[Verdin iMX95 BSP 7.6.0] DSI-to-HDMI (LT8912B) No Display — imx95-pixel-interleaver fails to create device link with display-controller (fw_devlink cycle)
[Verdin iMX95] DSI-to-HDMI (LT8912B) Not Working — imx95-pixel-interleaver Failed to Create Device Link
Environment
Item Detail
SoM Verdin iMX95 Hexa 8GB WB IT V1.0B (S/N: 12594470)
Carrier Board Custom carrier board (Mallow-compatible socket)
DSI Adapter Custom expansion module with Lontium LT8912B (DSI-to-HDMI bridge)
OS Image TDX Wayland with XWayland 7.6.0+build.14 (Reference Multimedia Image)
Kernel 6.6.129-7.6.0
Base DTB imx95-verdin-wifi-dev.dtb
Active Overlays verdin-imx95_dsi-to-hdmi_overlay.dtbo, verdin-imx95_spidev_overlay.dtbo
Background / Setup
This setup uses a custom carrier board (not the official Dahlia or Mallow) designed around the Mallow SOM socket. The board has the following relevant hardware:
  • LT8912B DSI-to-HDMI bridge connected to I2C_2_DSI (SODIMM pins 53/55, lpi2c3, 42530000.i2c, bus i2c-2) at addresses 0x48 and 0x49
  • DSI signals all routed to the LT8912B expansion module socket
  • No on-board GPIO expander at i2c-1 (0x21) — only the SOM-internal pca953x 0-0020 is present
Image Recovery
The board was originally running a minimal image. Since the custom board lacks USB pinctrl for RNDIS/UMS recovery and has no recovery button or accessible SODIMM Pin 246, USB-based TEZI recovery was not possible.
Recovery was performed manually via USB RNDIS (usb0: 192.168.11.1/24) using HTTP + dd:
  1. Flashed imx-boot to /dev/mmcblk0boot0
  2. Extracted rootfs.bootfs.tar.xz to mmcblk0p1 (FAT)
  3. Extracted rootfs.tar.xz to mmcblk0p2 (ext4)
  4. Applied u-boot-initial-env-sd via fw_setenv -s
After recovery, the board boots successfully into TDX Wayland with XWayland 7.6.0+build.14.
Overlay Modification
The stock verdin-imx95_dsi-to-hdmi_overlay.dtbo references lpi2c4 (42540000.i2c), but the LT8912B is physically connected to lpi2c3 (42530000.i2c, i.e., i2c-2). This was corrected by decompiling the DTB overlay with dtc, changing lpi2c4 → lpi2c3 in __fixups__, recompiling, and deploying.
Verification:
i2cdetect -y 2
# 0x48, 0x49 detected (UU — driver bound)
ls -la /sys/bus/i2c/devices/2-0048/driver
# → .../bus/i2c/drivers/lt8912
LT8912B is correctly detected and driver-bound on i2c-2. :white_check_mark:
Problem Description
Despite the LT8912B driver binding successfully, HDMI output never works. Weston fails to start, and no CRTC is created.
Key dmesg errors (every boot):
[9.223] imx95-dpu 4b400000.display-controller: [drm] Cannot find any crtc or sizes
[9.237] imx95-dpu 4b400000.display-controller: [drm] Cannot find any crtc or sizes
[9.239] imx95-pixel-interleaver 4b0d0000.bridge: Failed to create device link (0x180) with 4b400000.display-controller
Weston log:
DRM: head 'HDMI-A-1' found, connector 41 is connected
Failed to lookup init function: /lib/libgbm.so.1: undefined symbol: gbm_surface_get_in_fence_fd
no available modes for HDMI-A-1
Cannot configure an output using weston_drm_output_api.
DRM state:
ls /sys/class/drm/card0/crtc*
# (empty — no CRTC registered)
cat /sys/class/drm/card0-HDMI-A-1/status
# connected
Root Cause Analysis
Source code review
After reviewing the BSP kernel source (toradex_6.6-2.2.x-imx):
  • imx95-pixel-interleaver.c: No device_link_add call found. The driver only calls drm_bridge_add() and of_drm_find_bridge().
  • dpu95-kms.c (dpu95_kms_prepare → dpu95_kms_init_encoder_per_crtc): Calls drm_bridge_attach() which traverses the full bridge chain (DPU → pixel-interleaver → pixel-link → MIPI-DSI → LT8912B).
