Good day!
I try to start system from NFS server
Here log of start system.
Please tell somebody why it is not working.
Colibri iMX6 # run bootcmd_dhcp
BOOTP broadcast 1
DHCP client bound to address 192.168.0.2 (16 ms)
Using ethernet@2188000 device
TFTP from server 192.168.0.1; our IP address is 192.168.0.2
Filename 'boot.scr'.
Load address: 0x18280000
Loading: ##
1.4 MiB/s
done
Bytes transferred = 5962 (174a hex)
## Executing script at 18280000
Loading DeviceTree: imx6dl-colibri-eval-v3.dtb
BOOTP broadcast 1
DHCP client bound to address 192.168.0.2 (3 ms)
Filename 'imx6dl-colibri-eval-v3.dtb'.
Load address: 0x18200000
Loading: #############
3 MiB/s
done
Bytes transferred = 65459 (ffb3 hex)
BOOTP broadcast 1
Filename 'overlays.txt'.
Load address: 0x14200000
Loading: #
24.4 KiB/s
done
Bytes transferred = 51 (33 hex)
Applying Overlay: colibri-imx6_vga-640x480_overlay.dtbo
BOOTP broadcast 1
DHCP client bound to address 192.168.0.2 (2 ms)
Filename 'overlays/colibri-imx6_vga-640x480_overlay.dtbo'.
Loading: #
443.4 KiB/s
done
Bytes transferred = 1364 (554 hex)
BOOTP broadcast 1
Filename 'zImage'.
Loading: #################################################################
3.4 MiB/s
done
Bytes transferred = 10777736 (a47488 hex)
Bootargs: enable_wait_mode=off galcore.contiguousSize=50331648 root=/dev/nfs ip=dhcp fec_mac=00:14:2d:a4:8f:d2 consoleblank=0 no_console_suspend=1 cM
Kernel image @ 0x14200000 [ 0x000000 - 0xa47488 ]
## Flattened Device Tree blob at 18200000
Booting using the fdt blob at 0x18200000
Loading Device Tree to 1ffcc000, end 1fffffff ... OK
Starting kernel ...
[ 0.000000] Linux version 6.0.17-6.1.0+git.71e1e02850ab (oe-user@oe-host) (arm-tdx-linux-gnueabi-gcc (GCC) 11.3.0, GNU ld (GNU Binutils) 2.38.2023
[ 0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Toradex Colibri iMX6DL/S on Colibri Evaluation Board V3
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] cma: Reserved 192 MiB at 0x24000000
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x0000000010000000-0x000000002fffffff]
[ 0.000000] HighMem empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000010000000-0x000000002fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000010000000-0x000000002fffffff]
[ 0.000000] percpu: Embedded 17 pages/cpu s38068 r8192 d23372 u69632
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 130048
[ 0.000000] Kernel command line: enable_wait_mode=off galcore.contiguousSize=50331648 root=/dev/nfs ip=dhcp fec_mac=00:14:2d:a4:8f:d2 consoleblanM
[ 0.000000] Unknown kernel command line parameters "enable_wait_mode=off fec_mac=00:14:2d:a4:8f:d2 fbmem=8M", will be passed to user space.
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 294336K/524288K available (13312K kernel code, 1935K rwdata, 4704K rodata, 1024K init, 6670K bss, 33344K reserved, 196608K cm)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] trace event string verifier disabled
[ 0.000000] Running RCU self tests
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU lockdep checking is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] L2C-310 erratum 769419 enabled
[ 0.000000] L2C-310 enabling early BRESP for Cortex-A9
[ 0.000000] L2C-310 full line of zeros enabled for Cortex-A9
[ 0.000000] L2C-310 ID prefetch enabled, offset 16 lines
[ 0.000000] L2C-310 dynamic clock gating enabled, standby mode enabled
[ 0.000000] L2C-310 cache controller enabled, 16 ways, 512 kB
[ 0.000000] L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76450001
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] Switching to timer-based delay loop, resolution 333ns
[ 0.000001] sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 715827882841ns
[ 0.000024] clocksource: mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 637086815595 ns
[ 0.002163] Console: colour dummy device 80x30
[ 0.006201] printk: console [tty1] enabled
[ 0.006277] Lock dependency validator: Copyright (c) 2006 Red Hat, Inc., Ingo Molnar
[ 0.006393] ... MAX_LOCKDEP_SUBCLASSES: 8
[ 0.006460] ... MAX_LOCK_DEPTH: 48
[ 0.006529] ... MAX_LOCKDEP_KEYS: 8192
[ 0.006600] ... CLASSHASH_SIZE: 4096
[ 0.006671] ... MAX_LOCKDEP_ENTRIES: 32768
[ 0.006744] ... MAX_LOCKDEP_CHAINS: 65536
[ 0.006815] ... CHAINHASH_SIZE: 32768
[ 0.006886] memory used by lock dependency info: 4061 kB
[ 0.006970] memory used for stack traces: 2112 kB
[ 0.007045] per task-struct memory footprint: 1536 bytes
[ 0.007219] Calibrating delay loop (skipped), value calculated using timer frequency.. 6.00 BogoMIPS (lpj=30000)
[ 0.007385] pid_max: default: 32768 minimum: 301
[ 0.008106] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.008243] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.012340] CPU: Testing write buffer coherency: ok
[ 0.012575] CPU0: Spectre v2: using BPIALL workaround
[ 0.013769] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.017850] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.018172] cblist_init_generic: Setting shift to 1 and lim to 1.
