Hello @jon2023 ,
Here is my test (with Torizon OS 6.4)
My screen for the tests was the 7" capacitive touch display parallel
torizon@colibri-imx6-10866299:~$ sudo tdx-info
Password:
Software summary
Bootloader: U-Boot
Kernel version: 6.1.55-6.4.0+git.d23900f974e0 #1-TorizonCore SMP Mon May 22 09:17:34 UTC 2023
Kernel command line: enable_wait_mode=off galcore.contiguousSize=50331648 root=LABEL=otaroot rootfstype=ext4 quiet logo.nologo vt.global_cursor_default=0 plymouth.ignore-serial-consoles splash fbcon=map:3 ostree=/ostree/boot.1/torizon/8eae83cf4b4722ba086810d3d40eb912f1e958af0d7eab940dc6f835365d2029/0
Distro name: NAME="TorizonCore Upstream"
Distro version: VERSION_ID=6.4.0-build.5
Hostname: colibri-imx6-10866299
Hardware info
HW model: Toradex Colibri iMX6DL/S on Colibri Evaluation Board V3
Toradex version: 0017 V1.1B
Serial number: 10866299
Processor arch: armv7l
Check the available modes of the screen:
torizon@colibri-imx6-10866299:~$ cat /sys/class/drm/
card0/ card1/ card1-DPI-1/ renderD128/ version
torizon@colibri-imx6-10866299:~$ cat /sys/class/drm/card1-DPI-1/modes
800x480
Contents of /etc/xdg/weston/weston.ini
(I took yours and changed the resolution to 800x480)
torizon@colibri-imx6-10866299:~$ cat /etc/xdg/weston/weston.ini
[core]
idle-time=0
require-input=false
xwayland=true
modules=screen-share.so
# uncomment line below to use kiosk shell
#shell=kiosk-shell.so
[shell]
background-image=
background-color=0x00000000
panel-position=none
locking=false
allow-zap=false
num-workspaces=1
[keyboard]
vt-switching=false
# uncomment the [output] line below if you set any output configuration
[output]
# you must uncomment the "name” line and provide the name of the output interface being customized, otherwise, changes will not apply
name=DPI-1
# uncomment line below to configure screen rotation/flipping
transform=rotate-270
# uncomment line below to redirect the output; supported by kiosk shell
#mode=off
# uncomment line below to set an output resolution. Run for example 'cat /sys/class/drm/card1-HDMI-A-1/modes' to list the available modes.
mode=800x480
# or use the more detailed (mode=dotclock hdisp hsyncstart hsyncend htotal vdisp vsyncstart vsyncend vtotal hflag vflag)
#mode=146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync
# uncomment line below to make this output a clone of another
#same-as=DPI-1
#For multi-display support and other configurations, please read the article: https://developer.toradex.com/knowledge-base/working-with-weston-on-torizoncore
Contents of /var/sota/storage/docker-compose/docker-compose.yml
Here I added a bind mount of /etc/xdg/weston
in the weston
service
torizon@colibri-imx6-10866299:~$ cat /var/sota/storage/docker-compose/docker-compose.yml
services:
kiosk:
command: http://portainer:9000
depends_on:
portainer:
condition: service_started
weston:
device_cgroup_rules:
- c 226:* rmw
environment:
MACHINE: null
image: torizon/chromium@sha256:9d363b140a5f4584392432b4ed548c0b6fd5466fbf41b28e834f31924fb62d6d
platform: linux/arm
security_opt:
- seccomp:unconfined
shm_size: 256mb
volumes:
- source: /tmp
target: /tmp
type: bind
- source: /var/run/dbus
target: /var/run/dbus
type: bind
- source: /dev/dri
