Not a question. The instructions/cheat sheet here no longer works.
Found out the hard way flashing my board today.
ssh torizon@192.168.1.160
cd /
cd sysroot
cd boot
cd ostree
cd torizon hit the TAB key here to fill in the name then hit return
cd dtb
sudo nano overlays.txt
Erase what is there. Replace it with the following:
Apologies for any misleading instructions you may have received. The table on the bottom of this page should be up-to-date for which overlays to use for which Toradex peripheral: Device Tree Overlays on Torizon | Toradex Developer Center
Please note the accessory column, as there’s multiple accessories that give LVDS functionality here. The list of overlays you have seems to mix the mezzanine accessory and the DSI to LVDS adapter accessory. But I guess it still works fine enough it seems despite the mix.