[ 0.018752] Running RCU-tasks wait API self tests
[ 0.019091] Setting up static identity map for 0x10100000 - 0x10100078
[ 0.019918] Callback from call_rcu_tasks_trace() invoked.
[ 0.020372] rcu: Hierarchical SRCU implementation.
[ 0.020500] rcu: Max phase no-delay instances is 1000.
[ 0.025469] smp: Bringing up secondary CPUs ...
[ 0.029349] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.029374] CPU1: Spectre v2: using BPIALL workaround
[ 0.030872] smp: Brought up 1 node, 2 CPUs
[ 0.031003] SMP: Total of 2 processors activated (12.00 BogoMIPS).
[ 0.031158] CPU: All CPU(s) started in SVC mode.
[ 0.034266] devtmpfs: initialized
[ 0.088456] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[ 0.091688] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.091990] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.103221] pinctrl core: initialized pinctrl subsystem
[ 0.110157] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.141027] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.147023] thermal_sys: Registered thermal governor 'step_wise'
[ 0.147613] cpuidle: using governor menu
[ 0.148072] CPU identified as i.MX6DL, silicon rev 1.4
[ 0.250236] platform 2400000.ipu: Fixing up cyclic dependency with 20e0000.iomuxc-gpr:ipu1_csi1_mux
[ 0.250957] platform 2400000.ipu: Fixing up cyclic dependency with 20e0000.iomuxc-gpr:ipu1_csi0_mux
[ 0.260481] platform disp0: Fixing up cyclic dependency with 2400000.ipu
[ 0.262809] platform panel-dpi: Fixing up cyclic dependency with disp0
[ 0.271491] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
[ 0.271791] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.277676] imx6dl-pinctrl 20e0000.pinctrl: initialized IMX pinctrl driver
[ 0.324826] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[ 0.450426] SCSI subsystem initialized
[ 0.452022] usbcore: registered new interface driver usbfs
[ 0.452431] usbcore: registered new interface driver hub
[ 0.452733] usbcore: registered new device driver usb
[ 0.453288] usb_phy_generic usbphynop1: supply vcc not found, using dummy regulator
[ 0.454373] usb_phy_generic usbphynop1: dummy supplies not allowed for exclusive requests
[ 0.455119] usb_phy_generic usbphynop2: supply vcc not found, using dummy regulator
[ 0.455970] usb_phy_generic usbphynop2: dummy supplies not allowed for exclusive requests
[ 0.480767] stmpe-i2c 0-0041: stmpe811 detected, chip id: 0x811
[ 0.633107] i2c i2c-0: IMX I2C adapter registered
[ 0.638050] i2c i2c-1: IMX I2C adapter registered
[ 0.638728] mc: Linux media interface: v0.10
[ 0.639113] videodev: Linux video capture interface: v2.00
[ 0.640861] pps_core: LinuxPPS API ver. 1 registered
[ 0.641006] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.641290] PTP clock support registered
[ 0.643389] Advanced Linux Sound Architecture Driver Initialized.