target: /dev/dri
type: bind
portainer:
command: --templates https://feeds.toradex.com/portainer/5/$MACHINE/templates.json
--logo https://docs.toradex.com/109812-torizon-logo-portainer.svg -H unix:///var/run/docker.sock
image: portainer/portainer-ce@sha256:9fa1ec78b4e29d83593cf9720674b72829c9cdc0db7083a962bc30e64e27f64e
ports:
- published: 8840
target: 9000
restart: always
volumes:
- source: portainer_data
target: /data
type: volume
- source: /var/run/docker.sock
target: /var/run/docker.sock
type: bind
weston:
cap_add:
- CAP_SYS_TTY_CONFIG
- c 4:0 rmw
- c 4:7 rmw
- c 4:1 rmw
- c 13:* rmw
- c 226:* rmw
image: torizon/weston@sha256:804ee3cc495661a46816d86084a55b39a1aa725fc5ac24eafb49706d831fe615
network_mode: host
volumes:
- source: /tmp
target: /tmp
type: bind
- source: /dev
target: /dev
type: bind
- source: /run/udev
target: /run/udev
type: bind
- source: /etc/xdg/weston
target: /etc/xdg/weston
type: bind
version: '2.4'
volumes:
portainer_data: {}
After rebooting I executed bash
in the Weston container and ran weston-event
torizon@colibri-imx6-10866299:~$ docker ps
551c3bdb4bfc torizon/chromium "/usr/bin/start-brow…" 42 minutes ago Up 11 minutes torizon-kiosk-1
19c1bad5bcea torizon/weston "/usr/bin/entry.sh" 42 minutes ago Up 37 minutes torizon-weston-1
245c7539e958 portainer/portainer-ce "/portainer --templa…" 55 minutes ago Up 37 minutes 8000/tcp, 9443/tcp, 0.0.0.0:8840->9000/tcp, :::8840->9000/tcp torizon-portainer-1
torizon@colibri-imx6-10866299:~$ docker exec -it torizon-weston-1 bash
root@colibri-imx6-10866299:/home/torizon# weston
weston weston-dnd weston-multi-resource weston-simple-dmabuf-feedback weston-subsurfaces
weston-calibrator weston-editor weston-presentation-shm weston-simple-dmabuf-v4l weston-terminal
weston-clickdot weston-eventdemo weston-resizor weston-simple-egl weston-touch-calibrator
weston-cliptest weston-flower weston-scaler weston-simple-shm weston-transformed
weston-confine weston-fullscreen weston-screenshooter weston-simple-touch
weston-content_protection weston-image weston-simple-damage weston-smoke
weston-debug weston-info weston-simple-dmabuf-egl weston-stacking
root@colibri-imx6-10866299:/home/torizon# weston-eventdemo
could not load cursor 'dnd-move'
could not load cursor 'dnd-copy'
could not load cursor 'dnd-none'
resize width: 424, height: 303
redraw
focus x: 0, y: 0
redraw
The result , it works (the default orientation of the screen was landscape, now is portrait)
The output of weston-info (from inside the container)
root@colibri-imx6-10866299:/home/torizon# weston-info
*** Please use wayland-info instead
*** weston-info is deprecated and will be removed in a future version
interface: 'wl_compositor', version: 4, name: 1
interface: 'wl_subcompositor', version: 1, name: 2
interface: 'wp_viewporter', version: 1, name: 3
interface: 'zxdg_output_manager_v1', version: 2, name: 4
xdg_output_v1
output: 17
logical_x: 0, logical_y: 0
logical_width: 480, logical_height: 800
interface: 'wp_presentation', version: 1, name: 5
presentation clock id: 1 (CLOCK_MONOTONIC)
interface: 'zwp_relative_pointer_manager_v1', version: 1, name: 6
interface: 'zwp_pointer_constraints_v1', version: 1, name: 7
