I’m using a Verdin iMX8MM with BSP v6.2 on a custom carrier board and I have a similar problem like Weston-touch-calibrator problem: no devices listed.
We connected a display with USB touch, but weston doesn’t get the touch events most of the time.
The touch controller is enumerated:
$ lsusb
Bus 001 Device 004: ID 222a:0001 ILI Technology Corp. Multi-Touch Screen
The touch events are registered:
$ cat /proc/bus/input/devices
I: Bus=0003 Vendor=222a Product=0001 Version=0110
N: Name="ILITEK ILITEK-TP"
P: Phys=usb-ci_hdrc.1-1.4/input0
S: Sysfs=/devices/platform/soc@0/32c00000.bus/32e50000.usb/ci_hdrc.1/usb1/1-1/1-1.4/1-1.4:1.0/0003:222A:0001.0001/input/input5
U: Uniq=
H: Handlers=event2
B: PROP=2
B: EV=1b
B: KEY=400 0 0 0 0 0
B: ABS=260800000000003
B: MSC=20
N: Name="ILITEK ILITEK-TP Mouse"
S: Sysfs=/devices/platform/soc@0/32c00000.bus/32e50000.usb/ci_hdrc.1/usb1/1-1/1-1.4/1-1.4:1.0/0003:222A:0001.0001/input/input7
U: Uniq=
H: Handlers=event3
B: PROP=0
B: EV=1b
B: KEY=1f0000 0 0 0 0
B: ABS=3
B: MSC=10
And udevadm info shows that event2 is registered as a touchscreen:
udevadm info /dev/input/event2
P: /devices/platform/soc@0/32c00000.bus/32e50000.usb/ci_hdrc.1/usb1/1-1/1-1.4/1-1.4:1.0/0003:222A:0001.0001/input/input5/event2
N: input/event2
L: 0
S: input/by-id/usb-ILITEK_ILITEK-TP-event-if00
S: input/by-path/platform-ci_hdrc.1-usb-0:1.4:1.0-event
E: DEVPATH=/devices/platform/soc@0/32c00000.bus/32e50000.usb/ci_hdrc.1/usb1/1-1/1-1.4/1-1.4:1.0/0003:222A:0001.0001/input/input5/event2
E: DEVNAME=/dev/input/event2
E: MAJOR=13
E: MINOR=66
E: SUBSYSTEM=input
E: USEC_INITIALIZED=6375283
E: ID_INPUT=1
E: ID_INPUT_TOUCHSCREEN=1
E: ID_INPUT_WIDTH_MM=135
E: ID_INPUT_HEIGHT_MM=215
E: ID_VENDOR=ILITEK
E: ID_VENDOR_ENC=ILITEK
E: ID_VENDOR_ID=222a
E: ID_MODEL=ILITEK-TP
E: ID_MODEL_ENC=ILITEK-TP
E: ID_MODEL_ID=0001
E: ID_REVISION=0002
E: ID_SERIAL=ILITEK_ILITEK-TP
E: ID_TYPE=hid
E: ID_BUS=usb
E: ID_USB_INTERFACES=:030000:
E: ID_USB_INTERFACE_NUM=00
E: ID_USB_DRIVER=usbhid
E: ID_PATH=platform-ci_hdrc.1-usb-0:1.4:1.0
E: ID_PATH_TAG=platform-ci_hdrc_1-usb-0_1_4_1_0
E: LIBINPUT_DEVICE_GROUP=3/222a/1:usb-ci_hdrc.1-1
E: LIBINPUT_CALIBRATION_MATRIX=1 0 0 0 1 0
E: DEVLINKS=/dev/input/by-id/usb-ILITEK_ILITEK-TP-event-if00 /dev/input/by-path/platform-ci_hdrc.1-usb-0:1.4:1.0-event
I get touchevents:
$ evtest /dev/input/event2
Input driver version is 1.0.1
Input device ID: bus 0x3 vendor 0x222a product 0x1 version 0x110
Input device name: "ILITEK ILITEK-TP"
Supported events:
Event type 0 (EV_SYN)
Event type 1 (EV_KEY)
Event code 330 (BTN_TOUCH)
Event type 3 (EV_ABS)
Event code 0 (ABS_X)
Value 10090
Min 0
Max 16384
Resolution 53
Event code 1 (ABS_Y)
Value 4642
Min 0
Max 9600
Resolution 55
Event code 47 (ABS_MT_SLOT)
Value 1
Min 0
Max 9
Event code 53 (ABS_MT_POSITION_X)
Value 0
Min 0
Max 16384
Resolution 53
Event code 54 (ABS_MT_POSITION_Y)
Value 0
Min 0
Max 9600
Resolution 55
Event code 57 (ABS_MT_TRACKING_ID)
Value 0
Min 0
Max 65535
Event type 4 (EV_MSC)
Event code 5 (MSC_TIMESTAMP)
Properties:
Property type 1 (INPUT_PROP_DIRECT)
Testing ... (interrupt to exit)
Event: time 1673539603.417363, type 3 (EV_ABS), code 47 (ABS_MT_SLOT), value 0
Event: time 1673539603.417363, type 3 (EV_ABS), code 57 (ABS_MT_TRACKING_ID), value 3
Event: time 1673539603.417363, type 3 (EV_ABS), code 53 (ABS_MT_POSITION_X), value 9772
Event: time 1673539603.417363, type 3 (EV_ABS), code 54 (ABS_MT_POSITION_Y), value 6770
Event: time 1673539603.417363, type 3 (EV_ABS), code 47 (ABS_MT_SLOT), value 1
Event: time 1673539603.417363, type 3 (EV_ABS), code 57 (ABS_MT_TRACKING_ID), value 4
Event: time 1673539603.417363, type 3 (EV_ABS), code 53 (ABS_MT_POSITION_X), value 7274
Event: time 1673539603.417363, type 3 (EV_ABS), code 54 (ABS_MT_POSITION_Y), value 6403
Event: time 1673539603.417363, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 1
Event: time 1673539603.417363, type 3 (EV_ABS), code 0 (ABS_X), value 9772
