First boot
u-boot:
Verdin iMX8MP # printenv fdtfile
fdtfile=imx8mp-verdin-nonwifi-dev.dtb
Verdin iMX8MP # setenv fdtfile imx8mp-verdin-wifi-dahlia.dtb
fdtfile=imx8mp-verdin-wifi-dahlia.dtb
Verdin iMX8MP # saveenv
Saving Environment to MMC... Writing to MMC(2)... OK
Verdin iMX8MP # boot
Boot sequence:
MMC: no card present
switch to partitions #0, OK
mmc2(part 0) is current device
Scanning mmc 2:1...
Found U-Boot script /boot.scr
5754 bytes read in 8 ms (702.1 KiB/s)
## Executing script at 47000000
Loading DeviceTree: imx8mp-verdin-wifi-dahlia.dtb
Reference image (minimal):
root@verdin-imx8mp-07251034:~# fw_printenv | grep "fdtfile="
root@verdin-imx8mp-07251034:~# reboot
Second boot - did not enter u-boot
Boot sequence:
U-Boot SPL 2020.04-5.7.0+git.33bb8e968332 (Jul 06 2022 - 12:21:53 +0000)
DDRINFO: start DRAM init
DDRINFO: DRAM rate 4000MTS
Training FAILED
Quad die, dual rank failed, attempting dual die, single rank configuration.
DDRINFO:ddrphy calibration done
DDRINFO: ddrmix config done
Normal Boot
Trying to boot from BOOTROM
Find FIT header 0x4803a600, size 969
Need continue download 1024
Download 840704, total fit 842160
NOTICE: BL31: v2.2(release):toradex_imx_5.4.70_2.3.0-g2fa8c6349e
NOTICE: BL31: Built : 12:30:42, May 17 2022
U-Boot 2020.04-5.7.0+git.33bb8e968332 (Jul 06 2022 - 12:21:53 +0000)
CPU: i.MX8MP[8] rev1.1 1600 MHz (running at 1200 MHz)
CPU: Industrial temperature grade (-40C to 105C) at 35C
Reset cause: POR
DRAM: 4 GiB
MMC: FSL_SDHC: 1, FSL_SDHC: 2
In: serial
Out: serial
Err: serial
Model: Toradex Verdin iMX8M Plus Quad 4GB IT V1.1A, Serial# 07251034
Carrier: Toradex Dahlia V1.1C, Serial# 10985475
BuildInfo:
- ATF 2fa8c63
- U-Boot 2020.04-5.7.0+git.33bb8e968332
flash target is MMC:2
Net: eth1: ethernet@30be0000, eth0: ethernet@30bf0000 [PRIME]
Fastboot: Normal
Normal Boot
Scanning mmc 2:1...
Loading DeviceTree: imx8mp-verdin-nonwifi-dev.dtb
arch=arm
baudrate=115200
board=verdin-imx8mp
board_name=verdin-imx8mp
boot_a_script=load ${devtype} ${devnum}:${distro_bootpart} ${scriptaddr} ${prefix}${script}; source ${scriptaddr}
boot_efi_binary=if fdt addr ${fdt_addr_r}; then bootefi bootmgr ${fdt_addr_r};else bootefi bootmgr ${fdtcontroladdr};fi;load ${devtype} ${devnum}:${distro_bootpart} ${kernel_addr_r} efi/boot/bootaa64.efi; if fdt addr ${fdt_addr_r}; then bootefi ${kernel_addr_r} ${fdt_addr_r};else bootefi ${kernel_addr_r} ${fdtcontroladdr};fi
boot_extlinux=sysboot ${devtype} ${devnum}:${distro_bootpart} any ${scriptaddr} ${prefix}${boot_syslinux_conf}
boot_file=Image
boot_net_usb_start=usb start
boot_prefixes=/ /boot/
boot_script_dhcp=boot.scr
boot_scripts=boot.scr
boot_syslinux_conf=extlinux/extlinux.conf
boot_targets=mmc1 mmc2 usb0 dhcp
bootcmd=run distro_bootcmd
