cc1: error: unknown value ‘generic-armv7-a’ for ‘-mtune’
cc1: note: valid arguments are: cortex-a34 cortex-a35 cortex-a53 cortex-a57 cortex-a72 cortex-a73 thunderx thunderxt88p1 thunderxt88 octeontx octeontx81 octeontx83 thunderxt81 thunderxt83 ampere1 ampere1a emag xgene1 falkor qdf24xx exynos-m1 phecda thunderx2t99p1 vulcan thunderx2t99 cortex-a55 cortex-a75 cortex-a76 cortex-a76ae cortex-a77 cortex-a78 cortex-a78ae cortex-a78c cortex-a65 cortex-a65ae cortex-x1 cortex-x1c neoverse-n1 ares neoverse-e1 octeontx2 octeontx2t98 octeontx2t96 octeontx2t93 octeontx2f95 octeontx2f95n octeontx2f95mm a64fx tsv110 thunderx3t110 neoverse-v1 zeus neoverse-512tvb saphira cortex-a57.cortex-a53 cortex-a72.cortex-a53 cortex-a73.cortex-a35 cortex-a73.cortex-a53 cortex-a75.cortex-a55 cortex-a76.cortex-a55 cortex-r82 cortex-a510 cortex-a710 cortex-a715 cortex-x2 cortex-x3 neoverse-n2 cobalt-100 neoverse-v2 demeter generic
The error message you’re encountering indicates that the -mtune option in your U-Boot build process is set to an invalid value, generic-armv7-a. The valid values for -mtune are specific ARM cores and architectures, as listed in the error message.
To resolve this issue, you need to specify a valid -mtune value that matches the architecture of the target device you are building U-Boot for. You can do this by modifying the U-Boot configuration or the makefile where the -mtune option is set.
Here are some steps you can take:
Identify the Target Architecture: Determine the specific ARM core or architecture your target device uses. This information is usually available in the device’s datasheet or technical reference manual.
Modify the Configuration: Once you know the correct architecture, update the U-Boot configuration to use a valid
-mtunevalue. This might involve editing the configuration file or the makefile where the compiler flags are set. -
Rebuild U-Boot: After making the necessary changes, clean the build environment and rebuild U-Boot to ensure the changes take effect.
If you are unsure about the correct architecture for your device, you may need to consult the documentation for your specific Toradex module or reach out to Toradex support for further assistance.
Hi @bharath2204 ,
Whenever you post query, please provide proper information,
eg, for what platform you are building, what BSP , steps you performed and the error you are getting.
ERROR: Nothing RPROVIDES ‘docker’ (but /home/bharath/oe-core/build/../layers/meta-toradex-demos/recipes-images/images/tdx-reference-minimal-image.bb RDEPENDS on or otherwise requires it)
NOTE: Runtime target ‘docker’ is unbuildable, removing…
Missing or unbuildable dependency chain was: [‘docker’]
ERROR: Required build target ‘tdx-reference-minimal-image’ has no buildable providers.
Missing or unbuildable dependency chain was: [‘tdx-reference-minimal-image’, ‘docker’]
Hi @bharath2204 ,
Please create a new ticket with the below details.
- The hardware and software setup you have
- What you are doing (eg building linux kernel, device tree, u-boot, etc)
- At what step you are facing issue
- Error that you are getting
