I was able to flash the Reference Minimal Image built from your instructions
The installed image boots and runs apparently normally but I am unable to flash any new images.
I tried running bootcmd_usb0 and the following is the result:
U-Boot 2020.04-5.1.0-devel+git.8ca87245fde7 (Nov 23 2020 - 23:45:52 +0000)
CPU: NXP i.MX8QM RevB A53 at 1200 MHz
DRAM: 4 GiB
In: serial
Out: serial
Err: serial
Model: Toradex Apalis iMX8 QuadMax 4GB Wi-Fi / BT IT V1.0B, Serial# 06494646
BuildInfo:
- SCFW 732e719a, SECO-FW 376e3c15, IMX-MKIMAGE 6745ccdc, ATF
- U-Boot 2020.04-5.1.0-devel+git.8ca87245fde7
switch to partitions #0, OK
flash target is MMC:0
Net: eth0: ethernet@5b040000
Fastboot: Normal
Normal Boot
Apalis iMX8 # run bootcmd_usb0
starting USB...
Bus usb@5b0d0000: usb dr_mode not found
Port not available.
Bus usbh3: XHCI-imx8 init hccr 0x000000005b130000 and hcor 0x000000005b130080 hc_length 128
Register 2000820 NbrPorts 2
Starting the controller
USB XHCI 1.00
scanning bus usbh3 for devices... cannot reset port 1!?
2 USB Device(s) found
scanning usb for storage devices... 1 Storage Device(s) found
Device 0: Vendor: Lexar Rev: 1.00 Prod: JumpDrive
Type: Removable Hard Disk
Capacity: 30544.0 MB = 29.8 GB (62554112 x 512)
... is now current device
Scanning usb 0:1...
Found U-Boot script /boot.scr
2246 bytes read in 3 ms (730.5 KiB/s)
## Executing script at 83100000
106496 bytes read in 4 ms (25.4 MiB/s)
Loading hdp firmware from 0x000000009c000000 offset 0x0000000000002000
Loading hdp firmware Complete
** Reading file would overwrite reserved memory **
SCRIPT FAILED: continuing...
106496 bytes read in 5 ms (20.3 MiB/s)
Apalis iMX8 #
It looks like the u-boot installed by the update has one or more incorrect addresses set.
I tried to work around this problem by continuing as follows:
Apalis iMX8 # setenv ramdisk_addr_r 0x8a000000
Apalis iMX8 # setenv fdtfile fsl-$fdtfile
Apalis iMX8 # run bootcmd_tezi && run bootcmd_run
37481764 bytes read in 212 ms (168.6 MiB/s)
## Loading kernel from FIT Image at 8a000000 ...
Using 'config@freescale_fsl-imx8qm-apalis-eval.dtb' configuration
Trying 'kernel@1' kernel subimage
Description: Linux kernel
Type: Kernel Image
Compression: gzip compressed
Data Start: 0x8a000108
Data Size: 6689782 Bytes = 6.4 MiB
Architecture: AArch64
OS: Linux
Load Address: 0x80280000
Entry Point: 0x80280000
Hash algo: sha1
Hash value: cb0cf197924e01466a3d824cccbabbb9ff0f5bd3
Verifying Hash Integrity ... sha1+ OK
## Loading ramdisk from FIT Image at 8a000000 ...
Trying 'ramdisk@1' ramdisk subimage
Description: tezi-initramfs
Type: RAMDisk Image
Compression: uncompressed
Data Start: 0x8a6b0584
Data Size: 30466048 Bytes = 29.1 MiB
OS: Linux
Load Address: 0xa0000000
Entry Point: unavailable
Hash algo: sha1
Hash value: 8e46cd4ad885859c0515a85a45195e7cfb8978bb
Loading ramdisk from 0x8a6b0584 to 0xa0000000
## Loading fdt from FIT Image at 8a000000 ...
Trying 'fdt@freescale_fsl-imx8qm-apalis-eval.dtb' fdt subimage
Description: Flattened Device Tree blob
Type: Flat Device Tree
Data Start: 0x8a66161c
Data Size: 107679 Bytes = 105.2 KiB
Hash algo: sha1
Hash value: 2090a5e0b2d81cff88023f488aeff3c216abf95a
Booting using the fdt blob at 0x8a66161c
Uncompressing Kernel Image
Loading Ramdisk to fb942000, end fd650000 ... OK
Loading Device Tree to 00000000fb924000, end 00000000fb94149e ... OK
/dma-controller@5a1f0000, 73816
/dma-controller@591F0000, 74772
/dma-controller@599F0000, 75928
sc_rm_set_master_sid: resource:4784 sid:17: res:3
config_smmu_resource_sid rsrc[-43707728] not owned
sc_rm_set_master_sid: resource:4784 sid:18: res:3
sc_rm_set_master_sid: resource:4784 sid:19: res:3
Starting kernel ...
[ 0.323130] clk: couldn't set hdmi_lis_ipg_clk clk rate to 100000000 (-22), current rate: 0
[ 0.438449] dmi: Firmware registration failed.
[ 0.529224] imx6q-pcie 5f000000.pcie: pcie_ext clock source missing or invalid
[ 0.531502] imx6q-pcie 5f010000.pcie: pcie_ext clock source missing or invalid
[ 0.579027] Can't support > 32 bit dma.
[ 0.661000] i.mx8-hdp 56268000.hdmi: invalid resource
[ 2.359441] ahci-imx 5f020000.sata: can't get per_clk0 clock.
[ 2.390804] Can't support > 32 bit dma.
