Hi Daniel, how are you?
Daniel, I tried anything and everything and it didn’t work.
Look at the answer I get:
weston-touch-calibrator /devices/platform/soc@0/soc@0:bus@32c00000/32e50000.usb/ci_hdrc.1/usb1/1-1/1-1.2/1-1.2.1/1-1.2.1:1.0/0003:062A:4C01.0001/input/input3/event3
could not load cursor 'dnd-move'
could not load cursor 'dnd-copy'
could not load cursor 'dnd-none'
weston-touch-calibrator error: "/devices/platform/soc@0/soc@0:bus@32c00000/32e50000.usb/ci_hdrc.1/usb1/1-1/1-1.2/1-1.2.1/1-1.2.1:1.0/0003:062A:4C01.0001/input/input3/event3" was not found.
Here is the requested dmesg log:
root@verdin-imx8mm-06827388:~# dmesg
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 5.4.161-39953-g0f0011824921 (novitech@novitech-VirtualBox) (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #1 SMP PREEMPT Fri Apr 1 13:12:12 -03 2022
[ 0.000000] Machine model: Toradex Verdin iMX8M Mini on Verdin Development Board
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] cma: Reserved 256 MiB at 0x000000006c000000
[ 0.000000] earlycon: ec_imx6q0 at MMIO 0x0000000030860000 (options '')
[ 0.000000] printk: bootconsole [ec_imx6q0] enabled
[ 0.000000] NUMA: No NUMA configuration found
[ 0.000000] NUMA: Faking a node at [mem 0x0000000040000000-0x000000007fffffff]
[ 0.000000] NUMA: NODE_DATA [mem 0x7fdc0500-0x7fdc1fff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA32 [mem 0x0000000040000000-0x000000007fffffff]
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000040000000-0x000000007fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000007fffffff]
[ 0.000000] On node 0 totalpages: 262144
[ 0.000000] DMA32 zone: 4096 pages used for memmap
[ 0.000000] DMA32 zone: 0 pages reserved
[ 0.000000] DMA32 zone: 262144 pages, LIFO batch:63
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 24 pages/cpu s58904 r8192 d31208 u98304
[ 0.000000] pcpu-alloc: s58904 r8192 d31208 u98304 alloc=24*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: detected: ARM erratum 845719
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 258048
[ 0.000000] Policy zone: DMA32
[ 0.000000] Kernel command line: root=PARTUUID=1c372956-02 ro rootwait console=ttymxc0,115200 console=tty1 consoleblank=0 earlycon
[ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 739524K/1048576K available (14460K kernel code, 1254K rwdata, 6652K rodata, 2944K init, 1014K bss, 46908K reserved, 262144K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 128 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: no VLPI support, no direct LPI support
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000038880000
[ 0.000000] ITS: No ITS available, not enabling LPIs
[ 0.000000] random: get_random_bytes called from start_kernel+0x2b8/0x43c with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 8.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 440795202120 ns
[ 0.000003] sched_clock: 56 bits at 8MHz, resolution 125ns, wraps every 2199023255500ns
[ 0.008443] Console: colour dummy device 80x25
[ 0.012520] printk: console [tty1] enabled
[ 0.016629] printk: bootconsole [ec_imx6q0] disabled
[ 0.021678] Calibrating delay loop (skipped), value calculated using timer frequency.. 16.00 BogoMIPS (lpj=32000)
[ 0.021704] pid_max: default: 32768 minimum: 301
[ 0.021776] LSM: Security Framework initializing
[ 0.021831] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
[ 0.021854] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
[ 0.022964] ASID allocator initialised with 32768 entries
[ 0.023046] rcu: Hierarchical SRCU implementation.
[ 0.025794] EFI services will not be available.
[ 0.025977] smp: Bringing up secondary CPUs ...
[ 0.026361] Detected VIPT I-cache on CPU1
[ 0.026383] GICv3: CPU1: found redistributor 1 region 0:0x00000000388a0000
[ 0.026414] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.026492] smp: Brought up 1 node, 2 CPUs
[ 0.026535] SMP: Total of 2 processors activated.
