Dear Toradex community,
we are currently try to enable the IC2-6 (Pins 87/99) on the Apalis iMX8QM 4GB WB IT V1.1C via the device-tree for Torizon. We have successfully used IC2-2 (Pins 209/211) with the folling modification to a device-tree:
/* I2C1_SDA/SCL on MXM3 209/211 (e.g. RTC on carrier board) */
// Touch connected to lvds2
&i2c2 {
The Problem is that the label &i2c2 does existis with our includes:
#include "imx8qm-apalis-v1.1.dtsi"
#include "imx8-apalis-eval.dtsi"
#include "pads-imx8qm.h" //include this so that you can redefine gpio pins // device-trees/include/dt-bindings/pinctrl/pads-imx8qm.h
But the label we need &i2c6 does not exists. In the file device-trees/dts-arm64/imx8mp.dtsi on line 1020 we see that there is a i2c6 configered.
We have tried to include the device-trees/dts-arm64/imx8mp.dtsi but this produece the folling errors:
torizoncore-builder dt apply imx8-apalis-sensgit-v1.1.dts --include-dir device-trees/include --include-dir device-trees/dts-arm64/ --include-dir device-trees/include/dt-bindings/pinctrl/
device-trees/dts-arm64/imx8mp.dtsi:479.23-483.7: ERROR (duplicate_label): /thermal-zones/cpu-thermal/trips/trip0: Duplicate label 'cpu_alert0' on /thermal-zones/cpu-thermal/trips/trip0 and /thermal-zones/cpu-thermal0/trips/trip0
device-trees/dts-arm64/imx8mp.dtsi:485.22-489.7: ERROR (duplicate_label): /thermal-zones/cpu-thermal/trips/trip1: Duplicate label 'cpu_crit0' on /thermal-zones/cpu-thermal/trips/trip1 and /thermal-zones/cpu-thermal0/trips/trip1
device-trees/dts-arm64/imx8mp.dtsi:205.30-208.5: ERROR (duplicate_label): /reserved-memory/dsp@92400000: Duplicate label 'dsp_reserved' on /reserved-memory/dsp@92400000 and /reserved-memory/dsp@0x92400000
device-trees/dts-arm64/imx8mp.dtsi:122.27-149.4: ERROR (duplicate_label): /opp-table: Duplicate label 'a53_opp_table' on /opp-table and /a53-opp-table
device-trees/dts-arm64/imx8mp.dtsi:151.29-155.4: ERROR (duplicate_label): /ddr_pmu@3d800000: Duplicate label 'ddr_pmu0' on /ddr_pmu@3d800000 and /bus@5c000000/ddr-pmu@5c020000
device-trees/dts-arm64/imx8mp.dtsi:163.37-171.4: ERROR (duplicate_label): /interrupt-controller@38800000: Duplicate label 'gic' on /interrupt-controller@38800000 and /interrupt-controller@51a00000
device-trees/dts-arm64/imx8mp.dtsi:530.27-533.5: ERROR (duplicate_label): /soc@0/caam-sm@100000: Duplicate label 'caam_sm' on /soc@0/caam-sm@100000 and /bus@31400000/caam-sm@31800000
device-trees/dts-arm64/imx8mp.dtsi:617.29-620.6: ERROR (duplicate_label): /soc@0/bus@30000000/pinctrl@30330000: Duplicate label 'iomuxc' on /soc@0/bus@30000000/pinctrl@30330000 and /scu/pinctrl
device-trees/dts-arm64/imx8mp.dtsi:628.26-647.6: ERROR (duplicate_label): /soc@0/bus@30000000/efuse@30350000: Duplicate label 'ocotp' on /soc@0/bus@30000000/efuse@30350000 and /scu/imx8qm-ocotp
device-trees/dts-arm64/imx8mp.dtsi:696.35-727.6: ERROR (duplicate_label): /soc@0/bus@30000000/clock-controller@30380000: Duplicate label 'clk' on /soc@0/bus@30000000/clock-controller@30380000 and /scu/clock-controller
device-trees/dts-arm64/imx8mp.dtsi:744.23-753.6: ERROR (duplicate_label): /soc@0/bus@30400000/pwm@30660000: Duplicate label 'pwm1' on /soc@0/bus@30400000/pwm@30660000 and /bus@5d000000/pwm@5d010000
