VS Code can't connect to my imx7
I cannot get VS Code to connect to my imx7. My network devices panel and connected devices panels are empty. Its odd because I can ssh into my device on both my host computer and a separate laptop I have on the same network.
When try to refresh the network devices I get this error:
Error running command apollox.NetworkDevicesRefresh: command ‘apollox.NetworkDevicesRefresh’ not found. This is likely caused by the extension that contributes apollox.NetworkDevicesRefresh.
When I try to manually add a connection, I get this error:
Error running command apollox.NetworkDeviceAdd: command ‘apollox.NetworkDeviceAdd’ not found. This is likely caused by the extension that contributes apollox.NetworkDeviceAdd.
I have tried uninstalling the toradex extension, v3.2.0, and reinstalling it to no avail. Still getting the same error.
Based on the error messages you’re encountering with the apollox.NetworkDevicesRefresh and apollox.NetworkDeviceAdd commands, this appears to be an extension loading issue with the Torizon VS Code Extension(1).
Troubleshooting Steps
1. Complete Extension Reinstallation
Since you’ve already tried uninstalling and reinstalling the extension, let’s ensure a complete clean installation(2):
  • Manually delete extension files: Navigate to your VS Code extensions directory and manually delete any remaining Torizon extension files(2)
  • Reinstall the extension: Install the Torizon extension fresh from the VS Code marketplace(2)
  • Install in WSL: If you’re using WSL, make sure the extension is installed in both Windows VS Code and WSL(2)
2. Verify VS Code Environment
Ensure you’re launching VS Code correctly for Torizon development(1):
  • If using WSL, launch VS Code from a WSL terminal using code .(2)
  • Check the bottom left corner of VS Code to confirm it shows the correct environment (WSL distribution name if applicable)(2)
3. Check Extension Logs
Use VS Code’s developer tools to examine internal logs(2):
  • Open the VS Code command palette
  • Select “Developer: Toggle Developer Tools”
  • Go to the “Console” tab to view logs and look for error messages related to the Torizon extension(2)
4. Network Configuration
Since you can SSH to the device successfully, verify the network setup(3)(2):
  • Ensure both your development machine and the iMX7 device are on the same network(2)
  • Confirm the device IP address using the methods described in the SSH documentation(3)
  • Check that necessary ports are open between your machine and the development board(2)
5. Extension Version Compatibility
The apollox command references suggest there might be a compatibility issue with the extension version. Consider:
  • Updating VS Code to the latest version
  • Checking if there’s a newer version of the Torizon extension available
  • Verifying that your VS Code version is compatible with the Torizon extension version you’re using
The fact that SSH connectivity works confirms your network setup is correct, so the issue is specifically with the VS Code extension’s command registration and loading process(3)(2).
I uninstalled the Toradex extension again and deleted anything with Toradex in the extensions directory.
C:\Users\SimonAb\.vscode\extensions
Still getting the same errors.
Here is the developer tools log:
event.ts:888 [7be] potential listener LEAK detected, having 175 listeners already. MOST frequent listener (1):
check @ event.ts:888
event.ts:889 Error
    at pFi.create (event.ts:920:15)
    at K2e.u [as onDidChange] (event.ts:1105:34)
    at new sg (textModel.ts:397:53)
    at ETt.o (instantiationService.ts:169:18)
    at ETt.createInstance (instantiationService.ts:135:18)
    at BYe.I (modelService.ts:310:55)
    at BYe.createModel (modelService.ts:446:21)
    at Dst.provideTextContent (codeBlockPart.ts:523:29)
    at kYe.u (textModelResolverService.ts:187:33)
    at kYe.r (textModelResolverService.ts:78:15)
check @ event.ts:889
log.ts:460   ERR [7be] potential listener LEAK detected, having 175 listeners already. MOST frequent listener (1):: Error
    at pFi.create (vscode-file://vscode-app/c:/Users/SimonAb/AppData/Local/Programs/Microsoft%20VS%20Code/resources/app/out/vs/workbench/workbench.desktop.main.js:27:12071)
    at K2e.u [as onDidChange] (vscode-file://vscode-app/c:/Users/SimonAb/AppData/Local/Programs/Microsoft%20VS%20Code/resources/app/out/vs/workbench/workbench.desktop.main.js:29:1377)
    at new sg (vscode-file://vscode-app/c:/Users/SimonAb/AppData/Local/Programs/Microsoft%20VS%20Code/resources/app/out/vs/workbench/workbench.desktop.main.js:275:31449)
    at ETt.o (vscode-file://vscode-app/c:/Users/SimonAb/AppData/Local/Programs/Microsoft%20VS%20Code/resources/app/out/vs/workbench/workbench.desktop.main.js:1399:1716)
    at ETt.createInstance (vscode-file://vscode-app/c:/Users/SimonAb/AppData/Local/Programs/Microsoft%20VS%20Code/resources/app/out/vs/workbench/workbench.desktop.main.js:1399:1213)
    at BYe.I (vscode-file://vscode-app/c:/Users/SimonAb/AppData/Local/Programs/Microsoft%20VS%20Code/resources/app/out/vs/workbench/workbench.desktop.main.js:1337:1910)
    at BYe.createModel (vscode-file://vscode-app/c:/Users/SimonAb/AppData/Local/Programs/Microsoft%20VS%20Code/resources/app/out/vs/workbench/workbench.desktop.main.js:1338:888)
    at Dst.provideTextContent (vscode-file://vscode-app/c:/Users/SimonAb/AppData/Local/Programs/Microsoft%20VS%20Code/resources/app/out/vs/workbench/workbench.desktop.main.js:1942:13412)
    at kYe.u (vscode-file://vscode-app/c:/Users/SimonAb/AppData/Local/Programs/Microsoft%20VS%20Code/resources/app/out/vs/workbench/workbench.desktop.main.js:1313:22428)
    at kYe.r (vscode-file://vscode-app/c:/Users/SimonAb/AppData/Local/Programs/Microsoft%20VS%20Code/resources/app/out/vs/workbench/workbench.desktop.main.js:1313:21511)
error @ log.ts:460
event.ts:888 [7be] potential listener LEAK detected, having 198 listeners already. MOST frequent listener (89):
event.ts:889 Error
log.ts:460   ERR [7be] potential listener LEAK detected, having 198 listeners already. MOST frequent listener (89):: Error
error @ log.ts:460
log.ts:440  INFO Started local extension host with pid 18208.
