We are trying to use both displays with imx8qm and ixora.
Tested with unmodified image from a link from toradex developer page image used: b2qt 6.4.3
from
Qt for Device Creation (Boot to Qt) | Toradex Developer Center
https://docs.toradex.com/106697-b2qt-embedded-qt5-image-apalis-imx8-tezi.tar?v=14
default settings for the display is HDMI and settings are following:
overlays.txt file:
fdt_overlays=apalis-imx8_hdmi_overlay.dtbo apalis-imx8_spi1_spidev_overlay.dtbo apalis-imx8_spi2_spidev_overlay.dtbo
kms.conf file:
"hwcursor": false,
"device": "/dev/dri/card1"
with these default settings HDMI works.
Then, we want to change it to use a touch screen :
overlays.txt file:
fdt_overlays=fdt_overlays=apalis-imx8_panel-lvds-dual-channel-1080p_overlay.dtbo
kms.conf file:
"hwcursor": false,
"device": "/dev/dri/card1",
"outputs":
{ "name":"LVDS-1", "mode":"1280x800", "virtualIndex":0 }
with these settings touch screen works.
But we want to use both screens.
When we change the settings on both files, kernel crashes on startup with different error on each time.
overlays.txt file:
fdt_overlays=fdt_overlays=apalis-imx8_panel-lvds-dual-channel-1080p_overlay.dtbo apalis-imx8_hdmi_overlay.dtbo apalis-imx8_spi1_spidev_overlay.dtbo apalis-imx8_spi2_spidev_overlay.dtbo
kms.conf file:
"hwcursor": false,
"outputs":
{ "name":"LVDS-1", "mode":"1280x800", "virtualIndex":0 },
{ "name":"HDMI-A-1", "mode":"1920x1080" }
Following is the early step of the startup, added as a information:
U-Boot 2022.04-0+git.1c83b1aaad86 (Jan 05 2023 - 08:25:45 +0000)
CPU: NXP i.MX8QM RevB A53 at 1200 MHz at 39C
DRAM: 4 GiB
Core: 186 devices, 15 uclasses, devicetree: separate
In: serial@5a070000
Out: serial@5a070000
Err: serial@5a070000
Model: Toradex 0037 Apalis iMX8QM 4GB WB IT V1.1E
Serial#: 14715897
BuildInfo:
- SCFW f5623878, SECO-FW c9de51c0, IMX-MKIMAGE 3bfcfccb, ATF 3c1583b
- U-Boot 2022.04-0+git.1c83b1aaad86
Net: eth0: ethernet@5b040000
Normal Boot
MMC: no card present
switch to partitions #0, OK
Scanning mmc 0:1...
Found U-Boot script /boot.scr
5964 bytes read in 2 ms (2.8 MiB/s)
Executing script at 9d480000
Loading DeviceTree: imx8qm-apalis-v1.1-eval.dtb
170359 bytes read in 7 ms (23.2 MiB/s)
98 bytes read in 2 ms (47.9 KiB/s)
Applying Overlay: apalis-imx8_panel-lvds-dual-channel-1080p_overlay.dtbo
1428 bytes read in 3 ms (464.8 KiB/s)
Applying Overlay: apalis-imx8_hdmi_overlay.dtbo
2205 bytes read in 3 ms (717.8 KiB/s)
11588488 bytes read in 261 ms (42.3 MiB/s)
Bootargs: pci=nomsi root=PARTUUID=c822a191-02 ro rootwait console=tty1 console=ttyLP1,115200 consoleblank=0 earlycon
Uncompressing Kernel Image
Flattened Device Tree blob at 9d400000
Booting using the fdt blob at 0x9d400000
Loading Device Tree to 00000000fd64f000, end 00000000fd69bfff ... OK
Disable pwm@5a190000 rsrc 188 not owned
Disable clock-controller@5a590000 rsrc 188 not owned
Starting kernel ...
Following is the errors happening after it:
error 1:
Starting Wait for udev To …plete Device Initialization...
