Hello, I am working with the Colibri VF61 and the Carrier board, however I am having trouble booting the board. When i plug in the power source and press ON/OFF, the RESET OUT# LED stays on RED, regardless if I press RESET or not. When I try to plug the board into a monitor via VGA-HDMI converter, nothing shows up. When I connect board to a terminal through USB B (after setting the proper jumpers for JP17/JP19) nothing shows up in the terminal (for 9600 or 115200 baudrate). I don’t see any forums that explain what this means.
It seems like you are experiencing a boot issue with the Colibri VF61 on your carrier board, where the RESET OUT# LED remains on, and you are unable to get any output on a monitor or terminal. Here are a few steps you can take to troubleshoot this issue:
Power Supply: Ensure that the power supply is providing the correct voltage and current as required by the Colibri VF61 and the carrier board. An inadequate power supply can cause the system to not boot properly.
Connections: Double-check all connections, including the power, HDMI/VGA, and USB connections. Make sure that all cables are securely connected and that there are no loose connections.
Jumpers and Switches: Verify that all jumpers and switches on the carrier board are set correctly, especially those related to boot configuration and serial communication (JP17/JP19).
Module Seating: Ensure that the Colibri VF61 module is properly seated in the connector on the carrier board. A misaligned or loose module can cause boot issues.
Serial Console: Since you are not seeing any output on the terminal, ensure that the serial console settings are correct. The typical settings are 115200 baud rate, 8 data bits, no parity, 1 stop bit, and no flow control.
Reset and Power Cycle: Try performing a reset and power cycle. Sometimes, a simple reset or power cycle can resolve boot issues.
Check for Damage: Inspect the board and module for any visible signs of damage, such as burnt components or broken traces.
Consult Documentation: Refer to the Colibri VF61 datasheet and carrier board documentation for any specific troubleshooting steps or known issues.
If none of these steps resolve the issue, it may be helpful to contact Toradex technical support for further assistance, as they can provide more specific guidance based on your setup.
