Hello there!
tdx-info output:
Software summary
Bootloader: U-Boot
Kernel version: 5.15.148-6.7.0+git.bfdbfb2c85fb #1-TorizonCore SMP PREEMPT Thu Jun 20 15:59:41 UTC 2024
Kernel command line: root=LABEL=otaroot rootfstype=ext4 quiet logo.nologo vt.global_cursor_default=0 plymouth.ignore-serial-consoles splash fbcon=map:3 ostree=/ostree/boot.1/torizon/90e01d0d190736f48ecdd06a21b8c8f58031df0728192beb7e16fa15b5dc7608/0
Distro name: NAME="TorizonCore"
Distro version: VERSION_ID=6.7.0-build.18
Distro variant: VARIANT="Docker"
Hostname: verdin-imx8mp-15128326
Hardware info
HW model: Toradex Verdin iMX8MP WB on prototype mk1
Toradex version: 0064 V1.1A
Serial number: 15128326
Processor arch: aarch64
I’ve recently received the prototype of a custom carrier board for an upcoming product of ours. One of the features the board needs to support is a USB hub, a Microchip USB2514B/M2, which is currently connected the USB_1 pins. Only SODIMM 163 (USB_1_D_N) and 165 (USB_1_D_P) are connected to the IC.
I’ve made a custom device tree, based off of the imx8mp-verdin-dev.dtsi. The relevant changes to phandles are:
/dts-v1/;
#include "imx8mp-verdin.dtsi"
#include "imx8mp-verdin-wifi.dtsi"
model = "Toradex Verdin iMX8MP WB on prototype mk1";
compatible = "toradex,verdin-imx8mp-wifi-dev",
"toradex,verdin-imx8mp-wifi",
"toradex,verdin-imx8mp",
"fsl,imx8mp";
&usb3_0 {
&usb_dwc3_0 {
dr_mode = "host";
&usb3_phy0 {
So far I’ve been able to get the SoM to recognize the hub, as evident by the output of lsusb:
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 002: ID 0424:2514 Microchip Technology, Inc. (formerly SMSC) USB 2.0 Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
However, when I connect any USB device to the hub, they aren’t recognized. I’ve looked for documentation on adding the USB2514B/M2 to our device tree, however i could only find documentation and examples utilizing I2C, whereas the SDA and SCL pins on the IC are wired to ground on the prototype I have at hand.
dmesg | grep -i usb logs:
[ 0.092780] usbcore: registered new interface driver usbfs
[ 0.092817] usbcore: registered new interface driver hub
[ 0.092840] usbcore: registered new device driver usb
[ 0.925089] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.925321] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.926003] usbcore: registered new interface driver uas
[ 0.926044] usbcore: registered new interface driver usb-storage
[ 0.926102] usbcore: registered new interface driver usbserial_generic
[ 0.926124] usbserial: USB Serial support registered for generic
[ 0.926375] usbcore: registered new device driver onboard-usb-hub
[ 0.969838] usbcore: registered new interface driver usbhid
[ 0.969843] usbhid: USB HID core driver
[ 0.980014] usbcore: registered new interface driver snd-usb-audio
[ 1.028304] imx8mq-usb-phy 381f0040.usb-phy: supply vbus not found, using dummy regulator
[ 1.061343] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1
[ 1.061932] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2
[ 1.061945] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[ 1.062779] hub 1-0:1.0: USB hub found
[ 1.063119] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.063523] hub 2-0:1.0: USB hub found
[ 1.356690] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[ 1.574217] hub 1-1:1.0: USB hub found
[ 1.734149] hub 1-1:1.0: USB hub found
[ 46.756375] usb 1-1.1: new full-speed USB device number 3 using xhci-hcd
[ 46.856399] usb 1-1.1: device no response, device descriptor read/64, error -32
[ 47.076388] usb 1-1.1: device no response, device descriptor read/64, error -32
[ 47.296376] usb 1-1.1: new full-speed USB device number 4 using xhci-hcd
[ 47.406396] usb 1-1.1: device no response, device descriptor read/64, error -32
[ 47.626408] usb 1-1.1: device no response, device descriptor read/64, error -32
[ 47.746520] usb 1-1-port1: attempt power cycle
[ 48.406373] usb 1-1.1: new full-speed USB device number 5 using xhci-hcd
[ 48.406462] usb 1-1.1: Device not responding to setup address.
[ 48.626469] usb 1-1.1: Device not responding to setup address.
[ 48.846375] usb 1-1.1: device not accepting address 5, error -71
[ 48.946377] usb 1-1.1: new full-speed USB device number 6 using xhci-hcd
[ 48.946466] usb 1-1.1: Device not responding to setup address.
[ 49.166464] usb 1-1.1: Device not responding to setup address.
[ 49.386374] usb 1-1.1: device not accepting address 6, error -71
[ 49.392534] usb 1-1-port1: unable to enumerate USB device
I’m quite at a loss, and am unsure how to continue the development on this part of the prototype… Any help which could point me in the right direction would be much appreciated!
Sophus
