var-volatile.mount service issue
I made below change in /etc/fstab file, trying to enable quota for tmpfs file system.
tmpfs /var/volatile tmpfs defaults,usrquota 0 0
Generated image and loaded.
During boot up I can see below errors:
var-volatile.mount: Mount process exited, code=exited, status=32/n/a
var-volatile.mount: Failed with result ‘exit-code’.
Complete Log can be found below:
/var/run/openvswitch/blackhat-logsyncd.pid → /run/openvswitch/blackhat-logsyncd.pid; please update the unit file accordingly.
/lib/systemd/system/rpcbind.socket:5: ListenStream= references a path below legacy directory /var/run/, updating /var/run/rpcbind.sock → /run/rpcbind.sock; please update the unit file accordingly.
/lib/systemd/system/remote-ovsdb.socket:5: ListenStream= references a path below legacy directory /var/run/, updating /var/run/openvswitch/remote-ovsdb.sock → /run/openvswitch/remote-ovsdb.sock; please update the unit file accordingly.
/lib/systemd/system/dbus.socket:5: ListenStream= references a path below legacy directory /var/run/, updating /var/run/dbus/system_bus_socket → /run/dbus/system_bus_socket; please update the unit file accordingly.
/lib/systemd/system/ha-type-check.service:8: Unit configured to use KillMode=none. This is unsafe, as it disables systemd’s process lifecycle management for the service. Please update your service to use a safer KillMode=, such as ‘mixed’ or ‘control-group’. Support for KillMode=none is deprecated and will eventually be removed.
cgroup compatibility translation between legacy and unified hierarchy settings activated. See cgroup-compat debug messages for details.
modprobe@configfs.service: Deactivated successfully.
modprobe@fuse.service: Deactivated successfully.
Using hardware watchdog ‘BLACKHAT FPGA Watchdog’, version 1, device /dev/watchdog0
Watchdog running with a pretimeout of 10s.
Watchdog running with a timeout of 40s.
systemd-journald.service: Job systemd-journald.service/start failed with result ‘dependency’.
var-volatile-lib.service: Job var-volatile-lib.service/start failed with result ‘dependency’.
local-fs.target: Job local-fs.target/start failed with result ‘dependency’.
local-fs.target: Triggering OnFailure= dependencies.
var-volatile-spool.service: Job var-volatile-spool.service/start failed with result ‘dependency’.
var-volatile-cache.service: Job var-volatile-cache.service/start failed with result ‘dependency’.
var-volatile-srv.service: Job var-volatile-srv.service/start failed with result ‘dependency’.
systemd-ask-password-console.path: Deactivated successfully.
syslog.socket: Deactivated successfully.
var-volatile.mount: Start request repeated too quickly.
systemd-journal-flush.service: Main process exited, code=exited, status=1/FAILURE
systemd-journal-flush.service: Failed with result ‘exit-code’.
systemd-udevd.service: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
(This warning is only shown for the first unit using IP firewalling.)
systemd-journald.socket: Trigger limit hit, refusing further activation.
systemd-journald.socket: Failed with result ‘trigger-limit-hit’.
fs-security.mount: Directory /fs/security to mount over is not empty, mounting anyway.
fs-logs.mount: Directory /fs/logs to mount over is not empty, mounting anyway.
System is initializing
ou are in emergency mode. After logging in, typ
Cannot open access to console, the root account is locked.
See sulogin(8) man page for more details.
Press Enter to continue.
Reloading system manager configuration
Reloading.
/lib/systemd/system-generators/systemd-gpt-auto-generator failed with exit status 1.
Configuration file /lib/systemd/system/blackhat-credmgr.service.d/enable-boot-failure-triage.conf is marked executable. Please remove executable permission bits. Proceeding anyway.
/lib/systemd/system/ssh-utild.service:28: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/ssh-utild.pid → /run/openvswitch/ssh-utild.pid; please update the unit file accordingly.
