Docker container taking too long to run application
I am working on a Yocto build for tdx-reference-multimedia-qt6-image and have containerized a Qt application for the Apalis iMX8 module. I successfully built the Docker image and pulled it onto my Toradex board. When I run the container, the application executes, but it takes almost 3 minutes for the Qt application to display. The Docker image size is 456MB, and I need to reduce both the image size and the execution time to seconds.
I am also attaching dockerfile below
`# Stage 1: Build Stage
FROM torizon/qt6-wayland:next AS build
Set environment variables
ENV DEBIAN_FRONTEND=noninteractive
Install build dependencies
RUN apt-get update && apt-get install -y
build-essential
cmake
qt6-base-dev
qt6-declarative-dev
libqt6quick6
libqt6qml6
qml6-module-qtquick
qml6-module-qtqml
qt6-wayland
qt6-tools-dev-tools
&& rm -rf /var/lib/apt/lists/*
Set the working directory
WORKDIR /app
Copy the project files
COPY . .
Configure the build with CMake
RUN cmake -S . -B build -DCMAKE_PREFIX_PATH=/usr/lib/x86_64-linux-gnu/cmake/Qt6
Build the application
RUN cmake --build build – -j$(nproc)
Stage 2: Runtime Stage
Install only the necessary runtime dependencies
libqt6quick6
libqt6qml6
qml6-module-qtquick
qml6-module-qtqml
qml6-module-qtquick-window
qml6-module-qtqml-workerscript
Copy the built application from the build stage
COPY --from=build /app/build/infotainment /usr/local/bin/infotainment
Make the binary executable
RUN chmod +x /usr/local/bin/infotainment
Set the entry point
CMD [“/usr/local/bin/infotainment”]
To address the issue of your Docker container taking too long to run the Qt application on the Apalis iMX8 module, you can consider the following optimizations:
1. Reduce Docker Image Size
Reducing the Docker image size can help in faster loading and execution. Here are some tips:
  • Minimize the number of layers: Combine multiple RUN commands into a single one.
  • Use a smaller base image: If possible, use a smaller base image that still meets your requirements.
  • Remove unnecessary files: Clean up any temporary files or caches created during the build process.
2. Optimize Dockerfile
Here is an optimized version of your Dockerfile:
# Set environment variables
# Install build dependencies
RUN apt-get update && apt-get install -y \
    build-essential \
    cmake \
    qt6-base-dev \
    qt6-declarative-dev \
    libqt6quick6 \
    libqt6qml6 \
    qml6-module-qtquick \
    qml6-module-qtqml \
    qt6-wayland \
    qt6-tools-dev-tools \
# Set the working directory
WORKDIR /app
# Copy the project files
COPY . .
# Configure the build with CMake
# Build the application
RUN cmake --build build -- -j$(nproc)
# Stage 2: Runtime Stage
# Install only the necessary runtime dependencies
    libqt6quick6 \
    libqt6qml6 \
    qml6-module-qtqml \
    qml6-module-qtquick-window \
    qml6-module-qtqml-workerscript \
# Copy the built application from the build stage
# Make the binary executable
# Set the entry point
CMD ["/usr/local/bin/infotainment"]
3. Use a Local Proxy for Package Downloads
As mentioned in the context, you can set up a local proxy to cache package downloads, which can speed up the build process. This is particularly useful if you frequently rebuild your Docker images.
4. Optimize Container Startup Time
To reduce the time it takes for the container to start and the application to display, consider the following:
  • Preload necessary libraries: Ensure that all required libraries are preloaded to avoid delays during runtime.
  • Optimize systemd services: If your application does not depend on certain services (e.g., network), you can disable them to speed up the boot process. Refer to the context on how to edit systemd services to make the boot faster.
5. Measure and Analyze Boot Time
Use systemd-analyze to measure and analyze the boot time. This can help you identify any bottlenecks in the boot process and optimize accordingly.
6. Blacklist Unnecessary Drivers
If there are any unnecessary drivers being loaded during boot, you can blacklist them to reduce boot time. Refer to the context on how to blacklist WiFi drivers to optimize boot time.
7. Use TorizonCore Builder Tool
Use the TorizonCore Builder Tool to further optimize the system for your specific needs. This tool allows you to customize and optimize TorizonCore for your application.
By applying these optimizations, you should be able to reduce both the Docker image size and the execution time of your Qt application.
Boot time for a typical QT application on IMX7 modules.
I need to optimize the container startup time. Currently, it takes 3 minutes between entering the command to start Docker and the display of the Qt application in the container. I need to reduce this time to a few seconds.
root@apalis-imx8-07239822:~# time docker run --rm -it -e XDG_RUNTIME_DIR=/run -e WAYLAND_DISPLAY=wayland-0 -v /run:/run srejivesree/automotive:automotive
QStandardPaths: wrong permissions on runtime directory /run, 0755 instead of 0700
libEGL warning: wayland-egl: could not open /dev/dri/card0 (No such file or directory)
CSV file path: “:/csv/radio.csv”
Hi @SruthiSathyan ,
Unfortunately, we have not tested container on reference-multimedia-images, If you want to use conatiner you can directly use our Torizon OS.
