The property broken -cd did not make difference in my situation . We still have two boards which boot all way through and other two experience NMI watch dog event before getting to command prompt. I am here with attaching again the debug out from the CLI .
U-Boot 2015.04+fslc+g10bc451 (Jun 28 2016 - 13:25:52)
CPU: Freescale Vybrid VF500 at 396 MHz
Reset cause: POWER ON RESET
DRAM: 128 MiB
NAND: 128 MiB
MMC: FSL_SDHC: 0
In: serial
Out: serial
Err: serial
Model: Toradex Colibri VF50 128MB IT V1.2A, Serial# 04892873
Net: FEC
Booting from MMC/SD card...
4739032 bytes read in 385 ms (11.7 MiB/s)
24497 bytes read in 66 ms (362.3 KiB/s)
Kernel image @ 0x81000000 [ 0x000000 - 0x484fd8 ]
## Flattened Device Tree blob at 82000000
Booting using the fdt blob at 0x82000000
Using Device Tree in place at 82000000, end 82008fb0
Updating MTD partitions...
Starting kernel ...
[ 0.000000] Linux version 4.4.14-v2.6b2+gefe965a (prutschman@doozer) (gcc version 5.2.1 20151005 (Linaro GCC 5.2-2015.11-2) ) #1 Wed Sep 21 12:25:49 PDT 2016
[ 0.000000] CPU: ARMv7 Processor [410fc051] revision 1 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: Toradex Colibri VF50 on Metafridge
[ 0.000000] cma: Reserved 16 MiB at 0x86c00000
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32004
[ 0.000000] Kernel command line: root=/dev/mmcblk0p2 rw rootwait console=tty1 console=ttyLP0,115200n8 consoleblank=0
[ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Memory: 102472K/129024K available (6071K kernel code, 216K rwdata, 2144K rodata, 228K init, 176K bss, 10168K reserved, 16384K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0x88000000 - 0xff800000 (1912 MB)
[ 0.000000] lowmem : 0x80000000 - 0x87e00000 ( 126 MB)
[ 0.000000] modules : 0x7f000000 - 0x80000000 ( 16 MB)
[ 0.000000] .text : 0x80008000 - 0x8080e034 (8217 kB)
[ 0.000000] .init : 0x8080f000 - 0x80848000 ( 228 kB)
[ 0.000000] .data : 0x80848000 - 0x8087e240 ( 217 kB)
[ 0.000000] .bss : 0x8087e240 - 0x808aa338 ( 177 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000054] sched_clock: 64 bits at 132MHz, resolution 7ns, wraps every 2199023255551ns
[ 0.000124] clocksource: arm_global_timer: mask: 0xffffffffffffffff max_cycles: 0x1e7178659b, max_idle_ns: 440795204301 ns
[ 0.001284] Console: colour dummy device 80x30
[ 0.002408] console [tty1] enabled
[ 0.002500] Calibrating delay loop... 262.96 BogoMIPS (lpj=1314816)
[ 0.070296] pid_max: default: 32768 minimum: 301
[ 0.070670] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.070793] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.072780] CPU: Testing write buffer coherency: ok
[ 0.073783] Setting up static identity map for 0x80008200 - 0x80008258
[ 0.077636] devtmpfs: initialized
[ 0.093196] VFP support v0.3: implementor 41 architecture 2 part 30 variant 5 rev 1
[ 0.094307] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.097578] pinctrl core: initialized pinctrl subsystem
[ 0.101147] NET: Registered protocol family 16
[ 0.104859] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.107730] cpuidle: using governor menu
[ 0.143909] irq: no irq domain found for /soc/aips-bus@40000000/gpio@40049000 !
[ 0.147266] PM: CKE/RESET pulls available, enable Suspend-to-RAM
[ 0.148898] hw-breakpoint: found 2 (+1 reserved) breakpoint and 1 watchpoint registers.
