Hi All,
Please, looking for some help on the following task.
Asking again here, because this is an addition to my previous question and scaled it down to a more basic state, to get specific help.
iMX8QM HDMI plus Touch screen overlays - Technical Support - Toradex Community
I have downloaded toradex multimedia referance image Apalis-iMX8_Reference-Multimedia-Image-Tezi_6.4.0+build.8 from Toradex Artifactory web page.
And tested it with default settings for an HDMI screen. It works out of box.
/boot/overlyas.txt file which has overlay driver setting file is as follows:
root@apalis-imx8-14715897:~# cat /boot/overlays.txt
fdt_overlays=apalis-imx8_hdmi_overlay.dtbo apalis-imx8_spi1_spidev_overlay.dtbo apalis-imx8_spi2_spidev_overlay.dtbo
And changed it for a LVDS touch screen:
fdt_overlays=apalis-imx8_panel-cap-touch-10inch-lvds_overlay.dtbo
It worked for the LVDS touch screen too.
Then I changed it for a dual screen usage.
fdt_overlays=fdt_overlays=apalis-imx8_hdmi_overlay.dtbo apalis-imx8_spi1_spidev_overlay.dtbo
apalis-imx8_spi2_spidev_overlay.dtbo apalis-imx8_panel-cap-touch-10inch-lvds_overlay.dtbo
This time it crashes. This is Toradex multimedia reference image. Could you please help on this.
crash on bootup:
[ OK ] Finished Load/Save Random Seed.
[ OK ] Started Rule-based Manager for Device Events and Files.
[ OK ] Finished Create Volatile Files and Directories.
Starting Network Time Synchronization…
Starting Record System Boot/Shutdown in UTMP…
[ OK ] Finished Record System Boot/Shutdown in UTMP.
[ OK ] Started Network Time Synchronization.
[ OK ] Reached target System Time Set.
[ 7.334769] amphion-vpu-core 2d090000.vpu-core: encoder firmware version : 1.3.3
[ OK ] Created slice Slice /system/systemd-backlight.
Starting Load/Save Screen …ness of backlight:backlight…
[ 7.370172] caam 31400000.crypto: device ID = 0x0a16040000000100 (Era 9)
[ 7.380032] caam 31400000.crypto: job rings = 2, qi = 0
[ 7.380898] amphion-vpu-core 2d080000.vpu-core: decoder firmware version : 1.8.5
[ OK ] Finished Coldplug All udev Devices.
[ OK ] Finished Load/Save Screen …htness of backlight:backlight.
[ 7.463687] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.2 (ops dpu_bliteng_ops)
[ 7.475011] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.5 (ops dpu_bliteng_ops)
Starting Wait for udev To …plete Device Initi[ 7.484528] imx-drm display-subsystem: bound imx-dpu-crtc.0 (ops dpu_crtc_ops)
alization…
[ 7.504549] imx8_media_dev: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.520860] imx-drm display-subsystem: bound imx-dpu-crtc.1 (ops dpu_crtc_ops)
[ 7.530226] imx-drm display-subsystem: bound imx-dpu-crtc.3 (ops dpu_crtc_ops)
[ 7.538303] imx-drm display-subsystem: bound imx-dpu-crtc.4 (ops dpu_crtc_ops)
[ 7.551383] mxc-jpeg 58400000.jpegdec: decoder device registered as /dev/video2 (81,2)
[ 7.561527] mxc-jpeg 58450000.jpegenc: encoder device registered as /dev/video3 (81,3)
[ 7.591032] [drm] Started firmware!
[ 7.603936] CAN device driver interface
[ 7.610487] [drm] HDP FW Version - ver 34559 verlib 20560
[ OK ] Found device /dev/ttyLP1.
[ 7.626849] cdns-mhdp-imx 56268000.hdmi: lane-mapping 0x93
[ 7.634356] [drm] HDCP is disabled
[ 7.640491] imx-drm display-subsystem: bound 56268000.hdmi (ops cdns_mhdp_imx_ops [cdns_mhdp_imx])
[ 7.671414] atmel_mxt_ts 4-004a: supply vdda not found, using dummy regulator
[ 7.682646] hdmi_pxl_clk: failed to set clock parent -16
[ 7.688154] clk: failed to reparent hdmi_pxl_clk to hdmi_av_pll_clk: -16
[ 7.695306] hdmi_pixel_mux_clk: failed to set clock parent -16
[ 7.701346] clk: failed to reparent hdmi_pixel_mux_clk to hdmi_av_pll_clk: -16
[ 7.706928] atmel_mxt_ts 4-004a: supply vdd not found, using dummy regulator
[ 7.708917] hdmi_pixel_link_clk: failed to set clock parent -16
[ 7.721732] clk: failed to reparent hdmi_pixel_link_clk to hdmi_av_pll_clk: -16
[ 7.732954] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.2 (ops dpu_bliteng_ops)
[ 7.741531] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.5 (ops dpu_bliteng_ops)
[ 7.751258] ahci-imx 5f020000.sata: Adding to iommu group 3
[ 7.752800] imx-drm display-subsystem: bound imx-dpu-crtc.0 (ops dpu_crtc_ops)
[ 7.757457] ahci-imx 5f020000.sata: phy impedance ratio is not specified.
[ 7.764579] imx-drm display-subsystem: bound imx-dpu-crtc.1 (ops dpu_crtc_ops)
[ 7.772847] ahci-imx 5f020000.sata: No cache used with register defaults set!