interface: 'zwp_input_timestamps_manager_v1', version: 1, name: 8
interface: 'wl_data_device_manager', version: 3, name: 9
interface: 'wl_shm', version: 1, name: 10
formats: 'XB30'(0x30334258) 'AB30'(0x30334241) 'XYUV'(0x56555958) 'YUYV'(0x56595559) 'NV12'(0x3231564e) 'YU12'(0x32315559) RGB565 XRGB8888 ARGB8888
interface: 'wl_drm', version: 2, name: 11
interface: 'wl_seat', version: 7, name: 12
capabilities: keyboard
keyboard repeat rate: 40
keyboard repeat delay: 400
interface: 'zwp_linux_dmabuf_v1', version: 4, name: 13
formats:
'UYVY'(0x59565955), modifier: 0x0600000000000002
'UYVY'(0x59565955), modifier: 0x0600000000000001
'UYVY'(0x59565955), modifier: 0x0000000000000000
'UYVY'(0x59565955), modifier: 0x00ffffffffffffff
'YUYV'(0x56595559), modifier: 0x0600000000000002
'YUYV'(0x56595559), modifier: 0x0600000000000001
'YUYV'(0x56595559), modifier: 0x0000000000000000
'YUYV'(0x56595559), modifier: 0x00ffffffffffffff
'Y410'(0x30313459), modifier: 0x0600000000000002
'Y410'(0x30313459), modifier: 0x0600000000000001
'Y410'(0x30313459), modifier: 0x0000000000000000
'Y410'(0x30313459), modifier: 0x00ffffffffffffff
'XYUV'(0x56555958), modifier: 0x0600000000000002
'XYUV'(0x56555958), modifier: 0x0600000000000001
'XYUV'(0x56555958), modifier: 0x0000000000000000
'XYUV'(0x56555958), modifier: 0x00ffffffffffffff
'AYUV'(0x56555941), modifier: 0x0600000000000002
'AYUV'(0x56555941), modifier: 0x0600000000000001
'AYUV'(0x56555941), modifier: 0x0000000000000000
'AYUV'(0x56555941), modifier: 0x00ffffffffffffff
'NV16'(0x3631564e), modifier: 0x0600000000000002
'NV16'(0x3631564e), modifier: 0x0600000000000001
'NV16'(0x3631564e), modifier: 0x0000000000000000
'NV16'(0x3631564e), modifier: 0x00ffffffffffffff
'NV12'(0x3231564e), modifier: 0x0600000000000002
'NV12'(0x3231564e), modifier: 0x0600000000000001
'NV12'(0x3231564e), modifier: 0x0000000000000000
'NV12'(0x3231564e), modifier: 0x00ffffffffffffff
'YV24'(0x34325659), modifier: 0x0600000000000002
'YV24'(0x34325659), modifier: 0x0600000000000001
'YV24'(0x34325659), modifier: 0x0000000000000000
'YV24'(0x34325659), modifier: 0x00ffffffffffffff
'YV16'(0x36315659), modifier: 0x0600000000000002
'YV16'(0x36315659), modifier: 0x0600000000000001
'YV16'(0x36315659), modifier: 0x0000000000000000
'YV16'(0x36315659), modifier: 0x00ffffffffffffff
'YV12'(0x32315659), modifier: 0x0600000000000002
'YV12'(0x32315659), modifier: 0x0600000000000001
'YV12'(0x32315659), modifier: 0x0000000000000000
'YV12'(0x32315659), modifier: 0x00ffffffffffffff
'YV11'(0x31315659), modifier: 0x0600000000000002
'YV11'(0x31315659), modifier: 0x0600000000000001
'YV11'(0x31315659), modifier: 0x0000000000000000
'YV11'(0x31315659), modifier: 0x00ffffffffffffff
'YVU9'(0x39555659), modifier: 0x0600000000000002
'YVU9'(0x39555659), modifier: 0x0600000000000001
'YVU9'(0x39555659), modifier: 0x0000000000000000
'YVU9'(0x39555659), modifier: 0x00ffffffffffffff
'YU24'(0x34325559), modifier: 0x0600000000000002
'YU24'(0x34325559), modifier: 0x0600000000000001
'YU24'(0x34325559), modifier: 0x0000000000000000
'YU24'(0x34325559), modifier: 0x00ffffffffffffff
'YU16'(0x36315559), modifier: 0x0600000000000002
'YU16'(0x36315559), modifier: 0x0600000000000001
'YU16'(0x36315559), modifier: 0x0000000000000000