[ 0.149049] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.150166] vf610-pinctrl 40048000.iomuxc: initialized IMX pinctrl driver
[ 0.190322] SCSI subsystem initialized
[ 0.191488] usbcore: registered new interface driver usbfs
[ 0.191820] usbcore: registered new interface driver hub
[ 0.192203] usbcore: registered new device driver usb
[ 0.195023] i2c i2c-0: IMX I2C adapter registered
[ 0.195285] i2c i2c-0: using dma0chan0 (tx) and dma0chan1 (rx) for DMA transfers
[ 0.195823] Linux video capture interface: v2.00
[ 0.196236] pps_core: LinuxPPS API ver. 1 registered
[ 0.196326] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.196553] PTP clock support registered
[ 0.197964] Advanced Linux Sound Architecture Driver Initialized.
[ 0.201365] clocksource: Switched to clocksource arm_global_timer
[ 0.243056] NET: Registered protocol family 2
[ 0.245408] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.245586] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.245703] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.246089] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.246219] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.246776] NET: Registered protocol family 1
[ 0.247885] RPC: Registered named UNIX socket transport module.
[ 0.248014] RPC: Registered udp transport module.
[ 0.248088] RPC: Registered tcp transport module.
[ 0.248154] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.250559] hw perfevents: enabled with armv7_cortex_a5 PMU driver, 3 counters available
[ 0.253897] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.278270] NFS: Registering the id_resolver key type
[ 0.278493] Key type id_resolver registered
[ 0.278578] Key type id_legacy registered
[ 0.278753] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.280751] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.282567] fuse init (API version 7.23)
[ 0.292823] io scheduler noop registered
[ 0.292963] io scheduler deadline registered
[ 0.293647] io scheduler cfq registered (default)
[ 0.309371] 40027000.serial: ttyLP0 at MMIO 0x40027000 (irq = 19, base_baud = 4125000) is a FSL_LPUART
[ 0.813260] console [ttyLP0] enabled
[ 0.818629] 40028000.serial: ttyLP1 at MMIO 0x40028000 (irq = 20, base_baud = 4125000) is a FSL_LPUART
[ 0.829947] 40029000.serial: ttyLP2 at MMIO 0x40029000 (irq = 21, base_baud = 4125000) is a FSL_LPUART
[ 0.842042] [drm] Initialized drm 1.1.0 20060810
[ 0.857630] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 0.864486] [drm] No driver support for vblank timestamp query.
[ 0.915617] Console: switching to colour frame buffer device 80x30
[ 0.949579] fsl-dcu 40058000.dcu: fb0: frame buffer device
[ 0.966474] [drm] Initialized fsl-dcu-drm 1.0.0 20150213 on minor 0
[ 1.007897] loop: module loaded
[ 1.025937] nand: device found, Manufacturer ID: 0xc2, Chip ID: 0xf1
[ 1.043536] nand: Macronix NAND 128MiB 3,3V 8-bit
[ 1.059196] nand: 128 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
[ 1.089448] Bad block table found at page 65472, version 0x01
[ 1.107059] Bad block table found at page 65408, version 0x01
[ 1.124253] nand_read_bbt: bad block at 0x0000013c0000
[ 1.140834] 4 ofpart partitions found on MTD device vf610_nfc
[ 1.158030] Creating 4 MTD partitions on "vf610_nfc":
[ 1.174661] 0x000000000000-0x000000020000 : "vf-bcb"
[ 1.192813] 0x000000020000-0x000000180000 : "u-boot"
