I try to set up a display using LVDS.
Therefore, I changed the device tree to adapt the timing and to disable the other framebuffers, so that only LVDS should be used. I have cleared the vidargs variable to use the device tree settings.
“fbset” displays the correct frequency of 33.3 MHZ, as set in the device tree.
If I measure the LVDS clock, it is only 25.1 MHZ and the output of “cat /sys/kernel/debug/clk/clk_summary” shows that the ldb clock is set to 25.1 MHZ as measured with an oscilloscope.
Do you have any idea why the ldb clock is not set to 33.3 MHZ or do I miss something?
You can find the device tree file in the attachment.
Thanks in advance
fbset:
mode "800x480-58"
# D: 33.300 MHz, H: 30.948 kHz, V: 57.847 Hz
geometry 800 480 800 480 32
timings 30030 46 210 23 22 20 10
accel false
rgba 8/16,8/8,8/0,8/24
endmode
cat /sys/kernel/debug/clk/clk_summary:
clock enable_cnt prepare_cnt rate accuracy phase
ds3231_clk_32khz 0 0 32768 0 0
ds3231_clk_sqw 0 0 8192 0 0
anaclk2 0 0 0 0 0
lvds2_in 0 0 0 0 0
anaclk1 0 0 0 0 0
lvds1_in 0 0 0 0 0
dummy 3 4 0 0 0
lvds2_sel 0 0 0 0 0
lvds2_gate 0 0 0 0 0
lvds1_sel 0 0 0 0 0
lvds1_gate 0 0 0 0 0
usbphy2_gate 1 1 0 0 0
usbphy1_gate 1 1 0 0 0
osc 6 6 24000000 0 0
cko2_sel 1 1 24000000 0 0
cko2_podf 1 1 24000000 0 0
cko2 1 1 24000000 0 0
cko 1 1 24000000 0 0
periph_clk2_sel 0 0 24000000 0 0
periph_clk2 0 0 24000000 0 0
gpt_3m 1 1 3000000 0 0
pll7 1 1 480000000 0 0
pll7_bypass 1 1 480000000 0 0
pll7_usb_host 1 1 480000000 0 0
usbphy2 1 1 480000000 0 0
pll6 1 1 500000000 0 0
pll6_bypass 1 1 500000000 0 0
pll6_enet 1 1 500000000 0 0
enet_ref 1 1 125000000 0 0
pcie_ref 0 0 125000000 0 0
pcie_ref_125m 0 0 125000000 0 0
sata_ref 0 0 100000000 0 0
sata_ref_100m 0 0 100000000 0 0
pll5 0 0 296600000 0 0
pll5_bypass 0 0 296600000 0 0
pll5_video 0 0 296600000 0 0
pll5_post_div 0 0 74150000 0 0
pll5_video_div 0 0 74150000 0 0
ipu2_di1_pre_sel 0 0 74150000 0 0
ipu2_di1_pre 0 0 24716667 0 0
ipu2_di1_sel 0 0 24716667 0 0
ipu2_di1 0 0 24716667 0 0
ipu2_di0_pre_sel 0 0 74150000 0 0
ipu2_di0_pre 0 0 24716667 0 0
ipu2_di0_sel 0 0 24716667 0 0
ipu2_di0 0 0 24716667 0 0
ipu1_di1_pre_sel 0 0 74150000 0 0
ipu1_di1_pre 0 0 24716667 0 0
ipu1_di1_sel 0 0 24716667 0 0
ipu1_di1 0 0 24716667 0 0
ipu1_di0_pre_sel 0 0 74150000 0 0
ipu1_di0_pre 0 0 24716667 0 0
pll4 0 0 147456000 0 0
pll4_bypass 0 0 147456000 0 0
pll4_audio 0 0 147456000 0 0
pll4_post_div 0 0 36864000 0 0
pll4_audio_div 0 0 36864000 0 0
pll3 1 1 480000000 0 0
pll3_bypass 1 1 480000000 0 0
pll3_usb_otg 2 2 480000000 0 0
gpu2d_core_sel 0 0 480000000 0 0
gpu2d_core_podf 0 0 480000000 0 0
gpu2d_core 0 0 480000000 0 0
asrc_sel 0 0 480000000 0 0
asrc_pred 0 0 240000000 0 0
asrc_podf 0 0 30000000 0 0