log.ts:460   ERR navigator is now a global in nodejs, please see https://aka.ms/vscode-extensions/navigator for additional info on this error.: PendingMigrationError: navigator is now a global in nodejs, please see https://aka.ms/vscode-extensions/navigator for additional info on this error.
    at get (file:///c:/Users/SimonAb/AppData/Local/Programs/Microsoft%20VS%20Code/resources/app/out/vs/workbench/api/node/extensionHostProcess.js:402:6611)
    at Ye (c:\Users\SimonAb\.vscode\extensions\ms-vscode-remote.remote-wsl-0.104.3\dist\node\extension.js:2:49943)
    at R (c:\Users\SimonAb\.vscode\extensions\ms-vscode-remote.remote-wsl-0.104.3\dist\node\extension.js:2:45899)
    at c:\Users\SimonAb\.vscode\extensions\ms-vscode-remote.remote-wsl-0.104.3\dist\node\extension.js:2:49796
    at k (c:\Users\SimonAb\.vscode\extensions\ms-vscode-remote.remote-wsl-0.104.3\dist\node\extension.js:2:331335)
    at c:\Users\SimonAb\.vscode\extensions\ms-vscode-remote.remote-wsl-0.104.3\dist\node\extension.js:2:379045
    at Object.f [as use] (c:\Users\SimonAb\.vscode\extensions\ms-vscode-remote.remote-wsl-0.104.3\dist\node\extension.js:2:403567)
    at c:\Users\SimonAb\.vscode\extensions\ms-vscode-remote.remote-wsl-0.104.3\dist\node\extension.js:2:402921
    at Object.watch (c:\Users\SimonAb\.vscode\extensions\ms-vscode-remote.remote-wsl-0.104.3\dist\node\extension.js:2:402932)
    at b (c:\Users\SimonAb\.vscode\extensions\ms-vscode-remote.remote-wsl-0.104.3\dist\node\extension.js:2:404804)
    at e.<computed> [as initialize] (c:\Users\SimonAb\.vscode\extensions\ms-vscode-remote.remote-wsl-0.104.3\dist\node\extension.js:2:378323)
    at e.r [as initialize] (c:\Users\SimonAb\.vscode\extensions\ms-vscode-remote.remote-wsl-0.104.3\dist\node\extension.js:2:349209)
    at c:\Users\SimonAb\.vscode\extensions\ms-vscode-remote.remote-wsl-0.104.3\dist\node\extension.js:2:387122
    at p (c:\Users\SimonAb\.vscode\extensions\ms-vscode-remote.remote-wsl-0.104.3\dist\node\extension.js:2:341770)
    at e.<computed> [as initialize] (c:\Users\SimonAb\.vscode\extensions\ms-vscode-remote.remote-wsl-0.104.3\dist\node\extension.js:2:386312)
    at t.r [as initialize] (c:\Users\SimonAb\.vscode\extensions\ms-vscode-remote.remote-wsl-0.104.3\dist\node\extension.js:2:349209)
    at Array.<anonymous> (c:\Users\SimonAb\.vscode\extensions\ms-vscode-remote.remote-wsl-0.104.3\dist\node\extension.js:2:56537)
    at Et (c:\Users\SimonAb\.vscode\extensions\ms-vscode-remote.remote-wsl-0.104.3\dist\node\extension.js:2:51449)
    at u (c:\Users\SimonAb\.vscode\extensions\ms-vscode-remote.remote-wsl-0.104.3\dist\node\extension.js:2:56498)
    at he (c:\Users\SimonAb\.vscode\extensions\ms-vscode-remote.remote-wsl-0.104.3\dist\node\extension.js:2:150349)
    at e.<computed> (c:\Users\SimonAb\.vscode\extensions\ms-vscode-remote.remote-wsl-0.104.3\dist\node\extension.js:2:153613)
    at Object.initialize (c:\Users\SimonAb\.vscode\extensions\ms-vscode-remote.remote-wsl-0.104.3\dist\node\extension.js:2:349963)
    at c:\Users\SimonAb\.vscode\extensions\ms-vscode-remote.remote-wsl-0.104.3\dist\node\extension.js:2:67620
    at e.<computed> [as initialize] (c:\Users\SimonAb\.vscode\extensions\ms-vscode-remote.remote-wsl-0.104.3\dist\node\extension.js:2:67545)
    at c:\Users\SimonAb\.vscode\extensions\ms-vscode-remote.remote-wsl-0.104.3\dist\node\extension.js:2:356456
    at async c:\Users\SimonAb\.vscode\extensions\ms-vscode-remote.remote-wsl-0.104.3\dist\node\extension.js:2:355860
error @ log.ts:460
log.ts:440  INFO Invoking resolveAuthority(wsl)...