bootcmd_dhcp=setenv devtype dhcp; run boot_net_usb_start; if dhcp ${scriptaddr} ${boot_script_dhcp}; then source ${scriptaddr}; fi;setenv efi_fdtfile ${fdtfile}; setenv efi_old_vci ${bootp_vci};setenv efi_old_arch ${bootp_arch};setenv bootp_vci PXEClient:Arch:00011:UNDI:003000;setenv bootp_arch 0xb;if dhcp ${kernel_addr_r}; then tftpboot ${fdt_addr_r} dtb/${efi_fdtfile};if fdt addr ${fdt_addr_r}; then bootefi ${kernel_addr_r} ${fdt_addr_r}; else bootefi ${kernel_addr_r} ${fdtcontroladdr};fi;fi;setenv bootp_vci ${efi_old_vci};setenv bootp_arch ${efi_old_arch};setenv efi_fdtfile;setenv efi_old_arch;setenv efi_old_vci;
bootcmd_mfg=fastboot 0
bootcmd_mmc1=devnum=1; run mmc_boot
bootcmd_mmc2=devnum=2; run mmc_boot
bootcmd_usb0=devnum=0; run usb_boot
bootcount=1
bootdelay=1
carrier_serial#=10985475
console=ttymxc2
cpu=armv8
distro_bootcmd=for target in ${boot_targets}; do run bootcmd_${target}; done
efi_dtb_prefixes=/ /dtb/ /dtb/current/
eth1addr=00:14:2d:7e:a4:5a
ethact=ethernet@30bf0000
ethaddr=00:14:2d:6e:a4:5a
ethprime=eth0
fastboot_dev=mmc2
fdt_addr_r=0x44000000
fdt_board=dev
fdtcontroladdr=fdbf7400
initrd_addr=0x43800000
initrd_high=0xffffffffffffffff
ipaddr=192.168.10.2
kernel_addr_r=0x40000000
load_efi_dtb=load ${devtype} ${devnum}:${distro_bootpart} ${fdt_addr_r} ${prefix}${efi_fdtfile}
loadaddr=0x44500000
mmc_boot=if mmc dev ${devnum}; then devtype=mmc; run scan_dev_for_boot_part; fi
netmask=255.255.255.0
preboot=setenv fdtfile imx8mp-verdin-${variant}-${fdt_board}.dtb
ramdisk_addr_r=0x47400000
rootpath=/srv/nfs
scan_dev_for_boot=echo Scanning ${devtype} ${devnum}:${distro_bootpart}...; for prefix in ${boot_prefixes}; do run scan_dev_for_extlinux; run scan_dev_for_scripts; done;run scan_dev_for_efi;
scan_dev_for_boot_part=part list ${devtype} ${devnum} -bootable devplist; env exists devplist || setenv devplist 1; for distro_bootpart in ${devplist}; do if fstype ${devtype} ${devnum}:${distro_bootpart} bootfstype; then run scan_dev_for_boot; fi; done; setenv devplist
scan_dev_for_efi=setenv efi_fdtfile ${fdtfile}; for prefix in ${efi_dtb_prefixes}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${efi_fdtfile}; then run load_efi_dtb; fi;done;if test -e ${devtype} ${devnum}:${distro_bootpart} efi/boot/bootaa64.efi; then echo Found EFI removable media binary efi/boot/bootaa64.efi; run boot_efi_binary; echo EFI LOAD FAILED: continuing...; fi; setenv efi_fdtfile
scan_dev_for_extlinux=if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${boot_syslinux_conf}; then echo Found ${prefix}${boot_syslinux_conf}; run boot_extlinux; echo SCRIPT FAILED: continuing...; fi
scan_dev_for_scripts=for script in ${boot_scripts}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${script}; then echo Found U-Boot script ${prefix}${script}; run boot_a_script; echo SCRIPT FAILED: continuing...; fi; done
scriptaddr=0x47000000
serial#=07251034
serverip=192.168.10.1
setup=setenv setupargs console=tty1 console=${console},${baudrate} consoleblank=0 earlycon
soc=imx8m
soc_type=imx8mp
update_uboot=askenv confirm Did you load imx-boot (y/N)?; if test "$confirm" = "y"; then setexpr blkcnt ${filesize} + 0x1ff && setexpr blkcnt ${blkcnt} / 0x200; mmc dev 2 1; mmc write ${loadaddr} 0x0 ${blkcnt}; fi