asrc 0 0 30000000 0 0
esai_sel 0 0 480000000 0 0
esai_pred 0 0 240000000 0 0
esai_podf 0 0 30000000 0 0
esai_extal 0 0 30000000 0 0
periph2_clk2_sel 0 0 480000000 0 0
periph2_clk2 0 0 480000000 0 0
pll3_60m 0 0 60000000 0 0
can_root 0 0 30000000 0 0
can2_serial 0 0 30000000 0 0
can1_serial 0 0 30000000 0 0
ecspi_root 0 0 60000000 0 0
ecspi5 0 0 60000000 0 0
ecspi4 0 0 60000000 0 0
ecspi3 0 0 60000000 0 0
ecspi2 0 0 60000000 0 0
ecspi1 0 0 60000000 0 0
pll3_80m 1 1 80000000 0 0
uart_serial_podf 1 1 80000000 0 0
uart_serial 1 2 80000000 0 0
pll3_120m 0 0 120000000 0 0
pll3_pfd3_454m 0 0 454736842 0 0
spdif_sel 0 0 454736842 0 0
spdif_pred 0 0 227368421 0 0
spdif_podf 0 0 28421053 0 0
spdif 0 0 28421053 0 0
pll3_pfd2_508m 0 0 508235294 0 0
ssi3_sel 0 0 508235294 0 0
ssi3_pred 0 0 127058824 0 0
ssi3_podf 0 0 63529412 0 0
ssi3 0 0 63529412 0 0
ssi2_sel 0 0 508235294 0 0
ssi2_pred 0 0 127058824 0 0
ssi2_podf 0 0 63529412 0 0
ssi2 0 0 63529412 0 0
ssi1_sel 0 0 508235294 0 0
ssi1_pred 0 0 127058824 0 0
ssi1_podf 0 0 63529412 0 0
ssi1 0 0 63529412 0 0
pll3_pfd1_540m 0 0 540000000 0 0
video_27m 0 0 27000000 0 0
mipi_core_cfg 0 0 27000000 0 0
hdmi_isfr 0 0 27000000 0 0
pll3_pfd0_720m 0 0 720000000 0 0
usbphy1 0 0 480000000 0 0
pll2 1 1 528000000 0 0
pll2_bypass 1 1 528000000 0 0
pll2_bus 3 3 528000000 0 0
periph2_pre 1 1 528000000 0 0
periph2 1 1 528000000 0 0
mmdc_ch1_axi_podf 1 1 176000000 0 0
mmdc_ch1_axi 1 1 176000000 0 0
ldb_di0_sel 1 1 176000000 0 0
ldb_di0_div_7 0 0 25142857 0 0
ldb_di0_div_sel 0 0 25142857 0 0
ldb_di0_div_3_5 1 1 50285714 0 0
ldb_di0_podf 1 1 25142857 0 0
ldb_di0 1 1 25142857 0 0
ipu1_di0_sel 1 1 25142857 0 0
ipu1_di0 1 1 25142857 0 0
ipu1_pclk0_sel 1 1 25142857 0 0
ipu1_pclk0_div 1 1 25142857 0 0
ipu1_pclk0 1 1 25142857 0 0
ldb_di1_sel 0 0 176000000 0 0
ldb_di1_div_7 0 0 25142857 0 0
ldb_di1_div_sel 0 0 25142857 0 0
ldb_di1_div_3_5 0 0 50285714 0 0
ldb_di1_podf 0 0 25142857 0 0
ldb_di1 0 0 25142857 0 0
periph_pre 1 1 528000000 0 0
periph 3 3 528000000 0 0
ahb 6 6 132000000 0 0
sdma 4 2 132000000 0 0
sata 0 0 132000000 0 0
rom 1 1 132000000 0 0
ocram 2 2 132000000 0 0
hdmi_iahb 0 0 132000000 0 0
esai_mem 0 0 132000000 0 0
esai_ipg 0 0 132000000 0 0
caam_aclk 1 1 132000000 0 0
caam_mem 1 1 132000000 0 0
asrc_mem 0 0 132000000 0 0
asrc_ipg 0 0 132000000 0 0
cko1_sel 0 0 132000000 0 0
cko1_podf 0 0 16500000 0 0
cko1 0 0 16500000 0 0
ipg 6 7 66000000 0 0
usboh3 1 1 66000000 0 0
uart_ipg 1 2 66000000 0 0
ssi3_ipg 0 0 66000000 0 0
ssi2_ipg 0 0 66000000 0 0
ssi1_ipg 0 1 66000000 0 0
spdif_gclk 0 0 66000000 0 0
spba 0 0 66000000 0 0
mipi_ipg 0 0 66000000 0 0
iim 0 0 66000000 0 0
gpt_ipg 1 1 66000000 0 0
enet 2 2 66000000 0 0
can2_ipg 0 0 66000000 0 0
can1_ipg 0 0 66000000 0 0