log.ts:440  INFO [LocalProcess0][resolveAuthority(wsl,1)][0ms] obtaining proxy...
log.ts:440  INFO [LocalProcess0][resolveAuthority(wsl,1)][6ms] invoking...
log.ts:440  INFO [LocalProcess0][resolveAuthority(wsl,1)][548ms] returned WebSocket(127.0.0.1:64020)
log.ts:440  INFO resolveAuthority(wsl) returned 'WebSocket(127.0.0.1:64020)' after 548 ms
log.ts:440  INFO Creating a socket (renderer-Management-34bb4da9-8039-4394-b28a-0ce81aca3557)...
log.ts:440  INFO Creating a socket (renderer-ExtensionHost-08b391b0-9d09-45a1-888a-ce8562678f44)...
log.ts:440  INFO Creating a socket (renderer-Management-34bb4da9-8039-4394-b28a-0ce81aca3557) was successful after 50 ms.
log.ts:440  INFO Creating a socket (renderer-ExtensionHost-08b391b0-9d09-45a1-888a-ce8562678f44) was successful after 294 ms.
TMScopeRegistry.ts:46 Overwriting grammar scope name to file mapping for scope source.yaml.
Old grammar file: file:///c%3A/Users/SimonAb/AppData/Local/Programs/Microsoft%20VS%20Code/resources/app/extensions/yaml/syntaxes/yaml.tmLanguage.json.
New grammar file: vscode-remote://wsl%2Btorizon/home/SAbrahamian/.vscode-server/extensions/redhat.vscode-yaml-1.19.1/syntaxes/yaml.tmLanguage.json
register @ TMScopeRegistry.ts:46
log.ts:440  INFO MCP Registry configured: https://api.mcp.github.com
log.ts:440  INFO Settings Sync: Account status changed from uninitialized to available
api.github.com/copilot/mcp_registry:1  Failed to load resource: the server responded with a status of 404 ()
log.ts:460   ERR Failed to fetch MCP registry providers Server returned 404
error @ log.ts:460
    at get (file:///home/SAbrahamian/.vscode-server/bin/1e3c50d64110be466c0b4a45222e81d2c9352888/out/vs/workbench/api/node/extensionHostProcess.js:402:6611)
    at /home/SAbrahamian/.vscode-server/extensions/github.copilot-chat-0.33.2/dist/extension.js:102:48546
    at /home/SAbrahamian/.vscode-server/extensions/github.copilot-chat-0.33.2/dist/extension.js:1:262
    at /home/SAbrahamian/.vscode-server/extensions/github.copilot-chat-0.33.2/dist/extension.js:102:50939
    at /home/SAbrahamian/.vscode-server/extensions/github.copilot-chat-0.33.2/dist/extension.js:102:52010
    at /home/SAbrahamian/.vscode-server/extensions/github.copilot-chat-0.33.2/dist/extension.js:102:54196
    at /home/SAbrahamian/.vscode-server/extensions/github.copilot-chat-0.33.2/dist/extension.js:111:2598
    at /home/SAbrahamian/.vscode-server/extensions/github.copilot-chat-0.33.2/dist/extension.js:112:2671
    at /home/SAbrahamian/.vscode-server/extensions/github.copilot-chat-0.33.2/dist/extension.js:112:9346
    at /home/SAbrahamian/.vscode-server/extensions/github.copilot-chat-0.33.2/dist/extension.js:114:21444
    at /home/SAbrahamian/.vscode-server/extensions/github.copilot-chat-0.33.2/dist/extension.js:114:25511
    at /home/SAbrahamian/.vscode-server/extensions/github.copilot-chat-0.33.2/dist/extension.js:114:27010
    at Object.<anonymous> (/home/SAbrahamian/.vscode-server/extensions/github.copilot-chat-0.33.2/dist/extension.js:1914:22058)
    at Module._compile (node:internal/modules/cjs/loader:1706:14)
    at Object..js (node:internal/modules/cjs/loader:1839:10)
    at Module.load (node:internal/modules/cjs/loader:1441:32)
    at Function.<anonymous> (node:internal/modules/cjs/loader:1263:12)
    at e._load (file:///home/SAbrahamian/.vscode-server/bin/1e3c50d64110be466c0b4a45222e81d2c9352888/out/vs/workbench/api/node/extensionHostProcess.js:402:5984)
    at t._load (file:///home/SAbrahamian/.vscode-server/bin/1e3c50d64110be466c0b4a45222e81d2c9352888/out/vs/workbench/api/node/extensionHostProcess.js:220:22582)
    at s._load (file:///home/SAbrahamian/.vscode-server/bin/1e3c50d64110be466c0b4a45222e81d2c9352888/out/vs/workbench/api/node/extensionHostProcess.js:212:24094)
    at TracingChannel.traceSync (node:diagnostics_channel:322:14)
    at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
    at Module.<anonymous> (node:internal/modules/cjs/loader:1463:12)
    at require (node:internal/modules/helpers:147:16)
    at kX.Cb (file:///home/SAbrahamian/.vscode-server/bin/1e3c50d64110be466c0b4a45222e81d2c9352888/out/vs/workbench/api/node/extensionHostProcess.js:251:1253)
    at process.processTicksAndRejections (node:internal/process/task_queues:105:5)
error @ log.ts:460
    at /home/SAbrahamian/.vscode-server/extensions/ms-azuretools.vscode-containers-2.3.0/dist/extension.bundle.js:2:1198730
