Okay I’ve connected the device via USB and logged the entire startup.
I’ve put it in here as code and enclosed it as file. Hopefully it’s the correct one
U-Boot 2016.11-2.7.5+g52259cf22a (Dec 06 2018 - 09:25:02 -0200)
CPU: Freescale i.MX7D rev1.3 996 MHz (running at 792 MHz)
CPU: Extended Commercial temperature grade (-20C to 105C) at 24C
Reset cause: POR
DRAM: 1 GiB
PMIC: RN5T567 LSIVER=0x01 OTPVER=0x0d
MMC: FSL_SDHC: 0, FSL_SDHC: 1
Video: 640x480x18
In: serial
Out: serial
Err: serial
Model: Toradex Colibri iMX7 Dual 1GB V1.1A, Serial# 03111955
Net: FEC0
Hit any key to stop autoboot: 1 0
Booting from internal eMMC chip...
reading imx7d-colibri-emmc-eval-v3.dtb
45048 bytes read in 21 ms (2 MiB/s)
reading zImage
5482968 bytes read in 180 ms (29 MiB/s)
Kernel image @ 0x81000000 [ 0x000000 - 0x53a9d8 ]
## Flattened Device Tree blob at 82000000
Booting using the fdt blob at 0x82000000
Loading Device Tree to 8fff2000, end 8ffffff7 ... OK
Starting kernel ...
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.1.44-2.7.5+g18717e2b1ca9 (oe-user@oe-host) (gcc version 6.4.0 (GCC) ) #1 SMP Wed Dec 5 12:45:23 -02 2018
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: Toradex Colibri iMX7D 1GB on Colibri Evaluation Board V3
[ 0.000000] Reserved memory: created CMA memory pool at 0xb8000000, size 128 MiB
[ 0.000000] Reserved memory: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] PERCPU: Embedded 13 pages/cpu @b777c000 s21004 r8192 d24052 u53248
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 260096
[ 0.000000] Kernel command line: ip=off root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait console=tty1 console=ttymxc0,115200n8 consoleblank=0 video=mxsfb:640x480M-16@60
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 897352K/1048576K available (6839K kernel code, 533K rwdata, 2404K rodata, 408K init, 389K bss, 20152K reserved, 131072K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xc0800000 - 0xff000000 (1000 MB)
[ 0.000000] lowmem : 0x80000000 - 0xc0000000 (1024 MB)
[ 0.000000] modules : 0x7f000000 - 0x80000000 ( 16 MB)
[ 0.000000] .text : 0x80008000 - 0x8090f0e0 (9245 kB)
[ 0.000000] .init : 0x80910000 - 0x80976000 ( 408 kB)
[ 0.000000] .data : 0x80976000 - 0x809fb728 ( 534 kB)
[ 0.000000] .bss : 0x809fe000 - 0x80a5f674 ( 390 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] Architected cp15 timer(s) running at 8.00MHz (phys).
[ 0.000000] clocksource arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 440795202120 ns
[ 0.000006] sched_clock: 56 bits at 8MHz, resolution 125ns, wraps every 2199023255500ns
[ 0.000018] Switching to timer-based delay loop, resolution 125ns
[ 0.000472] mxc_clocksource_init 3000000
[ 0.000484] Ignoring duplicate/late registration of read_current_timer delay
[ 0.000500] clocksource mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 637086815595 ns
[ 0.001768] Console: colour dummy device 80x30
[ 0.002412] console [tty1] enabled
[ 0.002439] Calibrating delay loop (skipped), value calculated using timer frequency.. 16.00 BogoMIPS (lpj=80000)
[ 0.002482] pid_max: default: 32768 minimum: 301
[ 0.002595] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.002623] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.003288] Initializing cgroup subsys freezer
[ 0.003329] Initializing cgroup subsys debug
[ 0.003383] CPU: Testing write buffer coherency: ok
[ 0.003708] Setting up static identity map for 0x80008280 - 0x800082d8
[ 0.005749] Brought up 2 CPUs
[ 0.005782] SMP: Total of 2 processors activated (32.00 BogoMIPS).
