I’m looking to create a project with a Colibri IMX7s running a Qt application. I’ve seen several very interesting video about boot2Qt, which seems to do everything I need.
However, there is one element I wasn’t able to find: what kind of boot time can I expect? I know a precise figure is not possible to give, but can I have an approximation? Less than 5sec? 20sec?
The approximate boottime of boot2qt is 15-20s. However, this is without optimizing anything. You can be much faster if you strip down the kernel and you boot directly into the Qt Application instead of using e.g. systemd which is used by boot2qt by default. If you invest a lot of time in optimization ~5s can be achievable.
Thanks a lot for your answer! I was hoping that it was a bit more optimized by default, since I’ve got very limited knowledge in Linux. However thanks a lot for your links as it looks like a very good place to start
Also, is there some module that are faster than other in the colibri family?
I think maybe the iMX6 boots a little bit faster (because of the faster core and because of eMMC) but in general it wont make huge differences. By optimizing the image you can gain much more.