/lib/systemd/system/blackhat-rdntmgmtd.service:25: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/blackhat-rdntmgmtd.pid → /run/openvswitch/blackhat-rdntmgmtd.pid; please update the unit file accordingly.
/lib/systemd/system/sshd-vsf-mbr.service:13: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
/lib/systemd/system/ztpd.service:12: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/ztpd.pid → /run/openvswitch/ztpd.pid; please update the unit file accordingly.
/lib/systemd/system/vsxmgmtd.service:13: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/vsxmgmtd.pid → /run/openvswitch/vsxmgmtd.pid; please update the unit file accordingly.
/lib/systemd/system/vsx-swupdated.service:14: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/vsx-swupdated.pid → /run/openvswitch/vsx-swupdated.pid; please update the unit file accordingly.
/lib/systemd/system/vrfapp.service:12: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/vrfapp.pid → /run/openvswitch/vrfapp.pid; please update the unit file accordingly.
/lib/systemd/system/vland.service:13: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/vland.pid → /run/openvswitch/vland.pid; please update the unit file accordingly.
/lib/systemd/system/snmp-alarmd.service:12: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/snmp-alarmd.pid → /run/openvswitch/snmp-alarmd.pid; please update the unit file accordingly.
/lib/systemd/system/smart-fib-mgrd.service:14: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/smart-fib-mgrd.pid → /run/openvswitch/smart-fib-mgrd.pid; please update the unit file accordingly.
/lib/systemd/system/rmond.service:11: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/rmond.pid → /run/openvswitch/rmond.pid; please update the unit file accordingly.
/lib/systemd/system/port-accessd.service:16: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/port-accessd.pid → /run/openvswitch/port-accessd.pid; please update the unit file accordingly.
/lib/systemd/system/poe-protod.service:13: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/poe-protod.pid → /run/openvswitch/poe-protod.pid; please update the unit file accordingly.
/lib/systemd/system/poe-hald.service:25: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/poe-hald.pid → /run/openvswitch/poe-hald.pid; please update the unit file accordingly.
/lib/systemd/system/pmd.service:25: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/pmd.pid → /run/openvswitch/pmd.pid; please update the unit file accordingly.
/lib/systemd/system/pim.service:16: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/pimd.pid → /run/openvswitch/pimd.pid; please update the unit file accordingly.
/lib/systemd/system/ntp-mgrd.service:20: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/ntp-mgrd.pid → /run/openvswitch/ntp-mgrd.pid; please update the unit file accordingly.
/lib/systemd/system/nfs-server.service:16: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
/lib/systemd/system/mtmd.service:17: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/mtmd.pid → /run/openvswitch/mtmd.pid; please update the unit file accordingly.
/lib/systemd/system/mpls-mgrd.service:14: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/mpls-mgrd.pid → /run/openvswitch/mpls-mgrd.pid; please update the unit file accordingly.
/lib/systemd/system/mcast-msdpd.service:12: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/mcast-msdpd.pid → /run/openvswitch/mcast-msdpd.pid; please update the unit file accordingly.
/lib/systemd/system/lldpd.service:12: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/lldpd.pid → /run/openvswitch/lldpd.pid; please update the unit file accordingly.
/lib/systemd/system/l2mac-mgrd.service:11: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/l2mac-mgrd.pid → /run/openvswitch/l2mac-mgrd.pid; please update the unit file accordingly.
/lib/systemd/system/ipsla-responderd.service:12: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/ipsla-responderd.pid → /run/openvswitch/ipsla-responderd.pid; please update the unit file accordingly.
/lib/systemd/system/ipctd.service:15: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/ipctd.pid → /run/openvswitch/ipctd.pid; please update the unit file accordingly.
/lib/systemd/system/intfd.service:13: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/intfd.pid → /run/openvswitch/intfd.pid; please update the unit file accordingly.