[ 7.781741] imx-drm display-subsystem: bound imx-dpu-crtc.3 (ops dpu_crtc_ops)
[ 7.786988] ahci-imx 5f020000.sata: supply ahci not found, using dummy regulator
[ 7.793133] input: PenMount PM1410 as /devices/platform/bus@5b000000/5b0e0000.usb/ci_hdrc.1/usb3/3-1/3-1.3/3-1.3:1.0/0003:14E1:3508.0001/input/input2
[ 7.794276] imx-drm display-subsystem: bound imx-dpu-crtc.4 (ops dpu_crtc_ops)
[ 7.801089] ahci-imx 5f020000.sata: supply phy not found, using dummy regulator
[ 7.809418] SError Interrupt on CPU1, code 0x00000000bf000002 – SError
[ 7.809436] CPU: 1 PID: 295 Comm: kworker/u12:7 Tainted: G C O 5.15.129-6.4.0+git.67c3153d20ff #1
[ 7.809446] Hardware name: Toradex Apalis iMX8QM V1.1 on Apalis Evaluation Board (DT)
[ 7.809452] Workqueue: events_unbound deferred_probe_work_func
[ 7.809474] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=–)
[ 7.809481] pc : mutex_unlock+0x44/0x70
[ 7.809492] lr : cdns_mhdp_bus_write+0xa4/0x100 [cdns_mhdp_drmcore]
[ 7.809529] sp : ffff80000d08b910
[ 7.809531] x29: ffff80000d08b910 x28: ffff0008013ce550 x27: ffff00080560e300
[ 7.809541] x26: 0000000000000000 x25: ffff8000010b01c0 x24: ffff0008014e6120
[ 7.809550] x23: ffff0008014e4080 x22: 0000000022222211 x21: ffff0008014e4d88
[ 7.809559] x20: 0000000000000004 x19: ffff0008014e4080 x18: 0000000000000000
[ 7.809567] x17: 0000000000000000 x16: 0000000000000000 x15: 00006f5004b85d80
[ 7.809575] x14: 0224439cbc14c200 x13: 0000000000000001 x12: 0000000000000001
[ 7.809584] x11: 0000000000000001 x10: 00000000000009e0 x9 : ffff80000d08b810
[ 7.809592] x8 : ffff000801073500 x7 : ffff00087f706440 x6 : 0000000000000000
[ 7.809601] x5 : 0000000000220000 x4 : 0000000000000000 x3 : ffff0008014e4d88
[ 7.809609] x2 : 0000000000000000 x1 : ffff000801072ac0 x0 : ffff000801072ac0
[ 7.809620] Kernel panic - not syncing: Asynchronous SError Interrupt
[ 7.809624] CPU: 1 PID: 295 Comm: kworker/u12:7 Tainted: G C O 5.15.129-6.4.0+git.67c3153d20ff #1
[ 7.809630] Hardware name: Toradex Apalis iMX8QM V1.1 on Apalis Evaluation Board (DT)
[ 7.809634] Workqueue: events_unbound deferred_probe_work_func
[ 7.809642] Call trace:
[ 7.809644] dump_backtrace+0x0/0x1f0
[ 7.809657] show_stack+0x18/0x40
[ 7.809664] dump_stack_lvl+0x68/0x84
[ 7.809674] dump_stack+0x18/0x34
[ 7.809681] panic+0x18c/0x34c
[ 7.809686] add_taint+0x0/0xc0
[ 7.809697] arm64_serror_panic+0x6c/0x7c
[ 7.809703] do_serror+0x58/0x5c
[ 7.809707] el1h_64_error_handler+0x30/0x50
[ 7.809714] el1h_64_error+0x78/0x7c
[ 7.809720] mutex_unlock+0x44/0x70
[ 7.809727] cdns_mhdp_firmware_write_section+0x74/0xa0 [cdns_mhdp_imx]
[ 7.809742] cdns_mhdp_firmware_init_imx8qm+0xac/0x1c0 [cdns_mhdp_imx]
[ 7.809753] __cdns_hdmi_probe+0x174/0x37c [cdns_mhdp_drmcore]
[ 7.809778] cdns_hdmi_bind+0x28/0x90 [cdns_mhdp_drmcore]
[ 7.809804] cdns_mhdp_imx_bind+0xe4/0x170 [cdns_mhdp_imx]
[ 7.809815] component_bind_all+0x124/0x284
[ 7.809823] imx_drm_bind+0x15c/0x210
[ 7.809832] try_to_bring_up_master+0x228/0x314
[ 7.809838] __component_add+0xa0/0x18c
[ 7.809844] component_add+0x14/0x20
[ 7.809851] cdns_mhdp_imx_probe+0x1c/0x30 [cdns_mhdp_imx]
[ 7.809861] platform_probe+0x68/0xe0
[ 7.809869] really_probe+0xbc/0x46c
[ 7.809874] __driver_probe_device+0x104/0x160
[ 7.809880] driver_probe_device+0x40/0x120
[ 7.809886] __device_attach_driver+0xbc/0x160
[ 7.809892] bus_for_each_drv+0x7c/0xdc
[ 7.809901] __device_attach+0xac/0x1f0
[ 7.809907] device_initial_probe+0x14/0x20
[ 7.809913] bus_probe_device+0x98/0xa0
[ 7.809919] deferred_probe_work_func+0x94/0xe4
[ 7.809924] process_one_work+0x1d0/0x374
[ 7.809932] worker_thread+0x13c/0x490
[ 7.809937] kthread+0x150/0x160
[ 7.809948] ret_from_fork+0x10/0x20
[ 7.809957] SMP: stopping secondary CPUs
[ 7.813925] Kernel Offset: disabled
[ 7.813928] CPU features: 0x4,000820b1,20000846
[ 7.813933] Memory Limit: none
Ahmet