[ 0.026550] CPU features: detected: 32-bit EL0 Support
[ 0.026566] CPU features: detected: CRC32 instructions
[ 0.032305] CPU: All CPU(s) started at EL2
[ 0.032330] alternatives: patching kernel code
[ 0.033413] devtmpfs: initialized
[ 0.040893] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.040936] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.047322] pinctrl core: initialized pinctrl subsystem
[ 0.047799] DMI not present or invalid.
[ 0.048054] NET: Registered protocol family 16
[ 0.054556] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.054607] audit: initializing netlink subsys (disabled)
[ 0.054874] audit: type=2000 audit(0.048:1): state=initialized audit_enabled=0 res=1
[ 0.055407] cpuidle: using governor menu
[ 0.056048] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.056967] Serial: AMBA PL011 UART driver
[ 0.057027] imx mu driver is registered.
[ 0.057058] imx rpmsg driver is registered.
[ 0.061744] imx8mm-pinctrl 30330000.pinctrl: initialized IMX pinctrl driver
[ 0.082798] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.082828] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.082845] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.082861] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.083798] cryptd: max_cpu_qlen set to 1000
[ 0.086803] ACPI: Interpreter disabled.
[ 0.088360] iommu: Default domain type: Translated
[ 0.088492] vgaarb: loaded
[ 0.088770] SCSI subsystem initialized
[ 0.088897] libata version 3.00 loaded.
[ 0.089081] usbcore: registered new interface driver usbfs
[ 0.089127] usbcore: registered new interface driver hub
[ 0.089163] usbcore: registered new device driver usb
[ 0.090693] mc: Linux media interface: v0.10
[ 0.090737] videodev: Linux video capture interface: v2.00
[ 0.090816] pps_core: LinuxPPS API ver. 1 registered
[ 0.090830] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.090862] PTP clock support registered
[ 0.091007] EDAC MC: Ver: 3.0.0
[ 0.091840] No BMan portals available!
[ 0.092071] QMan: Allocated lookup table at (____ptrval____), entry count 65537
[ 0.092401] No QMan portals available!
[ 0.092885] No USDPAA memory, no 'fsl,usdpaa-mem' in device-tree
[ 0.093213] FPGA manager framework
[ 0.093310] Advanced Linux Sound Architecture Driver Initialized.
[ 0.094419] clocksource: Switched to clocksource arch_sys_counter
[ 0.094571] VFS: Disk quotas dquot_6.6.0
[ 0.094628] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.094817] pnp: PnP ACPI: disabled
[ 0.100262] thermal_sys: Registered thermal governor 'step_wise'
[ 0.100266] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.100598] NET: Registered protocol family 2
[ 0.100716] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.101218] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes, linear)
[ 0.101255] TCP established hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.101327] TCP bind hash table entries: 8192 (order: 5, 131072 bytes, linear)
[ 0.101457] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.101532] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.101569] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.101688] NET: Registered protocol family 1
[ 0.102002] RPC: Registered named UNIX socket transport module.
[ 0.102021] RPC: Registered udp transport module.
[ 0.102035] RPC: Registered tcp transport module.
[ 0.102049] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.102069] PCI: CLS 0 bytes, default 64
[ 0.102764] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.103153] kvm [1]: IPA Size Limit: 40 bits
[ 0.103756] kvm [1]: GICv3: no GICV resource entry
[ 0.103770] kvm [1]: disabling GICv2 emulation
[ 0.103797] kvm [1]: GIC system register CPU interface enabled
[ 0.103842] kvm [1]: vgic interrupt IRQ1
[ 0.103919] kvm [1]: Hyp mode initialized successfully
[ 0.106662] Initialise system trusted keyrings
[ 0.106784] workingset: timestamp_bits=44 max_order=18 bucket_order=0
[ 0.112535] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.113181] NFS: Registering the id_resolver key type
[ 0.113215] Key type id_resolver registered
[ 0.113228] Key type id_legacy registered
[ 0.113247] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.113264] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.113296] jffs2: version 2.2. (NAND) \xc2\xa9 2001-2006 Red Hat, Inc.