[ 6.538844] caam 31400000.crypto: device ID = 0x0a16040000000100 (Era 9)
[ OK ] Created slice Slice /system/systemd-[ 6.547304] caam 31400000.crypto: job rings = 2, qi = 0
backlight.
[ 6.567131] systemd-journald[305]: Oldest entry in /run/log/journal/2d7ccc10af54451ba75ca6b7b726924a/system.journal is older than the configured file retention duration (1month), suggesting rotation.
[ 6.571964] amphion-vpu-core 2d090000.vpu-core: encoder firmware version : 1.3.3
[ 6.589902] systemd-journald[305]: /run/log/journal/2d7ccc10af54451ba75ca6b7b726924a/system.journal: Journal header limits reached or header out-of-date, rotating.
Starting Load/Save Screen …ness of backlight:backlight...
[ 6.621867] random: crng init done
[ OK ] Started Network Time Synchronization[ 6.627460] amphion-vpu-core 2d080000.vpu-core: decoder firmware version : 1.8.5
[ OK ] Finished Load/Save Random Seed.
[ OK ] Finished Load/Save Screen …htness of backlight:backlight.
[ 6.688104] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.2 (ops dpu_bliteng_ops)
[ 6.701552] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.5 (ops dpu_bliteng_ops)
[ 6.711311] imx8_media_dev: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.711459] imx-drm display-subsystem: bound imx-dpu-crtc.0 (ops dpu_crtc_ops)
[ 6.729539] imx-drm display-subsystem: bound imx-dpu-crtc.1 (ops dpu_crtc_ops)
[ OK ] Reached target System Time Set.[ 6.739117] imx-drm display-subsystem: bound imx-dpu-crtc.3 (ops dpu_crtc_ops)
[ 6.752443] imx-drm display-subsystem: bound imx-dpu-crtc.4 (ops dpu_crtc_ops)
[ 6.783243] mxc-jpeg 58400000.jpegdec: decoder device registered as /dev/video2 (81,2)
[ 6.797635] mxc-jpeg 58450000.jpegenc: encoder device registered as /dev/video3 (81,3)
[ 6.806601] CAN device driver interface
[ OK ] Reached target Hardware activated USB[ 6.846467] [drm] Started firmware!
gadget.
[ 6.866978] [drm] HDP FW Version - ver 34559 verlib 20560
[ 6.883509] cdns-mhdp-imx 56268000.hdmi: lane-mapping 0x93
[ 6.890487] [drm] HDCP is disabled
[ 6.896350] imx-drm display-subsystem: bound 56268000.hdmi (ops cdns_mhdp_imx_ops [cdns_mhdp_imx])
[ 6.908529] input: PenMount PM1410 as /devices/platform/bus@5b000000/5b0e0000.usb/ci_hdrc.1/usb3/3-1/3-1.3/3-1.3:1.0/0003:14E1:3508.0001/input/input2
[ 6.932153] hdmi_pxl_clk: failed to set clock parent -16
[ 6.937704] clk: failed to reparent hdmi_pxl_clk to hdmi_av_pll_clk: -16
[ 6.938567] hid-multitouch 0003:14E1:3508.0001: input: USB HID v1.11 Device [PenMount PM1410] on usb-ci_hdrc.1-1.3/input0
[ 6.955629] hdmi_pixel_mux_clk: failed to set clock parent -16
[ 6.961724] clk: failed to reparent hdmi_pixel_mux_clk to hdmi_av_pll_clk: -16
[ 6.970857] hdmi_pixel_link_clk: failed to set clock parent -16