Actual cause: fw_devlink circular dependency
The Failed to create device link (0x180) error originates from the Linux fw_devlink subsystem (not the driver code itself), which automatically creates device links from DTB phandle references. The display pipeline has a circular dependency:
/soc/display-controller@4b400000  ←→  /soc/bridge@4b0d0000/channel@0
Both devices reference each other via OF graph endpoints. When fw_devlink tries to enforce probe ordering, it detects the cycle and the device_link_add call fails with -EINVAL, causing imx95-pixel-interleaver probe to fail. Without a registered bridge, imx95-dpu cannot build the DRM pipeline and reports “Cannot find any crtc or sizes”.
Confirmed by kernel boot log:
[0.041] /soc/bridge@4b0d0000/channel@0: Fixed dependency cycle(s) with /soc/display-controller@4b400000
[0.041] /soc/display-controller@4b400000: Fixed dependency cycle(s) with /soc/bridge@4b0d0000/channel@0
Attempted Workarounds
1. fw_devlink=off
fw_setenv tdxargs "fw_devlink=off"
Result: Circular dependency resolved — but new error appeared:
imx95-pixel-interleaver 4b0d0000.bridge: failed to request irq: -13 (EACCES)
imx95-pixel-interleaver: probe of 4b0d0000.bridge failed with error -13
With fw_devlink=off, irq_imx_irqsteer (the interrupt mux for the display subsystem) probes after imx95-pixel-interleaver, so the IRQ request fails with -EACCES.
2. fw_devlink=permissive
fw_setenv tdxargs "fw_devlink=permissive"
Result: Same as default — Failed to create device link (0x180) still occurs. permissive mode does not suppress the cycle detection failure.
3. Manual unbind/bind
echo "4b0d0000.bridge" > /sys/bus/platform/drivers/imx95-pixel-interleaver/unbind
echo "4b0d0000.bridge" > /sys/bus/platform/drivers/imx95-pixel-interleaver/bind
echo "4b400000.display-controller" > /sys/bus/platform/drivers/imx95-dpu/unbind
echo "4b400000.display-controller" > /sys/bus/platform/drivers/imx95-dpu/bind
Result: imx95-dpu rebind fails with -EEXIST because lt8912 already registered its DSI device during the first probe attempt (devm_mipi_dsi_device_register_full), and the second attempt finds a duplicate entry.
Additional Context
  • Same issue exists on SMARC iMX95 with DSI-to-HDMI adapter (community thread)
  • The mainline kernel patch series (October 2025, Marek Vasut) reworks pixel-interleaver and pixel-link drivers to remove inter-channel dependencies, and confirms: “Both DSI-to-HDMI path using LT8912 bridge and LVDS single-lane were tested on Toradex i.MX95 Verdin EVK v1.2” — but these changes are not yet in the Toradex BSP 7.6.0
Questions
  1. Is there a known fix or patch for imx95-pixel-interleaver probe failure due to fw_devlink circular dependency in BSP 7.6.0?
  2. Is there a pre-built kernel-devsrc or cross-compilation SDK available to rebuild the imx95_pixel_interleaver.ko module with a fix (e.g., returning -EPROBE_DEFER instead of -EINVAL on device_link_add failure)?
  3. Is BSP 7.7.0 or a nightly build expected to include the mainline pixel-interleaver rework that resolves this?
Full dmesg (display-related excerpt)
[    8.670] lt8912 2-0048: supply vccmipirx not found, using dummy regulator
[    8.697] lt8912 2-0048: supply vcchdmipll not found, using dummy regulator
[    9.174] [drm] Initialized imx95-dpu 1.0.0 20230213 for 4b400000.display-controller on minor 0
[    9.188] imx95-dpu 4b400000.display-controller: [drm] Cannot find any crtc or sizes
[    9.201] imx95-pixel-interleaver 4b0d0000.bridge: Failed to create device link (0x180) with 4b400000.display-controller
[    9.214] imx95-dpu 4b400000.display-controller: [drm] Cannot find any crtc or sizes
Posted by: Verdin iMX95 custom carrier board developer BSP: 7.6.0+build.14 | Kernel: 6.6.129-7.6.0 | Date: May 2026
I’d be glad to help with your Verdin iMX95 DSI-to-HDMI display issue! Could you let me know which OS and version you are using?
To help me provide the most accurate guidance for your specific setup, please also run the tdx-info command on your device and share the output. You can find more information about this command at https://developer.toradex.com/software/development-resources/tdx-info/.