    at get value (/home/SAbrahamian/.vscode-server/extensions/ms-azuretools.vscode-containers-2.3.0/dist/extension.bundle.js:2:1198051)
    at /home/SAbrahamian/.vscode-server/extensions/ms-azuretools.vscode-containers-2.3.0/dist/extension.bundle.js:2:1218394
    at Function.init (/home/SAbrahamian/.vscode-server/extensions/ms-azuretools.vscode-containers-2.3.0/dist/extension.bundle.js:2:1195207)
    at /home/SAbrahamian/.vscode-server/extensions/ms-azuretools.vscode-containers-2.3.0/dist/extension.bundle.js:2:1245105
    at init (/home/SAbrahamian/.vscode-server/extensions/ms-azuretools.vscode-containers-2.3.0/dist/extension.bundle.js:2:1195207)
    at new ZodObject (/home/SAbrahamian/.vscode-server/extensions/ms-azuretools.vscode-containers-2.3.0/dist/extension.bundle.js:2:1195448)
    at object (/home/SAbrahamian/.vscode-server/extensions/ms-azuretools.vscode-containers-2.3.0/dist/extension.bundle.js:2:1247246)
    at 69760 (/home/SAbrahamian/.vscode-server/extensions/ms-azuretools.vscode-containers-2.3.0/dist/extension.bundle.js:2:1250784)
    at __webpack_require__ (/home/SAbrahamian/.vscode-server/extensions/ms-azuretools.vscode-containers-2.3.0/dist/extension.bundle.js:2:1919530)
    at 37447 (/home/SAbrahamian/.vscode-server/extensions/ms-azuretools.vscode-containers-2.3.0/dist/extension.bundle.js:2:832978)
    at 66824 (/home/SAbrahamian/.vscode-server/extensions/ms-azuretools.vscode-containers-2.3.0/dist/extension.bundle.js:2:1153630)
    at 50724 (/home/SAbrahamian/.vscode-server/extensions/ms-azuretools.vscode-containers-2.3.0/dist/extension.bundle.js:2:928205)
    at 74265 (/home/SAbrahamian/.vscode-server/extensions/ms-azuretools.vscode-containers-2.3.0/dist/extension.bundle.js:2:1371595)
    at /home/SAbrahamian/.vscode-server/extensions/ms-azuretools.vscode-containers-2.3.0/dist/extension.bundle.js:2:1921176
    at Object.<anonymous> (/home/SAbrahamian/.vscode-server/extensions/ms-azuretools.vscode-containers-2.3.0/dist/extension.bundle.js:2:1921221)
    at Module.require (/home/SAbrahamian/.vscode-server/extensions/github.copilot-chat-0.33.2/dist/extension.js:82:36133)
    at Object.<anonymous> (/home/SAbrahamian/.vscode-server/extensions/ms-azuretools.vscode-containers-2.3.0/main.js:22:19)
error @ log.ts:460
log.ts:460   ERR [Extension Host] (node:15896) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
(Use `node --trace-deprecation ...` to show where the warning was created)
error @ log.ts:460
console.ts:139 [Extension Host] (node:15896) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
gCs @ console.ts:139
log.ts:460   ERR [Extension Host] (node:15896) ExperimentalWarning: SQLite is an experimental feature and might change at any time
error @ log.ts:460
console.ts:139 [Extension Host] (node:15896) ExperimentalWarning: SQLite is an experimental feature and might change at any time
log.ts:440  INFO [perf] Render performance baseline is 10ms
console.ts:139 [Extension Host] [11-20 08:49:55.218] TCB Extension activated
console.ts:139 [Extension Host] [11-20 08:49:55.223] TC Build IntelliSense schema loaded
console.ts:139 [Extension Host] [11-20 08:49:55.255] TC Build IntelliSense registered
console.ts:139 [Extension Host] [11-20 08:49:55.438] Activating Torizon IDE ...
console.ts:139 [Extension Host] [11-20 08:49:55.438] Torizon IDE version :: 3.2.0
log.ts:460   ERR chatParticipant must be declared in package.json: claude-code
error @ log.ts:460
console.ts:139 [Extension Host] [11-20 08:49:57.264] Latest Torizon IDE published :: 3.2.102
console.ts:139 [Extension Host] [11-20 08:49:57.264] Telemetry is enabled
console.ts:139 [Extension Host] [11-20 08:49:57.264] Extension collects completely anonymous telemetry data about templates usage. Participation in this anonymous program is optional, and you may opt-out if you'd not like to share any information. Check: https://developer.toradex.com/torizon/application-development/ide-extension/reference-documentation/data-collection/#how-to-opt-in-or-out
console.ts:139 [Extension Host] [11-20 08:49:57.264] Telemetry allows us to accurately gauge templates usage. This data will help us to focus better on the most used templates, adding new features and putting effort in the right place.
console.ts:139 [Extension Host] [11-20 08:49:57.264] Resolving host IP address ...
