Assistance Needed: Colibri iMX6S IT Version Flashing Issue
Hello there!
We are currently flashing the Colibri iMX6 modules using the Easy Installer. The process works flawlessly for the non-IT version. However, when attempting to flash the IT version (Colibri iMX6S 256 MB IT), we encounter the following error message: “Image not compatible with this module.”
Could you please advise on the necessary steps to resolve this compatibility issue?
Thank you in advance for your support!
The error message “Image not compatible with this module” suggests that the image you are trying to flash is not suitable for the Colibri iMX6S 256 MB IT version. Here are a few steps you can take to resolve this issue:
  1. Verify Image Compatibility: Ensure that the image you are using is specifically built for the Colibri iMX6S 256 MB IT version. The IT (Industrial Temperature) version may have specific requirements or configurations that differ from the non-IT version.
  2. Check Image Source: Make sure you are downloading the image from a reliable source, such as the official Toradex website, and that it is the correct version for your module.
  3. Update Easy Installer: Ensure that you are using the latest version of the Toradex Easy Installer. Sometimes, updates to the installer can resolve compatibility issues.
  4. Consult Documentation: Review the documentation and release notes for the image you are trying to flash. There may be specific instructions or known issues related to the IT version.
  5. Contact Support: If the above steps do not resolve the issue, consider reaching out to Toradex technical support for further assistance. They may have additional insights or solutions for your specific situation.
By following these steps, you should be able to address the compatibility issue and successfully flash the IT version of the Colibri iMX6S module.
Colibri iMX6 file system issue with flash.
Please fully specify your Colibri iMX6 module (you can scan the QR code on the label attached to the module and share the resulting 16 digits here). Also, provide details about the image you are trying to flash."
From the data matrix (QR code), the Product Identification (PID) for the board we are having issues flashing is: 00781100.
The board that successfully flashed has a PID of: 00141100.
The full data matrix values are:
  • 0078110011391429 (problematic board)
  • 0014110010833355 (successfully flashed board)
We are attempting to flash the following image (zip file contains all necessary files except the large .tar files that include the actual image):
Colibri-iMX6_Console-Image-Tezi_3.0b4-20210903.zip (307.7 KB)
Hi @raff
The problem here is that the newer Colibri iMX6 (2024 version, without WinCE) have a new product identification, that didn’t exists at the time of this image release (2021), so it was not included under the “compatibles modules list”. But there should not be any real incompatibility between the 2 modules.
I manually included the new modules product ID in the wrapup.sh and image.json files and, hopefully, it should work.
Colibri-iMX6_Console-Image-Tezi_3.0b4-20210903.zip (308.9 KB)
This issue is already solved on the latest images.