[ 0.648847] Bluetooth: Core ver 2.22
[ 0.649098] NET: Registered PF_BLUETOOTH protocol family
[ 0.649238] Bluetooth: HCI device and connection manager initialized
[ 0.651828] Bluetooth: HCI socket layer initialized
[ 0.651994] Bluetooth: L2CAP socket layer initialized
[ 0.652303] Bluetooth: SCO socket layer initialized
[ 1.408370] clocksource: Switched to clocksource mxc_timer1
[ 1.412260] VFS: Disk quotas dquot_6.6.0
[ 1.412566] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.470041] NET: Registered PF_INET protocol family
[ 1.471147] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 1.474153] tcp_listen_portaddr_hash hash table entries: 256 (order: 1, 10240 bytes, linear)
[ 1.474438] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 1.474661] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[ 1.474967] TCP bind hash table entries: 4096 (order: 5, 163840 bytes, linear)
[ 1.475745] TCP: Hash tables configured (established 4096 bind 4096)
[ 1.476483] UDP hash table entries: 256 (order: 2, 24576 bytes, linear)
[ 1.476783] UDP-Lite hash table entries: 256 (order: 2, 24576 bytes, linear)
[ 1.477497] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 1.489790] RPC: Registered named UNIX socket transport module.
[ 1.490044] RPC: Registered udp transport module.
[ 1.490174] RPC: Registered tcp transport module.
[ 1.490300] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.490476] PCI: CLS 0 bytes, default 64
[ 1.494517] armv7-pmu pmu: hw perfevents: no interrupt-affinity property, guessing.
[ 1.495474] hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
[ 1.502954] Initialise system trusted keyrings
[ 1.504112] workingset: timestamp_bits=30 max_order=17 bucket_order=0
[ 1.534981] NFS: Registering the id_resolver key type
[ 1.535298] Key type id_resolver registered
[ 1.535506] Key type id_legacy registered
[ 1.535969] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.536243] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 1.631724] Key type asymmetric registered
[ 1.631989] Asymmetric key parser 'x509' registered
[ 1.632833] io scheduler mq-deadline registered
[ 1.632975] io scheduler kyber registered
[ 1.642012] imx-weim 21b8000.weim: Driver registered.
[ 1.665691] mxs-dma 110000.dma-apbh: initialized
[ 1.679801] pfuze100-regulator 0-0008: Full layer: 2, Metal layer: 1
[ 1.681006] pfuze100-regulator 0-0008: FAB: 0, FIN: 0
[ 1.681154] pfuze100-regulator 0-0008: pfuze100 found.
[ 1.720357] 2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 269, base_baud = 5000000) is a IMX
[ 2.672985] printk: console [ttymxc0] enabled
[ 2.682853] 21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 270, base_baud = 5000000) is a IMX
[ 2.695191] 21ec000.serial: ttymxc2 at MMIO 0x21ec000 (irq = 271, base_baud = 5000000) is a IMX
[ 2.719129] panel-simple panel-dpi: supply power not found, using dummy regulator
[ 2.747044] etnaviv etnaviv: bound 130000.gpu (ops gpu_ops)
[ 2.754251] etnaviv etnaviv: bound 134000.gpu (ops gpu_ops)
[ 2.760132] etnaviv-gpu 130000.gpu: model: GC880, revision: 5106
[ 2.767757] etnaviv-gpu 134000.gpu: model: GC320, revision: 5007
[ 2.777744] [drm] Initialized etnaviv 1.3.0 20151214 for etnaviv on minor 0
[ 2.791883] imx-ipuv3 2400000.ipu: IPUv3H probed
[ 2.842724] brd: module loaded
[ 2.879264] loop: module loaded
[ 2.887091] physmap-flash 8000000.sram: physmap platform flash device: [mem 0x08000000-0x0800ffff]
[ 2.900086] physmap-flash 8000000.sram: map_probe failed
[ 2.906228] physmap-flash a000000.sram: physmap platform flash device: [mem 0x0a000000-0x0a00ffff]
[ 2.916662] physmap-flash a000000.sram: map_probe failed
