Hi @jeremias.tx , thank you for the quick response!
Yes, correct. Moreover, I was able to do online update installing v1 of my package before trying the offline update with v2.
Here are the logs:
From today - full logs, tried to reinsert usb and got the same message:
root@verdin-imx8mp-15230140:~# journalctl -u aktualizr*
Apr 11 13:07:39 verdin-imx8mp-15230140 systemd[1]: Started Aktualizr SOTA Client.
Apr 11 13:07:39 verdin-imx8mp-15230140 aktualizr-torizon[921]: Aktualizr version tdx-d71f18a1 starting
Apr 11 13:07:39 verdin-imx8mp-15230140 aktualizr-torizon[921]: Reading config: "/usr/lib/sota/conf.d/20-sota-device-cred.toml"
Apr 11 13:07:39 verdin-imx8mp-15230140 aktualizr-torizon[921]: Reading config: "/usr/lib/sota/conf.d/30-rollback.toml"
Apr 11 13:07:39 verdin-imx8mp-15230140 aktualizr-torizon[921]: Reading config: "/usr/lib/sota/conf.d/40-hardware-id.toml"
Apr 11 13:07:39 verdin-imx8mp-15230140 aktualizr-torizon[921]: Reading config: "/usr/lib/sota/conf.d/50-secondaries.toml"
Apr 11 13:07:39 verdin-imx8mp-15230140 aktualizr-torizon[921]: Reading config: "/usr/lib/sota/conf.d/60-polling-interval.toml"
Apr 11 13:07:39 verdin-imx8mp-15230140 aktualizr-torizon[921]: Reading config: "/etc/sota/conf.d/61-custom-polling-interval.toml"
Apr 11 13:07:39 verdin-imx8mp-15230140 aktualizr-torizon[921]: Reading config: "/usr/lib/sota/conf.d/70-reboot.toml"
Apr 11 13:07:39 verdin-imx8mp-15230140 aktualizr-torizon[921]: Reading config: "/etc/sota/conf.d/99-offline-updates.toml"
Apr 11 13:07:39 verdin-imx8mp-15230140 aktualizr-torizon[921]: Use existing SQL storage: "/var/sota/sql.db"
Apr 11 13:07:39 verdin-imx8mp-15230140 aktualizr-torizon[921]: Couldn`t import data: empty path received
Apr 11 13:07:39 verdin-imx8mp-15230140 aktualizr-torizon[921]: Initializing docker-compose Secondaries...
Apr 11 13:07:39 verdin-imx8mp-15230140 aktualizr-torizon[921]: Use existing SQL storage: "/var/sota/storage/docker-compose/sql.db"
Apr 11 13:07:39 verdin-imx8mp-15230140 aktualizr-torizon[921]: Adding Secondary with ECU serial: 5ae0967423406824c8156914969028ed6db1309799e6a608ad142eb3926535d1>
Apr 11 13:07:39 verdin-imx8mp-15230140 aktualizr-torizon[921]: Initializing torizon-generic Secondaries...
Apr 11 13:07:39 verdin-imx8mp-15230140 aktualizr-torizon[921]: Use existing SQL storage: "/var/sota/storage/bootloader/sql.db"
Apr 11 13:07:39 verdin-imx8mp-15230140 aktualizr-torizon[921]: No valid metadata found in storage.
Apr 11 13:07:39 verdin-imx8mp-15230140 aktualizr-torizon[921]: Adding Secondary with ECU serial: c876936a446d837e4e314a34c47a7bbad887b43e5e6c09d74961876b990fab32>
Apr 11 13:07:39 verdin-imx8mp-15230140 aktualizr-torizon[921]: Primary ECU serial: 69e2b3b43d09995076b9755077475af174c0ff7446029abb6b4ad35f470a74d9 with hardware>
Apr 11 13:07:39 verdin-imx8mp-15230140 aktualizr-torizon[921]: Device ID: 346413bd-6b49-4860-8454-9a22f7eef13c
Apr 11 13:07:39 verdin-imx8mp-15230140 aktualizr-torizon[921]: Device Gateway URL: https://dgw.torizon.io
Apr 11 13:07:39 verdin-imx8mp-15230140 aktualizr-torizon[921]: Certificate subject: CN=346413bd-6b49-4860-8454-9a22f7eef13c
Apr 11 13:07:39 verdin-imx8mp-15230140 aktualizr-torizon[921]: Certificate issuer: CN=ota-devices-CA
Apr 11 13:07:39 verdin-imx8mp-15230140 aktualizr-torizon[921]: Certificate valid from: Apr 5 16:23:38 2024 GMT until: Apr 5 16:23:38 2124 GMT
Apr 11 13:07:39 verdin-imx8mp-15230140 aktualizr-torizon[921]: PROXY: initializing...