[ 6.979555] clk: failed to reparent hdmi_pixel_link_clk to hdmi_av_pll_clk: -16
[ 6.996222] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 7.006647] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.2 (ops dpu_bliteng_ops)
[ 7.015006] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.5 (ops dpu_bliteng_ops)
[ 7.028421] imx-hdmi sound-hdmi: snd_soc_register_card failed (-517)
[ 7.030933] imx-drm display-subsystem: bound imx-dpu-crtc.0 (ops dpu_crtc_ops)
[ 7.046390] imx-drm display-subsystem: bound imx-dpu-crtc.1 (ops dpu_crtc_ops)
[ 7.050831] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 7.055581] imx-drm display-subsystem: bound imx-dpu-crtc.3 (ops dpu_crtc_ops)
[ 7.074063] imx-drm display-subsystem: bound imx-dpu-crtc.4 (ops dpu_crtc_ops)
[ 7.093894] SError Interrupt on CPU2, code 0xbf000002 -- SError
[ 7.093921] CPU: 2 PID: 194 Comm: kworker/u12:3 Tainted: G C O 5.15.77-0+git.349786b46e61 #1
[ 7.093931] Hardware name: Toradex Apalis iMX8QM V1.1 on Apalis Evaluation Board (DT)
[ 7.093938] Workqueue: events_unbound deferred_probe_work_func
[ 7.093964] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 7.093973] pc : mutex_lock_io+0xd0/0x2ec
[ 7.093984] lr : cdns_mhdp_bus_write+0xa4/0x100 [cdns_mhdp_drmcore]
[ 7.094026] sp : ffff80000b0bb910
[ 7.094029] x29: ffff80000b0bb910 x28: ffff000800765350 x27: ffff000804f83700
[ 7.094039] x26: 0000000000000000 x25: ffff80000109b1b8 x24: ffff00080578e120
[ 7.094048] x23: ffff00080578c080 x22: 0000000022222211 x21: ffff00080578cd88
[ 7.094057] x20: 0000000000000004 x19: ffff00080578c080 x18: 0000000000000000
[ 7.094066] x17: ffff80087600e000 x16: ffff800009c0c000 x15: 00007f57a150dbb6
[ 7.094074] x14: 00000000000003b0 x13: 0000000000000001 x12: 0000000000000001
[ 7.094083] x11: 0000000000000000 x10: 00000000000009c0 x9 : ffff80000b0bb810
[ 7.094092] x8 : ffff0008017e7a20 x7 : ffff00087f75a400 x6 : 0000000000000000
[ 7.094101] x5 : 0000000000220000 x4 : 0000000000000000 x3 : ffff00080578cd88
[ 7.094110] x2 : 0000000000000000 x1 : ffff0008017e7000 x0 : ffff0008017e7000
[ 7.094122] Kernel panic - not syncing: Asynchronous SError Interrupt
[ 7.094127] CPU: 2 PID: 194 Comm: kworker/u12:3 Tainted: G C O 5.15.77-0+git.349786b46e61 #1
[ 7.094134] Hardware name: Toradex Apalis iMX8QM V1.1 on Apalis Evaluation Board (DT)
[ 7.094137] Workqueue: events_unbound deferred_probe_work_func
[ 7.094149] Call trace:
[ 7.094150] dump_backtrace+0x0/0x1cc
[ 7.094164] show_stack+0x18/0x70
[ 7.094172] dump_stack_lvl+0x68/0x84
[ 7.094180] dump_stack+0x18/0x34
[ 7.094185] panic+0x15c/0x31c
[ 7.094194] nmi_panic+0x8c/0x90
[ 7.094205] arm64_serror_panic+0x6c/0x7c
[ 7.094210] do_serror+0x58/0x5c
[ 7.094215] el1h_64_error_handler+0x30/0x50
[ 7.094224] el1h_64_error+0x78/0x7c
