Hello Gustavo,
in the following the desired log outputs. On TEZI 2.05 there is no output from the usb generic driver when plugging the devices. And lsusb looks totally different.
This happens with the USB-OTG port on the Colibri Evaluation board (the one that is connected to the micro-usb jack). Please correct me, but as far as I understand, the other USB ports on the Colibri base port have no function when using the Colibri iMX7, do they?
dmesg TEZI 2.05:
[ 0.293859] Creating 5 MTD partitions on "gpmi-nand":
[ 0.293870] 0x000000000000-0x000000080000 : "mx7-bcb"
[ 0.295152] 0x000000080000-0x000000200000 : "u-boot1"
[ 0.296390] 0x000000200000-0x000000380000 : "u-boot2"
[ 0.297602] 0x000000380000-0x000000400000 : "u-boot-env"
[ 0.298779] 0x000000400000-0x000020000000 : "ubi"
[ 0.301972] gpmi-nand 33002000.gpmi-nand: driver registered.
[ 0.303816] spi_imx 30840000.spi: probed
[ 0.304297] libphy: Fixed MDIO Bus: probed
[ 0.306315] pps pps0: new PPS source ptp0
[ 0.307643] libphy: fec_enet_mii_bus: probed
[ 0.309081] fec 30be0000.ethernet eth0: registered PHC device 0
[ 0.309285] usbcore: registered new interface driver asix
[ 0.309334] usbcore: registered new interface driver ax88179_178a
[ 0.309370] usbcore: registered new interface driver cdc_ether
[ 0.309411] usbcore: registered new interface driver cdc_eem
[ 0.309446] usbcore: registered new interface driver net1080
[ 0.309482] usbcore: registered new interface driver rndis_host
[ 0.309516] usbcore: registered new interface driver cdc_subset
[ 0.309550] usbcore: registered new interface driver zaurus
[ 0.309602] usbcore: registered new interface driver cdc_ncm
[ 0.309607] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.309641] ehci-pci: EHCI PCI platform driver
[ 0.309688] ehci-mxc: Freescale On-Chip EHCI Host driver
[ 0.310451] usbcore: registered new interface driver cdc_acm
[ 0.310456] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 0.310492] usbcore: registered new interface driver cdc_wdm
[ 0.310542] usbcore: registered new interface driver usb-storage
[ 0.310631] usbcore: registered new interface driver usbserial_generic
[ 0.310660] usbserial: USB Serial support registered for generic
[ 0.310694] usbcore: registered new interface driver ftdi_sio
[ 0.310719] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 0.310751] usbcore: registered new interface driver pl2303
[ 0.310775] usbserial: USB Serial support registered for pl2303
[ 0.312365] imx_usb 30b10000.usb: No over current polarity defined
[ 0.319538] input: AD7879 Touchscreen as /devices/platform/soc/30800000.aips-bus/30a20000.i2c/i2c-0/0-002c/input/input0
[ 0.319932] usbcore: registered new interface driver usbtouchscreen
[ 0.322962] rtc-ds1307 3-0068: oscillator failed, set time!