[ 2.615844] atmel_mxt_ts 4-004a: __mxt_read_reg: i2c transfer failed (-5)
[ 2.622890] atmel_mxt_ts 4-004a: mxt_bootloader_read: i2c recv failed (-5)
[ 2.629988] atmel_mxt_ts 4-004a: mxt_bootloader_read: i2c recv failed (-5)
[ 3.278963] imx6q-pcie 5f000000.pcie: phy link never came up
[ 3.284786] imx6q-pcie 5f000000.pcie: failed to initialize host
[ 3.290841] imx6q-pcie 5f000000.pcie: unable to add pcie port.
Running /etc/rc.local...
TDX_VER_ID="Apalis-iMX8_ToradexEasyInstaller_2.0b6-20201102"
Starting udev
[ 4.039151] hid-generic 0003:046D:C52B.0003: device has no listeners, quitting
System time was Tue Dec 22 00:46:54 UTC 2020.
Setting the System Clock using the Hardware Clock as reference...
System Clock set. System local time is now Tue Dec 22 00:46:54 UTC 2020.
Welcome to the Toradex Easy Installer
This is a Linux based installer for Toradex modules. Currently, the installer
does not have a serial console interface. You can use the Toradex Easy Installer
via any of the available display interfaces using USB mouse/keyboard or via a
network connection using VNC. Use:
# ip addr show eth0
to display the Ethernet IP address or use USB RNDIS at IP 192.168.11.1.
Check our documentation at:
https://developer.toradex.com/software/toradex-easy-installer
/ # [ 12.771702] mmc0: Timeout waiting for hardware interrupt. retries left=0 opcode=0
[ 12.779206] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 12.785651] mmc0: sdhci: Sys addr: 0x00000000 | Version: 0x00000002
[ 12.792098] mmc0: sdhci: Blk size: 0x00000200 | Blk cnt: 0x00000001
[ 12.798544] mmc0: sdhci: Argument: 0x00000000 | Trn mode: 0x00000013
[ 12.804987] mmc0: sdhci: Present: 0x01fd8a0a | Host ctl: 0x00000011
[ 12.811435] mmc0: sdhci: Power: 0x00000002 | Blk gap: 0x00000080
[ 12.817881] mmc0: sdhci: Wake-up: 0x00000008 | Clock: 0x000020ff
[ 12.824326] mmc0: sdhci: Timeout: 0x0000008f | Int stat: 0x00000000
[ 12.830774] mmc0: sdhci: Int enab: 0x117f100b | Sig enab: 0x117f100b
[ 12.837220] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000502
[ 12.843664] mmc0: sdhci: Caps: 0x07eb0000 | Caps_1: 0x8000b407
[ 12.850112] mmc0: sdhci: Cmd: 0x0000083a | Max curr: 0x00ffffff
[ 12.856557] mmc0: sdhci: Resp[0]: 0x00000900 | Resp[1]: 0xffffffff
[ 12.863000] mmc0: sdhci: Resp[2]: 0x328f5903 | Resp[3]: 0x00d02701
[ 12.869441] mmc0: sdhci: Host ctl2: 0x00000000
[ 12.873888] mmc0: sdhci: ADMA Err: 0x00000004 | ADMA Ptr: 0xfffffffc
[ 12.880330] mmc0: sdhci: ============================================
[ 12.886869] mmc0: error -110 whilst initialising MMC card
[ 23.011709] mmc0: Timeout waiting for hardware interrupt. retries left=0 opcode=0
[ 23.019214] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 23.025661] mmc0: sdhci: Sys addr: 0x00000000 | Version: 0x00000002
[ 23.032105] mmc0: sdhci: Blk size: 0x00000200 | Blk cnt: 0x00000001
[ 23.038550] mmc0: sdhci: Argument: 0x00000000 | Trn mode: 0x00000013
[ 23.044999] mmc0: sdhci: Present: 0x01fd8a0a | Host ctl: 0x00000011
[ 23.051442] mmc0: sdhci: Power: 0x00000002 | Blk gap: 0x00000080
[ 23.057888] mmc0: sdhci: Wake-up: 0x00000008 | Clock: 0x000040af
[ 23.064339] mmc0: sdhci: Timeout: 0x0000008f | Int stat: 0x00000000
[ 23.070789] mmc0: sdhci: Int enab: 0x117f100b | Sig enab: 0x117f100b
[ 23.077235] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000502
[ 23.083683] mmc0: sdhci: Caps: 0x07eb0000 | Caps_1: 0x8000b407
[ 23.090127] mmc0: sdhci: Cmd: 0x0000083a | Max curr: 0x00ffffff
[ 23.096573] mmc0: sdhci: Resp[0]: 0x00000900 | Resp[1]: 0xffffffff
[ 23.103022] mmc0: sdhci: Resp[2]: 0x328f5903 | Resp[3]: 0x00d02701
[ 23.109465] mmc0: sdhci: Host ctl2: 0x00000000
[ 23.113914] mmc0: sdhci: ADMA Err: 0x00000004 | ADMA Ptr: 0xfffffffc
[ 23.120358] mmc0: sdhci: ============================================
[ 23.126954] mmc0: error -110 whilst initialising MMC card
On the HDMI monitor, it shows an error: Reading Config Block failed.
I now have two modules in this same stuck state.
I have tried using recovery mode to reinstall the Easy Installer. The recovery batch file starts okay, on the console I see u-boot start, but then it stalls at Hit any key to stop autoboot: 0
How can I update u-boot and linux on these modules?
