I can help you troubleshoot the display issue with your 10.1" DSI capacitive touch display on the Verdin iMX95.
Hardware Connection Verification
First, ensure your display is properly connected to the Mallow Carrier Board (1). The flat ribbon cable should be connected with pin 1 of the display controller matching pin 1 of the carrier board connector (1).
Device Tree Overlay Configuration
For the Capacitive Touch Display 10.1" DSI to work properly, you need to apply the correct device tree overlay (1). The display requires pre-compiled device tree overlays that are provided by Toradex (1).
For Yocto-based BSP
On Linux BSP, Toradex provides pre-compiled, ready-to-use device tree overlays for this display (1). You can enable them by following the instructions in the Device Tree Overlays (Linux) documentation (1).
Display Status Verification
You can check if the display is properly detected by examining the system files:
cat /sys/devices/platform/display-subsystem/drm/card0/card0-LVDS-1/status
cat /sys/devices/platform/display-subsystem/drm/card0/card0-LVDS-1/enabled
cat /sys/devices/platform/display-subsystem/drm/card0/card0-LVDS-1/modes
The display should show as “connected” and “enabled” with a resolution of 1280x800 (2).
Important Note About Display Interface
The 10.1" DSI display is actually an LVDS display with a DSI interface and a DSI-to-LVDS bridge (2). This is why you might see LVDS references in the system - this is expected behavior (2).
Troubleshooting Steps
Verify Hardware Connections: Double-check that the flat ribbon cable is properly seated and the blue stripes are facing up (2)
Check Device Tree: Ensure the correct device tree overlay for the 10.1" DSI display is applied to your system
Test Framebuffer: You can test if the display hardware is working by writing directly to the framebuffer:
dd if=/dev/urandom of=/dev/fb0 bs=1024 count=4096This should display a random pattern on the screen (2)
Review Display Logs: Check
dmesgoutput for any display-related errors or panel detection messages
Additional Resources
For more advanced display configuration, refer to the Display Output, Resolution and Timings (Linux) article (1). For brightness adjustment, consult the Backlight (Linux) documentation (1).
The capacitive touch screen should work out-of-the-box with the BSP, and touch screen calibration information is available in the dedicated Touch Screen Calibration (Linux) documentation (1).