[ 2.931636] CAN device driver interface
[ 2.941175] pps pps0: new PPS source ptp0
[ 2.956864] fec 2188000.ethernet eth0: registered PHC device 0
[ 2.965947] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.972788] ehci-pci: EHCI PCI platform driver
[ 2.977754] usbcore: registered new interface driver usb-storage
[ 3.003141] snvs_rtc 20cc000.snvs:snvs-rtc-lp: registered as rtc1
[ 3.010259] i2c_dev: i2c /dev entries driver
[ 3.027470] Bluetooth: HCI UART driver ver 2.3
[ 3.032310] Bluetooth: HCI UART protocol H4 registered
[ 3.037784] Bluetooth: HCI UART protocol LL registered
[ 3.046839] sdhci: Secure Digital Host Controller Interface driver
[ 3.053262] sdhci: Copyright(c) Pierre Ossman
[ 3.057815] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.069165] sdhci-esdhc-imx 2190000.mmc: Got CD GPIO
[ 3.083973] caam 2100000.crypto: Entropy delay = 3200
[ 3.114729] mmc2: SDHCI controller on 2198000.mmc [2198000.mmc] using ADMA
[ 3.125011] mmc0: SDHCI controller on 2190000.mmc [2190000.mmc] using ADMA
[ 3.150083] caam 2100000.crypto: Instantiated RNG4 SH0
[ 3.182436] mmc2: new DDR MMC card at address 0001
[ 3.192377] mmcblk2: mmc2:0001 Q2J54A 3.59 GiB
[ 3.210232] mmcblk2: p1 p2
[ 3.210845] caam 2100000.crypto: Instantiated RNG4 SH1
[ 3.216970] mmcblk2boot0: mmc2:0001 Q2J54A 16.0 MiB
[ 3.218498] caam 2100000.crypto: device ID = 0x0a16010000000100 (Era 4)
[ 3.230658] caam 2100000.crypto: job rings = 2, qi = 0
[ 3.231111] mmcblk2boot1: mmc2:0001 Q2J54A 16.0 MiB
[ 3.245803] caam algorithms registered in /proc/crypto
[ 3.249538] mmcblk2rpmb: mmc2:0001 Q2J54A 512 KiB, chardev (243:0)
[ 3.251611] caam 2100000.crypto: registering rng-caam
[ 3.393476] random: crng init done
[ 3.394002] caam 2100000.crypto: rng crypto API alg registered prng-caam
[ 3.409019] usbcore: registered new interface driver usbhid
[ 3.414760] usbhid: USB HID core driver
[ 3.423859] imx-ipuv3-csi imx-ipuv3-csi.0: Registered ipu1_csi0 capture as /dev/video0
[ 3.434043] imx-ipuv3 2400000.ipu: Registered ipu1_ic_prpenc capture as /dev/video1
[ 3.443213] imx-ipuv3 2400000.ipu: Registered ipu1_ic_prpvf capture as /dev/video2
[ 3.452700] imx-ipuv3-csi imx-ipuv3-csi.1: Registered ipu1_csi1 capture as /dev/video3
[ 3.468457] stmpe-adc stmpe-adc: DMA mask not set
[ 3.506944] sgtl5000 0-000a: sgtl5000 revision 0x11
[ 3.566224] fsl-ssi-dai 2028000.ssi: No cache defaults, reading back from HW
[ 3.582608] NET: Registered PF_INET6 protocol family
[ 3.592899] Segment Routing with IPv6
[ 3.596778] In-situ OAM (IOAM) with IPv6
[ 3.601149] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 3.610294] NET: Registered PF_PACKET protocol family
[ 3.615568] can: controller area network core
[ 3.620525] NET: Registered PF_CAN protocol family
[ 3.625465] can: raw protocol
[ 3.628831] can: broadcast manager protocol
[ 3.633189] can: netlink gateway - max_hops=1
[ 3.638406] Key type dns_resolver registered
[ 3.654809] Registering SWP/SWPB emulation handler
[ 3.661019] Loading compiled-in X.509 certificates
[ 3.878449] Stack Depot allocating hash table of 32768 entries with kvcalloc
[ 3.891876] imx-drm display-subsystem: bound imx-ipuv3-crtc.2 (ops ipu_crtc_ops)
[ 3.900346] imx-drm display-subsystem: bound imx-ipuv3-crtc.3 (ops ipu_crtc_ops)
[ 3.908926] imx-drm display-subsystem: bound disp0 (ops imx_pd_ops)
[ 3.919731] [drm] Initialized imx-drm 1.0.0 20120507 for display-subsystem on minor 1
[ 4.000367] Console: switching to colour frame buffer device 80x30
[ 4.027351] imx-drm display-subsystem: [drm] fb0: imx-drmdrmfb frame buffer device
[ 4.672547] mxs_phy 20c9000.usbphy: Data pin can't make good contact.