caam_ipg 1 1 66000000 0 0
ipg_per 1 1 66000000 0 0
pwm4 1 1 66000000 0 0
pwm3 0 0 66000000 0 0
pwm2 0 0 66000000 0 0
pwm1 0 0 66000000 0 0
i2c3 0 0 66000000 0 0
i2c2 0 0 66000000 0 0
i2c1 0 0 66000000 0 0
gpt_ipg_per 0 0 66000000 0 0
mmdc_ch0_axi_podf 1 1 528000000 0 0
mmdc_ch0_axi 2 3 528000000 0 0
gpu3d_core_sel 0 0 528000000 0 0
gpu3d_core_podf 0 0 528000000 0 0
gpu3d_core 0 0 528000000 0 0
ipu1_sel 1 1 528000000 0 0
ipu1_podf 1 1 264000000 0 0
ipu1 1 1 264000000 0 0
ipu1_pclk1_sel 0 0 264000000 0 0
ipu1_pclk1_div 0 0 0 0 0
ipu1_pclk1 0 0 0 0 0
dcic1 0 0 264000000 0 0
ipu2_sel 0 1 528000000 0 0
ipu2_podf 0 1 264000000 0 0
ipu2 0 1 264000000 0 0
ipu2_pclk1_sel 0 0 264000000 0 0
ipu2_pclk1_div 0 0 0 0 0
ipu2_pclk1 0 0 0 0 0
ipu2_pclk0_sel 0 0 264000000 0 0
ipu2_pclk0_div 0 0 0 0 0
ipu2_pclk0 0 0 0 0 0
dcic2 0 0 264000000 0 0
axi_sel 1 1 528000000 0 0
axi 2 2 264000000 0 0
openvg_axi 0 0 264000000 0 0
mlb 0 0 264000000 0 0
gpu2d_axi 0 0 264000000 0 0
gpu3d_axi 0 0 264000000 0 0
pcie_axi_sel 0 0 264000000 0 0
pcie_axi 0 0 264000000 0 0
eim_slow_sel 1 1 264000000 0 0
eim_slow_podf 1 1 132000000 0 0
eim_slow 1 1 132000000 0 0
vdo_axi_sel 0 0 264000000 0 0
vdo_axi 0 0 264000000 0 0
vdoa 0 0 264000000 0 0
vpu_axi_sel 0 0 264000000 0 0
vpu_axi_podf 0 0 264000000 0 0
vpu_axi 0 0 264000000 0 0
pll2_pfd2_396m 1 1 396000000 0 0
enfc_sel 0 0 396000000 0 0
enfc_pred 0 0 79200000 0 0
enfc_podf 0 0 19800000 0 0
enfc 0 0 19800000 0 0
gpmi_io 0 0 19800000 0 0
eim_sel 0 0 396000000 0 0
eim_podf 0 0 198000000 0 0
usdhc4_sel 0 0 396000000 0 0
usdhc4_podf 0 0 198000000 0 0
usdhc4 0 0 198000000 0 0
gpmi_bch 0 0 198000000 0 0
usdhc3_sel 0 0 396000000 0 0
usdhc3_podf 0 0 198000000 0 0
usdhc3 0 0 198000000 0 0
apbh_dma 0 0 198000000 0 0
per1_bch 0 0 198000000 0 0
gpmi_bch_apb 0 0 198000000 0 0
gpmi_apb 0 0 198000000 0 0
usdhc2_sel 0 0 396000000 0 0
usdhc2_podf 0 0 198000000 0 0
usdhc2 0 0 198000000 0 0
usdhc1_sel 0 0 396000000 0 0
usdhc1_podf 0 0 198000000 0 0
usdhc1 0 0 198000000 0 0
hsi_tx_sel 0 0 396000000 0 0
hsi_tx_podf 0 0 198000000 0 0
hsi_tx 0 0 198000000 0 0
axi_alt_sel 0 0 396000000 0 0
step 1 1 396000000 0 0
pll1_sw 1 1 396000000 0 0
arm 2 2 396000000 0 0
twd 1 1 198000000 0 0
pll2_198m 0 0 198000000 0 0
pll2_pfd1_594m 0 0 594000000 0 0
gpu3d_shader_sel 0 0 594000000 0 0
gpu3d_shader 0 0 594000000 0 0
pll2_pfd0_352m 0 0 352000000 0 0
pll1 0 0 996000000 0 0
pll7_bypass_src 0 0 24000000 0 0
pll6_bypass_src 0 0 24000000 0 0
pll5_bypass_src 0 0 24000000 0 0
pll4_bypass_src 0 0 24000000 0 0
pll3_bypass_src 0 0 24000000 0 0
pll2_bypass_src 0 0 24000000 0 0
pll1_bypass_src 0 0 24000000 0 0
pll1_bypass 0 0 24000000 0 0
pll1_sys 0 0 24000000 0 0
ckih1 0 0 0 0 0
ckil 0 0 32768 0 0