[ 0.323122] rtc-ds1307 3-0068: registered as rtc0
[ 0.324363] snvs_rtc 30370000.snvs:snvs-rtc-lp: registered as rtc1
[ 0.324485] i2c /dev entries driver
[ 0.326233] imx2-wdt 30280000.wdog: timeout 60 sec (nowayout=0)
[ 0.326650] CPUidle arm: CPU 0 failed to init idle CPU ops
[ 0.332459] sdhci: Secure Digital Host Controller Interface driver
[ 0.332463] sdhci: Copyright(c) Pierre Ossman
[ 0.332467] Synopsys Designware Multimedia Card Interface Driver
[ 0.332798] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.333683] sdhci-esdhc-imx 30b40000.usdhc: Got CD GPIO
[ 0.367455] mmc0: SDHCI controller on 30b40000.usdhc [30b40000.usdhc] using ADMA
[ 0.370028] caam 30900000.caam: Entropy delay = 3200
[ 0.370060] caam 30900000.caam: Instantiated RNG4 SH0
[ 0.429475] caam 30900000.caam: Instantiated RNG4 SH1
[ 0.429486] caam 30900000.caam: device ID = 0x0a16030000000000 (Era 8)
[ 0.429494] caam 30900000.caam: job rings = 3, qi = 0
[ 0.442717] caam algorithms registered in /proc/crypto
[ 0.445831] caam 30900000.caam: caam pkc algorithms registered in /proc/crypto
[ 0.447987] caam_jr 30901000.jr0: registering rng-caam
[ 0.449209] usbcore: registered new interface driver usbhid
[ 0.449214] usbhid: USB HID core driver
[ 0.451054] NET: Registered protocol family 10
[ 0.452038] Segment Routing with IPv6
[ 0.452141] mip6: Mobile IPv6
[ 0.452146] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 0.453325] NET: Registered protocol family 17
[ 0.453348] NET: Registered protocol family 15
[ 0.453849] imx-cpufreq-dt: probe of imx-cpufreq-dt failed with error -2
[ 0.453885] Registering SWP/SWPB emulation handler
[ 0.457993] registered taskstats version 1
[ 0.457999] Loading compiled-in X.509 certificates
[ 0.493620] vdd1p0d: supplied by DCDC3
[ 0.495616] input: gpio-keys as /devices/platform/gpio-keys/input/input1
[ 0.497320] rtc-ds1307 3-0068: hctosys: unable to read the hardware clock
[ 0.504401] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 0.506746] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 0.508172] RAMDISK: squashfs filesystem found at block 0
[ 0.508189] RAMDISK: Loading 23379KiB [1 disk] into ram disk... /
[ 0.514801] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 0.514812] cfg80211: failed to load regulatory.db
[ 0.515032] /
[ 0.620580] /
[ 0.725781] done.
[ 0.976260] VFS: Mounted root (squashfs filesystem) readonly on device 1:0.
[ 0.977047] devtmpfs: mounted
[ 0.978489] Freeing unused kernel memory: 1024K
[ 0.994740] Run /sbin/init as init process
[ 1.266287] udevd[317]: starting version 3.2.7
[ 1.268453] random: udevd: uninitialized urandom read (16 bytes read)
[ 1.268688] random: udevd: uninitialized urandom read (16 bytes read)
[ 1.268783] random: udevd: uninitialized urandom read (16 bytes read)
[ 1.318162] udevd[318]: starting eudev-3.2.7
[ 1.715569] Micrel KSZ8041 30be0000.ethernet-1:00: attached PHY driver [Micrel KSZ8041] (mii_bus:phy_addr=30be0000.ethernet-1:00, irq=POLL)
[ 3.025267] urandom_read: 4 callbacks suppressed
[ 3.025275] random: weston-keyboard: uninitialized urandom read (4 bytes read)
[ 3.029444] random: weston-keyboard: uninitialized urandom read (4 bytes read)
[ 3.030770] random: weston-keyboard: uninitialized urandom read (4 bytes read)
[ 3.772918] fec 30be0000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[ 3.772954] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 11.624641] random: crng init done
[ 11.823910] using random self ethernet address
[ 11.823921] using random host ethernet address
[ 11.825589] usb0: HOST MAC 00:14:2d:ff:ff:fe
[ 11.825664] usb0: MAC 00:14:2d:ff:ff:ff
[ 30.564632] 5V: disabling
[ 30.564643] VCC_USB[1-4]: disabling
dmesg TEZI 1.8:
dmesg
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.1.44-1.8.0+gf3637519a6aa (yocto@0434a2e15cf8) (gcc version 6.2.1 20161016 (Linaro GCC 6.2-2016.11) ) #1 SMP Fri Oct 19 13:28:43 UTC 2018
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: Toradex Colibri iMX7S on Colibri Evaluation Board V3
[ 0.000000] Reserved memory: created CMA memory pool at 0x84000000, size 128 MiB
[ 0.000000] Reserved memory: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 65536
[ 0.000000] free_area_init_node: node 0, pgdat 8094e1c0, node_mem_map 8fdba000
[ 0.000000] Normal zone: 512 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 65536 pages, LIFO batch:15
[ 0.000000] PERCPU: Embedded 12 pages/cpu @8fd8e000 s16844 r8192 d24116 u49152
[ 0.000000] pcpu-alloc: s16844 r8192 d24116 u49152 alloc=12*4096
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 65024
[ 0.000000] Kernel command line: console=ttymxc0,115200 quiet rootfstype=squashfs root=/dev/ram autoinstall
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Memory: 102860K/262144K available (6660K kernel code, 299K rwdata, 2216K rodata, 320K init, 380K bss, 28212K reserved, 131072K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0x90800000 - 0xff000000 (1768 MB)
[ 0.000000] lowmem : 0x80000000 - 0x90000000 ( 256 MB)
[ 0.000000] modules : 0x7f000000 - 0x80000000 ( 16 MB)
[ 0.000000] .text : 0x80008000 - 0x808b34e8 (8878 kB)
[ 0.000000] .init : 0x808b4000 - 0x80904000 ( 320 kB)
[ 0.000000] .data : 0x80904000 - 0x8094ee60 ( 300 kB)
[ 0.000000] .bss : 0x80951000 - 0x809b028c ( 381 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] Architected cp15 timer(s) running at 8.00MHz (phys).