[ 1.210540] 0x000000180000-0x000000200000 : "u-boot-env"
[ 1.228196] 0x000000200000-0x000008000000 : "ubi"
[ 1.249343] spidev spi1.0: buggy DT: spidev listed directly in DT
[ 1.266359] ------------[ cut here ]------------
[ 1.281574] WARNING: CPU: 0 PID: 1 at /home/prutschman/oe-core/build/out-glibc/work-shared/colibri-vf/kernel-source/drivers/spi/spidev.c:770 spidev_probe+0x1a8/0x1c4()
[ 1.327755] Modules linked in:
[ 1.341249] CPU: 0 PID: 1 Comm: swapper Not tainted 4.4.14-v2.6b2+gefe965a #1
[ 1.359166] Hardware name: Freescale Vybrid VF5xx/VF6xx (Device Tree)
[ 1.376420] Backtrace:
[ 1.389465] [<80013474>] (dump_backtrace) from [<8001366c>] (show_stack+0x18/0x1c)
[ 1.418280] r7:803b2598 r6:00000302 r5:00000009 r4:00000000
[ 1.435343] [<80013654>] (show_stack) from [<802a016c>] (dump_stack+0x24/0x28)
[ 1.464408] [<802a0148>] (dump_stack) from [<80021b64>] (warn_slowpath_common+0x88/0xb4)
[ 1.494662] [<80021adc>] (warn_slowpath_common) from [<80021c34>] (warn_slowpath_null+0x24/0x2c)
[ 1.526966] r8:00000000 r7:80869b8c r6:80869b7c r5:86af4400 r4:86af4400
[ 1.546462] [<80021c10>] (warn_slowpath_null) from [<803b2598>] (spidev_probe+0x1a8/0x1c4)
[ 1.579227] [<803b23f0>] (spidev_probe) from [<803affd8>] (spi_drv_probe+0x84/0xb0)
[ 1.612942] r8:00000000 r7:80869b8c r6:80869b7c r5:00000000 r4:86af4400
[ 1.634031] [<803aff54>] (spi_drv_probe) from [<80354644>] (driver_probe_device+0x204/0x2f8)
[ 1.670173] r7:80869b8c r6:00000000 r5:86af4400 r4:8089f82c
[ 1.690313] [<80354440>] (driver_probe_device) from [<8035485c>] (__device_attach_driver+0x8c/0xb4)
[ 1.726978] r9:00000000 r8:8089f808 r7:00000001 r6:86af4400 r5:86843c78 r4:80869b8c
[ 1.763459] [<803547d0>] (__device_attach_driver) from [<80352980>] (bus_for_each_drv+0x68/0x9c)
[ 1.800920] r7:00000001 r6:803547d0 r5:86843c78 r4:00000000
[ 1.821524] [<80352918>] (bus_for_each_drv) from [<80354398>] (__device_attach+0xb8/0x11c)
[ 1.858437] r6:86af4434 r5:86af4400 r4:86af4400
[ 1.877743] [<803542e0>] (__device_attach) from [<803548d0>] (device_initial_probe+0x14/0x18)
[ 1.914716] r7:00000000 r6:8086960c r5:86af4400 r4:86af4408
[ 1.935054] [<803548bc>] (device_initial_probe) from [<803538ac>] (bus_probe_device+0x8c/0x94)
[ 1.971791] [<80353820>] (bus_probe_device) from [<80351a1c>] (device_add+0x378/0x574)
[ 2.007880] r7:00000000 r6:86af4000 r5:86af4400 r4:86af4408
[ 2.028180] [<803516a4>] (device_add) from [<803b06f8>] (spi_add_device+0xa0/0x138)
[ 2.063643] r10:807a3e30 r9:807a3e3c r8:80755c54 r7:868ac610 r6:86af4000 r5:00000000
[ 2.099749] r4:86af4400
[ 2.116043] [<803b0658>] (spi_add_device) from [<803b1d58>] (spi_register_master+0x4b8/0x71c)
[ 2.152035] r7:87ce4c50 r6:86af4000 r5:00000000 r4:86af4400
[ 2.171822] [<803b18a0>] (spi_register_master) from [<803b400c>] (dspi_probe+0x200/0x314)
[ 2.207117] r10:00000000 r9:87ce4924 r8:86aea780 r7:868ac610 r6:86af42a0 r5:868ac600
[ 2.242410] r4:86af4000
[ 2.258281] [<803b3e0c>] (dspi_probe) from [<80356094>] (platform_drv_probe+0x54/0xb8)
[ 2.292739] r10:00000000 r9:00000007 r8:00000000 r7:fffffdfb r6:80869be0 r5:868ac610
[ 2.327874] r4:8089f82c
[ 2.343621] [<80356040>] (platform_drv_probe) from [<80354644>] (driver_probe_device+0x204/0x2f8)
[ 2.379041] r7:80869be0 r6:00000000 r5:868ac610 r4:8089f82c
[ 2.398495] [<80354440>] (driver_probe_device) from [<803547cc>] (__driver_attach+0x94/0x98)
