Install image using Tezi without display
In our devices we use a custom PCB that has a slot for plugging in the Verdin AM62 module. Our devices dont have displays, hence there is no HDMI port on the board.
My goal is to achieve easy batch programming of several devices. I was planning to have the following steps:
  1. Assemble device, slot the Verdin module in
  2. Connect device to a local network that serves my custom TorizonOS image (with autoinstall option enabled) over ethernet
  3. Boot device
  4. Expect OS to install automatically.
But I see that on our custom PCBs tezi fails to start because there is no graphical backend i guess. Below is the tezi.log from a Verdin am62 module with only Torizon Easy Installer image installed
/ # cat /var/volatile/tezi.log
  Failed to create wl_display (No such file or directory)
  qt.qpa.plugin: Could not load the Qt platform plugin "wayland" in "" even though it was found.
  This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
  Available platform plugins are: minimal, offscreen, vnc, wayland.
So, my question is, is tezi usable at all without the graphical backend? Does this behaviour mean that toradex boards are designed to be used with the display? Or do we need to do some HW hacks to trick the system into thinking that hdmi is connected?
Thank you for reaching out with your question. The Toradex Easy Installer (Tezi) is indeed designed to operate with a graphical interface, typically requiring a display or a remote interface like VNC. Since your custom PCB lacks HDMI support, you can use VNC to access the Tezi GUI remotely over the network, which is a practical solution for your setup.
Here’s how you can proceed:
  1. Network Configuration: Ensure your device is connected to a local network accessible from your host machine.
  2. VNC Setup: When Tezi boots, it should automatically start a VNC server. You can connect to this server using a VNC client from your host machine. The default VNC port is usually 5900, so you would connect to device_ip:5900.
  3. Autoinstall Configuration: To automate the installation process, ensure your custom TorizonOS image is configured with the autoinstall option enabled. This can be set in the image’s JSON configuration file.
  4. Testing: Before deploying this setup in production, test the VNC connection and autoinstall process to ensure everything works as expected.
By using VNC, you can effectively manage the installation process without needing a physical display, allowing you to perform batch programming of your devices efficiently.
I hope this helps! If you have any more questions, feel free to ask.
Easy Installer problem on AM62 D, IT with Mallow V1.1 board.
Hello @stasgil,
The Toradex Easy Installer is expected to work even without a graphical output.
Which version of the Toradex Easy Installer are you using? Is it the same that is pre-installed to your modules?
Also, what is the serial number of the module you are using?
Bruno
Hi Bruno.
Serial number of my “test module” is 15361822, Verdin AM62 V1.1B
I was testing Toradex Easy Installer 6.8.1+build9 , the image that is available to install after going through the recovery procedure.
I have to admit, since I don’t have any fresh out of factory modules at the moment, I don’t know which version of Tezi is preinstalled.
In addition:
The method I have described in the original post i tested with the USB media. But i’m not sure it matters, since it seems that Tezi fails to startup.
And to clarify, when I plug in the same module into my Yavia board, Tezi starts up as expected, so most likely some required hardware pin is not in the right state.
Any updates?
Hello @stasgil,
Sorry for the delay in getting back to you. @bruno.tx is busy attending Embedded World at the moment together with most of our team. I am working on this topic now and will try to reproduce the issue. You can expect an answer from me later today.
Hello @stasgil,
I could not reproduce this issue using our Mallow carrier board. I had a Verdin AM62D 1GB WB IT V1.1B module installed with Toradex Easy Installer version 6.8.1 plugged into the board. I had no display connected to the board. I served a reference Torizon OS image configured with autoinstall true over my local network server. The module automatically started the installation of the image and I could then reboot the device into this Torizon OS image.
Do you have one of our evaluation or production carrier boards with you? If yes, could you try to reproduce the issue on it?
Hi Rudhi,
Apologies, perhaps my explanation wasn’t clear enough.
We have a Yavia development board, that works without any display connected. The steps that you have performed work here as well.
My issue is that these steps don’t work on our custom PCB that has no HDMI port at all. So it seems that there is some HW difference, that prevents Tezi from starting (see tezi.log output in my original post).
So the reason I even posted this question is to check whether there are any HW requirements related to running the torizon easy installer image.
Hello @stasgil,
It looks like something is holding up weston from starting or delaying it and therefore the application itself does not start. I would like you to try a couple of things:
  1. Can you try to run tezi from the command line using tezictl commands (for example, tezictl image-list should show the available images.)