[ 0.005804] CPU: All CPU(s) started in SVC mode.
[ 0.006374] devtmpfs: initialized
[ 0.020212] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.020608] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.020668] futex hash table entries: 512 (order: 3, 32768 bytes)
[ 0.025937] pinctrl core: initialized pinctrl subsystem
[ 0.027227] NET: Registered protocol family 16
[ 0.033124] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.059957] cpuidle: using governor ladder
[ 0.089974] cpuidle: using governor menu
[ 0.103471] DDR type is DDR3!
[ 0.110688] imx7d_enet_clk_sel: failed to get enet_out clock, assuming ext. clock source
[ 0.110783] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.110819] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.111166] imx7d-pinctrl 30270000.lpsr-gpr: initialized IMX pinctrl driver
[ 0.111373] imx7d-pinctrl 302c0000.iomuxc-lpsr: initialized IMX pinctrl driver
[ 0.112690] imx7d-pinctrl 30330000.iomuxc: initialized IMX pinctrl driver
[ 0.114384] MU is ready for cross core communication!
[ 0.123996] mxs-dma 33000000.dma-apbh: initialized
[ 0.125867] VCC_USB[1-4]: supplied by 5V
[ 0.126360] SCSI subsystem initialized
[ 0.126704] usbcore: registered new interface driver usbfs
[ 0.126796] usbcore: registered new interface driver hub
[ 0.126927] usbcore: registered new device driver usb
[ 0.127191] 30800000.aips-bus:usbphy_nop1 supply vcc not found, using dummy regulator
[ 0.127504] 30800000.aips-bus:usbphy_nop2 supply vcc not found, using dummy regulator
[ 0.128574] i2c i2c-0: IMX I2C adapter registered
[ 0.128607] i2c i2c-0: can't use DMA
[ 0.129109] i2c i2c-3: IMX I2C adapter registered
[ 0.129140] i2c i2c-3: can't use DMA
[ 0.129274] Linux video capture interface: v2.00
[ 0.129348] pps_core: LinuxPPS API ver. 1 registered
[ 0.129371] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.129433] PTP clock support registered
[ 0.129984] Advanced Linux Sound Architecture Driver Initialized.
[ 0.131415] Switched to clocksource arch_sys_counter
[ 0.169575] NET: Registered protocol family 2
[ 0.170436] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.170558] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.170719] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.170802] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.170872] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.171097] NET: Registered protocol family 1
[ 0.171481] RPC: Registered named UNIX socket transport module.
[ 0.171512] RPC: Registered udp transport module.
[ 0.171533] RPC: Registered tcp transport module.
[ 0.171554] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.172875] imx rpmsg driver is registered.
[ 0.173864] Bus freq driver module loaded
[ 0.182301] VFS: Disk quotas dquot_6.6.0
[ 0.182527] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.184479] NFS: Registering the id_resolver key type
[ 0.184550] Key type id_resolver registered
[ 0.184574] Key type id_legacy registered
[ 0.184612] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.185144] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.185648] fuse init (API version 7.23)
[ 0.189552] io scheduler noop registered
[ 0.189592] io scheduler deadline registered