console.ts:139 [Extension Host] [11-20 08:49:57.983] Host IP address OK
console.ts:139 [Extension Host] [11-20 08:49:57.983] Bash as default shell OK
console.ts:139 [Extension Host] [11-20 08:49:57.990] Docker installed OK
console.ts:139 [Extension Host] [11-20 08:49:58.057] Docker running OK
console.ts:139 [Extension Host] [11-20 08:49:58.198] Docker compose OK
console.ts:139 [Extension Host] [11-20 08:49:58.212] WARNING :: PowerShell Core is not installed.
console.ts:139 [Extension Host] [11-20 08:49:58.217] git OK
console.ts:139 [Extension Host] [11-20 08:49:58.221] dig OK
console.ts:139 [Extension Host] [11-20 08:49:58.225] avahi-resolve OK
console.ts:139 [Extension Host] [11-20 08:49:58.231] nmap OK
console.ts:139 [Extension Host] [11-20 08:49:58.236] iputils-ping OK
console.ts:139 [Extension Host] [11-20 08:49:58.240] file OK
console.ts:139 [Extension Host] [11-20 08:49:58.245] sshpass OK
console.ts:139 [Extension Host] [11-20 08:49:58.258] iproute2 OK
console.ts:139 [Extension Host] [11-20 08:49:58.262] rsync OK
console.ts:139 [Extension Host] [11-20 08:49:58.267] python3 OK
console.ts:139 [Extension Host] [11-20 08:49:58.271] pipx OK
console.ts:139 [Extension Host] [11-20 08:49:58.272] Cloning project templates
console.ts:139 [Extension Host] [11-20 08:49:58.272] Templates repo: https://github.com/torizon/vscode-torizon-templates.git
console.ts:139 [Extension Host] [11-20 08:49:58.272] Templates branch: bookworm-7
console.ts:139 [Extension Host] [11-20 08:49:58.272] Templates tag/hash: tos7
console.ts:139 [Extension Host] [11-20 08:49:58.277] Project templates clone of branch bookworm-7 OK
console.ts:139 [Extension Host] [11-20 08:49:58.451] Project templates fetched OK
console.ts:139 [Extension Host] [11-20 08:49:58.464] Checkout templates repo to tag origin/bookworm-7 OK
log.ts:460   ERR [UriError]: Scheme contains illegal characters.: Error: [UriError]: Scheme contains illegal characters.
    at Q6 (file:///C:/Users/SimonAb/AppData/Local/Programs/Microsoft%20VS%20Code/resources/app/out/main.js:30:64382)
    at new cd (file:///C:/Users/SimonAb/AppData/Local/Programs/Microsoft%20VS%20Code/resources/app/out/main.js:30:67762)
    at new zr (file:///C:/Users/SimonAb/AppData/Local/Programs/Microsoft%20VS%20Code/resources/app/out/main.js:30:69200)
    at cd.revive (file:///C:/Users/SimonAb/AppData/Local/Programs/Microsoft%20VS%20Code/resources/app/out/main.js:30:68977)
    at d2.call (file:///C:/Users/SimonAb/AppData/Local/Programs/Microsoft%20VS%20Code/resources/app/out/main.js:88:106862)
    at Wf.s (file:///C:/Users/SimonAb/AppData/Local/Programs/Microsoft%20VS%20Code/resources/app/out/main.js:31:14859)
    at Wf.q (file:///C:/Users/SimonAb/AppData/Local/Programs/Microsoft%20VS%20Code/resources/app/out/main.js:31:14382)
    at ta.value (file:///C:/Users/SimonAb/AppData/Local/Programs/Microsoft%20VS%20Code/resources/app/out/main.js:31:13784)
    at P.C (file:///C:/Users/SimonAb/AppData/Local/Programs/Microsoft%20VS%20Code/resources/app/out/main.js:30:2373)
    at P.D (file:///C:/Users/SimonAb/AppData/Local/Programs/Microsoft%20VS%20Code/resources/app/out/main.js:30:2443)
    at P.fire (file:///C:/Users/SimonAb/AppData/Local/Programs/Microsoft%20VS%20Code/resources/app/out/main.js:30:2660)
    at ta.value (file:///C:/Users/SimonAb/AppData/Local/Programs/Microsoft%20VS%20Code/resources/app/out/main.js:28:5145)
    at P.fire (file:///C:/Users/SimonAb/AppData/Local/Programs/Microsoft%20VS%20Code/resources/app/out/main.js:30:2591)
    at ta.value (file:///C:/Users/SimonAb/AppData/Local/Programs/Microsoft%20VS%20Code/resources/app/out/main.js:28:5333)
    at F (file:///C:/Users/SimonAb/AppData/Local/Programs/Microsoft%20VS%20Code/resources/app/out/main.js:28:7627)
    at IpcMainImpl.i (file:///C:/Users/SimonAb/AppData/Local/Programs/Microsoft%20VS%20Code/resources/app/out/main.js:36:10815)
    at IpcMainImpl.emit (node:events:519:28)
    at Session.<anonymous> (node:electron/js2c/browser_init:2:106419)
    at Session.emit (node:events:519:28)
error @ log.ts:460
console.ts:139 [Extension Host] [11-20 08:50:03.142] xonsh installation OK
console.ts:139 [Extension Host] [11-20 08:50:03.142] WARNING :: PowerShell is not installed, if you are using Torizon v6.x.x or templates from Torizon v6.x.x, PowerShell is required.
mainThreadExtensionService.ts:108 Activating extension 'Toradex.apollox-vscode' failed: command 'torizon_debug_port.snmptoserial' already exists.