  2. Could you please send me the output of # cat /var/volatile/weston.log ?
  3. The last thing would be to look into the hardware aspect of the issue. As this only happens on your custom carrier board, I would be curious to understand the differences when compared to a Toradex design. It would be helpful if you could send us your schematics in a pdf file to support.eu@toradex.com.
Hi Rudhi,
Apologies for the delay in response. Please find the requested logs attached. This is from a “fresh from factory” toradex module we have just received, SN 15560026 V1.2A.
Re schematic - I will send it as soon as I can
weston.log (4.3 KB)
tezictl.log (657 Bytes)
I have sent our HW schematic to the support email
Hello @stasgil,
We received the carrier board schematics from you and are investigating this issue. We will get back to you soon with more updates.
Hi @stasgil
Thanks a lot for the schematics, the report and the logs. Rudhi asked me to have a look at it and I would have one more request. Can you send us the output of the following commands (please send the full output of dmesg)?
/ # dmesg
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 6.1.83-6.7.0+git.0a32d33d5fb7 (oe-user@oe-host) (aarch64-oe-linux-
/ # cat /sys/class/drm/card0-HDMI-A-1/status
connected
/ # cat /etc/xdg/weston/weston.ini
[core]
idle-time=0
idle-time=0
shell=kiosk-shell.so
modules=screen-share.so
use-pixman=true
[output]
name=HDMI-A-1
force-on=true
mode=640x480@60
[screen-share]
command=/usr/bin/weston --backend=vnc-backend.so --shell=fullscreen-shell.so
[shell]
background-color=0xff000000
background-image=/usr/share/weston/wallpaper.png
background-type=centered
panel-position=none
My assumption is that the lt8912 driver is doing something strange.
As a current workaround, I think it might be possible to start Toradex Easy Installer manually if you have access to the console. You can do this by running the following command:
/ # tezi -platform vnc &
QVncServer created on port 5900
USB Gadget: NCM enabled
Trying to read configblock from "mmcblk0boot0" at -512
Running Command:  "/usr/bin/avahi-set-host-name" ("verdin-am62-15355725")
Output: "Failed to create host name resolver: The requested operation is invalid because redundant\n"
Finished with exit code: 1
"AVAHI_CLIENT_S_RUNNING"
"New service 'Custom Toradex Easy Installer Feed' of type _tezi._tcp in domain local on protocol IPv4."
Scanning media initially...
"AVAHI_BROWSER_CACHE_EXHAUSTED"
"AVAHI_BROWSER_ALL_FOR_NOW"
Network up in 0.106 seconds
NCM up in 0.212 seconds
Tezi Server lookup successfully
Downloading image list from  "http://tezi.toradex.com/image_list.json?PID8=00721101"
Downloading image list from  "http://tezi.toradex.com/image_list_3rdparty.json?PID8=00721101"
Adding zeroconf feed "Custom Toradex Easy Installer Feed"
It should then work as if it would start with weston but only renders to VNC.
Stefan
Hi Stefan,
Apologies for late reply again, i somehow missed the notification..
Please find the log of the requested commands sequence attached.
It looks like I can start tezi successfully using the command you have provided, however this is not a feasible solution for my problem, as there is no easy access to the serial port in our production environment.
cmds_output.log (24.9 KB)
Hi @stasgil
It seems something (missing pull-up) is blocking the i2c2 bus on your carrier board:
[    2.918356] omap_i2c 20020000.i2c: Arbitration lost
[    3.940367] omap_i2c 20020000.i2c: controller timed out
[    4.996459] omap_i2c 20020000.i2c: controller timed out
[    5.026329] omap_i2c 20020000.i2c: Arbitration lost
A possible hardware workaround would be to connect SODIMM 53 and 55 to 1.8V as done on the Dahlia Carrier board:
I will also discuss it internally. However, most likely we can’t provide a short term SW solution for this.
Stefan
Hi stefan,
We have found a different HW workaround for this, that I will update at a later date.
Hi @stasgil
Sorry for the late reply. Great to hear you found a workaround. If you share it that would be great. We also escalated the ticket internally to R&D.
Stefan
Hello @stasgil,
I have an update for you from our R&D side. This issue has been fixed on TEZI versions 6.8.3 and 7.3.0. Feel free to test it and please let me know how that goes.
Hi Rudhi,
Thank you for the update, I tested it with the USB flashdrive and Tezi 7.3.0 and it worked !
Also i think our hardware hack didn’t seem to work, but i wasn’t able to give a proper update yet, since our HW engineer is on holiday.
Hello @stasgil,
Thanks for the update. I will close this thread from our side. If you have other topics/questions popping up in the future, feel free to create new threads.
