Greetings @i.staehli,
How do I know where the folders are located from an U-Boot point of view, as described in
I’ll address this part first since it’s straightforward. You basically would just use ext4ls mmc 2:1 to navigate the filesystem from U-Boot. As the article shows /var would correspond to /ostree/deploy/torizon/var/ in U-Boot. Though most other filesystem locations would be in /ostree/boot.1/torizon/<some hash>/0/, as I will show below.
What location should I use to store the binary using the filesystem changes?
From the sounds of it you want to store the M7 binary on the OS filesystem so that it can be updated as part of a OS update, is that correct?
If that is the case you don’t want this in /var. The /var directory is a special directory that is not tracked by OSTree, meaning it can’t be updated. This is by design to have a persistent location that is not affected by updates.
Typically the usual location for filesystem changes would be in /etc. Though this does pose another challenge. The path for /etc from U-Boot’s point of view is not so straightforward. For example on my device, from U-Boot the path would be: ostree/boot.1/torizon/aaeaee85433c423a8386667f25a9c812d2f4bd3f9e4eebc067895183f81570cf/0/etc/
The challenge here is that the hash part of the path: aaeaee85433c423a8386667f25a9c812d2f4bd3f9e4eebc067895183f81570cf
This hash changes whenever the OSTree deployment changes, which happens on every OS update. Meaning it would not be very consistent to set this path in U-Boot.
Probably a better alternative would be to use what we call “subsystem updates”. With this you can define the parameters and logic for an update. In this way you can specifically update only your specific M7 binary file without updating the rest of the OS/filesystem as well. You can even update/change directories that OSTree does not manage itself (like /var).
We actually have a webinar showing how one can use subsystem updates to manage and update M-core binaries/firmware: https://www.youtube.com/watch?v=djXt6HaI1jY
The demo in that webinar uses remoteproc, but the same principles would apply even if you aren’t using remoteproc. In theory you would just create a subsystem update that copies the new M7 binary to a known consistent location on the filesystem (i.e /var which is always /ostree/deploy/torizon/var/ from the U-Boot point of view). Then you would just need reboot the system to reload the new binary.
Furthermore, you can design whatever further logic or checks you want to occur during the update for further control. You could even designate your own rollback/failure logic if you want.