Apr 11 13:07:39 verdin-imx8mp-15230140 aktualizr-torizon[921]: PROXY: using TCP port 8850.
Apr 11 13:07:39 verdin-imx8mp-15230140 aktualizr-torizon[921]: Offline Updates are enabled
Apr 11 13:07:39 verdin-imx8mp-15230140 aktualizr-torizon[921]: PROXY: starting thread.
Apr 11 13:07:39 verdin-imx8mp-15230140 aktualizr-torizon[921]: PROXY: listening to connections...
Apr 11 13:07:42 verdin-imx8mp-15230140 aktualizr-torizon[921]: Event: SendDeviceDataComplete
Apr 11 13:15:04 verdin-imx8mp-15230140 aktualizr-torizon[921]: fetchMetaOffUpd() called with source_path: "/media/INSTALL/update"
Apr 11 13:15:04 verdin-imx8mp-15230140 aktualizr-torizon[921]: Event: UpdateCheckComplete, Result - No updates available
Here are the contents of USB media path, defined in offline updates.toml file
root@verdin-imx8mp-15230140:~# ls /media/INSTALL/update/
images metadata
Here is the /etc/sota/conf.d/ offline updates toml:
root@verdin-imx8mp-15230140:~# cat /etc/sota/conf.d/99-offline-updates.toml
[uptane]
enable_offline_updates = true
enable_online_updates = false
offline_updates_source = /media/INSTALL/update
This is from the logs when I used online updates to downgrade version 6.6.0 devel to 6.5.0 release:
Apr 10 15:11:23 verdin-imx8mp-15230140 aktualizr-torizon[1438]: Device Gateway URL: https://dgw.torizon.io
Apr 10 15:11:23 verdin-imx8mp-15230140 aktualizr-torizon[1438]: Certificate subject: CN=346413bd-6b49-4860-8454-9a22f7eef13c
Apr 10 15:11:23 verdin-imx8mp-15230140 aktualizr-torizon[1438]: Certificate issuer: CN=ota-devices-CA
Apr 10 15:11:23 verdin-imx8mp-15230140 aktualizr-torizon[1438]: Certificate valid from: Apr 5 16:23:38 2024 GMT until: Apr 5 16:23:38 2124 GMT
Apr 10 15:11:23 verdin-imx8mp-15230140 aktualizr-torizon[1438]: PROXY: initializing...
Apr 10 15:11:23 verdin-imx8mp-15230140 aktualizr-torizon[1438]: PROXY: using TCP port 8850.
Apr 10 15:11:23 verdin-imx8mp-15230140 aktualizr-torizon[1438]: Offline Updates are disabled
Apr 10 15:11:23 verdin-imx8mp-15230140 aktualizr-torizon[1438]: PROXY: starting thread.
Apr 10 15:11:23 verdin-imx8mp-15230140 aktualizr-torizon[1438]: PROXY: listening to connections...
Apr 10 15:11:29 verdin-imx8mp-15230140 aktualizr-torizon[1438]: Event: SendDeviceDataComplete
Apr 10 15:11:44 verdin-imx8mp-15230140 aktualizr-torizon[1438]: Event: UpdateCheckComplete, Result - No updates available
Apr 10 15:12:08 verdin-imx8mp-15230140 aktualizr-torizon[1438]: Event: UpdateCheckComplete, Result - No updates available
Apr 10 15:12:31 verdin-imx8mp-15230140 aktualizr-torizon[1438]: Event: UpdateCheckComplete, Result - No updates available
Apr 10 15:13:01 verdin-imx8mp-15230140 aktualizr-torizon[1438]: Event: UpdateCheckComplete, Result - No updates available
Apr 10 15:13:33 verdin-imx8mp-15230140 aktualizr-torizon[1438]: New updates found in Director metadata. Checking Image repo metadata...