[ 7.094231] mutex_lock_io+0xd0/0x2ec
[ 7.094237] cdns_mhdp_firmware_write_section+0x74/0xa0 [cdns_mhdp_imx]
[ 7.094252] cdns_mhdp_firmware_init_imx8qm+0xac/0x1c0 [cdns_mhdp_imx]
[ 7.094263] __cdns_hdmi_probe+0x174/0x37c [cdns_mhdp_drmcore]
[ 7.094291] cdns_hdmi_bind+0x28/0x90 [cdns_mhdp_drmcore]
[ 7.094317] cdns_mhdp_imx_bind+0xe0/0x160 [cdns_mhdp_imx]
[ 7.094328] component_bind_all+0x124/0x284
[ 7.094341] imx_drm_bind+0x15c/0x20c
[ 7.094348] try_to_bring_up_master+0x228/0x314
[ 7.094356] __component_add+0xa0/0x18c
[ 7.094364] component_add+0x14/0x20
[ 7.094371] cdns_mhdp_imx_probe+0x1c/0x30 [cdns_mhdp_imx]
[ 7.094382] platform_probe+0x68/0xe0
[ 7.094388] really_probe+0xbc/0x46c
[ 7.094395] __driver_probe_device+0x114/0x190
[ 7.094402] driver_probe_device+0x40/0x100
[ 7.094410] __device_attach_driver+0xbc/0x160
[ 7.094417] bus_for_each_drv+0x78/0xd0
[ 7.094424] __device_attach+0xa8/0x1e4
[ 7.094432] device_initial_probe+0x14/0x20
[ 7.094439] bus_probe_device+0x98/0xa0
[ 7.094446] deferred_probe_work_func+0x94/0xe4
[ 7.094453] process_one_work+0x1d0/0x354
[ 7.094461] worker_thread+0x13c/0x470
[ 7.094467] kthread+0x150/0x160
[ 7.094476] ret_from_fork+0x10/0x20
[ 7.094485] SMP: stopping secondary CPUs
[ 7.094500] Kernel Offset: disabled
[ 7.094502] CPU features: 0x800820b1,20000846
[ 7.094507] Memory Limit: none
error 2 on another startup:
[ OK ] Started Network Time Synchronization.
[ OK ] Created slice Slice /system/systemd-backlight.
[ 6.766987] caam 31400000.crypto: device ID = 0x0a16040000000100 (Era 9)
[ 6.768649] amphion-vpu-core 2d090000.vpu-core: encoder firmware version : 1.3.3
[ 6.786089] caam 31400000.crypto: job rings = 2, qi = 0
[ 6.810161] amphion-vpu-core 2d080000.vpu-core: decoder firmware version : 1.8.5
[ 6.923103] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.2 (ops dpu_bliteng_ops)
[ OK ] Finished Coldplug All udev Devices 6.933842] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.5 (ops dpu_bliteng_ops)
0m.
[ 6.949687] imx-drm display-subsystem: bound imx-dpu-crtc.0 (ops dpu_crtc_ops)
[ 6.959900] imx8_media_dev: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.962273] imx-drm display-subsystem: bound imx-dpu-crtc.1 (ops dpu_crtc_ops)
[ 6.985157] imx-drm display-subsystem: bound imx-dpu-crtc.3 (ops dpu_crtc_ops)
Starting Wait for udev To …plete Device Initi[ 7.016515] imx-drm display-subsystem: bound imx-dpu-crtc.4 (ops dpu_crtc_ops)
alization...
[ 7.118834] CAN device driver interface
[ 7.126212] mxc-jpeg 58400000.jpegdec: decoder device registered as /dev/video2 (81,2)
[ OK ] Reached target Hardware activated USB gadget.
[ 7.162069] mxc-jpeg 58450000.jpegenc: encoder device registered as /dev/video3 (81,3)
[ 7.207419] [drm] Started firmware!