[ 0.189794] io scheduler cfq registered (default)
[ 0.191969] backlight supply power not found, using dummy regulator
[ 0.193967] 30730000.lcdif supply lcd not found, using dummy regulator
[ 0.194184] fbcvt: 640x480@60: CVT Name - .307M3
[ 0.259771] mxsfb 30730000.lcdif: failed to find mxc display driver
[ 0.268627] Console: switching to colour frame buffer device 80x30
[ 0.286767] mxsfb 30730000.lcdif: initialized
[ 0.289618] imx-sdma 30bd0000.sdma: no event needs to be remapped
[ 0.291478] imx-sdma 30bd0000.sdma: loaded firmware 4.2
[ 0.296445] imx-sdma 30bd0000.sdma: initialized
[ 0.299254] 30860000.serial: ttymxc0 at MMIO 0x30860000 (irq = 279, base_baud = 1500000) is a IMX
[ 1.017609] console [ttymxc0] enabled
[ 1.023773] 30890000.serial: ttymxc1 at MMIO 0x30890000 (irq = 280, base_baud = 1500000) is a IMX
[ 1.036919] 30880000.serial: ttymxc2 at MMIO 0x30880000 (irq = 281, base_baud = 5000000) is a IMX
[ 1.055623] loop: module loaded
[ 1.076103] spi_imx 30840000.ecspi: probed
[ 1.086098] pps pps0: new PPS source ptp0
[ 1.094121] libphy: fec_enet_mii_bus: probed
[ 1.101953] fec 30be0000.ethernet eth0: registered PHC device 0
[ 1.109889] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.118345] ehci-mxc: Freescale On-Chip EHCI Host driver
[ 1.125825] usbcore: registered new interface driver usb-storage
[ 1.133977] usbcore: registered new interface driver usbserial
[ 1.141794] usbcore: registered new interface driver usbserial_generic
[ 1.150230] usbserial: USB Serial support registered for generic
[ 1.158159] usbcore: registered new interface driver ftdi_sio
[ 1.165807] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 1.176804] usbcore: registered new interface driver pl2303
[ 1.184300] usbserial: USB Serial support registered for pl2303
[ 1.193332] 30b10200.usbmisc supply vbus-wakeup not found, using dummy regulator
[ 1.204780] 30b30200.usbmisc supply vbus-wakeup not found, using dummy regulator
[ 1.216281] 30b20200.usbmisc supply vbus-wakeup not found, using dummy regulator
[ 1.228375] imx_usb 30b10000.usb: Can't register ci_hdrc platform device, err=-517
[ 1.243020] ci_hdrc ci_hdrc.0: EHCI Host Controller
[ 1.249971] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
[ 1.271468] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[ 1.279977] hub 1-0:1.0: USB hub found
[ 1.285911] hub 1-0:1.0: 1 port detected
[ 1.292866] mousedev: PS/2 mouse device common for all mice
[ 1.303330] input: AD7879 Touchscreen as /devices/platform/soc/30800000.aips-bus/30a20000.i2c/i2c-0/0-002c/input/input0
[ 1.321393] rtc-ds1307 3-0068: oscillator failed, set time!
[ 1.329372] rtc-ds1307 3-0068: rtc core: registered m41t0 as rtc0
[ 1.338363] snvs_rtc 30370000.snvs:snvs-rtc-lp: rtc core: registered 30370000.snvs:snvs- as rtc1
[ 1.351683] i2c /dev entries driver
[ 1.360178] imx2-wdt 30280000.wdog: timeout 60 sec (nowayout=0)
[ 1.368652] sdhci: Secure Digital Host Controller Interface driver
[ 1.377027] sdhci: Copyright(c) Pierre Ossman
[ 1.383545] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.392228] /soc/aips-bus@30800000/usdhc@30b40000: voltage-ranges unspecified
[ 1.401579] sdhci-esdhc-imx 30b40000.usdhc: Got CD GPIO