[ 0.126893] Key type asymmetric registered
[ 0.126912] Asymmetric key parser 'x509' registered
[ 0.126956] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 0.126976] io scheduler mq-deadline registered
[ 0.126991] io scheduler kyber registered
[ 0.130806] EINJ: ACPI disabled.
[ 0.136989] mxs-dma 33000000.dma-controller: initialized
[ 0.137606] Bus freq driver module loaded
[ 0.142398] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.144474] 30860000.serial: ttymxc0 at MMIO 0x30860000 (irq = 35, base_baud = 1500000) is a IMX
[ 1.052767] printk: console [ttymxc0] enabled
[ 1.057654] 30880000.serial: ttymxc2 at MMIO 0x30880000 (irq = 36, base_baud = 1500000) is a IMX
[ 1.066893] 30890000.serial: ttymxc1 at MMIO 0x30890000 (irq = 37, base_baud = 1500000) is a IMX
[ 1.081721] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.088375] [drm] No driver support for vblank timestamp query.
[ 1.094400] imx-drm soc@0:bus@32c00000:display-subsystem: bound imx-lcdif-crtc.0 (ops lcdif_crtc_ops)
[ 1.103708] imx_sec_dsim_drv 32e10000.mipi_dsi: failed to get blk_ctl
[ 1.110304] imx_sec_dsim_drv 32e10000.mipi_dsi: version number is 0x1060200
[ 1.117335] imx_sec_dsim_drv 32e10000.mipi_dsi: Failed to attach bridge: 32e10000.mipi_dsi
[ 1.125626] imx_sec_dsim_drv 32e10000.mipi_dsi: failed to bind sec dsim bridge: -517, retry 0
[ 1.143518] brd: module loaded
[ 1.151580] loop: module loaded
[ 1.155122] zram: Added device: zram0
[ 1.163572] libphy: Fixed MDIO Bus: probed
[ 1.167962] tun: Universal TUN/TAP device driver, 1.6
[ 1.174233] Freescale FM module, FMD API version 21.1.0
[ 1.179764] Freescale FM Ports module
[ 1.184106] VFIO - User Level meta-driver version: 0.3
[ 1.190789] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.197362] ehci-pci: EHCI PCI platform driver
[ 1.202278] usbcore: registered new interface driver usb-storage
[ 1.208373] usbcore: registered new interface driver usbserial_generic
[ 1.214939] usbserial: USB Serial support registered for generic
[ 1.220991] usbcore: registered new interface driver cp210x
[ 1.226596] usbserial: USB Serial support registered for cp210x
[ 1.232554] usbcore: registered new interface driver ftdi_sio
[ 1.238336] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 1.245687] usbcore: registered new interface driver pl2303
[ 1.251290] usbserial: USB Serial support registered for pl2303
[ 1.257253] usbcore: registered new interface driver usb_serial_simple
[ 1.263814] usbserial: USB Serial support registered for carelink
[ 1.269942] usbserial: USB Serial support registered for zio
[ 1.275634] usbserial: USB Serial support registered for funsoft
[ 1.281670] usbserial: USB Serial support registered for flashloader
[ 1.288058] usbserial: USB Serial support registered for google
[ 1.294009] usbserial: USB Serial support registered for libtransistor
[ 1.300573] usbserial: USB Serial support registered for vivopay
[ 1.306615] usbserial: USB Serial support registered for moto_modem
[ 1.312916] usbserial: USB Serial support registered for motorola_tetra