$onExtensionActivationError @ mainThreadExtensionService.ts:108
console.ts:139 [Extension Host] [FileSystemService] file:///home/SAbrahamian/.vscode-server/data/User/globalStorage/github.copilot-chat/commandEmbeddings.json is a LARGE file (14MB > 5MB)
$logExtensionHostMessage @ mainThreadConsole.ts:39
S @ rpcProtocol.ts:458
Q @ rpcProtocol.ts:443
M @ rpcProtocol.ts:373
L @ rpcProtocol.ts:299
(anonymous) @ rpcProtocol.ts:161
C @ event.ts:1201
fire @ event.ts:1232
fire @ ipc.net.ts:652
A @ ipc.net.ts:1022
(anonymous) @ ipc.net.ts:879
C @ event.ts:1201
acceptChunk @ ipc.net.ts:394
(anonymous) @ ipc.net.ts:350
(anonymous) @ browserSocketFactory.ts:232
C @ event.ts:1201
Vbn.j.onload @ browserSocketFactory.ts:93
Any help is appreciated.
Hi Simon,
One of our support engineers will look at this. Maybe we start by suggesting some things by email, otherwise we jump on a call this afternoon.
Michael Park
Toradex
Hey @SAbrahamian,
Can you try and add your device manually?
-Eric
Hi @eric.tx,
When I click the + button in the network devices tab, I immediately get this error:
Hey @SAbrahamian ,
When you open vscode/the extension, there should be some logs in the output terminal for the Torizon IDE activating. Can you post these full logs?
-Eric
Hey @SAbrahamian,
Looking into this, we have another customer will the same issue. I will try and replicate. We did just do a 3.2.0 release of the IDE, so maybe this has something to do. I will find out.
-Eric
Hey @SAbrahamian
Are you trying to do it from the WSL side? From the Windows side you should be able to only connect to WSL, so these kinds os messages are expected.
Could you confirm?
@eric.tx Hi eric,
Here is the log:
event.ts:888 [77f] potential listener LEAK detected, having 175 listeners already. MOST frequent listener (1):
event.ts:889 Error
log.ts:460   ERR [77f] potential listener LEAK detected, having 175 listeners already. MOST frequent listener (1):: Error
error @ log.ts:460
event.ts:888 [77f] potential listener LEAK detected, having 198 listeners already. MOST frequent listener (89):
event.ts:889 Error
log.ts:460   ERR [77f] potential listener LEAK detected, having 198 listeners already. MOST frequent listener (89):: Error
error @ log.ts:460
log.ts:440  INFO Started local extension host with pid 23860.
error @ log.ts:460
log.ts:440  INFO [LocalProcess0][resolveAuthority(wsl,1)][5ms] invoking...
log.ts:440  INFO [LocalProcess0][resolveAuthority(wsl,1)][524ms] returned WebSocket(127.0.0.1:65504)
log.ts:440  INFO resolveAuthority(wsl) returned 'WebSocket(127.0.0.1:65504)' after 524 ms
log.ts:440  INFO Creating a socket (renderer-Management-8f0c8284-5598-4a5c-b1e7-7bedbb720022)...
log.ts:440  INFO Creating a socket (renderer-ExtensionHost-0b23c4f3-2d02-42bc-b7fb-37df02571279)...
log.ts:440  INFO Creating a socket (renderer-Management-8f0c8284-5598-4a5c-b1e7-7bedbb720022) was successful after 50 ms.
log.ts:440  INFO Creating a socket (renderer-ExtensionHost-0b23c4f3-2d02-42bc-b7fb-37df02571279) was successful after 291 ms.
error @ log.ts:460
error @ log.ts:460
error @ log.ts:460
log.ts:460   ERR [Extension Host] (node:2736) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
error @ log.ts:460
console.ts:139 [Extension Host] (node:2736) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
log.ts:460   ERR [Extension Host] (node:2736) ExperimentalWarning: SQLite is an experimental feature and might change at any time
error @ log.ts:460
console.ts:139 [Extension Host] (node:2736) ExperimentalWarning: SQLite is an experimental feature and might change at any time
console.ts:139 [Extension Host] [11-20 10:07:00.499] TCB Extension activated
console.ts:139 [Extension Host] [11-20 10:07:00.502] TC Build IntelliSense schema loaded
console.ts:139 [Extension Host] [11-20 10:07:00.540] TC Build IntelliSense registered
console.ts:139 [Extension Host] [11-20 10:07:00.675] Activating Torizon IDE ...
console.ts:139 [Extension Host] [11-20 10:07:00.676] Torizon IDE version :: 3.2.0
log.ts:440  INFO [perf] Render performance baseline is 11ms
console.ts:139 [Extension Host] [11-20 10:07:01.046] Latest Torizon IDE published :: 3.2.102
console.ts:139 [Extension Host] [11-20 10:07:01.046] Telemetry is enabled
console.ts:139 [Extension Host] [11-20 10:07:01.046] Extension collects completely anonymous telemetry data about templates usage. Participation in this anonymous program is optional, and you may opt-out if you'd not like to share any information. Check: https://developer.toradex.com/torizon/application-development/ide-extension/reference-documentation/data-collection/#how-to-opt-in-or-out
console.ts:139 [Extension Host] [11-20 10:07:01.046] Telemetry allows us to accurately gauge templates usage. This data will help us to focus better on the most used templates, adding new features and putting effort in the right place.