[ 0.000000] clocksource arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 440795202120 ns
[ 0.000006] sched_clock: 56 bits at 8MHz, resolution 125ns, wraps every 2199023255500ns
[ 0.000018] Switching to timer-based delay loop, resolution 125ns
[ 0.000470] mxc_clocksource_init 3000000
[ 0.000484] Ignoring duplicate/late registration of read_current_timer delay
[ 0.000500] clocksource mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 637086815595 ns
[ 0.001709] Console: colour dummy device 80x30
[ 0.001726] Calibrating delay loop (skipped), value calculated using timer frequency.. 16.00 BogoMIPS (lpj=80000)
[ 0.001740] pid_max: default: 32768 minimum: 301
[ 0.001841] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.001852] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.002453] Initializing cgroup subsys freezer
[ 0.002472] Initializing cgroup subsys debug
[ 0.002510] CPU: Testing write buffer coherency: ok
[ 0.002790] Setting up static identity map for 0x80008280 - 0x800082d8
[ 0.003948] Brought up 1 CPUs
[ 0.003964] SMP: Total of 1 processors activated (16.00 BogoMIPS).
[ 0.003971] CPU: All CPU(s) started in SVC mode.
[ 0.004456] devtmpfs: initialized
[ 0.017463] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.017827] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.017856] futex hash table entries: 256 (order: 2, 16384 bytes)
[ 0.023466] pinctrl core: initialized pinctrl subsystem
[ 0.023992] regulator-dummy: no parameters
[ 0.024680] NET: Registered protocol family 16
[ 0.030434] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.031329] cpuidle: using governor ladder
[ 0.031346] cpuidle: using governor menu
[ 0.040685] vdd1p0d: 800 <--> 1200 mV at 1000 mV
[ 0.041118] vdd1p2: 1100 <--> 1300 mV
[ 0.044078] DDR type is DDR3!
[ 0.050247] imx7d_enet_clk_sel: failed to get enet_out clock, assuming ext. clock source
[ 0.050294] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.050303] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.050609] imx7d-pinctrl 30270000.lpsr-gpr: initialized IMX pinctrl driver
[ 0.050795] imx7d-pinctrl 302c0000.iomuxc-lpsr: initialized IMX pinctrl driver
[ 0.052070] imx7d-pinctrl 30330000.iomuxc: initialized IMX pinctrl driver
[ 0.052867] imx-gpcv2 303a0000.gpc: Looking up mipi-phy-supply from device tree
[ 0.052942] imx-gpcv2 303a0000.gpc: Looking up pcie-phy-supply from device tree
[ 0.052992] imx-gpcv2 303a0000.gpc: Looking up vcc-supply from device tree
[ 0.053555] MU is ready for cross core communication!