[ 1.410663] sdhci-esdhc-imx 30b40000.usdhc: No vqmmc regulator found
[ 1.461595] mmc1: SDHCI controller on 30b40000.usdhc [30b40000.usdhc] using ADMA
[ 1.476253] /soc/aips-bus@30800000/usdhc@30b60000: voltage-ranges unspecified
[ 1.486131] sdhci-esdhc-imx 30b60000.usdhc: No vmmc regulator found
[ 1.494484] sdhci-esdhc-imx 30b60000.usdhc: No vqmmc regulator found
[ 1.541446] mmc0: SDHCI controller on 30b60000.usdhc [30b60000.usdhc] using ADMA
[ 1.559387] caam 30900000.caam: Entropy delay = 3200
[ 1.566513] caam 30900000.caam: Instantiated RNG4 SH0
[ 1.611443] usb 1-1: new high-speed USB device number 2 using ci_hdrc
[ 1.625927] caam 30900000.caam: Instantiated RNG4 SH1
[ 1.633093] caam 30900000.caam: device ID = 0x0a16030000000000 (Era -524)
[ 1.641959] caam 30900000.caam: job rings = 3, qi = 0
[ 1.649043] mmc0: MAN_BKOPS_EN bit is not set
[ 1.704631] mmc0: new HS400 MMC card at address 0001
[ 1.712181] mmcblk0: mmc0:0001 Q2J54A 3.64 GiB
[ 1.718774] mmcblk0boot0: mmc0:0001 Q2J54A partition 1 2.00 MiB
[ 1.726828] mmcblk0boot1: mmc0:0001 Q2J54A partition 2 2.00 MiB
[ 1.735909] mmcblk0: p1 p2
[ 1.756134] caam algorithms registered in /proc/crypto
[ 1.766630] caam_jr 30901000.jr0: registering rng-caam
[ 1.774500] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.782009] usbcore: registered new interface driver usbhid
[ 1.782064] hub 1-1:1.0: USB hub found
[ 1.789458] hub 1-1:1.0: 4 ports detected
[ 1.800806] usbhid: USB HID core driver
[ 1.811295] coresight-tmc 30086000.etr: TMC initialized
[ 1.819017] coresight-tmc 30084000.etf: TMC initialized
[ 1.826129] coresight-tpiu 30087000.tpiu: TPIU initialized
[ 1.833599] coresight-funnel 30083000.funnel: FUNNEL initialized
[ 1.841460] coresight-funnel 30041000.funnel: FUNNEL initialized
[ 1.849280] coresight-replicator replicator: REPLICATOR initialized
[ 1.857688] coresight-etm3x 3007c000.etm: ETM initialized
[ 1.865063] coresight-etm3x 3007d000.etm: ETM initialized
[ 1.876805] sgtl5000 0-000a: sgtl5000 revision 0x11
[ 1.919788] imx-sgtl5000 sound: sgtl5000 <-> 308a0000.sai mapping ok
[ 1.928990] Netfilter messages via NETLINK v0.30.
[ 1.935229] nfnl_acct: registering with nfnetlink.
[ 1.941519] nf_conntrack version 0.5.0 (16069 buckets, 64276 max)
[ 1.949698] nf_tables: (c) 2007-2009 Patrick McHardy <kaber@trash.net>
[ 1.958254] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.965902] NET: Registered protocol family 10
[ 1.973049] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 1.980054] NET: Registered protocol family 17
[ 1.986149] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 2.002157] Bridge firewalling registered
[ 2.007933] 8021q: 802.1Q VLAN Support v1.8
[ 2.013832] Key type dns_resolver registered
[ 2.026972] Registering SWP/SWPB emulation handler
[ 2.034491] registered taskstats version 1
[ 2.046758] ci_hdrc ci_hdrc.1: EHCI Host Controller
[ 2.053117] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 2
[ 2.091509] usb 1-1.1: new low-speed USB device number 3 using ci_hdrc
[ 2.111508] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[ 2.119224] hub 2-0:1.0: USB hub found
[ 2.124746] hub 2-0:1.0: 1 port detected
[ 2.133527] input: gpio-keys as /devices/platform/gpio-keys/input/input1
