DSI to LVDS error at boot
I am using the Verdin DSI-LVDS adapter on Verdine Development board V1.1 and have connected a 7" LVDS LCD without a touchscreen. I loaded the following overlay:
 * Copyright 2020-2022 NUPI I.I.
// Verdin DSI to LVDS Adapter with plugged in
// Capacitive Touch Display 7" LVDS orderable at Toradex.
/dts-v1/;
/plugin/;
	compatible = "toradex,verdin-imx8mm";
#include "verdin-imx8_mipi-dsi-to-sn65dsi84.dtsi"
#include "display-hx8282a11_sn65dsi84_overlay.dtsi"
&atmel_mxt_ts {
&backlight {
&gpu {
/* Verdin I2C_1 */
&i2c4 {
&lcdif {
&panel_lvds {
	panel-timing {
		 * video_pll1 is at 1039500000, take PLL1/15
		 * otherwise we don't get a picture on NXP i.MX 8M Mini
		clock-frequency = <51200000>;
, derived from your example for the 10" display. The display works correctly, but at boot, I get this error:
[    2.767713] [drm:drm_bridge_attach] *ERROR* failed to attach bridge /soc@0/bus@32c00000/mipi_dsi@32e10000 to encoder DSI-34: -517
[    2.779603] imx_sec_dsim_drv 32e10000.mipi_dsi: Failed to attach bridge: 32e10000.mipi_dsi
[    2.788014] imx_sec_dsim_drv 32e10000.mipi_dsi: failed to bind sec dsim bridge: -517
Starting version 250.5+
[    8.146481] atmel_mxt_ts 3-004a: __mxt_read_reg: i2c transfer failed (-6)
[    8.169004] atmel_mxt_ts 3-004a: mxt_bootloader_read: i2c recv failed (-6)
[    8.228942] atmel_mxt_ts 3-004a: mxt_bootloader_read: i2c recv failed (-6)
How can I resolve this?
Thank you for reaching out with your question. It seems you’re encountering some boot errors with your Verdin DSI-LVDS adapter and 7" LVDS LCD setup. Let’s address these issues step by step:
  1. DRM Bridge Attachment Error (-517):
    • This error often indicates a deferred probe, meaning a driver is waiting for a resource that isn’t yet available. Ensure all necessary drivers are included in your kernel configuration and are loading in the correct order.
    • Double-check your device tree overlay configuration. The compatible property should match your hardware, and the included overlays should be appropriate for your display and adapter.
    • Verify that all connections between the Verdin module, the DSI-LVDS adapter, and the display are secure and correct.
  2. I2C Communication Error (-6):
    • This error suggests an issue with I2C communication with the Atmel touch controller. Ensure your I2C bus configuration in the device tree is correct, with the right bus number and address.
    • Inspect the physical connections on the I2C bus to ensure there are no loose wires or incorrect connections.
    • If the touch controller is not needed, consider disabling it in the device tree to prevent these errors.
  3. General Recommendations:
    • Make sure your device tree overlay is tailored to your specific hardware setup. Since your overlay is derived from a 10" display example, ensure all parameters are suitable for your 7" display.
    • Review the datasheets and design resources for both the Verdin DSI-LVDS adapter and your specific display to confirm compatibility and correct configuration.
By following these steps, you should be able to resolve the boot errors and achieve a stable setup with your display. If you have further questions, feel free to ask.
Toradex AI Assistant
Add uboot splash screen on iMX8MM EVK with LVDS display - NXP Community.
But the LCD work fine !
Hi @VLengineering !
A general tip: when creating a topic here (or via email), pleas be sure to always share details about your setup. Things like which exact hardware (full name of the carrier board and the module) with its exact version. The same goes to the OS in use and its version.
So, could you please share the details of your setup? :slight_smile:
The tdx-info script is something we created specifically to help us to get some of this info. You can execute sudo tdx-info on your Torizon OS (reference: Getting Device Information with Tdx-Info | Toradex Developer Center).
Could you please also share the output of sudo tdx-info -dt?
So, you have your display working but you simply would like to remove the errors/failed messages? Are such messages and issue to your use case?
Hi @VLengineering !
Do you have any updates here?
Hi @drhkocher !
Could you please provide an update regarding this topic?
Was it solved on your side?
