Thank you for reaching out with your question. The issue you’re encountering, where GDB exits unexpectedly with code 255 during offline debugging, can be due to several factors. Here are some steps to help you resolve this issue:
GDB Configuration: Ensure that your GDB settings are correctly configured for offline use. Double-check that all paths and settings in your debugging configuration are accurate and do not rely on online resources.
Dependencies: Offline environments can sometimes lack necessary libraries or dependencies that are automatically available online. Verify that all required libraries and tools are included in your container image. You can do this by reviewing the Dockerfile used to build the image and ensuring all dependencies are explicitly listed and installed.
Container Image Compatibility: Make sure the container image you are using is fully compatible with your offline setup. Some images may have dependencies or configurations that assume an online environment. Test the image in an online environment to confirm it works as expected, then replicate the necessary conditions offline.
Testing in Online Environment: If possible, test your debugging setup in a fully online environment to determine if the issue is specific to the offline configuration. This can help isolate the problem to either the environment or the setup itself.
By systematically checking these areas, you should be able to identify and resolve the cause of the GDB exit error. If the problem persists, consider simplifying your setup to the most basic configuration that reproduces the issue, which can help in pinpointing the exact cause.
I hope this helps you resolve the issue. If you have any further questions, feel free to ask.
