I’m using the Verdin imx8mm dl 1GB WB IT V1.1B.
The Dahlia is the V1.1C.
I’m running a custom image that I made from TorizonCore Builder Tool guide. It’s based on the TorizonCore image without evaluation containers and I’m running a docker container at boot that has python and alsa and some other things installed.
How do I enter U-boot console with the Dahlia board? The U-boot page only talks about the Verdin, Apalis and Iris boards.
When I enter aplay -L i get:
null
Discard all samples (playback) or generate zero samples (capture)
hw:CARD=imx8mmnau8822,DEV=0
imx8mm-nau8822,
Direct hardware device without any conversions
plughw:CARD=imx8mmnau8822,DEV=0
imx8mm-nau8822,
Hardware device with all software conversions
default:CARD=imx8mmnau8822
imx8mm-nau8822,
Default Audio Device
sysdefault:CARD=imx8mmnau8822
imx8mm-nau8822,
dmix:CARD=imx8mmnau8822,DEV=0
imx8mm-nau8822,
Direct sample mixing device
cat /proc/asound/cards gives me:
0 [imx8mmnau8822 ]: imx8mm-nau8822 - imx8mm-nau8822
imx8mm-nau8822
But when I try amixer set “Capture” cap i get:
amixer: Unable to find simple control ‘Capture’,0
When i list the amixer controls with amixer scontrols i get this:
Simple mixer control ‘Headphone’,0
Simple mixer control ‘Headphone ZC’,0
Simple mixer control ‘Speaker’,0
Simple mixer control ‘Speaker RInversion’,0
Simple mixer control ‘Speaker ZC’,0
Simple mixer control ‘PCM’,0
Simple mixer control ‘Aux Boost’,0
Simple mixer control ‘ADC’,0
Simple mixer control ‘ADC 128x Oversampling’,0
Simple mixer control ‘ADC Companding’,0
Simple mixer control ‘ADC Inversion’,0
Simple mixer control ‘ALC Attack’,0
Simple mixer control ‘ALC Decay’,0
Simple mixer control ‘ALC Enable’,0
Simple mixer control ‘ALC Hold’,0
Simple mixer control ‘ALC Max Gain’,0
Simple mixer control ‘ALC Min Gain’,0
Simple mixer control ‘ALC Mode’,0
Simple mixer control ‘ALC Noise Gate’,0
Simple mixer control ‘ALC Noise Gate Threshold’,0
Simple mixer control ‘ALC Target’,0
Simple mixer control ‘AUX1 Output Mixer LDAC’,0
Simple mixer control ‘AUX1 Output Mixer LMIX’,0
Simple mixer control ‘AUX1 Output Mixer RDAC’,0
Simple mixer control ‘AUX1 Output Mixer RINMIX’,0
Simple mixer control ‘AUX1 Output Mixer RMIX’,0
Simple mixer control ‘AUX2 Output Mixer AUX1MIX Output’,0
Simple mixer control ‘AUX2 Output Mixer LDAC’,0
Simple mixer control ‘AUX2 Output Mixer LINMIX’,0
Simple mixer control ‘AUX2 Output Mixer LMIX’,0
Simple mixer control ‘AUXOUT’,0
Simple mixer control ‘DAC 128x Oversampling’,0
Simple mixer control ‘DAC Companding’,0
Simple mixer control ‘DAC Inversion’,0
Simple mixer control ‘DAC Limiter’,0
Simple mixer control ‘DAC Limiter Attack’,0
Simple mixer control ‘DAC Limiter Decay’,0
Simple mixer control ‘DAC Limiter Threshold’,0
Simple mixer control ‘Digital Loopback’,0
Simple mixer control ‘EQ Function’,0
Simple mixer control ‘High Pass Cut Off’,0
Simple mixer control ‘High Pass Filter’,0
Simple mixer control ‘L2/R2 Boost’,0
Simple mixer control ‘Left Input Mixer L2’,0
Simple mixer control ‘Left Input Mixer MicN’,0
Simple mixer control ‘Left Input Mixer MicP’,0
Simple mixer control ‘Left Output Mixer LAUX’,0
Simple mixer control ‘Left Output Mixer LDAC’,0
Simple mixer control ‘Left Output Mixer LINMIX’,0
Simple mixer control ‘Left Output Mixer RDAC’,0
Simple mixer control ‘PGA’,0
Simple mixer control ‘PGA Boost’,0
Simple mixer control ‘PGA ZC’,0
Simple mixer control ‘Right Input Mixer MicN’,0
Simple mixer control ‘Right Input Mixer MicP’,0
Simple mixer control ‘Right Input Mixer R2’,0
Simple mixer control ‘Right Output Mixer LDAC’,0
Simple mixer control ‘Right Output Mixer RAUX’,0
Simple mixer control ‘Right Output Mixer RDAC’,0
Simple mixer control ‘Right Output Mixer RINMIX’,0
Should the aplay and arecord commands work with headphones connected to the 3,5mm jack on the Dahlia board?
Pontus