Event: time 1673539603.417363, type 3 (EV_ABS), code 1 (ABS_Y), value 6770
Event: time 1673539603.417363, type 4 (EV_MSC), code 5 (MSC_TIMESTAMP), value 0
Event: time 1673539603.417363, -------------- SYN_REPORT ------------
Event: time 1673539603.423000, type 4 (EV_MSC), code 5 (MSC_TIMESTAMP), value 8000
Event: time 1673539603.423000, -------------- SYN_REPORT ------------
Event: time 1673539603.430351, type 4 (EV_MSC), code 5 (MSC_TIMESTAMP), value 16000
Event: time 1673539603.430351, -------------- SYN_REPORT ------------
Event: time 1673539603.440355, type 4 (EV_MSC), code 5 (MSC_TIMESTAMP), value 24000
Event: time 1673539603.440355, -------------- SYN_REPORT ------------
Event: time 1673539603.447102, type 4 (EV_MSC), code 5 (MSC_TIMESTAMP), value 32000
Event: time 1673539603.447102, -------------- SYN_REPORT ------------
Event: time 1673539603.452982, type 3 (EV_ABS), code 47 (ABS_MT_SLOT), value 0
Event: time 1673539603.452982, type 3 (EV_ABS), code 53 (ABS_MT_POSITION_X), value 9775
Event: time 1673539603.452982, type 3 (EV_ABS), code 54 (ABS_MT_POSITION_Y), value 6763
Event: time 1673539603.452982, type 3 (EV_ABS), code 47 (ABS_MT_SLOT), value 1
Event: time 1673539603.452982, type 3 (EV_ABS), code 53 (ABS_MT_POSITION_X), value 7277
Event: time 1673539603.452982, type 3 (EV_ABS), code 54 (ABS_MT_POSITION_Y), value 6395
Event: time 1673539603.452982, type 3 (EV_ABS), code 0 (ABS_X), value 9775
Event: time 1673539603.452982, type 3 (EV_ABS), code 1 (ABS_Y), value 6763
Event: time 1673539603.452982, type 4 (EV_MSC), code 5 (MSC_TIMESTAMP), value 40000
Event: time 1673539603.452982, -------------- SYN_REPORT ------------
Event: time 1673539603.460366, type 3 (EV_ABS), code 47 (ABS_MT_SLOT), value 0
Event: time 1673539603.460366, type 3 (EV_ABS), code 53 (ABS_MT_POSITION_X), value 9781
Event: time 1673539603.460366, type 3 (EV_ABS), code 54 (ABS_MT_POSITION_Y), value 6747
Event: time 1673539603.460366, type 3 (EV_ABS), code 47 (ABS_MT_SLOT), value 1
Event: time 1673539603.460366, type 3 (EV_ABS), code 53 (ABS_MT_POSITION_X), value 7283
Event: time 1673539603.460366, type 3 (EV_ABS), code 54 (ABS_MT_POSITION_Y), value 6379
Event: time 1673539603.460366, type 3 (EV_ABS), code 0 (ABS_X), value 9781
Event: time 1673539603.460366, type 3 (EV_ABS), code 1 (ABS_Y), value 6747
Event: time 1673539603.460366, type 4 (EV_MSC), code 5 (MSC_TIMESTAMP), value 48000
Event: time 1673539603.460366, -------------- SYN_REPORT ------------
Event: time 1673539603.796334, type 3 (EV_ABS), code 57 (ABS_MT_TRACKING_ID), value -1
Event: time 1673539603.796334, type 3 (EV_ABS), code 47 (ABS_MT_SLOT), value 1
Event: time 1673539603.796334, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 0
Event: time 1673539603.796334, type 4 (EV_MSC), code 5 (MSC_TIMESTAMP), value 408000
Event: time 1673539603.796334, -------------- SYN_REPORT ------------
But weston sees no device:
$ weston-touch-calibrator
could not load cursor 'dnd-move'
could not load cursor 'dnd-copy'
could not load cursor 'dnd-none'
No devices listed.
It only works when I restart weston
$ systemctl restart weston
[ 752.141395] audit: type=1701 audit(1692372715.840:34): auid=1001 uid=1001 gid=1005 ses=2 pid=765 comm="weston" exe="/usr/bin/weston" sig=11 res=1
[ 752.363841] audit: type=1006 audit(1692372716.064:35): pid=828 uid=0 old-auid=4294967295 auid=1001 tty=tty7 old-ses=4294967295 ses=4 res=1
[ 752.376552] audit: type=1300 audit(1692372716.064:35): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffd7a009d0 a2=4 a3=0 items=0 ppid=1 pid=828 auid=1001 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=tty7 ses=4 comm="(weston)" exe="/lib/systemd/systemd" key=(null)
[ 752.402349] audit: type=1327 audit(1692372716.064:35): proctitle="(weston)"
device "/sys/devices/platform/soc@0/32c00000.bus/32e50000.usb/ci_hdrc.1/usb1/1-1/1-1.4/1-1.4:1.0/0003:222A:0001.0001/input/input5/event2" - head "DSI-1"
But then I’m lost with a blackscreen. What can I do?
dmesg.log (30.9 KB)
Markus