[ 1.319567] usbserial: USB Serial support registered for novatel_gps
[ 1.325954] usbserial: USB Serial support registered for hp4x
[ 1.331736] usbserial: USB Serial support registered for suunto
[ 1.337686] usbserial: USB Serial support registered for siemens_mpi
[ 1.346652] input: 30370000.snvs:snvs-powerkey as /devices/platform/soc@0/soc@0:bus@30000000/30370000.snvs/30370000.snvs:snvs-powerkey/input/input0
[ 1.360631] rotary-encoder rotary-encoder: gray
[ 1.366204] snvs_rtc 30370000.snvs:snvs-rtc-lp: registered as rtc1
[ 1.372509] i2c /dev entries driver
[ 1.380274] imx2-wdt 30280000.watchdog: timeout 60 sec (nowayout=0)
[ 1.387653] sdhci: Secure Digital Host Controller Interface driver
[ 1.393862] sdhci: Copyright(c) Pierre Ossman
[ 1.398423] Synopsys Designware Multimedia Card Interface Driver
[ 1.405015] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.443675] mmc0: SDHCI controller on 30b40000.mmc [30b40000.mmc] using ADMA
[ 1.453035] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.460451] caam 30900000.crypto: device ID = 0x0a16040100000000 (Era 9)
[ 1.467269] caam 30900000.crypto: job rings = 3, qi = 0
[ 1.493850] caam algorithms registered in /proc/crypto
[ 1.503070] caam 30900000.crypto: caam pkc algorithms registered in /proc/crypto
[ 1.510507] caam 30900000.crypto: registering rng-caam
[ 1.516880] Device caam-keygen registered
[ 1.523939] caam-snvs 30370000.caam-snvs: violation handlers armed - non-secure state
[ 1.532076] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.538619] usbcore: registered new interface driver usbhid
[ 1.544215] usbhid: USB HID core driver
[ 1.545199] mmc0: new HS400 MMC card at address 0001
[ 1.549560] No fsl,qman node
[ 1.553585] mmcblk0: mmc0:0001 Q2J54A 3.59 GiB
[ 1.555963] Freescale USDPAA process driver
[ 1.555965] fsl-usdpaa: no region found
[ 1.555967] Freescale USDPAA process IRQ driver
[ 1.559731] galcore: clk_get vg clock failed, disable vg!
[ 1.560827] mmcblk0boot0: mmc0:0001 Q2J54A partition 1 16.0 MiB
[ 1.565102] Galcore version 6.4.3.p1.305572
[ 1.568804] mmcblk0boot1: mmc0:0001 Q2J54A partition 2 16.0 MiB
[ 1.584805] random: fast init done
[ 1.598507] mmcblk0rpmb: mmc0:0001 Q2J54A partition 3 512 KiB, chardev (237:0)
[ 1.610879] random: crng init done
[ 1.616001] mmcblk0: p1 p2
[ 1.660285] [drm] Initialized vivante 1.0.0 20170808 for 38000000.gpu on minor 0
[ 1.678698] pktgen: Packet Generator for packet performance testing. Version: 2.75
[ 1.687360] NET: Registered protocol family 26
[ 1.692337] NET: Registered protocol family 10
[ 1.697535] Segment Routing with IPv6
[ 1.701270] NET: Registered protocol family 17
[ 1.705771] tsn generic netlink module v1 init...
[ 1.710557] Key type dns_resolver registered
[ 1.715542] registered taskstats version 1
[ 1.719664] Loading compiled-in X.509 certificates
[ 1.741928] GPIO line 129 (CTRL_SLEEP_MOCI#) hogged as output/high
[ 1.958914] pca9450 0-0025: Device ID=0x10
[ 1.963947] pca9450 0-0025: gpio_intr = 3
[ 1.967982] pca9450 0-0025: chip_irq=66
[ 1.988841] rtc-ds1307 0-0032: oscillator failed, set time!
