ 4.399074] systemd[1]: Mounted POSIX Message Queue File System.
[ 4.430831] systemd[1]: Mounted Kernel Debug File System.
[ 4.463006] systemd[1]: Started Journal Service.
[ 4.847712] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
[ 4.940586] systemd-journald[156]: Received client request to flush runtime journal.
[ 5.112054] audit: type=1334 audit(1651167747.516:2): prog-id=5 op=LOAD
[ 5.120158] audit: type=1334 audit(1651167747.524:3): prog-id=6 op=LOAD
[ 6.183773] ina2xx 1-0040: power monitor ina260 (Rshunt = 0 uOhm)
[ 6.191174] ina2xx 1-0041: power monitor ina260 (Rshunt = 0 uOhm)
[ 6.202589] ina2xx 1-0042: power monitor ina260 (Rshunt = 0 uOhm)
[ 6.210974] omap8250 2b300000.serial: No clock speed specified: using default: 48000000
[ 6.212292] ina2xx 1-0043: power monitor ina260 (Rshunt = 0 uOhm)
[ 6.229902] 2b300000.serial: ttyS1 at MMIO 0x2b300000 (irq = 482, base_baud = 3000000) is a 8250
[ 6.232047] ina2xx 1-0044: power monitor ina260 (Rshunt = 0 uOhm)
[ 6.250041] ina2xx 1-0045: power monitor ina260 (Rshunt = 0 uOhm)
[ 6.268497] ina2xx 1-0046: power monitor ina260 (Rshunt = 0 uOhm)
[ 6.285751] random: crng init done
[ 6.292941] ina2xx 1-0047: power monitor ina260 (Rshunt = 0 uOhm)
[ 6.320437] ina2xx 1-004b: power monitor ina260 (Rshunt = 0 uOhm)
[ 6.390314] pwm-backlight backlight-mezzanine: supply power not found, using dummy regulator
[ 6.605294] k3-m4-rproc 5000000.m4fss: device does not reserved memory regions, ret = -22
[ 6.634230] k3-m4-rproc 5000000.m4fss: reserved memory init failed, ret = -22
[ 6.647336] remoteproc remoteproc0: releasing 5000000.m4fss
[ 6.661283] k3-m4-rproc: probe of 5000000.m4fss failed with error -22
[ 6.772774] rtc-ti-k3 2b1f0000.rtc: registered as rtc1
[ 6.848028] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[ 6.849537] pvrsrvkm: loading out-of-tree module taints kernel.
[ 6.872658] [drm] Initialized tidss 1.0.0 20180215 for 30200000.dss on minor 0
[ 6.896922] Console: switching to colour frame buffer device 240x67
[ 6.938105] platform 78000000.r5f: configured R5F for IPC-only mode
[ 6.943481] tidss 30200000.dss: [drm] fb0: tidssdrmfb frame buffer device
[ 6.996080] platform 78000000.r5f: device does not have reserved memory regions, ret = -22
[ 7.050432] k3_r5_rproc bus@f0000:bus@b00000:r5fss@78000000: reserved memory init failed, ret = -22
[ 7.091013] remoteproc remoteproc0: releasing 78000000.r5f
[ 7.097603] PVR_K: 186: Device: fd00000.gpu
[ 7.102536] PVR_K: 186: Read BVNC 33.15.11.3 from HW device registers
[ 7.132631] k3_r5_rproc bus@f0000:bus@b00000:r5fss@78000000: k3_r5_cluster_rproc_init failed, ret = -22
[ 7.147386] PVR_K: 186: RGX Device registered with BVNC 33.15.11.3
[ 7.189936] [drm] Initialized pvr 23.3.6512818 20170530 for fd00000.gpu on minor 1
[ 7.208346] k3_r5_rproc: probe of bus@f0000:bus@b00000:r5fss@78000000 failed with error -22
[ 9.210316] remoteproc remoteproc0: 30074000.pru is available
[ 9.247258] remoteproc remoteproc1: 30078000.pru is available
[ 10.101149] audit: type=1334 audit(1651194971.476:4): prog-id=7 op=LOAD
[ 10.109430] audit: type=1334 audit(1651194971.484:5): prog-id=8 op=LOAD
[ 10.595368] audit: type=1334 audit(1651194971.972:6): prog-id=9 op=LOAD
[ 10.618243] audit: type=1334 audit(1651194971.992:7): prog-id=10 op=LOAD
[ 10.794628] using random self ethernet address
[ 10.807464] using random host ethernet address
[ 11.247557] UDC core: g1: couldn't find an available UDC or it's busy
[ 11.567366] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 11.612030] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 11.619895] cfg80211: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[ 11.737986] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=357)
[ 11.754573] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
[ 11.874322] audit: type=1334 audit(1651194973.252:8): prog-id=11 op=LOAD
[ 11.890484] audit: type=1334 audit(1651194973.260:9): prog-id=12 op=LOAD
[ 12.309242] audit: type=1334 audit(1651194973.684:10): prog-id=13 op=LOAD
[ 12.330615] audit: type=1334 audit(1651194973.696:11): prog-id=14 op=LOAD
[ 12.828935] audit: type=1006 audit(1651194974.204:12): pid=567 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=1 res=1
[ 12.852378] audit: type=1300 audit(1651194974.204:12): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=fffff2db3fb0 a2=1 a3=0 items=0 ppid=1 pid=567 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/lib/systemd/systemd" key=(null)
[ 13.392780] systemd-journald[156]: Data hash table of /run/log/journal/e0ce9ad8216448fabc0c3c94d3b8442b/system.journal has a fill level at 75.1 (2732 of 3640 items, 2097152 file size, 767 bytes per hash table item), suggesting rotation.
[ 13.418528] systemd-journald[156]: /run/log/journal/e0ce9ad8216448fabc0c3c94d3b8442b/system.journal: Journal header limits reached or header out-of-date, rotating.
[ 13.870975] PVR_K: 561: RGX Firmware image 'rgx.fw.33.15.11.3' loaded
[ 13.885513] PVR_K: 561: Shader binary image 'rgx.sh.33.15.11.3' loaded
[ 42.510084] kauditd_printk_skb: 12 callbacks suppressed
[ 42.510125] audit: type=1334 audit(1651195003.888:18): prog-id=12 op=UNLOAD
[ 42.522774] audit: type=1334 audit(1651195003.888:19): prog-id=11 op=UNLOAD
BSP/OS Version:
Linux verdin-am62-15133535 6.1.80-6.7.0-devel+git.603f75dc931d #1 SMP PREEMPT Wed Aug 28 15:15:41 UTC 2024 aarch64 aarch64 aarch64 GNU/Linux
k3-am625-verdin-nonwifi-dev.dtb (67.6 KB)