[ 0.063281] mxs-dma 33000000.dma-apbh: initialized
[ 0.063928] +V3.3: 3300 mV
[ 0.063974] reg-fixed-voltage regulator-module-3v3: +V3.3 supplying 3300000uV
[ 0.064177] +V3.3_AVDD_AUDIO: 3300 mV
[ 0.064226] reg-fixed-voltage regulator-module-3v3-avdd: +V3.3_AVDD_AUDIO supplying 3300000uV
[ 0.064429] 3.3V: 3300 mV
[ 0.064465] reg-fixed-voltage regulator-3v3: 3.3V supplying 3300000uV
[ 0.064651] 5V: 5000 mV
[ 0.064686] reg-fixed-voltage regulator-5v0: 5V supplying 5000000uV
[ 0.064982] VCC_USB[1-4]: 5000 mV
[ 0.065040] reg-fixed-voltage regulator-usbh-vbus: Looking up vin-supply from device tree
[ 0.065078] VCC_USB[1-4]: supplied by 5V
[ 0.065123] reg-fixed-voltage regulator-usbh-vbus: VCC_USB[1-4] supplying 5000000uV
[ 0.065524] SCSI subsystem initialized
[ 0.065813] usbcore: registered new interface driver usbfs
[ 0.065890] usbcore: registered new interface driver hub
[ 0.066010] usbcore: registered new device driver usb
[ 0.066219] usb_phy_generic 30800000.aips-bus:usbphy_nop1: Looking up vcc-supply from device tree
[ 0.066234] usb_phy_generic 30800000.aips-bus:usbphy_nop1: Looking up vcc-supply property in node /soc/aips-bus@30800000/usbphy_nop1 failed
[ 0.066247] 30800000.aips-bus:usbphy_nop1 supply vcc not found, using dummy regulator
[ 0.066382] usb_phy_generic 30800000.aips-bus:usbphy_nop3: Looking up vcc-supply from device tree
[ 0.067376] i2c i2c-0: IMX I2C adapter registered
[ 0.067391] i2c i2c-0: can't use DMA
[ 0.067878] i2c i2c-3: IMX I2C adapter registered
[ 0.067894] i2c i2c-3: can't use DMA
[ 0.067995] Linux video capture interface: v2.00
[ 0.068055] pps_core: LinuxPPS API ver. 1 registered
[ 0.068064] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti
[ 0.068095] PTP clock support registered
[ 0.068608] Advanced Linux Sound Architecture Driver Initialized.
[ 0.069869] Switched to clocksource arch_sys_counter
[ 0.080362] NET: Registered protocol family 2
[ 0.081119] TCP established hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.081160] TCP bind hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.081203] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.081258] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.081290] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.081461] NET: Registered protocol family 1
[ 0.081712] RPC: Registered named UNIX socket transport module.
[ 0.081722] RPC: Registered udp transport module.
[ 0.081728] RPC: Registered tcp transport module.
[ 0.081735] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.081975] Trying to unpack rootfs image as initramfs...
[ 0.082205] rootfs image is not initramfs (junk in compressed archive); looks like an initrd
[ 0.131398] Freeing initrd memory: 15560K
[ 0.132459] imx rpmsg driver is registered.
[ 0.133429] Bus freq driver module loaded
[ 0.141604] VFS: Disk quotas dquot_6.6.0
[ 0.141801] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.142983] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.143814] NFS: Registering the id_resolver key type
[ 0.143870] Key type id_resolver registered
[ 0.143878] Key type id_legacy registered
[ 0.143901] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.144471] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.145010] fuse init (API version 7.23)
[ 0.149558] io scheduler noop registered
[ 0.149578] io scheduler deadline registered
[ 0.149625] io scheduler cfq registered (default)
[ 0.150966] pwm-backlight backlight: Looking up power-supply from device tree
[ 0.150985] pwm-backlight backlight: Looking up power-supply property in node /backlight failed
[ 0.150999] backlight supply power not found, using dummy regulator
[ 0.152950] mxsfb 30730000.lcdif: Looking up lcd-supply from device tree
[ 0.152969] mxsfb 30730000.lcdif: Looking up lcd-supply property in node /soc/aips-bus@30400000/lcdif@30730000 failed
[ 0.152979] 30730000.lcdif supply lcd not found, using dummy regulator
[ 0.219055] mxsfb 30730000.lcdif: failed to find mxc display driver
[ 0.228004] Console: switching to colour frame buffer device 80x30
[ 0.243932] mxsfb 30730000.lcdif: initialized
[ 0.245065] imx-sdma 30bd0000.sdma: no event needs to be remapped
[ 0.245201] imx-sdma 30bd0000.sdma: loaded firmware 4.2
[ 0.248382] imx-sdma 30bd0000.sdma: initialized
[ 0.249513] 30860000.serial: ttymxc0 at MMIO 0x30860000 (irq = 277, base_baud = 1500000) is a IMX
[ 0.250140] console [ttymxc0] enabled
[ 0.250835] 30890000.serial: ttymxc1 at MMIO 0x30890000 (irq = 278, base_baud = 1500000) is a IMX
[ 0.251442] 30880000.serial: ttymxc2 at MMIO 0x30880000 (irq = 279, base_baud = 5000000) is a IMX
[ 0.262629] brd: module loaded
[ 0.267708] loop: module loaded
[ 0.269505] DCDC1: 1000 <--> 1100 mV at 1000 mV
[ 0.270838] DCDC2: 975 <--> 1100 mV at 1100 mV
[ 0.272140] DCDC3: 1800 mV
[ 0.273460] DCDC4: 1350 mV
[ 0.274766] LDO1: 1800 <--> 3300 mV at 3300 mV
[ 0.275549] LDO2: 1800 <--> 3300 mV at 3300 mV
[ 0.276328] LDO3: 3300 mV
[ 0.277090] LDO4: 1800 mV
[ 0.277870] LDO5: 3300 mV
[ 0.278624] LDORTC1: at 3000 mV
[ 0.279375] LDORTC2: at 900 mV
[ 0.286654] nand: device found, Manufacturer ID: 0xc2, Chip ID: 0xdc
[ 0.286669] nand: Macronix MX30LF4G28AC
[ 0.286680] nand: 512 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 112
[ 0.287019] gpmi-nand 33002000.gpmi-nand: mode:5 ,failed in set feature.