[ 1.994876] rtc-ds1307 0-0032: registered as rtc0
[ 2.004128] at24 0-0050: 256 byte 24c02 EEPROM, writable, 16 bytes/write
[ 2.010906] i2c i2c-0: IMX I2C adapter registered
[ 2.016600] i2c i2c-1: IMX I2C adapter registered
[ 2.022163] i2c i2c-2: IMX I2C adapter registered
[ 2.027883] pca953x 3-0021: using no AI
[ 2.033446] sn65dsi83 3-002c: sn65dsi83_probe
[ 2.037885] sn65dsi83 3-002c: sn65dsi83_brg_power_off
[ 2.062431] sn65dsi83 3-002c: sn65dsi83_brg_power_on
[ 2.078432] sn65dsi83 3-002c: client 0x00000000dd7f2eb4
[ 2.085255] sn65dsi83 3-002c: sn65dsi83_brg_reset
[ 2.089983] sn65dsi83 3-002c: sn65dsi83_brg_power_off
[ 2.116969] at24 3-0050: 256 byte 24c02 EEPROM, writable, 16 bytes/write
[ 2.125204] at24 3-0057: 256 byte 24c02 EEPROM, writable, 16 bytes/write
[ 2.132131] i2c i2c-3: IMX I2C adapter registered
[ 2.139397] imx6q-pcie 33800000.pcie: PLL REF_CLK is used!.
[ 2.140151] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 2.147895] imx6q-pcie 33800000.pcie: PCIe PLL locked after 20 us.
[ 2.151646] [drm] No driver support for vblank timestamp query.
[ 2.151707] imx-drm soc@0:bus@32c00000:display-subsystem: bound imx-lcdif-crtc.0 (ops lcdif_crtc_ops)
[ 2.173079] imx_sec_dsim_drv 32e10000.mipi_dsi: failed to get blk_ctl
[ 2.179642] imx_sec_dsim_drv 32e10000.mipi_dsi: version number is 0x1060200
[ 2.186665] imx-drm soc@0:bus@32c00000:display-subsystem: sn65dsi83_bridge_attach
[ 2.194184] sn65dsi83 3-002c: sn65dsi83_attach_dsi
[ 2.199139] imx-drm soc@0:bus@32c00000:display-subsystem: bound 32e10000.mipi_dsi (ops imx_sec_dsim_ops)
[ 2.209559] [drm] Initialized imx-drm 1.0.0 20120507 for soc@0:bus@32c00000:display-subsystem on minor 1
[ 2.219091] imx-drm soc@0:bus@32c00000:display-subsystem: sn65dsi83_connector_detect
[ 2.226858] imx-drm soc@0:bus@32c00000:display-subsystem: sn65dsi83_connector_get_modes
[ 2.234890] imx-drm soc@0:bus@32c00000:display-subsystem: sn65dsi83_connector_mode_valid: mode: 1024*768@68900 is valid
[ 2.249298] imx-drm soc@0:bus@32c00000:display-subsystem: sn65dsi83_bridge_mode_set: mode: 1024*768@68900
[ 2.253589] imx-drm soc@0:bus@32c00000:display-subsystem: sn65dsi83_bridge_enable
[ 2.253595] sn65dsi83 3-002c: sn65dsi83_brg_setup
[ 2.253598] sn65dsi83 3-002c: sn65dsi83_brg_power_on
[ 2.263087] sn65dsi83 3-002c: DSI clock [ 206700000 ] Hz
[ 2.263094] sn65dsi83 3-002c: GeoMetry [ 1024 x 768 ] Hz
[ 2.265070] sn65dsi83 3-002c: client 0x00000000dd7f2eb4
[ 2.277202] sn65dsi83 3-002c: sn65dsi83_brg_start_stream
[ 2.370845] imx6q-pcie 33800000.pcie: host bridge /soc@0/pcie@33800000 ranges:
[ 2.370874] imx6q-pcie 33800000.pcie: IO 0x1ff80000..0x1ff8ffff -> 0x00000000
[ 2.370888] imx6q-pcie 33800000.pcie: MEM 0x18000000..0x1fefffff -> 0x18000000
[ 2.483977] sn65dsi83 3-002c: client 0x00000000dd7f2eb4
[ 2.485258] sn65dsi83 3-002c: CHA (0xe5) = 0x01
[ 2.522798] Console: switching to colour frame buffer device 128x48
[ 2.623740] imx-drm soc@0:bus@32c00000:display-subsystem: fb0: imx-drmdrmfb frame buffer device
[ 2.635506] pps pps0: new PPS source ptp0
[ 2.645727] libphy: fec_enet_mii_bus: probed
[ 2.651895] fec 30be0000.ethernet eth0: registered PHC device 0
[ 2.665730] ci_hdrc ci_hdrc.1: EHCI Host Controller
