Physmap-flash 8000000.sram: map_probe failed
お世話になっております。
下記のfailed が表示されていますが、ハード的に問題ないでしょうか?
physmap-flash 8000000.sram: map_probe failed
physmap-flash a000000.sram: map_probe failed
Colibri iMX6DL 512MB V1.1B
Colibri Evaluation V3.2
OS:Torizon OS Easy Pairing (UPSTREAM) 6.8.0+build.22.modified.contaauner(2024-10-12)
このFailedの表示は1つの個体だけでなく、手持ちのColibri iMX6DL 512MB V1.1B 及びColibri iMX6DL 512MB V1.1A で表示されます。
SoMの問題ではなく、Torizon OS Easy Pairing (UPSTREAM)の問題ではないでしょうか?
デバイスツリーの設定に問題があるのではないかとRMAチームの方から言われましたが、そもそもデバイスツリーは操作せず、提供されたOSをインストールしています。
ハード的に 8000000とa000000 に問題があるのか、ソフト的に問題があるのか お教え願います。
Thank you for reaching out with your concern. The ‘map_probe failed’ error message you’re encountering on your Colibri iMX6DL modules typically suggests an issue with the memory mapping configuration, which could be related to software settings rather than hardware.
Possible Causes and Solutions:
  1. Device Tree Configuration:
    • This error might stem from incorrect or missing configurations in the device tree. Since you mentioned not modifying the device tree, it would be prudent to verify that the default configuration provided with Torizon OS aligns with your hardware setup. Sometimes, default settings may not perfectly match all hardware variations.
  2. Torizon OS Version:
    • Ensure that the version of Torizon OS you are using is fully compatible with your Colibri iMX6DL modules. Occasionally, updates or patches in newer software versions address such issues.
  3. Known Software Issues:
    • Check for any known issues or errata related to the Colibri iMX6DL modules and Torizon OS. There might be documented cases similar to yours with recommended solutions.
  4. Testing with Different Software Configurations:
    • If feasible, try testing with a different version of the operating system or a different configuration to determine if the issue persists. This can help identify if the problem is software-related.
If the error does not impact the functionality of your application, it might be safe to ignore it, as some non-critical errors do not affect system performance. However, if it does affect functionality, further investigation into the device tree and software configuration is advisable.
I hope this helps clarify the situation. Please feel free to reach out if you have further questions.
Torizon VS integration error.
Easyinstallerでinstallしています。
Colibri-iMX6_ToradexEasyInstaller_5.7.6+build.21
これは、インストール成功しますが、相談している内容の結果になります。
以下はインストールしようとしてもエラーになり、途中で止まります。
Colibri-iMX6_ToradexEasyInstaller_6.7.0+build.7
Colibri-iMX6_ToradexEasyInstaller_6.8.1+build.9
この個体は数年前にリリースされているものです。
なぜ、このエラーが表示されるのでしょうか
