Hello Gerald,
To run a DHCP server and a Python application with a Flask API in a Docker container on your Toradex Apalis module, you can follow these steps:
Docker Container Setup:
- Create a Dockerfile for your application. This should include both the DHCP server and the Python application. Use a base image that supports Python and any other necessary dependencies.
- Define the entry point in the Dockerfile to start the DHCP server first, followed by the Python application. You can achieve this by using a shell script that initiates both services in the correct order.
Autorun on Startup:
- On TorizonCore, configure your Docker container to start automatically on boot. This is done by defining the container in a Docker Compose file and using TorizonCore services to manage it.
- Ensure your Docker Compose file specifies the correct startup order if there are dependencies between services.
Debugging the Python Application:
- Use the Torizon IDE extension for Visual Studio Code or another supported IDE to manage the debugging environment for applications running in Docker containers.
- Configure the
launch.jsonfile in your IDE to set up the debugging environment. This file allows you to specify how the debugger should start your application, including any necessary command-line arguments. - Ensure the debugger is set to attach to the Python process after the DHCP server has started.
Testing and Validation:
- Test your setup by running the Docker container manually to ensure both the DHCP server and the Python application start correctly.
- Use the debugging tools in your IDE to step through the Python application and verify that it behaves as expected.
By following these steps, you can effectively manage the startup and debugging of your applications on a Toradex Apalis module using Docker and TorizonCore. This setup provides a robust development and deployment environment tailored to your needs.
Toradex AI Assistant