[ 2.674405] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
[ 2.698439] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[ 2.708424] hub 1-0:1.0: USB hub found
[ 2.715924] hub 1-0:1.0: 1 port detected
[ 2.724587] rotary-encoder rotary-encoder: gray
[ 2.733795] input: rotary-encoder as /devices/platform/rotary-encoder/input/input1
[ 2.745806] imx-cpufreq-dt imx-cpufreq-dt: cpu speed grade 3 mkt segment 0 supported-hw 0x8 0x1
[ 2.763532] sdhci-esdhc-imx 30b50000.mmc: Got CD GPIO
[ 2.806637] mmc1: SDHCI controller on 30b50000.mmc [30b50000.mmc] using ADMA
[ 2.822833] input: gpio-keys as /devices/platform/gpio-keys/input/input2
[ 2.835113] rtc-ds1307 0-0032: hctosys: unable to read the hardware clock
[ 2.846745] ALSA device list:
[ 2.852202] No soundcards found.
[ 2.990808] usb 1-1: new high-speed USB device number 2 using ci_hdrc
[ 3.159869] hub 1-1:1.0: USB hub found
[ 3.167453] hub 1-1:1.0: 4 ports detected
[ 3.354803] imx6q-pcie 33800000.pcie: Phy link never came up
[ 3.364088] imx6q-pcie 33800000.pcie: failed to initialize host
[ 3.373521] imx6q-pcie 33800000.pcie: unable to add pcie port.
[ 3.390648] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 3.401177] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 3.410960] devtmpfs: mounted
[ 3.417167] Freeing unused kernel memory: 2944K
[ 3.426461] Run /sbin/init as init process
[ 3.466464] usb 1-1.1: new full-speed USB device number 3 using ci_hdrc
[ 3.537373] systemd[1]: System time before build time, advancing clock.
[ 3.558267] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[ 3.585523] systemd[1]: Detected architecture arm64.
[ 3.596829] ftdi_sio 1-1.1:1.0: FTDI USB Serial Device converter detected
[ 3.606259] usb 1-1.1: Detected FT-X
[ 3.613551] usb 1-1.1: FTDI USB Serial Device converter now attached to ttyUSB0
[ 3.634018] systemd[1]: Set hostname to <verdin-imx8mm-06827388>.
[ 3.710481] usb 1-1.2: new full-speed USB device number 4 using ci_hdrc
[ 3.828062] hub 1-1.2:1.0: USB hub found
[ 3.834831] hub 1-1.2:1.0: 4 ports detected
[ 3.867899] systemd[1]: /lib/systemd/system/gpsd.socket:5: ListenStream= references a path below legacy directory /var/run/, updating /var/run/gpsd.sock \xe2\x86\x92 /run/gpsd.sock; please update the unit file accordingly.
[ 3.908674] systemd[1]: Created slice system-getty.slice.
[ 3.920637] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 3.930436] usb 1-1.4: new high-speed USB device number 5 using ci_hdrc
[ 3.942860] systemd[1]: Created slice system-weston.slice.
[ 3.955036] systemd[1]: Created slice User and Session Slice.
[ 3.966731] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 3.980610] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 3.994048] systemd[1]: Reached target Host and Network Name Lookups.
[ 4.006325] systemd[1]: Reached target Paths.
[ 4.016505] systemd[1]: Reached target Remote File Systems.
[ 4.028002] systemd[1]: Reached target Slices.
[ 4.038376] systemd[1]: Reached target Swap.
[ 4.061968] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 4.075479] systemd[1]: Reached target RPC Port Mapper.
[ 4.088546] systemd[1]: Listening on Syslog Socket.