Common platforms include:
  • Hardware: Verdin i.MX8M Plus, Verdin AM62, Aquila AM69, Apalis i.MX8QP, Colibri i.MX8X, Ivy Carrier Board, Ixora Carrier Board, Mallow Carrier Board, IMX95
  • Operating System: Yocto 7.2.0, Torizon 6.8.2, Torizon OS 6, BSP 7, BSP 6, Torizon OS 7.2.0-build.13
  • Implementation: Docker, Chromium, Qt, weston
  • Integration: Device tree, gpio, spi, can, hdmi, display, camera, recovery mode, device driver, kernel patch, ethernet, rpmsg, lvds
Once I have this information, I can provide specific guidance for your DSI-to-HDMI configuration and the fw_devlink circular dependency issue you’re experiencing.
root@verdin-imx95-12594470:~# sh /tmp/tdx-info
Software summary
Bootloader: U-Boot
Kernel version: 6.6.129-7.6.0 #1 SMP PREEMPT Thu Mar 26 15:16:22 UTC 2026
Kernel command line: root=PARTUUID=5805e274-02 ro rootwait console=tty1 console=ttyLP2,115200 fw_devlink=permissive
Distro name: NAME=“TDX Wayland with XWayland”
Distro version: VERSION_ID=7.6.0-build.14
Distro variant: -
Hostname: verdin-imx95-12594470
Hardware info
HW model: Toradex Verdin iMX95 WB on Verdin Development Board
Toradex version: 0089 V1.0B
Serial number: 12594470
Processor arch: aarch64
Available block devices:
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
mmcblk0 179:0 0 28.8G 0 disk
mmcblk0p1 179:1 0 48M 0 part /boot\x0a/run/media/BOOT-mmcblk0p1
mmcblk0p2 179:2 0 28.8G 0 part /
mmcblk0boot0 179:8 0 31.5M 1 disk
mmcblk0boot1 179:16 0 31.5M 1 disk
root@verdin-imx95-12594470:~# tdx-info -dt
Device tree
Device tree enabled: imx95-verdin-wifi-dev.dtb
Compatible string: toradex,verdin-imx95-wifi-devtoradex,verdin-imx95-wifitoradex,verdin-imx95fsl,imx95
Device trees available:
imx95-verdin-nonwifi-dahlia.dtb
imx95-verdin-nonwifi-dev.dtb
imx95-verdin-nonwifi-ivy.dtb
imx95-verdin-nonwifi-mallow.dtb
imx95-verdin-nonwifi-yavia.dtb
imx95-verdin-wifi-dahlia.dtb
imx95-verdin-wifi-ivy.dtb
imx95-verdin-wifi-mallow.dtb
imx95-verdin-wifi-yavia.dtb
Device tree overlays
Overlays enabled: fdt_overlays=verdin-imx95_dsi-to-hdmi_overlay.dtbo verdin-imx95_spidev_overlay.dtbo
Overlays available:
verdin-imx95_dsi-to-lvds_panel-cap-touch-10inch-lvds_overlay.dtbo
verdin-imx95_mezzanine_panel-cap-touch-10inch-lvds_overlay.dtbo
verdin-imx95_mezzanine_panel-lvds-dual-channel-1080p_overlay.dtbo
verdin-imx95_nau8822-btl_overlay.dtbo
verdin-imx95_ov5640-27mhz_overlay.dtbo
verdin-imx95_ov5640_overlay.dtbo
verdin-imx95_panel-cap-touch-10inch-dsi_overlay.dtbo
verdin-imx95_panel-cap-touch-10inch-lvds_overlay.dtbo
verdin-imx95_panel-cap-touch-7inch-dsi_overlay.dtbo
verdin-imx95_reserve-cm7-uart_overlay.dtbo
Thank you for providing the detailed information! I can see you’re running TDX Wayland with XWayland 7.6.0-build.14 on a Verdin iMX95 Hexa 8GB WB IT V1.0B with the DSI-to-HDMI overlay enabled.
Issue Analysis
Based on your detailed description and the available documentation, you’re encountering a known issue with the fw_devlink circular dependency between the display controller and pixel interleaver on Verdin iMX95 (1). The error you’re seeing:
This is indeed related to the circular dependency in the device tree graph between the display pipeline components (1).
Current Status and Recommendations
Device Tree Overlay Configuration
Your current overlay configuration shows you’re using the correct overlay for DSI-to-HDMI functionality (2):
  • Enabled: verdin-imx95_dsi-to-hdmi_overlay.dtbo (2)
  • Base DTB: imx95-verdin-wifi-dev.dtb
The documentation confirms that this overlay is available for Verdin iMX95 starting from BSP version 7.3.0 (2).
Troubleshooting Steps
  1. Verify I2C Connection: Since you mentioned the LT8912B is connected to lpi2c3 instead of lpi2c4, ensure your modified overlay correctly targets the right I2C bus.
  2. Check Display Pipeline: The Verdin iMX95 uses a complex display pipeline that includes the pixel interleaver component (1).