[ 2.433109] r9:00000007 r8:8087e240 r7:00000000 r6:868ac644 r5:80869be0 r4:868ac610
[ 2.467577] [<80354738>] (__driver_attach) from [<803528c0>] (bus_for_each_dev+0x70/0xa4)
[ 2.502333] r7:00000000 r6:80354738 r5:80869be0 r4:00000000
[ 2.521672] [<80352850>] (bus_for_each_dev) from [<80353f30>] (driver_attach+0x24/0x28)
[ 2.556697] r6:80861a40 r5:86aad900 r4:80869be0
[ 2.575115] [<80353f0c>] (driver_attach) from [<80353b68>] (bus_add_driver+0x1a8/0x220)
[ 2.610021] [<803539c0>] (bus_add_driver) from [<80354f4c>] (driver_register+0x80/0x100)
[ 2.645054] r7:86aea180 r6:8084e1a0 r5:80828478 r4:80869be0
[ 2.664705] [<80354ecc>] (driver_register) from [<80355fbc>] (__platform_driver_register+0x48/0x50)
[ 2.701263] r5:80828478 r4:8084e1a0
[ 2.718622] [<80355f74>] (__platform_driver_register) from [<80828494>] (fsl_dspi_driver_init+0x1c/0x20)
[ 2.755098] [<80828478>] (fsl_dspi_driver_init) from [<80009614>] (do_one_initcall+0x98/0x1e0)
[ 2.791523] [<8000957c>] (do_one_initcall) from [<8080fe64>] (kernel_init_freeable+0x148/0x1e0)
[ 2.828167] r10:8083a838 r9:00000007 r8:8087e240 r7:8083a830 r6:8087e240 r5:80847a74
[ 2.864557] r4:8080b6f0
[ 2.880821] [<8080fd1c>] (kernel_init_freeable) from [<805f07a8>] (kernel_init+0x10/0xf0)
[ 2.916210] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:805f0798
[ 2.951762] r4:00000000
[ 2.967754] [<805f0798>] (kernel_init) from [<8000f7f8>] (ret_from_fork+0x14/0x3c)
[ 3.002124] r5:805f0798 r4:00000000
[ 3.019243] ---[ end trace ade595bfc0826987 ]---
[ 3.041784] +V3.3: supplied by 3.3V
[ 3.060123] pps pps0: new PPS source ptp0
[ 3.086653] libphy: fec_enet_mii_bus: probed
[ 3.105134] fec 400d1000.ethernet eth0: registered PHC device 0
[ 3.124623] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 3.144548] usbcore: registered new interface driver usb-storage
[ 3.163719] usbcore: registered new interface driver usbserial
[ 3.181938] usbcore: registered new interface driver usbserial_generic
[ 3.200400] usbserial: USB Serial support registered for generic
[ 3.218398] usbcore: registered new interface driver ftdi_sio
[ 3.235792] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 3.265054] usbcore: registered new interface driver pl2303
[ 3.281826] usbserial: USB Serial support registered for pl2303
[ 3.302831] 40034000.usb supply vbus not found, using dummy regulator
[ 3.323407] mousedev: PS/2 mouse device common for all mice
[ 3.342331] rtc-ds1307: probe of 0-0068 failed with error -5
[ 3.361197] snvs_rtc 400a7000.snvs:snvs-rtc-lp: rtc core: registered 400a7000.snvs:snvs- as rtc0
[ 3.391562] i2c /dev entries driver
[ 3.411164] imx2-wdt 4003e000.wdog: timeout 60 sec (nowayout=0)
[ 3.428682] sdhci: Secure Digital Host Controller Interface driver
[ 3.445569] sdhci: Copyright(c) Pierre Ossman
[ 3.460541] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.478495] /soc/aips-bus@40080000/esdhc@400b2000: voltage-ranges unspecified
[ 3.496975] sdhci-esdhc-imx 400b2000.esdhc: Got CD GPIO
[ 3.513830] sdhci-esdhc-imx 400b2000.esdhc: No vmmc regulator found
[ 3.531449] sdhci-esdhc-imx 400b2000.esdhc: No vqmmc regulator found
[ 3.581933] mmc0: SDHCI controller on 400b2000.esdhc [400b2000.esdhc] using ADMA
[ 3.616498] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.634523] usbcore: registered new interface driver usbhid
[ 3.651863] usbhid: USB HID core driver
[ 3.690947] Netfilter messages via NETLINK v0.30.