/lib/systemd/system/blackhat-vsxkad.service:12: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/blackhat-vsxkad.pid → /run/openvswitch/blackhat-vsxkad.pid; please update the unit file accordingly.
/lib/systemd/system/blackhat-vsxd.service:11: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/blackhat-vsxd.pid → /run/openvswitch/blackhat-vsxd.pid; please update the unit file accordingly.
/lib/systemd/system/blackhat-repld.service:12: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/blackhat-repld.pid → /run/openvswitch/blackhat-repld.pid; please update the unit file accordingly.
/lib/systemd/system/blackhat-relay.service:14: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/blackhat-relay.pid → /run/openvswitch/blackhat-relay.pid; please update the unit file accordingly.
/lib/systemd/system/blackhat-rdiscd.service:12: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/blackhat-rdiscd.pid → /run/openvswitch/blackhat-rdiscd.pid; please update the unit file accordingly.
/lib/systemd/system/blackhat-mgmdd.service:12: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/blackhat-mgmdd.pid → /run/openvswitch/blackhat-mgmdd.pid; please update the unit file accordingly.
/lib/systemd/system/blackhat-lpd.service:12: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/blackhat-lpd.pid → /run/openvswitch/blackhat-lpd.pid; please update the unit file accordingly.
/lib/systemd/system/blackhat-ledarbd.service:14: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/blackhat-ledarbd.pid → /run/openvswitch/blackhat-ledarbd.pid; please update the unit file accordingly.
/lib/systemd/system/blackhat-entityd.service:12: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/blackhat-entityd.pid → /run/openvswitch/blackhat-entityd.pid; please update the unit file accordingly.
/lib/systemd/system/blackhat-buttond.service:14: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/blackhat-buttond.pid → /run/openvswitch/blackhat-buttond.pid; please update the unit file accordingly.
/lib/systemd/system/fault-monitord.service:12: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/fault-monitord.pid → /run/openvswitch/fault-monitord.pid; please update the unit file accordingly.
/lib/systemd/system/fault-handlerd.service:15: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/fault-handlerd.pid → /run/openvswitch/fault-handlerd.pid; please update the unit file accordingly.
/lib/systemd/system/external-storage.service:12: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/external-storage.pid → /run/openvswitch/external-storage.pid; please update the unit file accordingly.
/lib/systemd/system/dhcp-server-adapter.service:9: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/dhcp_server_adapter.pid → /run/openvswitch/dhcp_server_adapter.pid; please update the unit file accordingly.
/lib/systemd/system/classifierd.service:13: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/classifierd.pid → /run/openvswitch/classifierd.pid; please update the unit file accordingly.
/lib/systemd/system/vsfd.service:14: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/vsfd.pid → /run/openvswitch/vsfd.pid; please update the unit file accordingly.
/lib/systemd/system/pmd-ntb.service:16: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/pmd.pid → /run/openvswitch/pmd.pid; please update the unit file accordingly.
/lib/systemd/system/certmgr.service:9: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/certmgr.pid → /run/openvswitch/certmgr.pid; please update the unit file accordingly.
/lib/systemd/system/cdpd.service:12: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/cdpd.pid → /run/openvswitch/cdpd.pid; please update the unit file accordingly.
/lib/systemd/system/captiveportald.service:18: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/captiveportald.pid → /run/openvswitch/captiveportald.pid; please update the unit file accordingly.
/lib/systemd/system/portd.service:12: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/portd.pid → /run/openvswitch/portd.pid; please update the unit file accordingly.
/lib/systemd/system/ndmd.service:14: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/ndmd.pid → /run/openvswitch/ndmd.pid; please update the unit file accordingly.
/lib/systemd/system/log-persistd.service:17: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/log-persistd.pid → /run/openvswitch/log-persistd.pid; please update the unit file accordingly.