[ 0.294093] Bad block table found at page 262080, version 0x01
[ 0.294500] Bad block table found at page 262016, version 0x01
[ 0.294839] nand_read_bbt: bad block at 0x000001680000
[ 0.294850] nand_read_bbt: bad block at 0x000002c00000
[ 0.294885] nand_read_bbt: bad block at 0x00000f640000
[ 0.294904] nand_read_bbt: bad block at 0x000014e40000
[ 0.295214] 5 ofpart partitions found on MTD device gpmi-nand
[ 0.295650] Creating 5 MTD partitions on "gpmi-nand":
[ 0.295666] 0x000000000000-0x000000080000 : "mx7-bcb"
[ 0.296054] 0x000000080000-0x000000200000 : "u-boot1"
[ 0.296436] 0x000000200000-0x000000380000 : "u-boot2"
[ 0.296812] 0x000000380000-0x000000400000 : "u-boot-env"
[ 0.297189] 0x000000400000-0x000020000000 : "ubi"
[ 0.298368] gpmi-nand 33002000.gpmi-nand: driver registered.
[ 0.300295] spi_imx 30840000.ecspi: probed
[ 0.303573] fec 30be0000.ethernet: Looking up phy-supply from device tree
[ 0.304109] pps pps0: new PPS source ptp0
[ 0.305375] fec 30be0000.ethernet (unnamed net_device) (uninitialized): Invalid MAC address: 00:00:00:00:00:00
[ 0.315481] fec 30be0000.ethernet (unnamed net_device) (uninitialized): Using random MAC address: 8a:47:15:b3:e1:df
[ 0.316237] libphy: fec_enet_mii_bus: probed
[ 0.317842] fec 30be0000.ethernet eth0: registered PHC device 0
[ 0.318041] usbcore: registered new interface driver asix
[ 0.318127] usbcore: registered new interface driver ax88179_178a
[ 0.318191] usbcore: registered new interface driver cdc_ether
[ 0.318253] usbcore: registered new interface driver cdc_eem
[ 0.318315] usbcore: registered new interface driver net1080
[ 0.318377] usbcore: registered new interface driver rndis_host
[ 0.318439] usbcore: registered new interface driver cdc_subset
[ 0.318508] usbcore: registered new interface driver zaurus
[ 0.318616] usbcore: registered new interface driver cdc_ncm
[ 0.318631] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.318644] ehci-mxc: Freescale On-Chip EHCI Host driver
[ 0.318863] usbcore: registered new interface driver usb-storage
[ 0.319013] usbcore: registered new interface driver usbserial
[ 0.319063] usbcore: registered new interface driver usbserial_generic
[ 0.319113] usbserial: USB Serial support registered for generic
[ 0.319170] usbcore: registered new interface driver ftdi_sio
[ 0.319218] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 0.319272] usbcore: registered new interface driver pl2303
[ 0.319318] usbserial: USB Serial support registered for pl2303
[ 0.320535] usbmisc_imx 30b10200.usbmisc: Looking up vbus-wakeup-supply from device tree
[ 0.320552] usbmisc_imx 30b10200.usbmisc: Looking up vbus-wakeup-supply property in node /soc/aips-bus@30800000/usbmisc@30b10200 failed
[ 0.320574] 30b10200.usbmisc supply vbus-wakeup not found, using dummy regulator
[ 0.320701] usbmisc_imx 30b30200.usbmisc: Looking up vbus-wakeup-supply from device tree
[ 0.320716] usbmisc_imx 30b30200.usbmisc: Looking up vbus-wakeup-supply property in node /soc/aips-bus@30800000/usbmisc@30b30200 failed
