Yocto Build for python3-playsound Completes Successfully but Only Outputs Logs
I’m working on building a custom Yocto recipe for python3-playsound (version 1.2.2) on a Cortex-A72/Cortex-A53 target. The build completes successfully without any errors, but the only outputs I get are log files—no actual files from the package are showing up in the final output directories.
here’s the recipe:
LICENSE = "MIT"
LIC_FILES_CHKSUM = "file://playsound-1.2.2.dist-info/METADATA;md5=942cdc91f8f53ffd960367b0ba0e652c"
SRC_URI = "https://files.pythonhosted.org/packages/f5/16/10d897b0a83fb4b05b03a63d7a2667ab75f857f67f7062fd447dd3f49bf7/playsound-1.2.2-py2.py3-none-any.whl;downloadfilename=playsound-${PV}-py2.py3-none-any.zip;subdir=python3-playsound-1.2.2"
SRC_URI[sha256sum] =  "1e83750a5325cbccee03d6e751ba3e78c037ac95b95a3ba1f38d0c5aca9e1a34"
SRC_URI[md5sum] = "30f7763f7ec70f351b0767eb71e289f3"
inherit python3-dir
do_unpack[depends] += "unzip-native:do_populate_sysroot"
DEPENDS += "python3"
do_install() {
    install -d ${D}${bindir}
    install -m 644 ${S}/playsound.py ${D}${bindir}/
Based on the context provided, the issue with your Yocto recipe for python3-playsound seems to be related to the do_install function, where the playsound.py file is not being installed correctly. Here are some steps you can take to resolve the issue:
  1. Verify File Existence: After the do_unpack step, check the directory structure to ensure that playsound.py exists at the expected path ${S}/playsound.py. If the file is not present, the installation will fail silently.
  2. Correct File Path: The source file path ${S}/playsound.py might be incorrect. Since you are dealing with a wheel file, the structure might be different. You may need to extract the wheel file manually to verify the correct path to playsound.py.
  3. Modify do_install: If playsound.py is not directly available, you might need to adjust the do_install function to correctly reference the file’s location. This could involve navigating into subdirectories created by the wheel extraction.
  4. Check Logs for Errors: Review the log files generated during the build process for any warnings or errors that might indicate why the files are not being installed.
  5. Review Package Structure: Ensure that the package structure conforms to the expected layout for Python packages. If the wheel file contains additional directories or files, you may need to adjust the recipe to handle these appropriately.
By following these steps, you should be able to identify and resolve the issue with the missing package files in your Yocto build.
Recipe editing/modification in Yocto build system.
rania@rania:~/pixii_os/pixii_os/build/tmp/work/cortexa72-cortexa53-tdx-linux/python3-playsound/1.2.2-r0$ ls
configure.sstate python3-playsound-1.2.2 source-date-epoch
image recipe-sysroot temp
pseudo recipe-sysroot-native
rania@rania:~/pixii_os/pixii_os/build/tmp/work/cortexa72-cortexa53-tdx-linux/python3-playsound/1.2.2-r0$ cd image/usr/bin/ && ls
rania@rania:~/pixii_os/pixii_os/build/tmp/work/cortexa72-cortexa53-tdx-linux/python3-playsound/1.2.2-r0/image/usr/bin$
things got better but still have nothing under usr/bin
do_install() {
    install -m 644 ${WORKDIR}/playsound.py ${D}${bindir}/
this is the extracted folder
rania@rania:~/Downloads/playsound-1.2.2-py2.py3-none-any$ tree
├── playsound-1.2.2.dist-info
│   ├── DESCRIPTION.rst
│   ├── METADATA
│   ├── metadata.json
│   ├── RECORD
│   ├── top_level.txt
│   └── WHEEL
└── playsound.py
here’s log file:
rania@rania:~$ cat /home/rania/pixii_os/pixii_os/build/tmp/work/cortexa72-cortexa53-tdx-linux/python3-playsound/1.2.2-r0/temp/log.do_install.335873
DEBUG: Executing python function extend_recipe_sysroot
NOTE: Direct dependencies are ['/home/rania/pixii_os/pixii_os/build/../layers/openembedded-core/meta/recipes-core/glibc/glibc_2.35.bb:do_populate_sysroot', '/home/rania/pixii_os/pixii_os/build/../layers/openembedded-core/meta/recipes-devtools/gcc/gcc-cross_11.4.bb:do_populate_sysroot', '/home/rania/pixii_os/pixii_os/build/../layers/openembedded-core/meta/recipes-devtools/gcc/gcc-runtime_11.4.bb:do_populate_sysroot', '/home/rania/pixii_os/pixii_os/build/../layers/openembedded-core/meta/recipes-devtools/python/python3_3.10.14.bb:do_populate_sysroot', '/home/rania/pixii_os/pixii_os/build/../layers/openembedded-core/meta/recipes-devtools/quilt/quilt-native_0.67.bb:do_populate_sysroot', 'virtual:native:/home/rania/pixii_os/pixii_os/build/../layers/openembedded-core/meta/recipes-devtools/patch/patch_2.7.6.bb:do_populate_sysroot', 'virtual:native:/home/rania/pixii_os/pixii_os/build/../layers/openembedded-core/meta/recipes-devtools/pseudo/pseudo_git.bb:do_populate_sysroot', 'virtual:native:/home/rania/pixii_os/pixii_os/build/../layers/openembedded-core/meta/recipes-extended/unzip/unzip_6.0.bb:do_populate_sysroot']
NOTE: Installed into sysroot: []
NOTE: Skipping as already exists in sysroot: ['glibc', 'gcc-cross-aarch64', 'gcc-runtime', 'python3', 'quilt-native', 'patch-native', 'pseudo-native', 'unzip-native', 'libtool-native', 'attr-native', 'linux-libc-headers', 'libgcc', 'opkg-utils', 'xz', 'libnsl2', 'libffi', 'bzip2', 'util-linux-libuuid', 'readline', 'sqlite3', 'ncurses', 'gdbm', 'openssl', 'zlib', 'libtirpc', 'libxcrypt', 'texinfo-dummy-native', 'gmp-native', 'flex-native', 'zstd-native', 'gnu-config-native', 'mpfr-native', 'binutils-cross-aarch64', 'zlib-native', 'xz-native', 'libmpc-native', 'gettext-minimal-native', 'm4-native']
DEBUG: Python function extend_recipe_sysroot finished
DEBUG: Executing shell function do_install
install: cannot stat '/home/rania/pixii_os/pixii_os/build/tmp/work/cortexa72-cortexa53-tdx-linux/python3-playsound/1.2.2-r0/playsound.py': No such file or directory
Hi @rania !
If I am not wrong, the do_unpack unpacks to the ${WORKDIR} and not on the ${S}. Have you tried ${WORKDIR} instead of ${S}?
yes that’s what i did i worked with {WORKDIR} instead here’s the updated recipe :
LICENSE = "MIT"
inherit python3-dir
FILES:${PN} += "/usr/lib/python3.10/site-packages/playsound.py"
do_install() {
    install -d ${D}${PYTHON_SITEPACKAGES_DIR}
    install -m 644 ${WORKDIR}/python3-playsound-1.2.2/playsound.py ${D}${PYTHON_SITEPACKAGES_DIR}/
