I’m working to configure the devicetree for our custom Verdin carrierboard (for Verdin IMX8MP) , and I noticed something weird for the USB_2_OC# verdin module pin.
Looking at the USB_1_OC# pin (the overcurrent detection pin for the first USB port, SODIMM 157), I see that it has hardware support for this function. From the Verdin iMX8M Plus V1.1 Datasheet:
However, the USB_2_OC# pin (SODIMM pin 187) does not have this function, so it can only be used as a GPIO to do overcurrent detection. At the same time, SODIMM pin 91 (IMX ball GPIO1_IO15/B5) does have the USB2_OTG_OC alt function, but is used as a regular GPIO (looking at the default pin mux function, bold in the above image).
I suspect that pin 91 / GPIO1_IO15 (named CSI_1_MCLK in the verdin family spec) might be needed for the MCLK pin function (provided by the CCM_CLKO2 alt function?) and that this is a compromise because of pin muxing limitations?
So I have a few questions:
Is pin muxing limitations the only reason why this routing was chosen? Or is there another limitation to consider?
Given that we do not need CSI MCLK and are not intending to be compatible across the entire verdin family, would there be any problems if we would connect our USB OC signal to pin 91 and configure the DT pinmux accordingly?
If we would keep the current assignment, is there an example of the devicetree configuration needed to connect the pin 187 GPIO to the usb controller as overcurrent detection? All the Toradex carrierboards I looked at (devboard, dahlia, mallow) have an USB hub on USB2, so they do OC detection on the hub downstream ports only.
Answer:
Let’s address your questions one by one:
Pin muxing limitations:
Yes, pin muxing limitations are a significant reason for the current routing. The i.MX8M Plus SoC has a limited number of pins, and many of them are multiplexed to support multiple functions. The design choices for the Verdin iMX8M Plus module aim to balance the needs of various interfaces and functions. In this case, the USB_2_OC# pin (SODIMM pin 187) is configured as a GPIO because the USB2_OTG_OC function is not available on this pin. Instead, the USB2_OTG_OC function is available on SODIMM pin 91 (GPIO1_IO15), which is also used for the CSI_1_MCLK function. This decision likely reflects a compromise to support the most critical functions across the entire Verdin family.
Using pin 91 for USB OC signal:
If you do not need the CSI MCLK function and are not concerned about maintaining compatibility across the entire Verdin family, you can indeed connect your USB OC signal to pin 91 (GPIO1_IO15) and configure the device tree pinmux accordingly. This should work as long as you ensure that the pinmux settings in the device tree correctly reflect this change. You would need to modify the device tree to set the pin function to USB2_OTG_OC instead of its default GPIO function.
Device tree configuration for pin 187 GPIO as overcurrent detection:
If you decide to keep the current assignment and use pin 187 (USB_2_OC#) as a GPIO for overcurrent detection, you will need to configure the device tree to link this GPIO to the USB controller. Here is an example of how you might configure this in the device tree:
&usbotg2 {
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_usbotg2>;
dr_mode = "host";
vbus-supply = <®_usb_vbus>;
oc-gpios = <&gpio1 15 GPIO_ACTIVE_LOW>; // Assuming GPIO1_IO15 is used for OC detection
&iomuxc {
pinctrl_usbotg2: usbotg2grp {
fsl,pins = <
MX8MP_IOMUXC
As for the DT suggestion from the bot, that seems to be totally off - Looking through the kernel documentation and sources, I can see there is an oc-gpio or oc-gpios attribute, but only for a few specific USB drivers (ohcid-da88xx, at91). Looking through the code for the imx8mp USB driver (which is a bit spread around because there is the dwc3 core, the usb core and the phy), I cannot find any code to handle GPIO overcurrent detection (but maybe there is some generic usb core code that handles this?). I also could not really find where the OC condition is handled if it occurs (drivers/usb/dwc3/dwc3-imx8mp.c sets the OC pin polarity, but does not seem to handle the actual condition, but maybe this also happens in a generic usb hci driver).
Also, the &usbotg2 node referenced does not exist in the imx8mp DT (it does seem to exist for the imx6/7 devicetrees, though).
In the Verdin iMX8M Plus V1.0 modules, pins 91 and 187 were swapped in the SoM.
This was changed in V1.1 in order to make the CSI MCLK function available.
As you do not need the CSI MCLK and you are only targeting the Verdin iMX8M Plus, you can use pin 91 as one of its alternate function without issues.
The following device tree snippet should contain the needed changes:
It is unclear to me if such use case would be possible.
The OC signal is just a regular input, but the driver has no explicit use of GPIOs so that is why I am uncertain.
You could test this with USB1 on an existing board, by changing pinctrl_usb_1_oc_n:
Your suggestion would, AFAICS, only set up the pin mux to turn the USB_1_OC pin into a GPIO. Without anything else, this would prevent the usb controller from detecting an overcurrent condition and needing some userspace code to read the pin and handle overcurrent conditions. Is that what you are suggesting?
Ok, that is what I suspected (assuming you meant 187 and not 197). But if Linux does not support a GPIO OC pin, then this seems like an unfortunate choice to me, since this now means that people should choose between CSI MCLK or USB2 OC, and also that the pin labeled “USB_2_OC” (which is an “Always compatible” pin in the Verdin family spec) is not actually usable as such?
Will this be at least documented in the verdin datasheet and carrier board design guide?
Thanks, as it looks I suspect that this might be our best route forward, but we’ll have to do a bit more testing on our current revision (if we can get a patch wire onto the SODIMM connector on pin 91 to test…).
This suggestion is intended to test if the overcurrent signal can work as a GPIO.
And this appears to be the case.
Using the X34 port on the Verdin Development Board, with the original device tree or with a device tree with the MX8MP_IOMUXC_GPIO1_IO13__GPIO1_IO13, the board correctly detected an overcurrent condition.
However, upon further testing, this did not translate to the ability to use any other GPIO as the OC pin.
Therefore, only the assigned pins can be used as the OC pins for USB.
This however is not as big of a limitation as it may seem.
The overcurrent detection and protection can be implemented in the carrier board, as it is in our reference designs.
Even without the OC pin connected, the USB controller can detect an overcurrent condition by monitoring the VBUS when USB_ID indicates a device is connected.
You can test this with the X34 USB port on the Verdin Development Board.
Thanks for the correction, I will update my previous post with the correct pin number.
I will also bring this up with the team that maintains this document, as labeling these as “Always Compatible” can cause some confusion given that not all SoCs actually support an OC pin for the USB controller.