[ 3.707395] nfnl_acct: registering with nfnetlink.
[ 3.723690] nf_conntrack version 0.5.0 (1857 buckets, 7428 max)
[ 3.743361] nf_tables: (c) 2007-2009 Patrick McHardy <kaber@trash.net>
[ 3.763406] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 3.782819] NET: Registered protocol family 10
[ 3.799621] mmc0: new high speed SDHC card at address 0007
[ 3.819690] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 3.838033] mmcblk0: mmc0:0007 SD08G 7.42 GiB
[ 3.853510] sit: IPv6 over IPv4 tunneling driver
[ 3.872388] mmcblk0: p1 p2
[ 3.887424] NET: Registered protocol family 17
[ 3.905072] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 3.938997] Bridge firewalling registered
[ 3.954072] 8021q: 802.1Q VLAN Support v1.8
[ 3.968872] Key type dns_resolver registered
[ 3.983736] Registering SWP/SWPB emulation handler
[ 4.001624] registered taskstats version 1
[ 4.023072] 40034000.usb supply vbus not found, using dummy regulator
[ 4.046464] ci_hdrc ci_hdrc.0: EHCI Host Controller
[ 4.061777] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
[ 4.091514] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[ 4.110075] hub 1-0:1.0: USB hub found
[ 4.124206] hub 1-0:1.0: 1 port detected
[ 4.140691] VCC_USB[1-4]: supplied by 5V
[ 4.159342] ci_hdrc ci_hdrc.1: EHCI Host Controller
[ 4.174330] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 2
[ 4.211522] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[ 4.229652] hub 2-0:1.0: USB hub found
[ 4.243974] hub 2-0:1.0: 1 port detected
[ 4.261121] input: colibri-vf50-ts as /devices/platform/vf50-touchscreen/input/input0
[ 4.295975] input: gpio-keys as /devices/platform/gpio-keys/input/input1
[ 4.315854] snvs_rtc 400a7000.snvs:snvs-rtc-lp: setting system clock to 1970-01-01 00:00:00 UTC (0)
[ 4.383212] ALSA device list:
[ 4.396581] No soundcards found.
[ 4.446080] random: nonblocking pool is initialized
[ 32.071386] NMI watchdog: BUG: soft lockup - CPU#0 stuck for 22s! [mmcqd/0:56]
[ 32.098635] Modules linked in:
[ 32.111762] CPU: 0 PID: 56 Comm: mmcqd/0 Tainted: G W 4.4.14-v2.6b2+gefe965a #1
[ 32.140612] Hardware name: Freescale Vybrid VF5xx/VF6xx (Device Tree)
[ 32.157573] task: 86aaa400 ti: 86b46000 task.ti: 86b46000
[ 32.173524] PC is at __do_softirq+0xa0/0x25c
[ 32.188236] LR is at 0x288840
[ 32.201391] pc : [<80024894>] lr : [<00288840>] psr: 60000113
[ 32.201391] sp : 86b47c88 ip : 8087ea80 fp : 86b47ce4
[ 32.234241] r10: 868bda84 r9 : 88003100 r8 : 86806000
[ 32.250111] r7 : 00000001 r6 : 00000000 r5 : 00000000 r4 : 00000002
[ 32.267356] r3 : 00000000 r2 : 8087ea40 r1 : 00000100 r0 : 00288040