[ 0.320726] 30b30200.usbmisc supply vbus-wakeup not found, using dummy regulator
[ 0.321470] imx_usb 30b10000.usb: Can't register ci_hdrc platform device, err=-517
[ 0.329560] mousedev: PS/2 mouse device common for all mice
[ 0.332237] input: AD7879 Touchscreen as /devices/platform/soc/30800000.aips-bus/30a20000.i2c/i2c-0/0-002c/input/input0
[ 0.335436] rtc-ds1307 3-0068: rtc core: registered m41t0 as rtc0
[ 0.336081] snvs_rtc 30370000.snvs:snvs-rtc-lp: rtc core: registered 30370000.snvs:snvs- as rtc1
[ 0.336209] i2c /dev entries driver
[ 0.338815] imx2-wdt 30280000.wdog: timeout 60 sec (nowayout=0)
[ 0.339119] sdhci: Secure Digital Host Controller Interface driver
[ 0.339127] sdhci: Copyright(c) Pierre Ossman
[ 0.339140] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.340128] /soc/aips-bus@30800000/usdhc@30b40000: voltage-ranges unspecified
[ 0.340166] sdhci-esdhc-imx 30b40000.usdhc: Got CD GPIO
[ 0.341712] sdhci-esdhc-imx 30b40000.usdhc: Looking up vmmc-supply from device tree
[ 0.341846] sdhci-esdhc-imx 30b40000.usdhc: Looking up vqmmc-supply from device tree
[ 0.341863] sdhci-esdhc-imx 30b40000.usdhc: Looking up vqmmc-supply property in node /soc/aips-bus@30800000/usdhc@30b40000 failed
[ 0.341887] sdhci-esdhc-imx 30b40000.usdhc: No vqmmc regulator found
[ 0.380034] mmc0: SDHCI controller on 30b40000.usdhc [30b40000.usdhc] using ADMA
[ 0.384385] caam 30900000.caam: Entropy delay = 3200
[ 0.384417] caam 30900000.caam: Instantiated RNG4 SH0
[ 0.443834] caam 30900000.caam: Instantiated RNG4 SH1
[ 0.443849] caam 30900000.caam: device ID = 0x0a16030000000000 (Era -524)
[ 0.443860] caam 30900000.caam: job rings = 3, qi = 0
[ 0.452398] caam algorithms registered in /proc/crypto
[ 0.455947] caam_jr 30901000.jr0: registering rng-caam
[ 0.456696] hidraw: raw HID events driver (C) Jiri Kosina
[ 0.456950] usbcore: registered new interface driver usbhid
[ 0.456958] usbhid: USB HID core driver
[ 0.458113] imx7d_adc 30610000.adc: Looking up vref-supply from device tree
[ 0.458980] imx7d_adc 30620000.adc: Looking up vref-supply from device tree
[ 0.461683] coresight-tmc 30086000.etr: TMC initialized
[ 0.462015] coresight-tmc 30084000.etf: TMC initialized
[ 0.462249] coresight-tpiu 30087000.tpiu: TPIU initialized
[ 0.462555] coresight-funnel 30083000.funnel: FUNNEL initialized
[ 0.462758] coresight-funnel 30041000.funnel: FUNNEL initialized
[ 0.463036] coresight-replicator replicator: REPLICATOR initialized
[ 0.463606] coresight-etm3x 3007c000.etm: ETM initialized
[ 0.466628] sgtl5000 0-000a: Looking up VDDD-supply from device tree
[ 0.466748] sgtl5000 0-000a: Looking up VDDA-supply from device tree
[ 0.466814] sgtl5000 0-000a: Looking up VDDIO-supply from device tree
[ 0.466893] sgtl5000 0-000a: Looking up VDDD-supply from device tree
[ 0.468403] sgtl5000 0-000a: sgtl5000 revision 0x11
[ 0.504674] imx-sgtl5000 sound: sgtl5000 <-> 308a0000.sai mapping ok
[ 0.505847] Netfilter messages via NETLINK v0.30.