console.ts:139 [Extension Host] [11-20 10:07:01.046] Resolving host IP address ...
error @ log.ts:460
console.ts:139 [Extension Host] [11-20 10:07:02.314] Host IP address OK
console.ts:139 [Extension Host] [11-20 10:07:02.314] Bash as default shell OK
console.ts:139 [Extension Host] [11-20 10:07:02.322] Docker installed OK
console.ts:139 [Extension Host] [11-20 10:07:02.684] Docker running OK
error @ log.ts:460
console.ts:139 [Extension Host] [11-20 10:07:03.125] Docker compose OK
console.ts:139 [Extension Host] [11-20 10:07:03.223] WARNING :: PowerShell Core is not installed.
console.ts:139 [Extension Host] [11-20 10:07:03.317] git OK
console.ts:139 [Extension Host] [11-20 10:07:03.406] dig OK
console.ts:139 [Extension Host] [11-20 10:07:03.417] avahi-resolve OK
console.ts:139 [Extension Host] [11-20 10:07:03.424] nmap OK
console.ts:139 [Extension Host] [11-20 10:07:03.437] iputils-ping OK
console.ts:139 [Extension Host] [11-20 10:07:03.456] file OK
console.ts:139 [Extension Host] [11-20 10:07:03.461] sshpass OK
console.ts:139 [Extension Host] [11-20 10:07:03.474] iproute2 OK
console.ts:139 [Extension Host] [11-20 10:07:03.479] rsync OK
console.ts:139 [Extension Host] [11-20 10:07:03.483] python3 OK
console.ts:139 [Extension Host] [11-20 10:07:03.488] pipx OK
console.ts:139 [Extension Host] [11-20 10:07:03.488] Cloning project templates
console.ts:139 [Extension Host] [11-20 10:07:03.488] Templates repo: https://github.com/torizon/vscode-torizon-templates.git
console.ts:139 [Extension Host] [11-20 10:07:03.488] Templates branch: bookworm-7
console.ts:139 [Extension Host] [11-20 10:07:03.488] Templates tag/hash: tos7
console.ts:139 [Extension Host] [11-20 10:07:03.497] Project templates clone of branch bookworm-7 OK
console.ts:139 [Extension Host] [11-20 10:07:03.760] Cloning project templates
console.ts:139 [Extension Host] [11-20 10:07:03.760] Using TEST_TEMPLATES_GIT_REPO=https://github.com/torizon/vscode-torizon-templates.git
console.ts:139 [Extension Host] [11-20 10:07:03.760] Using TEST_TEMPLATES_GIT_REPO_BRANCH=bookworm-7
console.ts:139 [Extension Host] [11-20 10:07:05.562] Project templates clone of branch bookworm-7 OK
console.ts:139 [Extension Host] [11-20 10:07:05.615] Checkout templates repo to tag origin/bookworm-7 OK
console.ts:139 [Extension Host] [11-20 10:07:09.507] xonsh installation OK
console.ts:139 [Extension Host] [11-20 10:07:09.507] WARNING :: PowerShell is not installed, if you are using Torizon v6.x.x or templates from Torizon v6.x.x, PowerShell is required.
notificationsAlerts.ts:42 Error running command apollox.NetworkDevicesRefresh: command 'apollox.NetworkDevicesRefresh' not found. This is likely caused by the extension that contributes apollox.NetworkDevicesRefresh.
c @ notificationsAlerts.ts:42
(anonymous) @ notificationsAlerts.ts:28
C @ event.ts:1201
D @ event.ts:1212
fire @ event.ts:1236
addNotification @ notifications.ts:228
error @ notificationService.ts:189
(anonymous) @ treeView.ts:1677
C @ event.ts:1201
D @ event.ts:1212
run @ actions.ts:195
await in run
onClick @ menuEntryActionViewItem.ts:210
(anonymous) @ actionViewItems.ts:157
notificationsAlerts.ts:42 Error running command apollox.NetworkDeviceAdd: command 'apollox.NetworkDeviceAdd' not found. This is likely caused by the extension that contributes apollox.NetworkDeviceAdd.
C @ event.ts:1201
D @ event.ts:1212
C @ event.ts:1201
D @ event.ts:1212
await in run
Could you confirm?
Hi @matheus.tx ,
I usually run VS code from my windows desktop, without issue. This connectivity issue is recent, within the last few days.
I had recently reloaded my device with the torizon easy installer, and reloaded the Torizon OS Upstream v7.4.0-build.28.
Here’s my device info if it helps.