[ 4.702280] ci_hdrc ci_hdrc.1: EHCI Host Controller
[ 4.709409] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
[ 4.748317] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[ 4.762390] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.00
[ 4.777413] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.791365] usb usb1: Product: EHCI Host Controller
[ 4.799772] usb usb1: Manufacturer: Linux 6.0.17-6.1.0+git.71e1e02850ab ehci_hcd
[ 4.813954] usb usb1: SerialNumber: ci_hdrc.1
[ 4.828858] hub 1-0:1.0: USB hub found
[ 4.834946] hub 1-0:1.0: 1 port detected
[ 4.849883] video-mux 20e0000.iomuxc-gpr:ipu1_csi0_mux: Consider updating driver video-mux to match on endpoints
[ 4.867291] video-mux 20e0000.iomuxc-gpr:ipu1_csi1_mux: Consider updating driver video-mux to match on endpoints
[ 4.892647] imx-media: Registered ipu_ic_pp csc/scaler as /dev/video4
[ 4.907190] imx_thermal 20c8000.anatop:tempmon: Industrial CPU temperature grade - max:105C critical:105C passive:95C
[ 4.927880] fsl-ssi-dai 2028000.ssi: No cache defaults, reading back from HW
[ 4.946038] fsl-ssi-dai 2028000.ssi: No cache defaults, reading back from HW
[ 4.964010] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 4.979966] fsl-ssi-dai 2028000.ssi: No cache defaults, reading back from HW
[ 5.005837] Micrel KSZ8041 2188000.ethernet-1:00: attached PHY driver (mii_bus:phy_addr=2188000.ethernet-1:00, irq=POLL)
[ 7.119854] fec 2188000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[ 7.135266] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 7.178243] Sending DHCP requests .., OK
[ 9.765326] IP-Config: Got DHCP answer from 192.168.0.1, my address is 192.168.0.2
[ 9.779733] IP-Config: Complete:
[ 9.786162] device=eth0, hwaddr=00:14:2d:a4:8f:d2, ipaddr=192.168.0.2, mask=255.255.255.0, gw=192.168.0.1
[ 9.802938] host=192.168.0.2, domain=colibri.net, nis-domain=(none)
[ 9.813290] bootserver=192.168.0.1, rootserver=192.168.0.1, rootpath=/srv/nfs/rootfs,wsize=1024,rsize=1024,v3
[ 9.813333] nameserver0=192.168.0.1
[ 9.844709] ALSA device list:
[ 9.849722] No soundcards found.
[ 9.901274] VFS: Mounted root (nfs filesystem) readonly on device 0:16.
[ 9.912345] devtmpfs: mounted
[ 9.919751] Freeing unused kernel image (initmem) memory: 1024K
[ 9.979454] Run /sbin/init as init process
[ 11.715862] systemd[1]: System time before build time, advancing clock.
[ 12.010407] systemd[1]: systemd 250.5+ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL )
[ 12.052382] systemd[1]: Detected architecture arm.
Welcome to TDX Wayland with XWayland Upstream 6.1.0+build.5 (kirkstone)!
[ 12.125885] systemd[1]: Hostname set to <colibri-imx6-05117108>.
[ 12.808619] systemd[164]: /lib/systemd/system-generators/systemd-gpt-auto-generator failed with exit status 1.
[ 14.141892] systemd[1]: Queued start job for default target Multi-User System.
[ 14.259596] systemd[1]: Created slice Slice /system/getty.
[ OK ] Created slice Slice /system/getty.
[ 14.306964] systemd[1]: Created slice Slice /system/modprobe.
[ OK ] Created slice Slice /system/modprobe.
[ 14.356730] systemd[1]: Created slice Slice /system/serial-getty.
[ OK ] Created slice Slice /system/serial-getty.
[ 14.405020] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 14.451985] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password …ts to Console Directory Watch.
[ 14.501027] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password R…uests to Wall Directory Watch.
[ 14.549598] systemd[1]: Reached target Host and Network Name Lookups.
[ OK ] Reached target Host and Network Name Lookups.
[ 14.589716] systemd[1]: Reached target Path Units.
[ OK ] Reached target Path Units.
[ 14.628315] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 14.668903] systemd[1]: Reached target Slice Units.
[ OK ] Reached target Slice Units.
[ 14.719019] systemd[1]: Reached target Swaps.
[ OK ] Reached target Swaps.
[ 14.903319] systemd[1]: Listening on RPCbind Server Activation Socket.
[ OK ] Listening on RPCbind Server Activation Socket.
[ 14.959083] systemd[1]: Reached target RPC Port Mapper.
