I’ve been working with the Toradex T20 NVIDIA cpu modules in combination with a fitting carrier board in order to flash the Toradex Embedded Linux BSP quite a while now.
Currently I am searching for a reliable information source to relate to whether these modules we have in approach in the production side are eMMCorNAND based Toradex modules?
Where would I correctly look for this information: bootlaoder or Linux?
This question result of my need to clone the whole system including all configuration respectively services I have applied manually to.
Which declarations of device would mean which (flash)-memory (in boot-log or sysfs)?
I would be very thankful for any constructive contribution of you
Colibri T20 512MB V1.2A
Colibri Carrier Board
Linux BSP 2.8.7
All Colibri T20 SKUs have a raw NAND flash only.
All Colibri T30 modules are equipped with eMMC storage only.
You can get a module type by reading /proc/cpuinfo
@alex.tx
Which procedure would you recommend to fully or most possible configuration clone or backup the image that is stored onto the NAND of a T20 module.
May I ask you to help me with eventually extisting article.
Or would there be a practical approach you could describe to me.
# tell to start ubi (set current partition)
ubi part ubi
# list layout
ubi info layout
# read a ubi volume
ubi read ${loadaddr} kernel
# now you can save it on a USB stick with the command
save
help save
Be aware that this loads everything into RAM first before saving it on the stick.