[ 2.144561] rtc-ds1307 3-0068: hctosys: unable to read the hardware clock
[ 2.188197] ALSA device list:
[ 2.192729] #0: imx7-colibri-sgtl5000
[ 2.206808] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.217994] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 2.228150] devtmpfs: mounted
[ 2.233121] Freeing unused kernel memory: 408K
[ 2.245780] input: PixArt USB Optical Mouse as /devices/platform/soc/30800000.aips-bus/30b20000.usb/ci_hdrc.0/usb1/1-1/1-1.1/1-1.1:1.0/0003:0461:4D0F.0001/input/input2
[ 2.246191] mmcblk0: retrying because a re-tune was needed
[ 2.273091] hid-generic 0003:0461:4D0F.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-ci_hdrc.0-1.1/input0
[ 2.285247] mmcblk0: error -84 transferring data, sector 1189712, nr 32, cmd response 0x900, card status 0xb00
[ 2.285256] mmcblk0: retrying using single block read
[ 2.326844] mmcblk0: retrying because a re-tune was needed
[ 2.367105] mmcblk0: error -84 transferring data, sector 1189840, nr 136, cmd response 0x900, card status 0xb00
[ 2.380682] mmcblk0: retrying using single block read
[ 2.402159] usb 1-1.2: new low-speed USB device number 4 using ci_hdrc
[ 2.430531] mmcblk0: error -84 transferring data, sector 1189912, nr 64, cmd response 0x900, card status 0x0
[ 2.443981] blk_update_request: I/O error, dev mmcblk0, sector 1189912
[ 2.485120] mmcblk0: error -84 transferring data, sector 1189920, nr 56, cmd response 0x900, card status 0x0
[ 2.498625] blk_update_request: I/O error, dev mmcblk0, sector 1189920
[ 2.549984] mmcblk0: retrying because a re-tune was needed
[ 2.582632] input: SCISSORS Keyboard as /devices/platform/soc/30800000.aips-bus/30b20000.usb/ci_hdrc.0/usb1/1-1/1-1.2/1-1.2:1.0/0003:0DC6:2013.0002/input/input3
[ 2.588861] mmcblk0: error -110 sending stop command, original cmd response 0x900, card status 0x400900
[ 2.588864] mmcblk0: retrying because a re-tune was needed
[ 2.620414] mmcblk0: error -84 transferring data, sector 1189912, nr 8, cmd response 0x900, card status 0xb00
[ 2.620421] mmcblk0: retrying using single block read
[ 2.651963] mmcblk0: error -84 transferring data, sector 1189912, nr 8, cmd response 0x900, card status 0x0
[ 2.665430] blk_update_request: I/O error, dev mmcblk0, sector 1189912
[ 2.704179] hid-generic 0003:0DC6:2013.0002: input,hidraw1: USB HID v1.00 Keyboard [ SCISSORS Keyboard] on usb-ci_hdrc.0-1.2/input0
[ 2.716237] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000007
[ 2.716237]
[ 2.719955] CPU1: stopping
[ 2.719964] CPU: 1 PID: 68 Comm: kworker/1:1 Not tainted 4.1.44-2.7.5+g18717e2b1ca9 #1
[ 2.719966] Hardware name: Freescale i.MX7 Dual (Device Tree)
[ 2.719984] Workqueue: usb_hub_wq hub_event
[ 2.720006] [<800160a0>] (unwind_backtrace) from [<80012c4c>] (show_stack+0x10/0x14)
[ 2.720017] [<80012c4c>] (show_stack) from [<80681dbc>] (dump_stack+0x84/0x98)
[ 2.720027] [<80681dbc>] (dump_stack) from [<80015418>] (handle_IPI+0x29c/0x2bc)
[ 2.720036] [<80015418>] (handle_IPI) from [<800093e4>] (gic_handle_irq+0x5c/0x60)
[ 2.720044] [<800093e4>] (gic_handle_irq) from [<80013700>] (__irq_svc+0x40/0x54)
[ 2.720048] Exception stack(0xb43b1908 to 0xb43b1950)
[ 2.720056] 1900: 00000000 00000004 000007fc 60000113 80a40218 80a00318