[ 4.099532] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 4.112250] systemd[1]: Listening on Journal Audit Socket.
[ 4.123732] systemd[1]: Listening on Journal Socket (/dev/log).
[ 4.135682] systemd[1]: Listening on Journal Socket.
[ 4.146802] systemd[1]: Listening on Network Service Netlink Socket.
[ 4.159223] systemd[1]: Listening on udev Control Socket.
[ 4.170591] systemd[1]: Listening on udev Kernel Socket.
[ 4.183918] systemd[1]: Mounting Huge Pages File System...
[ 4.197447] systemd[1]: Mounting POSIX Message Queue File System...
[ 4.211927] systemd[1]: Mounting Kernel Debug File System...
[ 4.226077] systemd[1]: Mounting Temporary Directory (/tmp)...
[ 4.241322] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 4.258059] systemd[1]: Starting RPC Bind...
[ 4.270761] systemd[1]: Starting File System Check on Root Device...
[ 4.288873] systemd[1]: Starting Journal Service...
[ 4.311607] systemd[1]: Starting Load Kernel Modules...
[ 4.336545] systemd[1]: Starting udev Coldplug all Devices...
[ 4.357926] systemd[1]: Started RPC Bind.
[ 4.365060] galcore: loading out-of-tree module taints kernel.
[ 4.387562] galcore: module is already loaded
[ 4.395126] systemd[1]: Started Journal Service.
[ 4.465512] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 4.478502] usb 1-1.2.1: new full-speed USB device number 6 using ci_hdrc
[ 4.539470] systemd-journald[235]: Received client request to flush runtime journal.
[ 4.611373] input: MOSART Semi. 2.4G Keyboard Mouse as /devices/platform/soc@0/soc@0:bus@32c00000/32e50000.usb/ci_hdrc.1/usb1/1-1/1-1.2/1-1.2.1/1-1.2.1:1.0/0003:062A:4C01.0001/input/input3
[ 4.691183] hid-generic 0003:062A:4C01.0001: input,hidraw0: USB HID v1.10 Keyboard [MOSART Semi. 2.4G Keyboard Mouse] on usb-ci_hdrc.1-1.2.1/input0
[ 4.696097] input: MOSART Semi. 2.4G Keyboard Mouse as /devices/platform/soc@0/soc@0:bus@32c00000/32e50000.usb/ci_hdrc.1/usb1/1-1/1-1.2/1-1.2.1/1-1.2.1:1.1/0003:062A:4C01.0002/input/input4
[ 4.734497] input: MOSART Semi. 2.4G Keyboard Mouse Consumer Control as /devices/platform/soc@0/soc@0:bus@32c00000/32e50000.usb/ci_hdrc.1/usb1/1-1/1-1.2/1-1.2.1/1-1.2.1:1.1/0003:062A:4C01.0002/input/input5
[ 4.818755] input: MOSART Semi. 2.4G Keyboard Mouse System Control as /devices/platform/soc@0/soc@0:bus@32c00000/32e50000.usb/ci_hdrc.1/usb1/1-1/1-1.2/1-1.2.1/1-1.2.1:1.1/0003:062A:4C01.0002/input/input6
[ 4.866846] input: MOSART Semi. 2.4G Keyboard Mouse as /devices/platform/soc@0/soc@0:bus@32c00000/32e50000.usb/ci_hdrc.1/usb1/1-1/1-1.2/1-1.2.1/1-1.2.1:1.1/0003:062A:4C01.0002/input/input7
[ 4.906738] hid-generic 0003:062A:4C01.0002: input,hidraw1: USB HID v1.10 Mouse [MOSART Semi. 2.4G Keyboard Mouse] on usb-ci_hdrc.1-1.2.1/input1
[ 5.034486] usb 1-1.2.2: new full-speed USB device number 7 using ci_hdrc
[ 5.162375] input: EloTouchSystems,Inc Elo TouchSystems 2216 AccuTouch\xc2\xae USB Touchmonitor Interface as /devices/platform/soc@0/soc@0:bus@32c00000/32e50000.usb/ci_hdrc.1/usb1/1-1/1-1.2/1-1.2.2/1-1.2.2:1.0/0003:04E7:0050.0003/input/input8
[ 5.199822] galcore: module is already loaded
[ 5.209672] hid-generic 0003:04E7:0050.0003: input,hidraw2: USB HID v1.00 Pointer [EloTouchSystems,Inc Elo TouchSystems 2216 AccuTouch\xc2\xae USB Touchmonitor Interface] on usb-ci_hdrc.1-1.2.2/input0
[ 5.322903] galcore: module is already loaded
[ 5.418080] imx-sdma 302c0000.dma-controller: loaded firmware 4.5
[ 5.460461] spi_imx 30840000.spi: probed
[ 5.478044] ina2xx 3-0040: power monitor ina219 (Rshunt = 10000 uOhm)
[ 5.495217] lm75 3-004f: hwmon1: sensor 'tmp75c'
[ 5.508002] debugfs: Directory '30020000.sai' with parent 'imx8mm-nau8822' already present!