(.venv) 🐧 SAbrahamian @MU69-PC~/snmptoserial: ssh torizon@10.85.76.237
torizon@10.85.76.237's password:
Last login: Thu Nov 20 15:13:39 2025 from 10.85.76.221
Provision Code: QPOVZJ
Use this code to pair this device on https://pair.torizon.io
torizon@colibri-imx7-emmc-12828052:~$ sudo tdx-info
Password:
Software summary
Kernel version:           6.6.108-7.4.0-00057-g451f1e35226f #1-Torizon SMP PREEMPT Mon Jun 30 14:11:55 UTC 2025
Kernel command line:      root=LABEL=otaroot rootfstype=ext4 quiet logo.nologo vt.global_cursor_default=0 plymouth.ignore-serial-consoles splash fbcon=map:3 ostree=/ostree/boot.1/torizon/22d58afd3489301015d8dd92011adee7c16b9fe8bedfe39c90cb8b42e0278e8d/0
Distro name:              NAME="Torizon OS Upstream"
Distro version:           VERSION_ID=7.4.0-build.28
Hostname:                 colibri-imx7-emmc-12828052
Hardware info
HW model:                 Toradex Colibri iMX7D 1GB (eMMC) on Colibri Evaluation Board V3
Toradex version:          0039 V1.1B
Serial number:            12828052
Processor arch:           armv7l
torizon@colibri-imx7-emmc-12828052:~$ ifconfig
br-aef29238d6e8: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        inet 172.18.0.1  netmask 255.255.0.0  broadcast 172.18.255.255
        ether 02:42:be:73:a1:53  txqueuelen 0  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 0  bytes 0 (0.0 B)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
docker0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        inet 172.17.0.1  netmask 255.255.0.0  broadcast 172.17.255.255
        ether 02:42:04:45:19:7b  txqueuelen 0  (Ethernet)
ethernet0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 10.85.76.237  netmask 255.255.255.0  broadcast 10.85.76.255
        inet6 fe80::b094:b8ff:35da:e989  prefixlen 64  scopeid 0x20<link>
        ether 00:14:2d:c3:bd:94  txqueuelen 1000  (Ethernet)
        RX packets 7577  bytes 957477 (935.0 KiB)
        RX errors 0  dropped 494  overruns 0  frame 0
        TX packets 1638  bytes 298439 (291.4 KiB)
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 10  bytes 1690 (1.6 KiB)
        TX packets 10  bytes 1690 (1.6 KiB)
you have this on the bottom of your VS Code instance?
The commands will work only on the WSL side.
@matheus.tx, yes I do have that in the corner of my VS Code window. Working with embedded linux is new to me.
I uninstalled v3.2.0 of the Torizon IDE Extension and installed V3.1.1 and I am able to see my device again.
Hey @SAbrahamian,
Why this is a great short term solution, Long term it would be better if you weren’t limited to a specific version.
Would you mind letting me know how you installed WSL? Was anything modified from this environment to the best of your knowledge?
-Eric
Hi @eric.tx
I installed WSL when I installed VS Code. When I open a terminal in WSL I get this message:
Welcome to the Torizon WSL 2 v1.0.0
Docker service OK
Success
🐧 SAbrahamian @MU69-PC~:
This is what windows tells me about the WSL version.
I have not modified the WSL environment to my knowledge.
Hey @SAbrahamian,
Thanks for that,
And can you check while in WSL on two environment variables. Also in the standard windows cmd line.
  • printenv TEST_TEMPLATES_GIT_REPO
  • printenv TEST_TEMPLATES_GIT_REPO_BRANCH
These variables came from your logs you shared.
-Eric
I was not able to see those individual environment variables.
🐧 SAbrahamian @MU69-PC~: sudo printenv TEST_TEMPLATES_GIT_REPO
[sudo] password for SAbrahamian:
🐧 SAbrahamian @MU69-PC~: sudo printenv TEST_TEMPLATES_GIT_REPO_BRANCH
🐧 SAbrahamian @MU69-PC~: printenv
SHELL=/bin/bash
SLINT_STYLE=fluent-dark
WSL2_GUI_APPS_ENABLED=1
WSL_DISTRO_NAME=Torizon
NAME=MU69-PC
PWD=/home/SAbrahamian
LOGNAME=SAbrahamian
HOME=/home/SAbrahamian
LANG=en_US.UTF-8
WSL_INTEROP=/run/WSL/21814_interop
WAYLAND_DISPLAY=wayland-0
TERM=xterm-256color
USER=SAbrahamian
DISPLAY=:0
SHLVL=1
XDG_RUNTIME_DIR=/mnt/wslg/runtime-dir
PS1=\[\033[1;48;5;15;38;5;17m\]🐧 \u \[\033[0;32m\]\[\033[1;38;5;34m\]@\h\[\033[0;32m\]\[\033[1;38;5;111m\]\w\[\033[0m\]:
WSLENV=
PATH=/home/SAbrahamian/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/usr/lib/wsl/lib:/mnt/c/Program Files/WindowsApps/MicrosoftCorporationII.WindowsSubsystemForLinux_2.5.7.0_x64__8wekyb3d8bbwe:/mnt/c/WINDOWS/system32:/mnt/c/WINDOWS:/mnt/c/WINDOWS/System32/Wbem:/mnt/c/WINDOWS/System32/WindowsPowerShell/v1.0/:/mnt/c/WINDOWS/System32/OpenSSH/:/mnt/c/Program Files/dotnet/:/mnt/c/Program Files (x86)/Microchip/MPLAB C32 Suite/bin:/mnt/c/Program Files/PuTTY/:/mnt/c/Users/SimonAb/AppData/Local/Microsoft/WindowsApps:/mnt/c/Users/SimonAb/AppData/Local/Programs/Microsoft VS Code/bin:/home/SAbrahamian/.local/bin:/home/SAbrahamian/.local/bin:/home/SAbrahamian/.local/bin
HOSTTYPE=x86_64
PULSE_SERVER=unix:/mnt/wslg/PulseServer
_=/usr/bin/printenv
Hey @SAbrahamian,
Thank you,
Looks like we could reproduce the error. So A fix is coming soon.
-Eric
