So I tried to rebuild the SDK this morning in VSCode and the process is failing here:
[4631 ms] Start: Starting container
[4632 ms] Start: Run: docker run --sig-proxy=false -a STDOUT -a STDERR --mount type=bind,source=z:\Docs\tarform\code\founders,target=/workspaces/founders,consistency=cached --mount source=C:\Users\fireeC:\Users\firee/.moses,target=/home/torizon/.moses,type=bind --mount source=//var/run/docker.sock,target=/var/run/docker.sock,type=bind --mount source=c:\Users\firee\.vscode\extensions\toradex.torizon-1.3.0,target=/home/torizon/.torizon-extension,type=bind --mount type=volume,src=vscode,dst=/vscode -l vsch.local.folder=z:\Docs\tarform\code\founders\tarform -l vsch.quality=stable -l vsch.remote.devPort=0 -e AR=arm-linux-gnueabihf-ar -e AS=arm-linux-gnueabihf-as -e CC=arm-linux-gnueabihf-gcc -e CXX=arm-linux-gnueabihf-g++ -e CPP=arm-linux-gnueabihf-cpp -e STRIP=arm-linux-gnueabihf-strip -e LD=arm-linux-gnueabihf-ld -e CROSS_COMPILE=arm-linux-gnueabihf- -e QMAKE=arm-linux-gnueabihf-qmake -e QT_INCLUDES=/usr/include/arm-linux-gnueabihf/qt5 --network=host --entrypoint /bin/sh vsc-tarform-f5b799831addd84f05f587dff0335418 -c echo Container started
docker: Error response from daemon: CreateFile C:\Users\fireeC:\Users\firee\.mos
es: The filename, directory name, or volume label syntax is incorrect.
See 'docker run --help'.
[5603 ms] Start: Run: docker ps -q -a --filter label=vsch.local.folder=z:\Docs\tarform\code\founders\tarform --filter label=vsch.quality=stable
[6363 ms] Command failed: docker run --sig-proxy=false -a STDOUT -a STDERR --mount type=bind,source=z:\Docs\tarform\code\founders,target=/workspaces/founders,consistency=cached --mount source=C:\Users\fireeC:\Users\firee/.moses,target=/home/torizon/.moses,type=bind --mount source=//var/run/docker.sock,target=/var/run/docker.sock,type=bind --mount source=c:\Users\firee\.vscode\extensions\toradex.torizon-1.3.0,target=/home/torizon/.torizon-extension,type=bind --mount type=volume,src=vscode,dst=/vscode -l vsch.local.folder=z:\Docs\tarform\code\founders\tarform -l vsch.quality=stable -l vsch.remote.devPort=0 -e AR=arm-linux-gnueabihf-ar -e AS=arm-linux-gnueabihf-as -e CC=arm-linux-gnueabihf-gcc -e CXX=arm-linux-gnueabihf-g++ -e CPP=arm-linux-gnueabihf-cpp -e STRIP=arm-linux-gnueabihf-strip -e LD=arm-linux-gnueabihf-ld -e CROSS_COMPILE=arm-linux-gnueabihf- -e QMAKE=arm-linux-gnueabihf-qmake -e QT_INCLUDES=/usr/include/arm-linux-gnueabihf/qt5 --network=host --entrypoint /bin/sh vsc-tarform-f5b799831addd84f05f587dff0335418 -c echo Container started
trap "exit 0" 15
while sleep 1 & wait $!; do :; done
I’ve got a hunch the the error docker: Error response from daemon: CreateFile C:\Users\fireeC:\Users\firee\.mos es: The filename, directory name, or volume label syntax is incorrect. correctly identifies that the path C:\Users\fireeC:\Users\firee\.mos does not exist on my system… I’ll try the bleeding edge version of the VSCode plugin…
