I accidentally installed the wrong operating system on my Verdin iMX8M Plus module. Now, I need to replace it with the correct OS, but I’m unsure about the proper steps to do this. Could someone guide me on how to:
Wipe the current OS or prepare the module for a fresh installation.
Flash the correct OS onto the module.
Avoid any potential pitfalls during the process.
I’d appreciate detailed instructions or links to relevant documentation/tools. For context, I’m comfortable with Linux-based systems and have access to a host PC for flashing.
Hello!
To replace the operating system on your Verdin iMX8M Plus module, you can use the Toradex Easy Installer, which is a straightforward tool for flashing the correct OS. Here’s how you can proceed:
Prepare the Module for Installation:
Connect your Verdin iMX8M Plus module to a suitable carrier board.
Ensure you have a display connected to view the Easy Installer interface.
Power on the module. If the Toradex Easy Installer is already installed, it should boot up automatically.
Wipe the Current OS:
The Easy Installer will display a list of available OS images. If you need to wipe the current OS, you can select a new image to install, which will overwrite the existing one.
Flash the Correct OS:
If the Easy Installer is not present, you can use a USB drive or SD card to install it.
Once the Easy Installer is running, connect your host PC to the same network as the module.
Use the Easy Installer to select the correct OS image from the list or provide a custom image via a USB drive or network.
Follow the on-screen instructions to flash the OS onto the module.
Avoid Potential Pitfalls:
Ensure the power supply is stable during the flashing process to prevent corruption.
Verify the integrity of the OS image before flashing.
If using a network to provide the image, ensure the network connection is reliable.
By following these steps, you should be able to successfully replace the OS on your Verdin iMX8M Plus module. The Toradex Easy Installer simplifies the process and helps avoid common issues associated with manual flashing methods.
I tried to wipe old OS, i failed. Wheneven i power it, old os is booting up instead of Displaying Toradex easy installer. What is thr right way to factory reset/reboot/wipe old os. and i want to boot new os
