I have a Colibri VF50 module and I am trying to install Linux 4.4 on it. I have built the UBI file system image from scratch using OpenEmbedded core (oe-core).
$ cd
$ cd oe-core
$ source export
$ bitbake core-image-minimal
$ cd ../deploy/images/colibri-vf
$ cp u-boot-colibri-vf-2016.11-2.7.4+gitr1b121c6.imx /media/USER/SDCARD/u-boot-nand.imx
$ cp zImage--4.4-2.7.4-colibri-vf-20171105074336.bin /media/USER/SDCARD/zImage
$ cp Angstrom-core-image-minimal-glibc-ipk-v2016.12-colibri-vf.rootfs.ubifs /media/USER/SDCARD/ubifs.img
# run setupdate
# run update
The problem with it is that it fails mounting the following file systems:
[ 7.043046] systemd[1]: Failed to mount Temporary Directory.
[FAILED] Failed to mount Temporary Directory.
See 'systemctl status tmp.mount' for details.
[ 7.094547] systemd[1]: Dependency failed for Network Time Synchronization.
[DEPEND] Dependency failed for Network Time Synchronization.
[ 7.211779] systemd[1]: systemd-timesyncd.service: Job systemd-timesyncd.service/start failed with result 'dependency'.
[ 7.435442] systemd[1]: Failed to mount Debug File System.
[FAILED] Failed to mount Debug File System.
See 'systemctl status sys-kernel-debug.mount' for details.
[ 7.504513] systemd[1]: sys-kernel-debug.mount: Unit entered failed state.
[ 7.545521] systemd[1]: sys-fs-fuse-connections.mount: Mount process exited, code=exited status=1
[ 7.615242] systemd[1]: Failed to mount FUSE Control File System.
[FAILED] Failed to mount FUSE Control File System.
See 'systemctl status sys-fs-fuse-connections.mount' for details.
[ 7.694521] systemd[1]: sys-fs-fuse-connections.mount: Unit entered failed state.
[ 7.815691] systemd[1]: Failed to start Remount Root and Kernel File Systems.
[FAILED] Failed to start Remount Root and Kernel File Systems.
See 'systemctl status systemd-remount-fs.service' for details.
[ 7.874361] systemd[1]: systemd-remount-fs.service: Unit entered failed state.
[ 7.906935] systemd[1]: systemd-remount-fs.service: Failed with result 'exit-code'.
[FAILED] Failed to mount /var/volatile.
See 'systemctl status var-volatile.mount' for details.
[DEPEND] Dependency failed for Bind mount volatile /var/lib.
[DEPEND] Dependency failed for Bind mount volatile /var/spool.
[DEPEND] Dependency failed for Bind mount volatile /srv.
[DEPEND] Dependency failed for Bind mount volatile /var/cache.
Mounting FUSE Control File System...
Welcome to emergency mode! After logging in, type "journalctl -xb" to view
system logs, "systemctl reboot" to reboot, "systemctl default" or ^D to
try again to boot into default mode.
Press Enter for maintenance
(or press Control-D to continue):
Does anyone have any ideas?
Bacheh Karaji
