Host PC: WSL on Windows 11. 16GB RAM.
It seems that I can run 8 tasks at a time when building, and twice I had to restart the build. First time, it shut down on me. Second time, it was hung for at least an hour. I wish I took record of which task it was.
I would then force close (CTRL+C), do rm bitbake.lock in the build folder, and rerun the build again as bitbake tdx-reference-multimedia-image
I’m still building, but the number of tasks are ahead now. It was at 5000 ish, now it’s at 5300 range (total is 8672). Unfortunately, it seems that there is one task that hangs which I think is dependent on other tasks and then there’s another task that is dependent on another task, which is probably why my build just stays hung.
Any suggestions?
Also - what happens if there’s an ERROR: task failed with exit code '1'? Does running bitbake again fix this?
Edit: Running for the third time, almost at 5400 tasks, but it’s been 20 minutes so far. Attached is what the screen looks like.
2024-02-09-build-hung.txt (3.6 KB)