[ 7.220299] [drm] HDP FW Version - ver 34559 verlib 20560
[ 7.235921] cdns-mhdp-imx 56268000.hdmi: lane-mapping 0x93
[ 7.241858] [drm] HDCP is disabled
[ 7.257783] imx-drm display-subsystem: bound 56268000.hdmi (ops cdns_mhdp_imx_ops [cdns_mhdp_imx])
[ 7.283346] hdmi_pxl_clk: failed to set clock parent -16
[ 7.288774] clk: failed to reparent hdmi_pxl_clk to hdmi_av_pll_clk: -16
[ 7.293388] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 7.296566] hdmi_pixel_mux_clk: failed to set clock parent -16
[ 7.310116] clk: failed to reparent hdmi_pixel_mux_clk to hdmi_av_pll_clk: -16
[ 7.316323] input: PenMount PM1410 as /devices/platform/bus@5b000000/5b0e0000.usb/ci_hdrc.1/usb3/3-1/3-1.3/3-1.3:1.0/0003:14E1:3508.0001/input/input2
[ 7.323277] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 7.330921] hdmi_pixel_link_clk: failed to set clock parent -16
[ 7.333555] hid-multitouch 0003:14E1:3508.0001: input: USB HID v1.11 Device [PenMount PM1410] on usb-ci_hdrc.1-1.3/input0
[ 7.355389] clk: failed to reparent hdmi_pixel_link_clk to hdmi_av_pll_clk: -16
[ 7.368556] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.2 (ops dpu_bliteng_ops)
[ 7.376840] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.5 (ops dpu_bliteng_ops)
[ 7.385666] imx-drm display-subsystem: bound imx-dpu-crtc.0 (ops dpu_crtc_ops)
[ 7.393739] imx-drm display-subsystem: bound imx-dpu-crtc.1 (ops dpu_crtc_ops)
[ 7.393820] mwifiex_pcie 0000:01:00.0: no quirks enabled
[ 7.401432] imx-drm display-subsystem: bound imx-dpu-crtc.3 (ops dpu_crtc_ops)
[ 7.408969] mwifiex_pcie 0000:01:00.0: enabling device (0000 -> 0002)
[ 7.415332] imx-drm display-subsystem: bound imx-dpu-crtc.4 (ops dpu_crtc_ops)
[ 7.420424] mwifiex_pcie: PCI memory map Virt0: (____ptrval____) PCI memory map Virt2: (____ptrval____)
[ 7.441592] imx-hdmi sound-hdmi: snd_soc_register_card failed (-517)
[ 7.447227] SError Interrupt on CPU5, code 0xbf000002 -- SError
[ 7.447238] CPU: 5 PID: 186 Comm: kworker/u12:3 Tainted: G C O 5.15.77-0+git.349786b46e61 #1
[ 7.447244] Hardware name: Toradex Apalis iMX8QM V1.1 on Apalis Evaluation Board (DT)
[ 7.447248] Workqueue: events_unbound deferred_probe_work_func
[ 7.447267] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 7.447272] pc : cdns_mhdp_bus_write+0x8c/0x100 [cdns_mhdp_drmcore]
[ 7.447295] lr : cdns_mhdp_bus_write+0x2c/0x100 [cdns_mhdp_drmcore]
[ 7.447307] sp : ffff80000af9b910
[ 7.447309] x29: ffff80000af9b910 x28: ffff000801258350 x27: ffff0008056ab200
[ 7.447316] x26: 0000000000000000 x25: ffff80000109f1b8 x24: ffff0008054c2120
[ 7.447321] x23: ffff0008054c0080 x22: 0000000022222211 x21: ffff0008054c0d88
[ 7.447326] x20: 0000000000010004 x19: ffff0008054c0080 x18: 0000000000000000
[ 7.447332] x17: ffff80087604a000 x16: ffff800009c24000 x15: 000000aab6440090
[ 7.447337] x14: 0000000000000384 x13: 0000000000000001 x12: 0000000000000001
[ 7.447342] x11: 0000000000000000 x10: 00000000000009c0 x9 : ffff80000af9b810
[ 7.447347] x8 : ffff0008018c7a20 x7 : ffff00087f796400 x6 : 0000000000000000
[ 7.447352] x5 : 0000000000220000 x4 : 0000000000000000 x3 : ffff0008054c0d88
[ 7.447356] x2 : ffff0008018c7000 x1 : 0000000000000010 x0 : ffff80000a313008