[ 32.284438] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment none
[ 32.302327] Control: 10c5387d Table: 80004059 DAC: 00000051
[ 32.319069] CPU: 0 PID: 56 Comm: mmcqd/0 Tainted: G W 4.4.14-v2.6b2+gefe965a #1
[ 32.348973] Hardware name: Freescale Vybrid VF5xx/VF6xx (Device Tree)
[ 32.366279] Backtrace:
[ 32.379265] [<80013474>] (dump_backtrace) from [<8001366c>] (show_stack+0x18/0x1c)
[ 32.408143] r7:86b47c38 r6:86b46000 r5:8084a180 r4:808540c8
[ 32.425314] [<80013654>] (show_stack) from [<802a016c>] (dump_stack+0x24/0x28)
[ 32.455153] [<802a0148>] (dump_stack) from [<8001031c>] (show_regs+0x14/0x18)
[ 32.473982] [<80010308>] (show_regs) from [<80077984>] (watchdog_timer_fn+0x170/0x1a4)
[ 32.505259] [<80077814>] (watchdog_timer_fn) from [<800587dc>] (__hrtimer_run_queues.constprop.6+0x110/0x18c)
[ 32.539110] r10:8087e089 r9:00000001 r8:80852fcc r7:00000000 r6:80852fc0 r5:808540d8
[ 32.571518] r4:80852f80
[ 32.586227] [<800586cc>] (__hrtimer_run_queues.constprop.6) from [<80058a1c>] (hrtimer_interrupt+0x90/0x1b0)
[ 32.621106] r10:80853018 r9:80852f80 r8:80853038 r7:ffffffff r6:7fffffff r5:00000003
[ 32.655267] r4:80852f80
[ 32.670920] [<8005898c>] (hrtimer_interrupt) from [<8044b7c0>] (gt_clockevent_interrupt+0x4c/0x6c)
[ 32.706351] r10:868bda84 r9:88003100 r8:87cd8140 r7:00000010 r6:86817fc0 r5:87cd8140
[ 32.741233] r4:00000001
[ 32.756854] [<8044b774>] (gt_clockevent_interrupt) from [<80050ec0>] (handle_percpu_devid_irq+0x68/0x80)
[ 32.792900] r5:8085c084 r4:86804c00
[ 32.809553] [<80050e58>] (handle_percpu_devid_irq) from [<8004d344>] (generic_handle_irq+0x2c/0x3c)
[ 32.844818] r9:88003100 r8:86806000 r7:00000001 r6:86b47d50 r5:00000000 r4:8085bf40
[ 32.879071] [<8004d318>] (generic_handle_irq) from [<8004d5b0>] (__handle_domain_irq+0x5c/0xb0)
[ 32.914321] [<8004d554>] (__handle_domain_irq) from [<800093ec>] (gic_handle_irq+0x50/0x84)
[ 32.949178] r9:88003100 r8:86b47c38 r7:88002100 r6:8800210c r5:8084a3a4 r4:8085c080
[ 32.983669] [<8000939c>] (gic_handle_irq) from [<800140d4>] (__irq_svc+0x54/0x70)
[ 33.018398] Exception stack(0x86b47c38 to 0x86b47c80)
[ 33.037086] 7c20: 00288040 00000100
[ 33.071508] 7c40: 8087ea40 00000000 00000002 00000000 00000000 00000001 86806000 88003100
[ 33.106330] 7c60: 868bda84 86b47ce4 8087ea80 86b47c88 00288840 80024894 60000113 ffffffff
[ 33.141151] r9:88003100 r8:86806000 r7:86b47c6c r6:ffffffff r5:60000113 r4:80024894
[ 33.176178] [<800247f4>] (__do_softirq) from [<80024d24>] (irq_exit+0xe0/0x114)
[ 33.210913] r10:868bda84 r9:88003100 r8:86806000 r7:00000001 r6:00000000 r5:00000000
[ 33.247104] r4:8085bf40