device-trees/dts-arm64/imx8mp.dtsi:755.23-764.6: ERROR (duplicate_label): /soc@0/bus@30400000/pwm@30670000: Duplicate label 'pwm2' on /soc@0/bus@30400000/pwm@30670000 and /bus@5d000000/pwm@5d020000
device-trees/dts-arm64/imx8mp.dtsi:766.23-775.6: ERROR (duplicate_label): /soc@0/bus@30400000/pwm@30680000: Duplicate label 'pwm3' on /soc@0/bus@30400000/pwm@30680000 and /bus@5d000000/pwm@5d030000
device-trees/dts-arm64/imx8mp.dtsi:889.27-902.6: ERROR (duplicate_label): /soc@0/bus@30800000/can@308c0000: Duplicate label 'flexcan1' on /soc@0/bus@30800000/can@308c0000 and /bus@5a000000/can@5a8d0000
device-trees/dts-arm64/imx8mp.dtsi:904.27-917.6: ERROR (duplicate_label): /soc@0/bus@30800000/can@308d0000: Duplicate label 'flexcan2' on /soc@0/bus@30800000/can@308d0000 and /bus@5a000000/can@5a8e0000
device-trees/dts-arm64/imx8mp.dtsi:919.28-947.6: ERROR (duplicate_label): /soc@0/bus@30800000/crypto@30900000: Duplicate label 'crypto' on /soc@0/bus@30800000/crypto@30900000 and /bus@31400000/crypto@31400000
device-trees/dts-arm64/imx8mp.dtsi:942.22-946.7: ERROR (duplicate_label): /soc@0/bus@30800000/crypto@30900000/jr@3000: Duplicate label 'sec_jr2' on /soc@0/bus@30800000/crypto@30900000/jr@3000 and /bus@31400000/crypto@31400000/jr@30000
device-trees/dts-arm64/imx8mp.dtsi:949.23-957.6: ERROR (duplicate_label): /soc@0/bus@30800000/i2c@30a20000: Duplicate label 'i2c1' on /soc@0/bus@30800000/i2c@30a20000 and /bus@5a000000/i2c@5a810000
device-trees/dts-arm64/imx8mp.dtsi:959.23-967.6: ERROR (duplicate_label): /soc@0/bus@30800000/i2c@30a30000: Duplicate label 'i2c2' on /soc@0/bus@30800000/i2c@30a30000 and /bus@5a000000/i2c@5a820000
device-trees/dts-arm64/imx8mp.dtsi:969.23-977.6: ERROR (duplicate_label): /soc@0/bus@30800000/i2c@30a40000: Duplicate label 'i2c3' on /soc@0/bus@30800000/i2c@30a40000 and /bus@5a000000/i2c@5a830000
device-trees/dts-arm64/imx8mp.dtsi:979.23-987.6: ERROR (duplicate_label): /soc@0/bus@30800000/i2c@30a50000: Duplicate label 'i2c4' on /soc@0/bus@30800000/i2c@30a50000 and /bus@5a000000/i2c@5a840000
device-trees/dts-arm64/imx8mp.dtsi:1030.25-1044.6: ERROR (duplicate_label): /soc@0/bus@30800000/mmc@30b40000: Duplicate label 'usdhc1' on /soc@0/bus@30800000/mmc@30b40000 and /bus@5b000000/mmc@5b010000
device-trees/dts-arm64/imx8mp.dtsi:1046.25-1060.6: ERROR (duplicate_label): /soc@0/bus@30800000/mmc@30b50000: Duplicate label 'usdhc2' on /soc@0/bus@30800000/mmc@30b50000 and /bus@5b000000/mmc@5b020000
device-trees/dts-arm64/imx8mp.dtsi:1062.25-1076.6: ERROR (duplicate_label): /soc@0/bus@30800000/mmc@30b60000: Duplicate label 'usdhc3' on /soc@0/bus@30800000/mmc@30b60000 and /bus@5b000000/mmc@5b030000
device-trees/dts-arm64/imx8mp.dtsi:1175.24-1189.7: ERROR (duplicate_label): /soc@0/bus@30c00000/spba-bus@30c00000/sai@30c10000: Duplicate label 'sai1' on /soc@0/bus@30c00000/spba-bus@30c00000/sai@30c10000 and /bus@59000000/sai@59050000
device-trees/dts-arm64/imx8mp.dtsi:1191.24-1205.7: ERROR (duplicate_label): /soc@0/bus@30c00000/spba-bus@30c00000/sai@30c20000: Duplicate label 'sai2' on /soc@0/bus@30c00000/spba-bus@30c00000/sai@30c20000 and /bus@59000000/sai@59060000