[ 7.447363] Kernel panic - not syncing: Asynchronous SError Interrupt
[ 7.447366] CPU: 5 PID: 186 Comm: kworker/u12:3 Tainted: G C O 5.15.77-0+git.349786b46e61 #1
[ 7.447370] Hardware name: Toradex Apalis iMX8QM V1.1 on Apalis Evaluation Board (DT)
[ 7.447372] Workqueue: events_unbound deferred_probe_work_func
[ 7.447378] Call trace:
[ 7.447379] dump_backtrace+0x0/0x1cc
[ 7.447387] show_stack+0x18/0x70
[ 7.447392] dump_stack_lvl+0x68/0x84
[ 7.447397] dump_stack+0x18/0x34
[ 7.447400] panic+0x15c/0x31c
[ 7.447405] nmi_panic+0x8c/0x90
[ 7.447411] arm64_serror_panic+0x6c/0x7c
[ 7.447414] do_serror+0x58/0x5c
[ 7.447416] el1h_64_error_handler+0x30/0x50
[ 7.447422] el1h_64_error+0x78/0x7c
[ 7.447426] cdns_mhdp_bus_write+0x8c/0x100 [cdns_mhdp_drmcore]
[ 7.447438] cdns_mhdp_firmware_write_section+0x74/0xa0 [cdns_mhdp_imx]
[ 7.447447] cdns_mhdp_firmware_init_imx8qm+0xac/0x1c0 [cdns_mhdp_imx]
[ 7.447453] __cdns_hdmi_probe+0x174/0x37c [cdns_mhdp_drmcore]
[ 7.447465] cdns_hdmi_bind+0x28/0x90 [cdns_mhdp_drmcore]
[ 7.447478] cdns_mhdp_imx_bind+0xe0/0x160 [cdns_mhdp_imx]
[ 7.447484] component_bind_all+0x124/0x284
[ 7.447491] imx_drm_bind+0x15c/0x20c
[ 7.447494] try_to_bring_up_master+0x228/0x314
[ 7.447499] __component_add+0xa0/0x18c
[ 7.447504] component_add+0x14/0x20
[ 7.447509] cdns_mhdp_imx_probe+0x1c/0x30 [cdns_mhdp_imx]
[ 7.447514] platform_probe+0x68/0xe0
[ 7.447518] really_probe+0xbc/0x46c
[ 7.447523] __driver_probe_device+0x114/0x190
[ 7.447527] driver_probe_device+0x40/0x100
[ 7.447532] __device_attach_driver+0xbc/0x160
[ 7.447536] bus_for_each_drv+0x78/0xd0
[ 7.447541] __device_attach+0xa8/0x1e4
[ 7.447545] device_initial_probe+0x14/0x20
[ 7.447550] bus_probe_device+0x98/0xa0
[ 7.447554] deferred_probe_work_func+0x94/0xe4
[ 7.447558] process_one_work+0x1d0/0x354
[ 7.447562] worker_thread+0x13c/0x470
[ 7.447564] kthread+0x150/0x160
[ 7.447569] ret_from_fork+0x10/0x20
[ 7.447574] SMP: stopping secondary CPUs
[ 7.447996] Kernel Offset: disabled
[ 7.447998] CPU features: 0x800820b1,20000846
[ 7.448002] Memory Limit: none
[ 7.769480] ---[ end Kernel panic - not syncing: Asynchronous SError Interrupt ]---
I see a massive difference on overlay file changes on this release.
On previouse releases boot/overlay/ folder had different dtbo files than this one. Such as, there were no apalis-imx8_spi1_spidev_overlay.dtbo apalis-imx8_spi2_spidev_overlay.dtbo files. Touch screen
overlays dtbo file had a different name.
ls /media/BOOT-mmcblk0p1/overlays/
apalis-imx8_ar0521_overlay.dtbo
apalis-imx8_mezzanine_can_overlay.dtbo
apalis-imx8_mezzanine_ov5640_overlay.dtbo
apalis-imx8_mezzanine_panel-cap-touch-10inch-lvds_overlay.dtbo
apalis-imx8_ov5640_overlay.dtbo
apalis-imx8_panel-cap-touch-10inch-lvds_overlay.dtbo
apalis-imx8_resistive-touch_overlay.dtbo
display-dpi-lt170410_overlay.dtbo
display-edt5.7_overlay.dtbo
display-edt7_overlay.dtbo
display-fullhd_overlay.dtbo
display-lt161010_overlay.dtbo
display-lt170410_overlay.dtbo
display-vga_overlay.dtbo
Could anyone help me on this. It is the default not-modified b2qt image and I’m still getting this error if I want to use dual screen setup.
Best regards
Ahmet.