Apr 10 15:13:40 verdin-imx8mp-15230140 aktualizr-torizon[1438]: 1 new update found in both Director and Image repo metadata.
Apr 10 15:13:40 verdin-imx8mp-15230140 aktualizr-torizon[1438]: Event: UpdateCheckComplete, Result - Updates available
Apr 10 15:13:43 verdin-imx8mp-15230140 aktualizr-torizon[1438]: ostree-pull: Scanning metadata: 198
Apr 10 15:13:43 verdin-imx8mp-15230140 aktualizr-torizon[1438]: Event: DownloadProgressReport, Progress at 0%
Apr 10 15:13:44 verdin-imx8mp-15230140 aktualizr-torizon[1438]: libostree pull from 'aktualizr-remote' for 0 refs complete
security: GPG: disabled
security: SIGN: disabled http: CA-pinned
non-delta: meta: 3 content: 0
transfer: secs: 3 size: 3.3 kB
Apr 10 15:13:44 verdin-imx8mp-15230140 aktualizr-torizon[1438]: ostree-pull: 3 metadata, 0 content objects fetched; 3 KiB transferred in 3 seconds; 0 bytes content written
Apr 10 15:13:44 verdin-imx8mp-15230140 aktualizr-torizon[1438]: Event: DownloadTargetComplete, Result - Success
Apr 10 15:13:44 verdin-imx8mp-15230140 aktualizr-torizon[1438]: Event: AllDownloadsComplete, Result - Success
Apr 10 15:13:44 verdin-imx8mp-15230140 aktualizr-torizon[1438]: Event: InstallStarted
Apr 10 15:13:45 verdin-imx8mp-15230140 aktualizr-torizon[1438]: Installing package using ostree package manager
Apr 10 15:13:45 verdin-imx8mp-15230140 aktualizr-torizon[1438]: Commit metadata kargs=quiet logo.nologo vt.global_cursor_default=0 plymouth.ignore-serial-consoles splash fbcon=map:3
Apr 10 15:13:47 verdin-imx8mp-15230140 aktualizr-torizon[1438]: Copying /etc changes: 4 modified, 2 removed, 24 added
Apr 10 15:13:48 verdin-imx8mp-15230140 aktualizr-torizon[1438]: Transaction complete; bootconfig swap: yes; bootversion: boot.1.1, deployment count change: 0
This is the earliest available log:
Apr 10 09:12:57 verdin-imx8mp-15230140 aktualizr-torizon[989]: Device Gateway URL: https://dgw.torizon.io
Apr 10 09:12:57 verdin-imx8mp-15230140 aktualizr-torizon[989]: Certificate subject: CN=346413bd-6b49-4860-8454-9a22f7eef13c
Apr 10 09:12:57 verdin-imx8mp-15230140 aktualizr-torizon[989]: Certificate issuer: CN=ota-devices-CA
Apr 10 09:12:57 verdin-imx8mp-15230140 aktualizr-torizon[989]: Certificate valid from: Apr 5 16:23:38 2024 GMT until: Apr 5 16:23:38 2124 GMT
Apr 10 09:12:57 verdin-imx8mp-15230140 aktualizr-torizon[989]: PROXY: initializing...
Apr 10 09:12:57 verdin-imx8mp-15230140 aktualizr-torizon[989]: PROXY: using TCP port 8850.
Apr 10 09:12:57 verdin-imx8mp-15230140 aktualizr-torizon[989]: Offline Updates are enabled
Apr 10 09:12:57 verdin-imx8mp-15230140 aktualizr-torizon[989]: PROXY: starting thread.
Apr 10 09:12:57 verdin-imx8mp-15230140 aktualizr-torizon[989]: PROXY: listening to connections...
Apr 10 09:13:03 verdin-imx8mp-15230140 aktualizr-torizon[989]: Event: SendDeviceDataComplete
Apr 10 09:36:01 verdin-imx8mp-15230140 aktualizr-torizon[989]: fetchMetaOffUpd() called with source_path: "/media/INSTALL/update"
Apr 10 09:36:01 verdin-imx8mp-15230140 aktualizr-torizon[989]: Event: UpdateCheckComplete, Result - No updates available
Thank you,
Andrey