device-trees/dts-arm64/imx8mp.dtsi:1207.24-1221.7: ERROR (duplicate_label): /soc@0/bus@30c00000/spba-bus@30c00000/sai@30c30000: Duplicate label 'sai3' on /soc@0/bus@30c00000/spba-bus@30c00000/sai@30c30000 and /bus@59000000/sai@59070000
device-trees/dts-arm64/imx8mp.dtsi:1223.24-1237.7: ERROR (duplicate_label): /soc@0/bus@30c00000/spba-bus@30c00000/sai@30c50000: Duplicate label 'sai5' on /soc@0/bus@30c00000/spba-bus@30c00000/sai@30c50000 and /bus@59000000/sai@59090000
device-trees/dts-arm64/imx8mp.dtsi:1239.24-1254.7: ERROR (duplicate_label): /soc@0/bus@30c00000/spba-bus@30c00000/sai@30c60000: Duplicate label 'sai6' on /soc@0/bus@30c00000/spba-bus@30c00000/sai@30c60000 and /bus@59000000/sai@59820000
device-trees/dts-arm64/imx8mp.dtsi:1256.24-1269.7: ERROR (duplicate_label): /soc@0/bus@30c00000/spba-bus@30c00000/sai@30c80000: Duplicate label 'sai7' on /soc@0/bus@30c00000/spba-bus@30c00000/sai@30c80000 and /bus@59000000/sai@59830000
device-trees/dts-arm64/imx8mp.dtsi:1589.37-1605.6: ERROR (duplicate_label): /soc@0/bus@32c00000/irqsteer@32fc2000: Duplicate label 'irqsteer_hdmi' on /soc@0/bus@32c00000/irqsteer@32fc2000 and /bus@56260000/irqsteer@56260000
device-trees/dts-arm64/imx8mp.dtsi:1661.24-1700.6: ERROR (duplicate_label): /soc@0/bus@32c00000/hdmi@32fd8000: Duplicate label 'hdmi' on /soc@0/bus@32c00000/hdmi@32fd8000 and /bus@56260000/hdmi@56268000
device-trees/dts-arm64/imx8mp.dtsi:1756.22-1905.6: ERROR (duplicate_label): /soc@0/bus@32c00000/camera: Duplicate label 'cameradev' on /soc@0/bus@32c00000/camera and /bus@58000000/camera
device-trees/dts-arm64/imx8mp.dtsi:1763.25-1790.7: ERROR (duplicate_label): /soc@0/bus@32c00000/camera/isi@32e00000: Duplicate label 'isi_0' on /soc@0/bus@32c00000/camera/isi@32e00000 and /bus@58000000/camera/isi@58100000
device-trees/dts-arm64/imx8mp.dtsi:1792.25-1813.7: ERROR (duplicate_label): /soc@0/bus@32c00000/camera/isi@32e02000: Duplicate label 'isi_1' on /soc@0/bus@32c00000/camera/isi@32e02000 and /bus@58000000/camera/isi@58110000
device-trees/dts-arm64/imx8mp.dtsi:1866.30-1884.7: ERROR (duplicate_label): /soc@0/bus@32c00000/camera/csi@32e40000: Duplicate label 'mipi_csi_0' on /soc@0/bus@32c00000/camera/csi@32e40000 and /bus@58000000/camera/csi@58227000
device-trees/dts-arm64/imx8mp.dtsi:1886.30-1904.7: ERROR (duplicate_label): /soc@0/bus@32c00000/camera/csi@32e50000: Duplicate label 'mipi_csi_1' on /soc@0/bus@32c00000/camera/csi@32e50000 and /bus@58000000/camera/csi@58247000
device-trees/dts-arm64/imx8mp.dtsi:1923.30-1934.4: ERROR (duplicate_label): /dma-apbh@33000000: Duplicate label 'dma_apbh' on /dma-apbh@33000000 and /bus@5b000000/dma-apbh@5b810000
device-trees/dts-arm64/imx8mp.dtsi:1936.26-1950.4: ERROR (duplicate_label): /gpmi-nand@33002000: Duplicate label 'gpmi' on /gpmi-nand@33002000 and /bus@5b000000/gpmi-nand@5b812000
device-trees/dts-arm64/imx8mp.dtsi:2203.20-2220.4: ERROR (duplicate_label): /dsp@3b6e8000: Duplicate label 'dsp' on /dsp@3b6e8000 and /bus@55000000/dsp@556e8000
ERROR: Input tree has errors, aborting (use -f to force output)
error: cannot apply imx8-apalis-sensgit-v1.1.dts.
What modifications does we have to make to use the IC2-6 (Pins 87/99)?
You can find our device-tree imx8-apalis-sensgit-v1.1.dts
Best regards
Alias-Alias