[ 2.720063] 1920: 00000006 00000000 80a40218 00000006 00000000 0000012e 00000000 b43b1950
[ 2.720068] 1940: 80049bdc 8006c754 60000113 ffffffff
[ 2.720079] [<80013700>] (__irq_svc) from [<8006c754>] (console_unlock+0x32c/0x4d0)
[ 2.720089] [<8006c754>] (console_unlock) from [<8006cba0>] (vprintk_emit+0x2a8/0x4dc)
[ 2.720101] [<8006cba0>] (vprintk_emit) from [<803b0074>] (dev_vprintk_emit+0xa0/0x1c0)
[ 2.720113] [<803b0074>] (dev_vprintk_emit) from [<803b01b0>] (dev_printk_emit+0x1c/0x2c)
[ 2.720123] [<803b01b0>] (dev_printk_emit) from [<803b04c4>] (__dev_printk+0x48/0x84)
[ 2.720133] [<803b04c4>] (__dev_printk) from [<803b0780>] (_dev_info+0x38/0x48)
[ 2.720143] [<803b0780>] (_dev_info) from [<804ea080>] (hid_connect+0x2d0/0x3a8)
[ 2.720153] [<804ea080>] (hid_connect) from [<804eb5f4>] (hid_device_probe+0xec/0x11c)
[ 2.720162] [<804eb5f4>] (hid_device_probe) from [<803b33cc>] (driver_probe_device+0x174/0x2a8)
[ 2.720173] [<803b33cc>] (driver_probe_device) from [<803b1b10>] (bus_for_each_drv+0x60/0x94)
[ 2.720182] [<803b1b10>] (bus_for_each_drv) from [<803b3224>] (device_attach+0x80/0x94)
[ 2.720190] [<803b3224>] (device_attach) from [<803b28e8>] (bus_probe_device+0x84/0xa8)
[ 2.720198] [<803b28e8>] (bus_probe_device) from [<803b0c0c>] (device_add+0x36c/0x568)
[ 2.720207] [<803b0c0c>] (device_add) from [<804eb25c>] (hid_add_device+0xd4/0x2b8)
[ 2.720216] [<804eb25c>] (hid_add_device) from [<804f531c>] (usbhid_probe+0x2bc/0x39c)
[ 2.720227] [<804f531c>] (usbhid_probe) from [<804380e4>] (usb_probe_interface+0xec/0x21c)
[ 2.720237] [<804380e4>] (usb_probe_interface) from [<803b33cc>] (driver_probe_device+0x174/0x2a8)
[ 2.720246] [<803b33cc>] (driver_probe_device) from [<803b1b10>] (bus_for_each_drv+0x60/0x94)
[ 2.720256] [<803b1b10>] (bus_for_each_drv) from [<803b3224>] (device_attach+0x80/0x94)
[ 2.720263] [<803b3224>] (device_attach) from [<803b28e8>] (bus_probe_device+0x84/0xa8)
[ 2.720272] [<803b28e8>] (bus_probe_device) from [<803b0c0c>] (device_add+0x36c/0x568)
[ 2.720282] [<803b0c0c>] (device_add) from [<804361f0>] (usb_set_configuration+0x4c8/0x87c)
[ 2.720293] [<804361f0>] (usb_set_configuration) from [<8043f928>] (generic_probe+0x2c/0x78)
[ 2.720302] [<8043f928>] (generic_probe) from [<803b33cc>] (driver_probe_device+0x174/0x2a8)
[ 2.720312] [<803b33cc>] (driver_probe_device) from [<803b1b10>] (bus_for_each_drv+0x60/0x94)
[ 2.720321] [<803b1b10>] (bus_for_each_drv) from [<803b3224>] (device_attach+0x80/0x94)
[ 2.720329] [<803b3224>] (device_attach) from [<803b28e8>] (bus_probe_device+0x84/0xa8)
[ 2.720338] [<803b28e8>] (bus_probe_device) from [<803b0c0c>] (device_add+0x36c/0x568)
[ 2.720348] [<803b0c0c>] (device_add) from [<8042d960>] (usb_new_device+0x200/0x51c)
[ 2.720358] [<8042d960>] (usb_new_device) from [<8042f438>] (hub_event+0xd1c/0x1074)
[ 2.720370] [<8042f438>] (hub_event) from [<8004375c>] (process_one_work+0x200/0x4f8)
[ 2.720382] [<8004375c>] (process_one_work) from [<800444b0>] (worker_thread+0x4c/0x55c)
[ 2.720392] [<800444b0>] (worker_thread) from [<80048df4>] (kthread+0xdc/0xf4)
[ 2.720403] [<80048df4>] (kthread) from [<8000f2e8>] (ret_from_fork+0x14/0x2c)
[ 3.270211] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000007
[ 3.270211][1]
