As part of EMC testing, I need to set the Wi-Fi module into a continuous transmission mode at maximum signal strength. I understand that this functionality is typically enabled through specific test mode commands or software. My module is Verdin iMX8M Plus Quad 4GB Wi-Fi / Bluetooth IT ( AW-CM276NF - Azurewave)
To configure your Verdin iMX8M Plus module’s Wi-Fi (AW-CM276NF) for continuous transmission at maximum signal strength, which is essential for EMC testing, you will need to follow specific procedures. This setup is crucial for assessing the device’s electromagnetic compatibility under maximum load conditions.
Here are some steps to guide you:
Consult the Documentation: Start by reviewing the technical documentation or user manual for the AW-CM276NF module. This will provide the necessary commands or software settings to activate continuous transmission mode. The documentation is vital as the required commands can vary depending on the firmware and software environment.
Adjust Configuration Settings: Ensure that the module is configured correctly to avoid interference during testing. This may involve setting parameters such as transmission power and frequency to achieve maximum signal strength. You might need to access the module’s configuration interface or use specific software tools designed for this purpose.
Prepare the Testing Environment: Set up the testing environment to evaluate the device’s performance under the specified conditions, including maximum signal strength. This setup is crucial for obtaining accurate and reliable testing results.
By following these guidelines and consulting the appropriate documentation, you can configure your module for successful EMC testing.
If you have any further questions or need additional assistance, feel free to ask.