[ 0.505882] nfnl_acct: registering with nfnetlink.
[ 0.505903] nf_conntrack version 0.5.0 (3898 buckets, 15592 max)
[ 0.506362] nf_tables: (c) 2007-2009 Patrick McHardy
[ 0.506799] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 0.507568] NET: Registered protocol family 10
[ 0.508662] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 0.508689] sit: IPv6 over IPv4 tunneling driver
[ 0.509432] NET: Registered protocol family 17
[ 0.509501] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 0.509538] Bridge firewalling registered
[ 0.509625] 8021q: 802.1Q VLAN Support v1.8
[ 0.509689] Key type dns_resolver registered
[ 0.510214] cpu cpu0: Looking up arm-supply from device tree
[ 0.516826] Registering SWP/SWPB emulation handler
[ 0.517565] registered taskstats version 1
[ 0.521481] imx_usb 30b10000.usb: Looking up vbus-supply from device tree
[ 0.527322] input: gpio-keys as /devices/platform/gpio-keys/input/input1
[ 0.529187] rtc-ds1307 3-0068: setting system clock to 2020-09-14 10:03:19 UTC (1600077799)
[ 0.546269] 5V: disabling
[ 0.546293] VCC_USB[1-4]: disabling
[ 0.567565] ALSA device list:
[ 0.567577] #0: imx7-colibri-sgtl5000
[ 0.567972] RAMDISK: squashfs filesystem found at block 0
[ 0.567995] RAMDISK: Loading 15555KiB [1 disk] into ram disk... done.
[ 0.828740] VFS: Mounted root (squashfs filesystem) readonly on device 1:0.
[ 0.829337] devtmpfs: mounted
[ 0.829762] Freeing unused kernel memory: 320K
[ 1.090203] fec 30be0000.ethernet eth0: Freescale FEC PHY driver [Micrel KSZ8041] (mii_bus:phy_addr=30be0000.etherne:00, irq=-1)
[ 1.090352] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 1.872195] using random self ethernet address
[ 1.872217] using random host ethernet address
[ 1.873944] usb0: HOST MAC 00:14:2d:ff:ff:fe
[ 1.874499] usb0: MAC 00:14:2d:ff:ff:ff
[ 1.874736] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 2.109531] configfs-gadget gadget: high-speed config #1: RNDIS
[ 2.109697] IPv6: ADDRCONF(NETDEV_CHANGE): usb0: link becomes ready
[ 4.090529] fec 30be0000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[ 4.090567] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 8.924933] random: tezi urandom read with 25 bits of entropy available
[ 71.521933] random: nonblocking pool is initialized
[ 95.390257] ci_hdrc ci_hdrc.0: EHCI Host Controller
[ 95.390294] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
[ 95.404531] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[ 95.405580] hub 1-0:1.0: USB hub found
[ 95.405633] hub 1-0:1.0: 1 port detected
[ 95.416370] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 251.128382] usb 1-1: new full-speed USB device number 2 using ci_hdrc
[ 251.296516] input: Logitech USB Receiver as /devices/platform/soc/30800000.aips-bus/30b10000.usb/ci_hdrc.0/usb1/1-1/1-1:1.0/0003:046D:C52B.0001/input/input2
[ 251.349117] hid-generic 0003:046D:C52B.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-ci_hdrc.0-1/input0
[ 251.357493] input: Logitech USB Receiver as /devices/platform/soc/30800000.aips-bus/30b10000.usb/ci_hdrc.0/usb1/1-1/1-1:1.1/0003:046D:C52B.0002/input/input3
[ 251.409406] hid-generic 0003:046D:C52B.0002: input,hiddev0,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-ci_hdrc.0-1/input1
[ 251.419849] hid-generic 0003:046D:C52B.0003: hiddev0,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-ci_hdrc.0-1/input2
lsusb TEZI 2.05
/ # lsusb
unable to initialize libusb: -99
lsusb TEZI 1.8
/ # lsusb
Bus 001 Device 002: ID 046d:c52b
Bus 001 Device 001: ID 1d6b:0002