[ 33.263273] [<80024c44>] (irq_exit) from [<8004d5b4>] (__handle_domain_irq+0x60/0xb0)
[ 33.298314] r5:00000000 r4:8085bf40
[ 33.315300] [<8004d554>] (__handle_domain_irq) from [<800093ec>] (gic_handle_irq+0x50/0x84)
[ 33.350166] r9:88003100 r8:86b47d50 r7:88002100 r6:8800210c r5:8084a3a4 r4:8085c080
[ 33.384624] [<8000939c>] (gic_handle_irq) from [<800140d4>] (__irq_svc+0x54/0x70)
[ 33.418501] Exception stack(0x86b47d50 to 0x86b47d98)
[ 33.436738] 7d40: a0000013 00000003 86aaa400 00000000
[ 33.471158] 7d60: 808a11dc a0000013 86aff840 80852f40 80045850 86b46000 868bda84 86b47dbc
[ 33.506334] 7d80: 86b47dc0 86b47da0 80464b48 80463fe4 60000013 ffffffff
[ 33.526633] r9:86b46000 r8:80045850 r7:86b47d84 r6:ffffffff r5:60000013 r4:80463fe4
[ 33.561451] [<80463f8c>] (clk_enable_unlock) from [<80464b48>] (clk_enable+0x30/0x40)
[ 33.596068] r7:80852f40 r6:86aff840 r5:a0000013 r4:00000000
[ 33.615445] [<80464b18>] (clk_enable) from [<80447360>] (sdhci_esdhc_runtime_resume+0xa8/0xbc)
[ 33.650598] r5:86afe490 r4:86ad1ac0
[ 33.667271] [<804472b8>] (sdhci_esdhc_runtime_resume) from [<8035ad84>] (pm_generic_runtime_resume+0x34/0x40)
[ 33.704057] r7:80852f40 r6:8035ad50 r5:00000000 r4:868bda10
[ 33.723388] [<8035ad50>] (pm_generic_runtime_resume) from [<8035c41c>] (rpm_callback+0x5c/0xcc)
[ 33.759260] [<8035c3c0>] (rpm_callback) from [<8035d200>] (rpm_resume+0x304/0x4ec)
[ 33.793965] r5:868b9e10 r4:868bda10
[ 33.810947] [<8035cefc>] (rpm_resume) from [<8035d444>] (__pm_runtime_resume+0x5c/0x78)
[ 33.845423] r10:86b46000 r9:86ad1a18 r8:ffffe000 r7:00000001 r6:86ad1800 r5:60000013
[ 33.880363] r4:868bda10
[ 33.896210] [<8035d3e8>] (__pm_runtime_resume) from [<8042dd6c>] (__mmc_claim_host+0x140/0x190)
[ 33.931552] r5:60000013 r4:00000000
[ 33.948303] [<8042dc2c>] (__mmc_claim_host) from [<8042dde4>] (mmc_get_card+0x28/0x2c)
[ 33.982344] r10:86b39340 r9:24590000 r8:ffffe000 r7:86b3e400 r6:86a05d40 r5:86ad2000
[ 34.016546] r4:86ad2000
[ 34.031834] [<8042ddbc>] (mmc_get_card) from [<8043e2b0>] (mmc_blk_issue_rq+0x264/0x4e8)
[ 34.065471] r5:86ad2000 r4:86b3e404
[ 34.081904] [<8043e04c>] (mmc_blk_issue_rq) from [<8043fc3c>] (mmc_queue_thread+0xa0/0x164)
[ 34.115774] r10:00000000 r9:24590000 r8:ffffe000 r7:86b3e40c r6:86a05d40 r5:86b46000
[ 34.149622] r4:86b3e404
[ 34.164630] [<8043fb9c>] (mmc_queue_thread) from [<8003ab48>] (kthread+0xdc/0xf4)
[ 34.196945] r9:00000000 r8:00000000 r7:8043fb9c r6:86b3e404 r5:86b38180 r4:00000000
[ 34.230491] [<8003aa6c>] (kthread) from [<8000f7f8>] (ret_from_fork+0x14/0x3c)
[ 34.263185] r7:00000000 r6:00000000 r5:8003aa6c r4:86b38180