[ OK ] Reached target RPC Port Mapper.
[ 15.011459] systemd[1]: Listening on Syslog Socket.
[ OK ] Listening on Syslog Socket.
[ 15.052436] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ OK ] Listening on initctl Compatibility Named Pipe.
[ 15.142973] systemd[1]: Journal Audit Socket was skipped because of a failed condition check (ConditionSecurity=audit).
[ 15.160353] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 15.203617] systemd[1]: Listening on Journal Socket.
[ 15.212163] fsl-ssi-dai 2028000.ssi: No cache defaults, reading back from HW
[ OK ] Listening on Journal Socket.
[ 15.226335] platform sound: deferred probe pending
[ 15.233296] platform 2028000.ssi: deferred probe pending
[ 15.240068] platform 2014000.spi: deferred probe pending
[ 15.251431] systemd[1]: Listening on Network Service Netlink Socket.
[ OK ] Listening on Network Service Netlink Socket.
[ 15.300913] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 15.340133] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 15.384709] systemd[1]: Listening on User Database Manager Socket.
[ OK ] Listening on User Database Manager Socket.
[ 15.431988] systemd[1]: Huge Pages File System was skipped because of a failed condition check (ConditionPathExists=/sys/kernel/mm/hugepages).
[ 15.449353] systemd[1]: POSIX Message Queue File System was skipped because of a failed condition check (ConditionPathExists=/proc/sys/fs/mqueue).
[ 15.551772] systemd[1]: Mounting Kernel Debug File System...
[ 15.603540] systemd[1]: Mounting Kernel Trace File System...
[ 15.653963] systemd[1]: Mounting Temporary Directory /tmp...
[ 15.742924] systemd[1]: Starting Create List of Static Device Nodes...
[ 15.811077] systemd[1]: Starting Load Kernel Module configfs...
[ 15.870694] systemd[1]: Starting Load Kernel Module drm...
[ 15.950949] systemd[1]: Starting Load Kernel Module fuse...
[ 16.062553] fuse: init (API version 7.36)
[ 16.090895] systemd[1]: Starting RPC Bind...
[ 16.211885] systemd[1]: Starting File System Check on Root Device...
[ 16.341532] systemd[1]: Starting Journal Service...
[ 16.450618] systemd[1]: Load Kernel Modules was skipped because all trigger condition checks failed.
[ 16.530043] systemd[1]: Starting Generate network units from Kernel command line...
Starting Generate network …ts from Kernel command line...
[ 16.596330] systemd[1]: Starting Apply Kernel Variables...
[ 16.655845] systemd[1]: Starting Coldplug All udev Devices...
[ 16.761753] systemd[1]: Started RPC Bind.
[ OK ] Started RPC Bind.
[ 16.810896] systemd[1]: Mounted Kernel Debug File System.
[ OK ] Mounted Kernel Debug File System.
[ 16.839926] systemd[1]: Mounted Kernel Trace File System.
[ OK ] Mounted Kernel Trace File System.
[ 16.860702] systemd[1]: Mounted Temporary Directory /tmp.
[ OK ] Mounted Temporary Directory /tmp.
[ 16.929345] systemd[1]: Finished Create List of Static Device Nodes.
[ OK ] Finished Create List of Static Device Nodes.
[ 16.955784] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 16.982066] systemd[1]: Finished Load Kernel Module configfs.
[ OK ] Finished Load Kernel Module configfs.
[ 17.044255] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 17.072018] systemd[1]: Finished Load Kernel Module drm.
[ OK ] Finished Load Kernel Module drm.
[ 17.123711] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 17.158581] systemd[1]: Finished Load Kernel Module fuse.
[ OK ] Finished Load Kernel Module fuse.
[ 17.183208] systemd[1]: Finished File System Check on Root Device.
[ OK ] Finished File System Check on Root Device.
[ 17.232802] systemd[1]: Finished Generate network units from Kernel command line.
[ OK ] Finished Generate network units from Kernel command line.
[ 17.293557] systemd[1]: Finished Apply Kernel Variables.
[ OK ] Finished Apply Kernel Variables.
[ 17.379815] systemd[1]: Mounting FUSE Control File System...
[ 17.439690] systemd[1]: Mounting Kernel Configuration File System...
[ 17.520250] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 17.573952] systemd[1]: Started Journal Service.
[ OK ] Started Journal Service.
[ OK ] Mounted FUSE Control File System.