[ 5.524879] asoc-simple-card sound-card: nau8822-hifi <-> 30020000.sai mapping ok
[ 5.542557] asoc-simple-card sound-card: ASoC: no DMI vendor name!
[ 5.567222] galcore: module is already loaded
[ 6.318099] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 6.591055] CAN device driver interface
[ 6.616863] galcore: module is already loaded
[ 6.632719] mcp25xxfd spi2.0: CRC read error: computed: 6c2a received: ffff - data: be 00 04 ff ff ff ff
[ 6.645559] mcp25xxfd spi2.0: CRC read of clock register resulted in a bad CRC mismatch - hw not found
[ 6.658207] mcp25xxfd spi2.0: Probe failed, err=84
[ 6.666369] mcp25xxfd: probe of spi2.0 failed with error -84
[ 7.916575] Bluetooth: Core ver 2.22
[ 7.928890] NET: Registered protocol family 31
[ 7.946342] using random self ethernet address
[ 7.952708] Bluetooth: HCI device and connection manager initialized
[ 7.955890] using random host ethernet address
[ 7.963534] Bluetooth: HCI socket layer initialized
[ 7.990521] Bluetooth: L2CAP socket layer initialized
[ 8.011952] Bluetooth: SCO socket layer initialized
[ 8.100841] usb0: HOST MAC 00:14:2d:ff:ff:fe
[ 8.124911] usb0: MAC 00:14:2d:ff:ff:ff
[ 8.242889] Microchip KSZ9131 Gigabit PHY 30be0000.ethernet-1:07: attached PHY driver [Microchip KSZ9131 Gigabit PHY] (mii_bus:phy_addr=30be0000.ethernet-1:07, irq=73)
[ 8.517186] audit: type=1006 audit(1649873757.720:2): pid=587 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=1 res=1
[ 9.121975] imx-drm soc@0:bus@32c00000:display-subsystem: sn65dsi83_connector_detect
[ 9.129750] imx-drm soc@0:bus@32c00000:display-subsystem: sn65dsi83_connector_get_modes
[ 9.137807] imx-drm soc@0:bus@32c00000:display-subsystem: sn65dsi83_connector_mode_valid: mode: 1024*768@68900 is valid
[ 9.880189] fec 30be0000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 9.888192] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 9.901696] 8021q: 802.1Q VLAN Support v1.8
[ 12.260718] imx-drm soc@0:bus@32c00000:display-subsystem: sn65dsi83_connector_detect
[ 12.269166] imx-drm soc@0:bus@32c00000:display-subsystem: sn65dsi83_connector_get_modes
[ 12.278911] imx-drm soc@0:bus@32c00000:display-subsystem: sn65dsi83_connector_mode_valid: mode: 1024*768@68900 is valid
[ 33.762739] REG_MIPI_PHY: disabling
[ 33.766240] usb_otg1_vbus: disabling
[ 33.769845] V3.3_SD: disabling
What can I do?
