It was expected that the imx7 V1.1D (code 0033) and V1.1A (code 0081) would be compatible in production - that is loading the same image. But there are several small differences leading to boot failure.
original working V1.1D boot
CPU: Freescale i.MX7D rev1.3 1000 MHz (running at 792 MHz)
CPU: Extended Commercial temperature grade (-20C to 105C) at 35C
Reset cause: POR
DRAM: 512 MiB
PMIC: RN5T567 LSIVER=0x01 OTPVER=0x0d
NAND: 512 MiB
MMC: FSL_SDHC: 0
Loading Environment from NAND... OK
In: serial
Out: serial
Err: serial
Model: Toradex Colibri iMX7 Dual 512MB V1.1D, Serial# 14782530
SEC0: RNG instantiated
Net: eth0: ethernet@30be0000
Booting from NAND...
ubi0: default fastmap pool size: 200
ubi0: default fastmap WL pool size: 100
ubi0: attaching mtd5
ubi0: attached by fastmap
ubi0: fastmap pool size: 200
ubi0: fastmap WL pool size: 100
ubi0: attached mtd5 (name "ubi", size 508 MiB)
ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
ubi0: good PEBs: 4056, bad PEBs: 8, corrupted PEBs: 0
ubi0: user volume: 4, internal volumes: 1, max. volumes count: 128
ubi0: max/mean erase counter: 20/8, WL threshold: 4096, image sequence number: 1851270044
ubi0: available PEBs: 0, total reserved PEBs: 4056, PEBs reserved for bad PEB handling: 72
No size specified -> Using max size (7041512)
Read 7041512 bytes from volume kernel to 81000000
No size specified -> Using max size (49766)
Read 49766 bytes from volume dtb to 82000000
Kernel image @ 0x81000000 [ 0x000000 - 0x6b71e8 ]
## Flattened Device Tree blob at 82000000
V1.1A with same image flashed from easyinstaller
CPU: Extended Commercial temperature grade (-20C to 105C) at 36C
Reset cause: POR
DRAM: 512 MiB
NAND: 512 MiB
MMC: FSL_SDHC: 0
In: serial
Out: serial
Err: serial
Model: Toradex *UNKNOWN MODULE V1.1A*, Serial# 15337877
ubi0: scanning is finished
ubi0: good PEBs: 4060, bad PEBs: 4, corrupted PEBs: 0
ubi0: *max/mean erase counter: 3/1*, WL threshold: 4096, image sequence number: 1913462415
ubi0: available PEBs: 0, total reserved PEBs: 4060, PEBs reserved for bad PEB handling: 76
No size specified -> Using *max size (7041464)*
Read 7041464 bytes from volume kernel to 81000000
Kernel image @ 0x81000000 [ 0x000000 - 0x6b71b8 ]
ERROR: Did not find a cmdline Flattened Device Tree
FDT and ATAGS support not compiled in - hanging
### ERROR ### Please RESET the board ###
========= our custom image.json ======================
"config_format": "2",
"autoinstall": false,
"name": "Toradex Embedded Linux Minimal Image BDSK",
"description": "Minimal image without graphical interface that just boots",
"version": "5.4.260",
"release_date": "2023-11-09",
"u_boot_env": "u-boot-initial-env",
"prepare_script": "prepare.sh",
"wrapup_script": "wrapup.sh",
"marketing": "marketing.tar",
"icon": "toradexlinux.png",
"license": "LA_OPT_NXP_SW.html",
"supported_product_ids": [
"0032",
"0033",
"0041",
"0081"
"mtddevs": [
"name": "u-boot1",
"content": {
"rawfile": {
"filename": "u-boot-nand.imx",
"size": 1
"name": "u-boot2",
"content": {
"rawfile": {
"size": 1
"name": "u-boot-env",
"erase": true,
"content": {}
"name": "ubi",
"ubivolumes": [
"name": "kernel",
"size_kib": 12288,
"type": "static",
"content": {
"rawfile": {
"filename": "zImage",
"size": 5
"name": "dtb",
"content": {
"rawfiles": [
"filename": "imx7d-colibri-eval-v3.dtb",
"product_ids": "0033"
"product_ids": "0041"
"size_kib": 128,
"type": "static"
"name": "m4firmware",
"size_kib": 896,
"type": "static"
"name": "rootfs",
"content": {
"filesystem_type": "ubifs",
"filename": "BDSK-rootfs.tar.gz",
"uncompressed_size": 187.8417969