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Finished Remount Root and Kernel File Systems.
Starting Flush Journal to Persistent Storage...
Starting Create Static Device Nodes in /dev...
[ 18.074723] systemd-journald[188]: Received client request to flush runtime journal.
[ OK ] Finished Flush Journal to Persistent Storage.
[ OK ] Finished Create Static Device Nodes in /dev.
[ OK ] Reached target Preparation for Local File Systems.
Mounting /var/volatile...
Starting Rule-based Manage…for Device Events and Files...
[ OK ] Mounted /var/volatile.
Starting Load/Save Random Seed...
[ OK ] Reached target Local File Systems.
Starting Create Volatile Files and Directories...
[ OK ] Finished Load/Save Random Seed.
[ OK ] Started Rule-based Manager for Device Events and Files.
[ OK ] Finished Create Volatile Files and Directories.
Starting Network Time Synchronization...
Starting Record System Boot/Shutdown in UTMP...
[ OK ] Finished Record System Boot/Shutdown in UTMP.
[ OK ] Created slice Slice /system/systemd-backlight.
Starting Load/Save Screen …ness of backlight:backlight...
[ OK ] Finished Coldplug All udev Devices.
[ 21.581301] fsl-ssi-dai 2028000.ssi: No cache defaults, reading back from HW
[ OK ] Finished Load/Save Screen …htness of backlight:backlight.
[ 21.811365] fsl-ssi-dai 2028000.ssi: No cache defaults, reading back from HW
[ 22.080086] coda 2040000.vpu: Firmware code revision: 46076
[ 22.087386] coda 2040000.vpu: Initialized CODA960.
[ 22.093786] coda 2040000.vpu: Firmware version: 3.1.1
[ 22.197255] coda 2040000.vpu: coda-jpeg-encoder registered as video5
[ 22.240788] coda 2040000.vpu: coda-jpeg-decoder registered as video6
[ 22.319592] coda 2040000.vpu: coda-video-encoder registered as video7
[ 22.345290] coda 2040000.vpu: coda-video-decoder registered as video8
[ 22.487421] fsl-ssi-dai 2028000.ssi: No cache defaults, reading back from HW
[ 23.367993] imx-sdma 20ec000.sdma: loaded firmware 3.5
[ 24.332376] systemd-journald[188]: Oldest entry in /run/log/journal/9c4a102d9e764c3792005b9922d68dc3/system.journal is older than the configured .
[ 24.365160] systemd-journald[188]: /run/log/journal/9c4a102d9e764c3792005b9922d68dc3/system.journal: Journal header limits reached or header out-.
[ OK ] Started Network Time Synchronization.
[ OK ] Reached target System Initialization.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target System Time Set.
[ OK ] Reached target Timer Units.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Listening on dropbear.socket.
[ OK ] Reached target Socket Units.
[ OK ] Reached target Basic System.
[ OK ] Started Kernel Logging Service.
[ OK ] Started System Logging Service.
Starting D-Bus System Message Bus...
Starting IPv6 Packet Filtering Framework...
Starting IPv4 Packet Filtering Framework...
Starting Telephony service...
Starting User Login Management...
[ OK ] Started Timestamping service.
Starting Load default USB gadget schema g1.schema...
[ OK ] Finished IPv6 Packet Filtering Framework.
[ OK ] Finished IPv4 Packet Filtering Framework.
[ OK ] Reached target Preparation for Network.
[ 28.686591] using random self ethernet address
[ 28.693604] using random host ethernet address
[ OK ] Started D-Bus System Message Bus.
[ OK ] Started Telephony service.
[ OK ] Started User Login Management.
[ OK ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
Starting Connection service...
[ 30.874560] usb0: HOST MAC 92:87:6c:0a:04:12
[ 30.881131] usb0: MAC b2:2d:5e:44:f6:21
[ OK ] Finished Load default USB gadget schema g1.schema.
[ OK ] Reached target Hardware activated USB gadget.
Starting Network Configuration...
[ 32.374129] mcp251x spi3.0: MCP251x didn't enter in conf mode after reset
[ 32.498211] mcp251x spi3.0: Probe failed, err=110
[ 32.504463] mcp251x: probe of spi3.0 failed with error -110
Starting Save/Restore Sound Card State...
[ OK ] Started Connection service.
Starting Avahi mDNS/DNS-SD Stack...
[*** ] (1 of 3) A start job is running for…ork Configuration (48s / 1min 47s)
