we are trying to boot from SD card using the MMC2 port.we have done the changes in the device tree as below,
/* On-module Wi-Fi on WB SKUs, module-specific SDIO otherwise /
pinctrl_sdhci2: main-mmc2-pins-default {
pinctrl-single,pins = <
AM62X_IOPAD(0x120, PIN_INPUT, 0) / (C24) MMC2_CMD / / WiFi_SDIO_CMD /
AM62X_IOPAD(0x118, PIN_INPUT, 0) / (D25) MMC2_CLK / / WiFi_SDIO_CLK /
AM62X_IOPAD(0x114, PIN_INPUT, 0) / (B24) MMC2_DAT0 / / WiFi_SDIO_DATA0 /
AM62X_IOPAD(0x110, PIN_INPUT, 0) / (C25) MMC2_DAT1 / / WiFi_SDIO_DATA1 /
AM62X_IOPAD(0x10c, PIN_INPUT, 0) / (E23) MMC2_DAT2 / / WiFi_SDIO_DATA2 /
AM62X_IOPAD(0x108, PIN_INPUT, 0) / (D24) MMC2_DAT3 / / WiFi_SDIO_DATA3 /
AM62X_IOPAD(0x11c, PIN_INPUT, 0) / (#N/A) MMC2_CLKB */
/* Verdin SD_2_CD# as GPIO */
pinctrl_sd2_cd_gpio: main-gpio0-71-pins-default {
AM62X_IOPAD(0x0124, PIN_INPUT_PULLUP, 7) /* (A23) MMC2_SDCD.GPIO0_71 */ /* SODIMM 157 */
&sdhci2 {
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_sdhci2>, <&pinctrl_sd2_cd_gpio>;
cd-gpios = <&main_gpio1 71 GPIO_ACTIVE_LOW>;
disable-wp;
ti,fails-without-test-cd;
ti,driver-strength-ohm = <33>;
we create a .wic image and write it into external Sd card using Sudo DD commad.
the issue is that when i try to boot from Sd card using mmc2.
in u-boot when i use the commad mmc dev 2, it returns an error stating No MMC 2 device found.
is there anything wrong in the above config or suggest me a way to boot from MMC2!
Thanks in advance