/lib/systemd/system/log-mgmtd.service:15: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/log-mgmtd.pid → /run/openvswitch/log-mgmtd.pid; please update the unit file accordingly.
/lib/systemd/system/lacpd.service:14: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/lacpd.pid → /run/openvswitch/lacpd.pid; please update the unit file accordingly.
/lib/systemd/system/blackhat-vrrpd.service:15: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/blackhat-vrrpd.pid → /run/openvswitch/blackhat-vrrpd.pid; please update the unit file accordingly.
/lib/systemd/system/blackhat-udldd.service:14: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/blackhat-udldd.pid → /run/openvswitch/blackhat-udldd.pid; please update the unit file accordingly.
/lib/systemd/system/blackhat-routing.service:34: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/blackhat-routing.pid → /run/openvswitch/blackhat-routing.pid; please update the unit file accordingly.
/lib/systemd/system/blackhat-pvstd.service:17: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/blackhat-pvstd.pid → /run/openvswitch/blackhat-pvstd.pid; please update the unit file accordingly.
/lib/systemd/system/blackhat-mvrpd.service:13: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/blackhat-mvrpd.pid → /run/openvswitch/blackhat-mvrpd.pid; please update the unit file accordingly.
/lib/systemd/system/blackhat-mstpd.service:14: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/blackhat-mstpd.pid → /run/openvswitch/blackhat-mstpd.pid; please update the unit file accordingly.
/lib/systemd/system/blackhat-ipsec.service:20: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/blackhat-ipsecd.pid → /run/openvswitch/blackhat-ipsecd.pid; please update the unit file accordingly.
/lib/systemd/system/fibapp.service:13: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/fibapp.pid → /run/openvswitch/fibapp.pid; please update the unit file accordingly.
/lib/systemd/system/btd.service:15: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/btd.pid → /run/openvswitch/btd.pid; please update the unit file accordingly.
/lib/systemd/system/bfdd.service:14: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/bfdd.pid → /run/openvswitch/bfdd.pid; please update the unit file accordingly.
/lib/systemd/system/aaautilscfgd.service:14: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/aautilscfgd.pid → /run/openvswitch/aautilscfgd.pid; please update the unit file accordingly.
/lib/systemd/system/blackhat-logsyncd.service:16: PIDFile= references a path below legacy directory /var/run/, updating /var/run/openvswitch/blackhat-logsyncd.pid → /run/openvswitch/blackhat-logsyncd.pid; please update the unit file accordingly.
/lib/systemd/system/var-volatile-srv.service:13: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
/lib/systemd/system/var-volatile-spool.service:13: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
/lib/systemd/system/var-volatile-lib.service:13: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
/lib/systemd/system/var-volatile-cache.service:13: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
Starting default target
/lib/systemd/systemergency.service: Deactivated successfully
The issue you’re encountering is due to the use of the usrquota option in the /etc/fstab entry for the tmpfs filesystem. The usrquota option is not applicable to tmpfs, which is an in-memory filesystem and does not support disk quotas. This is causing the mount process to fail with an exit code of 32, leading to a cascade of dependency failures for services that rely on the /var/volatile mount.
Here are the steps you can take to resolve this issue:
  1. Remove the usrquota Option: Edit the /etc/fstab file and remove the usrquota option from the tmpfs entry. The line should look like this:
    tmpfs /var/volatile tmpfs defaults 0 0
  2. Reboot the System: After making the change, reboot the system to see if the issue is resolved.
  3. Check System Logs: If the issue persists, check the system logs for any additional error messages that might provide more insight into the problem.
  4. Manual Mount Test: You can also try manually mounting the tmpfs to /var/volatile using the command line to ensure that it mounts correctly without the usrquota option:
    mount -t tmpfs tmpfs /var/volatile
By removing the unsupported usrquota option, the tmpfs should mount correctly, and the dependent services should start without issues.
Automount overlay for /etc.
Hi @KamalKumarM,
Is your issue solved?