usb_boot=usb start; if usb dev ${devnum}; then devtype=usb; run scan_dev_for_boot_part; fi
variant=nonwifi
vendor=toradex
Third boot
U-boot:
arch=arm
baudrate=115200
board=verdin-imx8mp
boot_file=Image
bootcount=1
bootdelay=1
console=ttymxc2
cpu=armv8
ethprime=eth0
fastboot_dev=mmc2
fdt_board=dev
ipaddr=192.168.10.2
loadaddr=0x44500000
rootpath=/srv/nfs
serial#=07251034
soc=imx8m
soc_type=imx8mp
variant=nonwifi
vendor=toradex
Environment size: 4261/8188 bytes
Boot sequence:
Scanning mmc 2:1...
arch=arm
baudrate=115200
board=verdin-imx8mp
boot_file=Image
bootcount=1
bootdelay=1
console=ttymxc2
cpu=armv8
ethprime=eth0
fastboot_dev=mmc2
fdt_board=dev
ipaddr=192.168.10.2
loadaddr=0x44500000
rootpath=/srv/nfs
serial#=07251034
soc=imx8m
soc_type=imx8mp
variant=nonwifi
vendor=toradex
root@verdin-imx8mp-07251034:~# ip addr
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,DYNAMIC,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether 00:14:2d:6e:a4:5a brd ff:ff:ff:ff:ff:ff
inet 192.168.1.117/24 brd 192.168.1.255 scope global eth0
inet6 fd2d:261d:f1fa:4f46:214:2dff:fe6e:a45a/64 scope global dynamic mngtmpaddr
valid_lft 1776sec preferred_lft 281sec
inet6 2404:4402:17dc:bc00:214:2dff:fe6e:a45a/64 scope global dynamic mngtmpaddr
valid_lft 599sec preferred_lft 599sec
inet6 fe80::214:2dff:fe6e:a45a/64 scope link
3: can0: <NOARP,ECHO> mtu 16 qdisc noop state DOWN group default qlen 10
link/can
4: can1: <NOARP,ECHO> mtu 16 qdisc noop state DOWN group default qlen 10
link/can
root@verdin-imx8mp-07251034:~# ifconfig -a
can0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
NOARP MTU:16 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:10
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:31
can1 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
Interrupt:32
eth0 Link encap:Ethernet HWaddr 00:14:2D:6E:A4:5A
inet addr:192.168.1.117 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fd2d:261d:f1fa:4f46:214:2dff:fe6e:a45a/64 Scope:Global
inet6 addr: 2404:4402:17dc:bc00:214:2dff:fe6e:a45a/64 Scope:Global
inet6 addr: fe80::214:2dff:fe6e:a45a/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:652 errors:0 dropped:0 overruns:0 frame:0
TX packets:117 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:189920 (185.4 KiB) TX bytes:14609 (14.2 KiB)
Interrupt:47
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:84 errors:0 dropped:0 overruns:0 frame:0
TX packets:84 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:6452 (6.3 KiB) TX bytes:6452 (6.3 KiB)
root@verdin-imx8mp-07251034:~# connmanctl
connmanctl> enable wifi
Error wifi: Method "SetProperty" with signature "sv" on interface "net.connman.Technology" doesn't exist
As you can see, there appears to be a disconnect between what is reported in u-boot (imx8mp-verdin-nonwifi-dev.dtb) and during the boot sequence, and what is being reported inside the OS (imx8mp-verdin-wifi-dahlia.dtb).