Alternative Approaches
Given the complexity of the fw_devlink issue you’re experiencing, you might consider:
  1. Try Different Base DTB: Test with other available device trees like imx95-verdin-wifi-mallow.dtb since you mentioned using a Mallow-compatible socket.
  2. Overlay Combinations: The documentation shows several display-related overlays available for Verdin iMX95 (2). You might try temporarily disabling the spidev overlay to isolate the display issue.
Support Resources
This appears to be a complex kernel-level issue that may require specific patches or kernel modifications. Based on the community discussion, similar fw_devlink issues have been reported (3).
For this specific kernel-level fw_devlink circular dependency issue, I recommend reaching out to Toradex support directly through the official channels, as this may require:
  • Specific kernel patches for the pixel interleaver driver
  • Updated device tree configurations
  • Potential BSP updates
The issue you’re experiencing appears to be at the kernel driver level and may need specialized support beyond what can be addressed through standard configuration changes.
Update: Also tested with imx95-verdin-wifi-mallow.dtb as base DTB — same error occurs.
Could you please clarify:
  1. Is there a known fix or kernel patch for this fw_devlink circular dependency in BSP 7.6.0?
  2. Is BSP 7.7.0 expected to include the mainline pixel-interleaver rework that resolves this?
Hi @Hajun!
I noticed you are testing with two overlays. To ensure there is no interference between them, could you test with only the DSI-to-HDMI overlay enabled?
Additionally, you are using the device tree from our Verdin Development Board, which means your custom carrier board may not be fully supported. The recommended approach would be to develop a device tree specifically for your board.
Regarding the DSI-to-HDMI adapter, are you using our adapter, or did you develop your own?
We also tested the Verdin iMX95 with an HDMI monitor, and it worked as expected.
Last but not least, I recommend customizing the DSI-to-HDMI adapter overlay by following the steps described in our Build Device Tree Overlays from Source Code article. By doing this, you can ensure that nothing can be broken by the process of decompiling and recompiling.
Best regards.
Hi Lucas, thanks for the follow-up, and good to hear the Verdin iMX95 + LT8912B
drives an HDMI monitor on the reference setup. Let me answer directly and share
where our diagnostics stand.
Adapter — ours or yours?
Our own option board, not the Toradex DSI-to-HDMI Adapter. It is LT8912B-based
and equivalent at the chip level; the DSI lanes are brought out over a 24-pin
2 mm-pitch header instead of the 34-pin 0.5 mm FFC (LSS-130), and the LT8912B
control I2C runs on lpi2c3 (hence the custom overlay).
Two overlays
The pixel-interleaver devlink warning is real, but it is not what blocks the
image. We ran the DSI host’s internal Video Pattern Generator (vpg), which
bypasses the DPU, pixel-interleaver and pixel-link entirely and streams a
pattern straight out of the DSI host. With vpg active, the LT8912B input sync
counters (0x9C–0x9F) still read zero. The upstream pipeline is fully bypassed
and the symptom is unchanged, so overlay interference in the display pipeline
is not the cause.
Custom device tree
At the control level the device tree already configures the chip correctly. On
a clean cold boot the full 0x48/0x49 register banks read back exactly the
driver’s init values (H/V timing, dds_config, lane count, chip ID 0x12/0xB2),
and I2C read/write/latch are all confirmed. So the DT is functionally correct
for LT8912B configuration.
Diagnostics summary (confirmed clean):
  • Chip + I2C: register banks latch to expected values on cold boot.
  • Upstream SW pipeline: vpg bypass still gives sync = 0.
  • OS/BSP/overlay independence: the input-sync registers (0x9C–0x9F) read
    identically from BSP 7.6.0 / kernel 6.6.129 through Torizon 7.6.1 / kernel
    6.6.138 — the symptom is unchanged across completely different images,
    drivers and overlays.
Given that the chip is correctly configured and the symptom is invariant across
the entire software stack, the only documented differences from the
confirmed-working configuration are the module revision and the adapter:
  1. The confirmed-working setup uses V1.0C; ours is V1.0B (S/N 12594470). Are
    there any DSI D-PHY differences (HS clock drive, lane calibration, PLL)
    between V1.0B and V1.0C relevant to LT8912B bring-up?
Hi @Hajun!
We tested the setup using a Verdin iMX95 V1.0B, a Verdin Development Board V1.1A, and a DSI-to-HDMI adapter, and it worked as expected. Based on that, I do not believe the hardware revision is the root cause of the issue.
You can also verify the changes between revisions in our Revision History.
I would recommend testing with a “default” setup (Verdin iMX95, Dev Board, DSI to HDMI adapter, and a reference image), and then introducing your customizations one at a time, testing after each change. This approach should help you narrow down the issue to a specific component or configuration in your environment.
Best regards.
