When we plug in the stick it’s recognized correctly as shown with “dmesg”:
[ 2699.072328] usb 2-1: new high-speed USB device number 4 using tegra-ehci
[ 2699.232956] usb 2-1: New USB device found, idVendor=148f, idProduct=5370
[ 2699.241870] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2699.249667] usb 2-1: Product: 802.11 n WLAN
[ 2699.254245] usb 2-1: Manufacturer: Ralink
[ 2699.258505] usb 2-1: SerialNumber: 1.0
We then tried the following command:
root@apalis-tk1:~# connmanctl enable wifi
Error wifi: Method "SetProperty" with signature "sv" on interface "net.connman.Technology" doesn't exist
We also updated the drivers with “opkg update” and “opkg --force-depends install linux-firmware”.
The same also happened when we tried another different stick ( TL-WN823N-v3 rtl8192cu ).
Are we missing a step? Thanks for any help or suggestions!
As dmesg output states, you have Ralink card, not Realtek. Vid - pid pair just confirms it. Pid 5370 tells that most likely you have Ralink RT5370 card. You need to compile kernel and drivers with support for RT53XX enabled. Once applying defconfig for your Apalis, make menuconfig, then look into Device Drivers → Network device support → Wireless LAN → Ralink driver support. Enable rt27xx/rt28xx/rt30xx and then as well enable “Include support for rt53xx”.
Prior to digging into Connman you should check if card is visible from ifconfig -a. Sometimes card is recognised and available to system but Connman requires a bit more from card driver.
[ 4581.180876] usb 2-1: USB disconnect, device number 2
[ 4586.767565] usb 2-1: new high-speed USB device number 3 using tegra-ehci
[ 4586.912804] usb 2-1: New USB device found, idVendor=2357, idProduct=0109
[ 4586.921328] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4586.929412] usb 2-1: Product: 802.11n NIC
[ 4586.934576] usb 2-1: Manufacturer: Realtek
[ 4586.940294] usb 2-1: SerialNumber: 00e04c000001
This one also doesn’t show via ifconfig -a.
We want to avoid having to compile again therefore we tried using a card that is already supported.
Looking at Apalis TK1 default kernel config it seems this card is as well not enabled by default, though drivers for both rtl8192cu and RT53XX are present in kernel tree. You need to get kernel sources, enable those drivers, make kernel+drivers and populate them to target.
Hi Edward,
is there any USB Wifi adapter that would work out of the box? The LM816 USB WiFi in the Toradex shop is not recommended for Embedded Linux. Is there any alternative?
we tried again with the mentioned chipset and it looks very similar:
root@apalis-tk1:~# dmesg
[ 63.900479] usb 2-1: new high-speed USB device number 2 using tegra-ehci
[ 64.052633] usb 2-1: New USB device found, idVendor=148f, idProduct=5572
[ 64.060761] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 64.068400] usb 2-1: Product: 802.11 n WLAN
[ 64.072998] usb 2-1: Manufacturer: Ralink
[ 64.077518] usb 2-1: SerialNumber: 1.0
With ifconfig -a we get the following:
root@apalis-tk1:~# ifconfig -a
can0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
UP RUNNING NOARP MTU:16 Metric:1
RX packets:3 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:10
RX bytes:3 (3.0 B) TX bytes:0 (0.0 B)
can1 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
RX packets:9 errors:0 dropped:0 overruns:0 frame:0
TX packets:8 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:65 (65.0 B) TX bytes:64 (64.0 B)
dummy0 Link encap:Ethernet HWaddr B6:A0:33:19:AF:FB
BROADCAST NOARP MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
collisions:0 txqueuelen:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
enp1s0 Link encap:Ethernet HWaddr 00:14:2D:63:0A:87
inet addr:192.168.106.53 Bcast:192.168.106.255 Mask:255.255.255.0
inet6 addr: fe80::214:2dff:fe63:a87%lo/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:149 errors:0 dropped:0 overruns:0 frame:0
TX packets:335 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:14525 (14.1 KiB) TX bytes:104834 (102.3 KiB)
ip6tnl0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
NOARP MTU:1452 Metric:1
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1%1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:10 errors:0 dropped:0 overruns:0 frame:0
TX packets:10 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:725 (725.0 B) TX bytes:725 (725.0 B)
rmnetctl Link encap:UNSPEC HWaddr 00-00-00-00-31-34-00-32-00-00-00-00-00-00-00-00
rndis0 Link encap:Ethernet HWaddr 6E:2E:8F:2E:50:8B
UP BROADCAST MULTICAST MTU:1500 Metric:1
The entry rmnetctl only appears with ifconfig -a not with ifconfig.
With lsusb we get the following:
root@apalis-tk1:~# lsusb
Bus 001 Device 005: ID 222a:0001
Bus 001 Device 004: ID 046d:c31c Logitech, Inc. Keyboard K120
Bus 001 Device 003: ID 17ef:6019 Lenovo
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 002: ID 148f:5572 Ralink Technology, Corp. RT5572 Wireless Adapter
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
But when we want to enable the wifi we still get an error from connman:
I don’t know what exactly you want to do with rmnetctl but it has definitely nothing to do with any of your Wi-Fi stuff. So please just deploy whatever proper driver for the exact USB Wi-Fi device you now want to use and connman will pick it up.