'YU16'(0x36315559), modifier: 0x00ffffffffffffff
'YU12'(0x32315559), modifier: 0x0600000000000002
'YU12'(0x32315559), modifier: 0x0600000000000001
'YU12'(0x32315559), modifier: 0x0000000000000000
'YU12'(0x32315559), modifier: 0x00ffffffffffffff
'YU11'(0x31315559), modifier: 0x0600000000000002
'YU11'(0x31315559), modifier: 0x0600000000000001
'YU11'(0x31315559), modifier: 0x0000000000000000
'YU11'(0x31315559), modifier: 0x00ffffffffffffff
'YUV9'(0x39565559), modifier: 0x0600000000000002
'YUV9'(0x39565559), modifier: 0x0600000000000001
'YUV9'(0x39565559), modifier: 0x0000000000000000
'YUV9'(0x39565559), modifier: 0x00ffffffffffffff
'GR88'(0x38385247), modifier: 0x0600000000000002
'GR88'(0x38385247), modifier: 0x0600000000000001
'GR88'(0x38385247), modifier: 0x0000000000000000
'GR88'(0x38385247), modifier: 0x00ffffffffffffff
'R8 '(0x20203852), modifier: 0x0600000000000002
'R8 '(0x20203852), modifier: 0x0600000000000001
'R8 '(0x20203852), modifier: 0x0000000000000000
'R8 '(0x20203852), modifier: 0x00ffffffffffffff
'RG16'(0x36314752), modifier: 0x0600000000000002
'RG16'(0x36314752), modifier: 0x0600000000000001
'RG16'(0x36314752), modifier: 0x0000000000000000
'RG16'(0x36314752), modifier: 0x00ffffffffffffff
'AR15'(0x35315241), modifier: 0x0600000000000002
'AR15'(0x35315241), modifier: 0x0600000000000001
'AR15'(0x35315241), modifier: 0x0000000000000000
'AR15'(0x35315241), modifier: 0x00ffffffffffffff
'XB24'(0x34324258), modifier: 0x0600000000000002
'XB24'(0x34324258), modifier: 0x0600000000000001
'XB24'(0x34324258), modifier: 0x0000000000000000
'XB24'(0x34324258), modifier: 0x00ffffffffffffff
'XR24'(0x34325258), modifier: 0x0600000000000002
'XR24'(0x34325258), modifier: 0x0600000000000001
'XR24'(0x34325258), modifier: 0x0000000000000000
'XR24'(0x34325258), modifier: 0x00ffffffffffffff
'AB24'(0x34324241), modifier: 0x0600000000000002
'AB24'(0x34324241), modifier: 0x0600000000000001
'AB24'(0x34324241), modifier: 0x0000000000000000
'AB24'(0x34324241), modifier: 0x00ffffffffffffff
'AR24'(0x34325241), modifier: 0x0600000000000002
'AR24'(0x34325241), modifier: 0x0600000000000001
'AR24'(0x34325241), modifier: 0x0000000000000000
'AR24'(0x34325241), modifier: 0x00ffffffffffffff
'XB30'(0x30334258), modifier: 0x0600000000000002
'XB30'(0x30334258), modifier: 0x0600000000000001
'XB30'(0x30334258), modifier: 0x0000000000000000
'XB30'(0x30334258), modifier: 0x00ffffffffffffff
'AB30'(0x30334241), modifier: 0x0600000000000002
'AB30'(0x30334241), modifier: 0x0600000000000001
'AB30'(0x30334241), modifier: 0x0000000000000000
'AB30'(0x30334241), modifier: 0x00ffffffffffffff
interface: 'weston_direct_display_v1', version: 1, name: 14
interface: 'zwp_linux_explicit_synchronization_v1', version: 2, name: 15
interface: 'weston_content_protection', version: 1, name: 16
interface: 'wl_output', version: 3, name: 17
x: 0, y: 0, scale: 1,
physical_width: 154 mm, physical_height: 86 mm,
make: 'unknown', model: 'unknown',
subpixel_orientation: unknown, output_transform: 270°,
mode:
width: 800 px, height: 480 px, refresh: 60.053 Hz,
flags: current preferred
interface: 'xdg_wm_base', version: 3, name: 18
interface: 'weston_screenshooter', version: 1, name: 19
Josep
